#define IR_1 0x20DF00FF // Кнопка вверх
#define IR_2 0x20DF807F // Кнопка вниз
#define IR_3 0x20DF40BF // Кнопка >
#define IR_4 0x20DFC03F // Кнопка <
#define IR_5 0x20DFD02F // Кнопка IN
#define IR_6 0x20DFC23D // Кнопка SET
#define IR_7 0x20DF906F // Кнопка MUTE
#define IR_8 0x20DF10EF // Кнопка STANDBY (POWER)
#define BRIG_H 200 // Яркость 0...255 POWER ON
#include <TDA7719.h> // http://rcl-radio.ru/wp-content/uploads/2019/07/TDA7719.zip
TDA7719 tda;
int in,loun,loun_f,vol_att,treb,treb_f,mid,mid_q,bass,bass_q,sub_f,faza,mid_f,bass_f; ////////////////////////////
int vol,att_lf,att_rf,att_lr,att_rr,att_l,att_rl;
long time0,oldPosition = -999,newPosition,times1;
int hour,minut,secon,mid_d,menu2,gain0,gain1,gain2,gain3,gain4,gain5,gain6,date,mont,year,korr;
bool power_off=1;
String dn[]={" ","MON","TUE","WED","THU","FRI","SAT","SUN"};
byte wesk,zast;
pinMode(2,INPUT_PULLUP); // КНОПКА SET
pinMode(3,INPUT_PULLUP); // КНОПКА IN
pinMode(4,INPUT_PULLUP); // КНОПКА MUTE
pinMode(5,INPUT_PULLUP); // КНОПКА STANDBY
pinMode(7,OUTPUT); // ВЫХОД УПРАВЛЕНИЯ STANDBY
pinMode(12,OUTPUT); // ВЫХОД УПРАВЛЕНИЯ Bluetooth
lcd.setCursor(3,1);lcd.print("Sound Processor");lcd.setCursor(7,2);lcd.print("TDA7719"); delay(2000);lcd.clear();
att_lr = EEPROM.read(4);att_rr = EEPROM.read(5);att_lf = EEPROM.read(6);att_rf = EEPROM.read(7);att_rl = EEPROM.read(8);att_l = EEPROM.read(9);
gain1 = EEPROM.read(18)-15;gain2 = EEPROM.read(19)-15;gain3 = EEPROM.read(20)-15;gain4=EEPROM.read(21)-15;gain5=EEPROM.read(22)-15;gain6=EEPROM.read(23)-15;
switch(in){
case 0: gain0 = gain1;break;
case 1: gain0 = gain2;break;
case 2: gain0 = gain3;break;
case 3: gain0 = gain4;break;
case 4: gain0 = gain5;break;
case 5: gain0 = gain6;break;
w2_arr();audio();cl();
date = DateTime.day;mont = DateTime.month;year = DateTime.year;wesk = DateTime.dayOfWeek;
if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);irrecv.resume();}// IR приемник - чтение, в мониторе порта отображаются коды кнопок
if((digitalRead(10)==LOW||digitalRead(2)==LOW||digitalRead(3)==LOW||digitalRead(4)==LOW||digitalRead(5)==LOW)&& zast==1){cl();w=0;times1=millis();zast=0;menu0=0;menu=0;menu1=0;menu2=0;in_x=0;w2_arr();}
if((ir.value==IR_1||ir.value==IR_2||ir.value==IR_3||ir.value==IR_4||ir.value==IR_5||ir.value==IR_6||ir.value==IR_7||ir.value==IR_8)&&zast==1){
if(power==0){
if(mute==1){
if(digitalRead(10)==LOW&&menu0==0){menu++;delay(200);time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu>3){menu=0;}}// меню 0
if(digitalRead(10)==LOW&&menu0==1){menu1++;delay(200);time0=millis();times1=millis();zast=0;in_x=0;w=1;if(menu1>7){menu1=0;}}// меню 1
if(digitalRead(10)==LOW&&menu0==2){menu2++;delay(200);time0=millis();times1=millis();zast=0;in_x=0;w=1;if(menu2>5){menu2=0;}}// меню 2
if(ir.value==IR_2&&menu0==0){menu++;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu>3){menu=0;}}//меню 0
if(ir.value==IR_1&&menu0==0){menu--;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu<0){menu=3;}}//меню 0
if(ir.value==IR_2&&menu0==1){menu1++;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu1>7){menu1=0;}}//меню 1
if(ir.value==IR_1&&menu0==1){menu1--;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu1<0){menu1=7;}}//меню 1
if(ir.value==IR_2&&menu0==2){menu2++;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu2>5){menu2=0;}}//меню 2
if(ir.value==IR_1&&menu0==2){menu2--;gr1=0;gr2=0;cl1();time0=millis();times1=millis();zast=0;in_x=0;w=1;w2_arr();if(menu2<0){menu2=5;}}//меню 2
if(ir.value==IR_6||digitalRead(2)==LOW){menu0++;if(menu0>2){menu0=0;}cl();in_x=0;w2_arr();time0=millis();times1=millis();zast=0;w=1;lcd.setCursor(5,1);
if(ir.value==IR_5||digitalRead(3)==LOW){in++;cl();time0=millis();times1=millis();zast=0;in_x=1;w=1;www=1;menu0=100;menu=100;if(in>5){in=0;}}// IN
} // mute off
if((ir.value==IR_7||digitalRead(4)==LOW)&&mute==1&&power==0){zast=0;mute=0;in_x=0;mute=0;menu0=100;cl();w=1;w2_arr();lcd.setCursor(8,1);lcd.print("MUTE");audio();delay(300);}// mute on
if((ir.value==IR_7||digitalRead(4)==LOW)&&mute==0&&power==0){mute=1;cl();time0=millis();times1=millis();zast=0;w=1;w2_arr();menu0=0;menu=0;myEnc.write(0);audio();}// mute off
}// power on
if((ir.value==IR_8||digitalRead(5)==LOW||power_off==1)&&power==0){times1=millis();zast=0;power_off=0;power=1;in_x=0;mute=0;cl();audio();lcd.setCursor(5,1);lcd.print("POWER OFF");menu0=100;delay(3000);analogWrite(6,BRIG_L);}// power off
if((ir.value==IR_8||digitalRead(5)==LOW)&&power==1){times1=millis();zast=0;power=0;analogWrite(6, BRIG_H);cl();lcd.setCursor(5,1);lcd.print("POWER ON ");w=1;w2_arr();menu0=0;myEnc.write(0);mute=1;audio();delay(3000);cl();}// power on
if(power==0){digitalWrite(7,HIGH);if(in==2){digitalWrite(12,HIGH);}else{digitalWrite(12,LOW);}}
if(power==1){digitalWrite(7,LOW);digitalWrite(12,LOW);}
if(power==0&&zast==0){
if(power==1||zast==1){
byte a[6];
a[0]=DateTime.hour/10;
a[1]=DateTime.hour%10;
a[2]=DateTime.minute/10;
a[3]=DateTime.minute%10;
a[4]=DateTime.second/10;
a[5]=DateTime.second%10;
for(int i=0;i<6;i++){
case 0: e1=0,e2=1,e3=2;break;
case 1: e1=3,e2=4,e3=5;break;
case 2: e1=7,e2=8,e3=9;break;
switch(a[i]){
lcd.setCursor(0,3);lcd.print(date/10);lcd.print(date%10),lcd.print(".");lcd.print(mont/10);lcd.print(mont%10);lcd.print(".");lcd.print(year);lcd.print(" ");
lcd.print(clock.readTemperature(),1);lcd.print((char)223);lcd.print(" ");
lcd.print(dn[wesk]);
//lcd.setCursor(5,3);lcd.print("POWER OFF");
if(digitalRead(10)==LOW&&digitalRead(2)==LOW){korr++;if(korr>6){korr=0;}delay(100);} // SET
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==1){hour++;if(hour>23){hour=23;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);} // IN
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==1){hour--;if(hour<0){hour=0;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);} // MUTE
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==2){minut++;if(minut>59){minut=59;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==2){minut--;if(minut<0){minut=0;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==3){secon=0;clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==3){secon=0;clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==4){date++;if(date>31){date=31;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==4){date--;if(date<1){date=1;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==5){mont++;if(mont>12){mont=12;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==5){mont--;if(mont<1){mont=1;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(3)==LOW&&korr==6){year++;if(year>2050){year=2050;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
if(digitalRead(10)==LOW&&digitalRead(4)==LOW&&korr==6){year--;if(year<2022){year=2022;} clock.setDateTime(year, mont, date, hour, minut, secon);delay(100);}
lcd.setCursor(0,2);
switch(korr){
case 0 : lcd.print(" ");lcd.print(" ");break;
case 1 : lcd.print("Time correction ");lcd.print("HOUR");break;
case 2 : lcd.print("Time correction ");lcd.print("MIN ");break;
case 3 : lcd.print("Time correction ");lcd.print("SEC ");break;
case 4 : lcd.print("Time correction ");lcd.print("DATE");break;
case 5 : lcd.print("Time correction ");lcd.print("MON ");break;
case 6 : lcd.print("Time correction ");lcd.print("YEAR");break;
if(menu0==0){
switch(menu){
if(ir.value==IR_3){temp0++;gr1=1;gr2=0;cl1();time0=millis();times1=millis();zast=0;w=1;w2[q]=1;www=1;}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){temp0++;gr2=0;cl1();time0=millis();times1=millis();zast=0;w=1;w2[q]=1;www=1;}// кнопка >>>>>>
if(ir.value==IR_4){temp0--;gr1=0;gr2=1;cl1();time0=millis();times1=millis();zast=0;w=1;w2[q]=1;www=1;}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){temp0--;gr1=0;cl1();time0=millis();times1=millis();zast=0;w=1;w2[q]=1;www=1;}// кнопка <<<<<<
temp0=temp0+newPosition;myEnc.write(0);newPosition=0;time0=millis();times1=millis();zast=0;w=1;w2[q]=1;www=1;}
switch(menu){
au();
lcd.setCursor(1,0);lcd.print("VOL(");lcd.print(in+1);lcd.print(") ");if(vol>=0){lcd.print(" ");}lcd.print(vol);lcd.print(" ");vol_d=map(vol,-63,0,1,24);
lcd.setCursor(1,1);lcd.print("BASS ");if(bass>=0){lcd.print(" ");}lcd.print(bass);lcd.print(" ");bass_d=map(bass,-15,15,1,24);
switch(n){
case 0: par = vol_d;break;
case 1: par = bass_d;break;
case 2: par = mid_d;break;
case 3: par = treb_d;break;
}}// menu0 = 0
if(menu0==1){
switch(menu1){
case 0: temp0 = att_lr;break;
case 1: temp0 = att_rr;break;
case 2: temp0 = att_lf;break;
case 3: temp0 = att_rf;break;
case 4: temp0 = att_rl;break;
case 5: temp0 = att_l;break;
case 6: temp0 = loun;break;
case 7: temp0 = loun_f;break;
if(ir.value==IR_3){temp0++;gr1=1;gr2=0;cl1();time0=millis();times1=millis();zast=0;w=1;www=1;}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){temp0++;gr2=0;cl1();time0=millis();times1=millis();zast=0;w=1;www=1;}// кнопка >>>>>>
if(ir.value==IR_4){temp0--;gr1=0;gr2=1;cl1();time0=millis();times1=millis();zast=0;;w=1;www=1;}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){temp0--;gr1=0;cl1();time0=millis();times1=millis();zast=0;w=1;www=1;}// кнопка <<<<<<
temp0=temp0+newPosition;myEnc.write(0);newPosition=0;time0=millis();times1=millis();zast=0;w=1;www=1;}
switch(menu1){
case 4: att_rl = temp0;att_rl_func();break;
case 5: att_l = temp0;att_l_func();break;
case 6: loun = temp0;loun_func();break;
case 7: loun_f = temp0;loun_f_func();break;
if (att_l = 0){faza = 180;}else{faza = 0;}
au();
lcd.setCursor(1,2);lcd.print("AT_SW ");lcd.print(att_r);lcd.print(" ");lcd.setCursor(11,2);lcd.print("PHASE ");lcd.print(faza);lcd.print(" ");
switch(loun_f){
case 1: lcd.print("400 Hz");break;
case 2: lcd.print("800 Hz");break;
} // menu0 = 1
if(menu0==2){
switch(menu2){
case 0: temp0 = bass_f;break;
case 1: temp0 = mid_f;break;
case 2: temp0 = treb_f;break;
case 3: temp0 = sub_f;break;
case 4: temp0 = bass_q;break;
case 5: temp0 = mid_q;break;
switch(menu2){
case 4: bass_q = temp0;bass_q_func();break;
case 5: mid_q = temp0;mid_q_func();break;
au();
switch(bass_f){
switch(mid_f){
switch(treb_f){
switch(sub_f){
case 1: lcd.print("80 Hz");break;
case 2: lcd.print("120 Hz");break;
case 3: lcd.print("160 Hz");break;}
switch(bass_q){
switch(mid_q){
} // menu0 = 2
if(in_x==1){ menu0=100;
switch(in){
if(ir.value==IR_3){gain0++;gr1=1;gr2=0;cl1();time0=millis();times1=millis();zast=0;www=1;w=1;gain_func();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr2=0;cl1();time0=millis();times1=millis();zast=0;www=1;w=1;gain_func();}// кнопка >>>>>>
if(ir.value==IR_4){gain0--;gr1=0;gr2=1;cl1();time0=millis();times1=millis();zast=0;www=1;w=1;gain_func();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl1();time0=millis();times1=millis();zast=0;www=1;w=1;gain_func();}// кнопка <<<<<<
if (newPosition != oldPosition) {oldPosition = newPosition;if(newPosition>1){newPosition=1;}if(newPosition<-1){newPosition=-1;}
gain0=gain0+newPosition;myEnc.write(0);newPosition=0;time0=millis();times1=millis();zast=0;www=1;w=1;gain_func();}
switch(in){
case 0: gain1 = gain0;break;
case 1: gain2 = gain0;break;
case 2: gain3 = gain0;break;
case 3: gain4 = gain0;break;
case 4: gain5 = gain0;break;
case 5: gain6 = gain0;break;
au();
lcd.setCursor(7,1);lcd.print("INPUT ");
switch(in){
case 0: lcd.print("AUX1");break;
case 1: lcd.print("AUX2");break;
case 2: lcd.print("AUX3");break;
case 3: lcd.print("AUX4");break;
case 4: lcd.print("AUX5");break;
case 5: lcd.print("AUX6");break;
lcd.setCursor(5,2);lcd.print("GAIN ");lcd.print(gain0);lcd.print(" ");lcd.setCursor(14,2);lcd.print("dB ");
if(millis()-time0>in_time&&w==1&&mute==1&&power==0&&zast==0){if(menu0==1){cl();}w=0;if(menu0!=0){cl();}menu0=0;menu=0;menu1=0;menu2=0;in_x=0;w2_arr();
EEPROM.update(4,att_lr);EEPROM.update(5,att_rr);EEPROM.update(6,att_lf);EEPROM.update(7,att_rf);EEPROM.update(8,att_rl);EEPROM.update(9,att_l);
EEPROM.update(18,gain1+15);EEPROM.update(19,gain2+15);EEPROM.update(20,gain3+15);EEPROM.update(21,gain4+15);EEPROM.update(22,gain5+15);EEPROM.update(23,gain6+15);
if(millis()-times1>60000&&zast==0&&mute==1){zast=1;menu0=100;}
if(w==1&&zast==1){cl2();w=0;times1=millis();zast=0;menu0=0;menu=0;menu1=0;menu2=0;in_x=0;w2_arr();}
void att_rl_func(){if(att_r>15){att_r=15;}if(att_r<0){att_r=0;}}
void att_l_func(){if(att_l>1){att_l=1;}if(att_l<0){att_l=0;}}
void cl2(){ir.value=0;lcd.clear();}
tda.setMute(mute,0,0,1,0,1,1); // 0...1, 0...1, 0...3, 0...1, 0...1, 0...1, 0...1 mute off = 1
tda.setLoudness(-loun,loun_f,1,1); // 0...-15, 0...3, 0...1, 0...1
tda.setVol(gain0,1,1); // -15...+15, 0...1, 0...1
tda.setSMB(sub_f,att_l,mid_f,bass_f,1); // 0...3, 0...1, 0...3, 0...3, 0...1
tda.setVol_LF(vol-att_lf,1); // 0...-79, 0...1 lov=63+16 att
tda.setVol_RF(vol-att_rf,1); // 0...-79, 0...1
tda.setVol_LR(vol-att_lr,1); // 0...-79, 0...1
tda.setVol_RR(vol-att_rr,1); // 0...-79, 0...1
tda.setVol_SUB_L(vol-att_rl,1); // 0...-79, 0...1
tda.setVol_SUB_R(vol-att_rl,1); // 0...-79, 0...1
