Тема: TDA7439 + OLED_1.3+IR+ENCODER
Основная статья - http://rcl-radio.ru/?p=131205
#define ENC_DT       8
#define ENC_CLK      9
#define ENC_SW       10
#define IR           12
#define MENU      0x33B820DF // button encoder
#define UP        0x33B810EF // >>>
#define DW        0x33B8E01F // <<<
#define INPUT_IR  0x33B88877 // IN
#define POWER_IR  0x33B800FF // POWER
#define IN            2
#define POWER         6
#define POWER_OUT_PIN 13
#include <TDA7439.h>
TDA7439 tda;
IRrecv irrecv(IR);
long oldPosition  = -999,newPosition, times;
int vol_reg,balans,treb_reg,bass_reg,mid_reg,in_reg,gain0,gain1,gain2,gain3,gain4,menu,vol_old;
bool gr1,gr2,w=1,w1,www,power;
  irrecv.enableIRIn();
  pinMode(ENC_SW,INPUT);
  pinMode(IN,INPUT_PULLUP);
  pinMode(POWER,INPUT_PULLUP);
  vol_reg = EEPROM.read(0);treb_reg = EEPROM.read(1)-7;mid_reg = EEPROM.read(2)-7;bass_reg = EEPROM.read(3)-7;
  in_reg = EEPROM.read(4);gain1 = EEPROM.read(5);gain2 = EEPROM.read(6);gain3 = EEPROM.read(7);gain4 = EEPROM.read(8);balans = EEPROM.read(9)-8;
  switch(in_reg){
    case 1: gain0=gain1;break;
    case 2: gain0=gain2;break;
    case 3: gain0=gain3;break;
    case 4: gain0=gain4;break;
// BUTTON ///////////////////////////////////////////////////
 if((digitalRead(POWER)==LOW||ir.value==POWER_IR)&&power==0){power=1;menu=100;cl();vol_old=vol_reg;vol_reg=48;audio();
  u8g.firstPage();do {u8g.setFont(u8g_font_profont12r);u8g.drawStr(40,30,"POWER OFF");} while( u8g.nextPage() );
  delay(1500); u8g.firstPage();do {} while( u8g.nextPage() );}
 if((digitalRead(POWER)==LOW||ir.value==POWER_IR)&&power==1){power=0;menu=0;vol_reg=vol_old;times=millis();w=1;w1=1;
  u8g.firstPage();do {u8g.drawStr(42,30,"POWER ON");} while( u8g.nextPage() );delay(1500);audio();}
if(power==0){digitalWrite(POWER_OUT_PIN,HIGH);}else{digitalWrite(POWER_OUT_PIN,LOW);}
 if(digitalRead(ENC_SW)==LOW||ir.value==MENU){menu++;cl();if(menu>4){menu=0;}times=millis();w=1;w1=1;delay(200);}
 if(digitalRead(IN)==LOW||ir.value==INPUT_IR){menu=10;cl();in_reg++;times=millis();w=1;w1=1;www=1;if(in_reg>4){in_reg=1;};delay(200);}
   vol_reg=vol_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;vol_func();audio();}
   if(ir.value==UP){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){vol_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){vol_reg--;gr1=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <<<<<<
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"VOLUME");u8g.drawStr(0,18,"IN");
  u8g.setPrintPos(20, 18);u8g.print(in_reg);u8g.drawStr(0,28,"GAIN");u8g.setPrintPos(30, 28);u8g.print(gain0);
  u8g.drawLine(0, 32, 128, 32);
  u8g.drawStr(0,44,"TREBLE");u8g.setPrintPos(80, 44);u8g.print(treb_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"MIDDLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"BASS");u8g.setPrintPos(80, 64);u8g.print(bass_reg*2);u8g.drawStr(95,64,"dB");
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(vol_reg);
//////// TRABLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
   treb_reg=treb_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;treb_func();audio();}
   if(ir.value==UP){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){treb_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){treb_reg--;gr1=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <<<<<<
   if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(treb_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"TREBLE");u8g.drawStr(0,44,"MIDDLE");u8g.setPrintPos(80, 44);u8g.print(mid_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"BASS");u8g.setPrintPos(80, 54);u8g.print(bass_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"BALANCE");u8g.setPrintPos(80, 64);u8g.print(balans);u8g.drawStr(95,64,"dB");
//////// MIDDLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
   mid_reg=mid_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;mid_func();audio();}
   if(ir.value==UP){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){mid_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){mid_reg--;gr1=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <<<<<<
   if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(mid_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"MIDDLE");u8g.drawStr(0,44,"BASS");u8g.setPrintPos(80, 44);u8g.print(bass_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"BALANCE");u8g.setPrintPos(80, 54);u8g.print(balans);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"VOLUME");u8g.setPrintPos(80, 64);u8g.print(vol_reg);u8g.drawStr(95,64,"dB");
   bass_reg=bass_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;bass_func();audio();}
   if(ir.value==UP){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){bass_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){bass_reg--;gr1=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <<<<<<
 if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(bass_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BASS");
  u8g.drawStr(0,44,"BALANCE");u8g.setPrintPos(80, 44);u8g.print(balans);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"VOLUME");u8g.setPrintPos(80, 54);u8g.print(vol_reg);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"TREBLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
  if (newPosition != oldPosition){oldPosition = newPosition;balans=balans+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;ball_func();audio();}
   if(ir.value==UP){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){balans--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){balans--;gr1=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <<<<<<
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BALANCE");u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(abs(balans));
  if(balans<=0){u8g.drawStr(50,20,"LCH");}
  if(balans>=0){u8g.drawStr(105,20,"RCH");}
  u8g.drawStr(0,44,"VOLUME");u8g.setPrintPos(80, 44);u8g.print(vol_reg);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"TREBLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"MIDDLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
 if(menu==10){
  switch(in_reg){
   gain0=gain0+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;www=1;gain_func();}
   if(ir.value==UP){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >>>>>>
   if(ir.value==DW){gain0--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <<<<<<
  switch(in_reg){
    case 1: gain1=gain0;break;
    case 2: gain2=gain0;break;
    case 3: gain3=gain0;break;
    case 4: gain4=gain0;break;
  if(www==1){audio();www=0;}
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(in_reg);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"INPUT");u8g.drawStr(0,44,"GAIN");
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 60);u8g.print(gain0);
if(millis()-times>5000 && w1==1 && power==0){
     EEPROM.update(0,vol_reg);EEPROM.update(1,treb_reg+7);EEPROM.update(2,mid_reg+7);EEPROM.update(3,bass_reg+7);
     EEPROM.update(4,in_reg);EEPROM.update(5,gain1);EEPROM.update(6,gain2);EEPROM.update(7,gain3);EEPROM.update(8,gain4);EEPROM.update(9,balans+8);
void vol_func(){if(vol_reg<0){vol_reg=0;}if(vol_reg>48){vol_reg=48;}}
void treb_func(){if(treb_reg<-7){treb_reg=-7;}if(treb_reg>7){treb_reg=7;}}
void mid_func(){if(mid_reg<-7){mid_reg=-7;}if(mid_reg>7){mid_reg=7;}}
void bass_func(){if(bass_reg<-7){bass_reg=-7;}if(bass_reg>7){bass_reg=7;}}
void gain_func(){if(gain0>15){gain0=15;}if(gain0<0){gain0=0;}}
void ball_func(){if(balans>8){balans=8;}if(balans<-8){balans=-8;}}
  tda.setInput(in_reg); // 1 to 4 // номер канала
  tda.setVolume(vol_reg); // 0 to 48 ( 0 is mute) // громкость
  tda.setSnd(bass_reg, 1); //-7 to +7 , 1 - Bass | 2 - Mids | 3 - Trebble
  tda.setSnd(mid_reg, 2);
  tda.setSnd(treb_reg, 3);
  tda.spkAtt(8 + balans ,8 - balans); // баланс R L от 0 to 79 (db)
2 (2023-11-23 22:01:10 отредактировано rudakov2002@mail.ru)
Re: TDA7439 + OLED_1.3+IR+ENCODER
Собрал на макетке,TDA 7439 подцепил, все работает. Большое Вам спасибо.
При подачи питания включается  режим POWER ON, а хотелось-бы POWER OFF.
При переходе с режима POWER ON в POWER OFF сигнал на микрухе идет на "прямую" с увеличенной громкостью.
Еще бы добавить лог. ед. на А0, А1, А2, А3  соответствующем входам TDA7439 IN 1...4 , и кнопку MUTE.
ЕЩЕ РАЗ ОГРОМНОЕ СПАСИБО.
http://forum.rcl-radio.ru/uploads/images/2023/11/ab02ebd43b1b3cb9f9acdf20efafdd6b.jpg
3
#define ENC_DT       8
#define ENC_CLK      9
#define ENC_SW       10
#define IR           12
#define MUTE_IR   0x33B811FF // MUTE
#define IN            2
#define POWER         6
#define MUTE          3
#define IN1_OUT   A0
#define IN2_OUT   A1
#define IN3_OUT   A2
#define IN4_OUT   A3
TDA7439 tda;
IRrecv irrecv(IR);
bool gr1,gr2,w=1,w1,www,power,power_off=1,mute;
  pinMode(MUTE,INPUT_PULLUP);
  pinMode(POWER_OUT_PIN,OUTPUT);
  pinMode(IN1_OUT,OUTPUT);
  pinMode(IN2_OUT,OUTPUT);
  pinMode(IN3_OUT,OUTPUT);
  pinMode(IN4_OUT,OUTPUT);
  switch(in_reg){
   if(in_reg==1){digitalWrite(IN1_OUT,HIGH);}else{digitalWrite(IN1_OUT,LOW);}
   if(in_reg==2){digitalWrite(IN2_OUT,HIGH);}else{digitalWrite(IN2_OUT,LOW);}
   if(in_reg==3){digitalWrite(IN3_OUT,HIGH);}else{digitalWrite(IN3_OUT,LOW);}
   if(in_reg==4){digitalWrite(IN4_OUT,HIGH);}else{digitalWrite(IN4_OUT,LOW);}
   else{digitalWrite(IN1_OUT,LOW);digitalWrite(IN2_OUT,LOW);digitalWrite(IN3_OUT,LOW);digitalWrite(IN4_OUT,LOW);}
 if((digitalRead(POWER)==LOW||ir.value==POWER_IR||power_off==1)&&power==0&&mute==0){power_off=0;power=1;menu=100;cl();vol_old=vol_reg;vol_reg=0;audio();
 if((digitalRead(MUTE)==LOW||ir.value==MUTE_IR)&&mute==0){mute=1;menu=100;cl();vol_old=vol_reg;vol_reg=0;audio();
     u8g.firstPage();do {u8g.setFont(u8g_font_profont12r);u8g.drawStr(53,30,"MUTE");} while( u8g.nextPage() );}
 if((digitalRead(MUTE)==LOW||ir.value==MUTE_IR)&&mute==1){mute=0;times=millis();w=1;w1=1;menu=0;cl();vol_reg=vol_old;audio();}
  if(w==1){w=0;
  u8g.firstPage();
   do {
   if(w==1){w=0;
  u8g.firstPage();
   do {
   if(w==1){w=0;
  u8g.firstPage();
   do {
 if(w==1){w=0;
  u8g.firstPage();
   do {
  if(w==1){w=0;
  u8g.firstPage();
   do {
 if(menu==10){
  switch(in_reg){
  switch(in_reg){
  if(w==1){w=0;
  u8g.firstPage();
   do {
if(millis()-times>5000 && w1==1 && power==0 && mute==0){
Отлично все, как и хотелось.
Завтра сделаю печатку.
Ещё раз большое спасибо
5
Здравствуйте, спасибо за проделанную работу собрал тоже на ардуинке все работает, а на LGT8F328 которая фиолетовая почему-то не сохраняются настройки. Может я такой криворукий умею только заливать скетчи. Возможно, ли прикрутить еще анализатор спектра? И еще когда нажимаю с пульта кнопки >>> и <<< часто срабатывает как-бы двойное нажатие.
6
Я делал на фиолетовой, настройки сохраняет.
Срабатывает удержание кнопки, это предусмотрено скетчем, если не нужно эта функция закомментируйте все строки с кодом FFFFFFFF
Вот пример
// if(ir.value==0xFFFFFFFF and gr2==1){treb_reg--;gr1=0;cl();times=millis();w=1;w1=1;treb_func();audio();}
Я подумаю над этим вопросом
7
С сохранением памяти разобрался, нашел в примерах LGT8F328 скетч EEPROM Clear после его применения все стало работать как надо.
8
Доброго времени суток,ребят а не поделитесь печатной платой?
9
Здравствуйте уважаемый liman324!
Скажите пожалуйста, возможно ли обьединить два устройства в одно, этот темброблок с радио http://rcl-radio.ru/?p=130883
Спасибо!
10
Какую библиотеку вы используете для TDA7439, у меня выдает ошибку!
11
Какую библиотеку вы используете для TDA7439, у меня появляется ошибка. Спасибо.
12
http://rcl-radio.ru/wp-content/uploads/ … DA7439.zip
13 (2024-11-03 01:35:10 отредактировано anasalan23)
Здравствуйте, не могу скачать архив, выдает ошибку (Неподтвержденный 363830), что это может быть? Спасибо!
14
anasalan23 пишет:
Здравствуйте, не могу скачать архив, выдает ошибку (Неподтвержденный 96715), что это может быть? Спасибо!
15
https://github.com/AussieMakerGeek/TDA7439/tree/master
16
Спасибо большое, бро!!
17
liman324 пожалуйста мне еще нужны библиотеки IRremote.zip, Encoder.zip, MsTimer2, у меня вылазят всякие ошибки, я в тумане, спасибо и извините за беспокойство!
18
19
Не могу скачать архивы бро, выдает ошибку "Неподтвержденный 179620", не скачивается, не знаю что делать!
20
не работает IR c  моими кодами
#define MENU    0xFF38C7 // button encoder
#define UP        0xFF5AA5 // >>>
#define DW        0xFF10EF // <<<
#define 3INPUT_IR  0xFFA25D // Кнопка IN   1
#define POWER_IR  0xFFB04F // POWER       #
#define MUTE_IR   0xFF629D // MUTE        2
21
Вы их взяли с монитора порта?
22 (2024-11-26 11:00:52 отредактировано liftovik)
в программе получения кодов в FLProg.  В других проектах этот пульт с этими кодами работает. в мониторе порта не вижу ни каких кодов. порт  D12  работает.
23
Эта строка
должна выводить коды кнопок в монитор порта
