Тема: TDA7439 + OLED_1.3+IR+ENCODER
Основная статья - http://rcl-radio.ru/?p=131205
#define ENC_DT 8
#define ENC_CLK 9
#define ENC_SW 10
#define IR 12
#define MENU 0x33B820DF // button encoder
#define UP 0x33B810EF // >>>
#define DW 0x33B8E01F // <<<
#define INPUT_IR 0x33B88877 // IN
#define POWER_IR 0x33B800FF // POWER
#define IN 2
#define POWER 6
#define POWER_OUT_PIN 13
#include <TDA7439.h>
TDA7439 tda;
IRrecv irrecv(IR);
long oldPosition = -999,newPosition, times;
int vol_reg,balans,treb_reg,bass_reg,mid_reg,in_reg,gain0,gain1,gain2,gain3,gain4,menu,vol_old;
bool gr1,gr2,w=1,w1,www,power;
irrecv.enableIRIn();
pinMode(ENC_SW,INPUT);
pinMode(IN,INPUT_PULLUP);
pinMode(POWER,INPUT_PULLUP);
vol_reg = EEPROM.read(0);treb_reg = EEPROM.read(1)-7;mid_reg = EEPROM.read(2)-7;bass_reg = EEPROM.read(3)-7;
in_reg = EEPROM.read(4);gain1 = EEPROM.read(5);gain2 = EEPROM.read(6);gain3 = EEPROM.read(7);gain4 = EEPROM.read(8);balans = EEPROM.read(9)-8;
switch(in_reg){
case 1: gain0=gain1;break;
case 2: gain0=gain2;break;
case 3: gain0=gain3;break;
case 4: gain0=gain4;break;
// IR ////////////////////////////////////////
if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);irrecv.resume();}// IR приемник - чтение, в мониторе порта отображаются коды кнопок
// BUTTON ///////////////////////////////////////////////////
if((digitalRead(POWER)==LOW||ir.value==POWER_IR)&&power==0){power=1;menu=100;cl();vol_old=vol_reg;vol_reg=48;audio();
u8g.firstPage();do {u8g.setFont(u8g_font_profont12r);u8g.drawStr(40,30,"POWER OFF");} while( u8g.nextPage() );
delay(1500); u8g.firstPage();do {} while( u8g.nextPage() );}
if((digitalRead(POWER)==LOW||ir.value==POWER_IR)&&power==1){power=0;menu=0;vol_reg=vol_old;times=millis();w=1;w1=1;
u8g.firstPage();do {u8g.drawStr(42,30,"POWER ON");} while( u8g.nextPage() );delay(1500);audio();}
if(power==0){digitalWrite(POWER_OUT_PIN,HIGH);}else{digitalWrite(POWER_OUT_PIN,LOW);}
if(power==0){
if(digitalRead(ENC_SW)==LOW||ir.value==MENU){menu++;cl();if(menu>4){menu=0;}times=millis();w=1;w1=1;delay(200);}
if(digitalRead(IN)==LOW||ir.value==INPUT_IR){menu=10;cl();in_reg++;times=millis();w=1;w1=1;www=1;if(in_reg>4){in_reg=1;};delay(200);}
vol_reg=vol_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;vol_func();audio();}
if(ir.value==UP){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >>>>>>
if(ir.value==DW){vol_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){vol_reg--;gr1=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <<<<<<
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"VOLUME");u8g.drawStr(0,18,"IN");
u8g.setPrintPos(20, 18);u8g.print(in_reg);u8g.drawStr(0,28,"GAIN");u8g.setPrintPos(30, 28);u8g.print(gain0);
u8g.drawLine(0, 32, 128, 32);
u8g.drawStr(0,44,"TREBLE");u8g.setPrintPos(80, 44);u8g.print(treb_reg*2);u8g.drawStr(95,44,"dB");
u8g.drawStr(0,54,"MIDDLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
u8g.drawStr(0,64,"BASS");u8g.setPrintPos(80, 64);u8g.print(bass_reg*2);u8g.drawStr(95,64,"dB");
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(vol_reg);
//////// TRABLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
treb_reg=treb_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;treb_func();audio();}
if(ir.value==UP){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >>>>>>
if(ir.value==DW){treb_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){treb_reg--;gr1=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <<<<<<
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(treb_reg*2);
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"TREBLE");u8g.drawStr(0,44,"MIDDLE");u8g.setPrintPos(80, 44);u8g.print(mid_reg*2);u8g.drawStr(95,44,"dB");
u8g.drawStr(0,54,"BASS");u8g.setPrintPos(80, 54);u8g.print(bass_reg*2);u8g.drawStr(95,54,"dB");
u8g.drawStr(0,64,"BALANCE");u8g.setPrintPos(80, 64);u8g.print(balans);u8g.drawStr(95,64,"dB");
//////// MIDDLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
mid_reg=mid_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;mid_func();audio();}
if(ir.value==UP){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >>>>>>
if(ir.value==DW){mid_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){mid_reg--;gr1=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <<<<<<
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(mid_reg*2);
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"MIDDLE");u8g.drawStr(0,44,"BASS");u8g.setPrintPos(80, 44);u8g.print(bass_reg*2);u8g.drawStr(95,44,"dB");
u8g.drawStr(0,54,"BALANCE");u8g.setPrintPos(80, 54);u8g.print(balans);u8g.drawStr(95,54,"dB");
u8g.drawStr(0,64,"VOLUME");u8g.setPrintPos(80, 64);u8g.print(vol_reg);u8g.drawStr(95,64,"dB");
bass_reg=bass_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;bass_func();audio();}
if(ir.value==UP){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >>>>>>
if(ir.value==DW){bass_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){bass_reg--;gr1=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <<<<<<
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(bass_reg*2);
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BASS");
u8g.drawStr(0,44,"BALANCE");u8g.setPrintPos(80, 44);u8g.print(balans);u8g.drawStr(95,44,"dB");
u8g.drawStr(0,54,"VOLUME");u8g.setPrintPos(80, 54);u8g.print(vol_reg);u8g.drawStr(95,54,"dB");
u8g.drawStr(0,64,"TREBLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
//////// BALANCE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
if(menu==4){
if (newPosition != oldPosition){oldPosition = newPosition;balans=balans+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;ball_func();audio();}
if(ir.value==UP){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >>>>>>
if(ir.value==DW){balans--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){balans--;gr1=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <<<<<<
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BALANCE");u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(abs(balans));
if(balans<=0){u8g.drawStr(50,20,"LCH");}
if(balans>=0){u8g.drawStr(105,20,"RCH");}
u8g.drawStr(0,44,"VOLUME");u8g.setPrintPos(80, 44);u8g.print(vol_reg);u8g.drawStr(95,44,"dB");
u8g.drawStr(0,54,"TREBLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
u8g.drawStr(0,64,"MIDDLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
if(menu==10){
switch(in_reg){
gain0=gain0+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;www=1;gain_func();}
if(ir.value==UP){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >>>>>>
if(ir.value==DW){gain0--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <<<<<<
switch(in_reg){
case 1: gain1=gain0;break;
case 2: gain2=gain0;break;
case 3: gain3=gain0;break;
case 4: gain4=gain0;break;
if(www==1){audio();www=0;}
if(w==1){w=0;
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(in_reg);
u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"INPUT");u8g.drawStr(0,44,"GAIN");
u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 60);u8g.print(gain0);
if(millis()-times>5000 && w1==1 && power==0){
EEPROM.update(0,vol_reg);EEPROM.update(1,treb_reg+7);EEPROM.update(2,mid_reg+7);EEPROM.update(3,bass_reg+7);
EEPROM.update(4,in_reg);EEPROM.update(5,gain1);EEPROM.update(6,gain2);EEPROM.update(7,gain3);EEPROM.update(8,gain4);EEPROM.update(9,balans+8);
void cl(){ir.value=0;delay(200);}
void vol_func(){if(vol_reg<0){vol_reg=0;}if(vol_reg>48){vol_reg=48;}}
void treb_func(){if(treb_reg<-7){treb_reg=-7;}if(treb_reg>7){treb_reg=7;}}
void mid_func(){if(mid_reg<-7){mid_reg=-7;}if(mid_reg>7){mid_reg=7;}}
void bass_func(){if(bass_reg<-7){bass_reg=-7;}if(bass_reg>7){bass_reg=7;}}
void gain_func(){if(gain0>15){gain0=15;}if(gain0<0){gain0=0;}}
void ball_func(){if(balans>8){balans=8;}if(balans<-8){balans=-8;}}
tda.setInput(in_reg); // 1 to 4 // номер канала
tda.inputGain(gain0); // 0 to 15 // усиление
tda.setVolume(vol_reg); // 0 to 48 ( 0 is mute) // громкость
tda.setSnd(bass_reg, 1); //-7 to +7 , 1 - Bass | 2 - Mids | 3 - Trebble
tda.setSnd(mid_reg, 2);
tda.setSnd(treb_reg, 3);
tda.spkAtt(8 + balans ,8 - balans); // баланс R L от 0 to 79 (db)
