Тема: PT2323 & PT2322 + IR + Clock + encoder
Good Day !
i have received This two ic's and fabricate the a PCB was shared on 320volt.com .
Liman im ready to test can you please add Clock and Standby mode to this ?
#include <PT2322.h>
#include <PT2323.h>
#include <LiquidCrystal.h>
#include <Encoder.h>
#include <MsTimer2.h>
#include <boarddefs.h>
#include <IRremote.h>
PT2322 pt; PT2323 pt0;
Encoder myEnc(9, 8);//CLK, DT encoder connection
IRrecv irrecv(13); // IR receiver module
unsigned long newPosition,time,oldPosition = -999;
int g1,g2,inn;
Wire.begin();Serial.begin(9600);irrecv.enableIRIn(); // запускаем модуль IR
pinMode(A0,INPUT); // menu encoder button
pinMode(12,INPUT); // MUTE button
pinMode(11,INPUT); // IN select button
delay(500);
audio();audio_in();
void loop(){delay(10);
if(analogRead(A0)<900){menu++;cl1();myEnc.write(0);time=millis();w=1;if(menu>11){menu=0;}}// menu
if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);time=millis();w=1;irrecv.resume();}// IR receiver
if(ir.value==0xFFE21D){menu++;g1=0;g2=0;cl1();time=millis();w=1;if(menu>11){menu=0;}}// menu CH+ remote button
if(ir.value==0xFF22DD){menu--;g1=0;g2=0;cl1();time=millis();w=1;if(menu<0){menu=11;}}// menu CH- remote button
if(ir.value==0xFF02FD){menu=0;g1=0;g2=0;cl1();time=millis();w=1;}// menu CH remote button (menu===0)
if(ir.value==0xFFC23D){inn=1;g1=0;g2=0;time=millis();w=1;audio();}// IN remote button
//////////////////////////////////////// Volume -79...0 dB //////////////////////////////////////
if(ir.value==0x4DB5DAAA){vol++;g1=1;g2=0;cl();time=millis();w=1;audio();}// VOL+ remote button 0xFFA857
if(ir.value==0xFFFFFFFF and g1==1){vol++;g2=0;cl();time=millis();w=1;audio();}// button >>>>>>
if(ir.value==0xFF18E7){vol--;g1=0;g2=1;cl();time=millis();w=1;audio();}// remote button VOL-
if(ir.value==0xFFFFFFFF and g2==1){vol--;g1=0;cl();time=millis();w=1;audio();}// button <<<<<<
oldPosition = newPosition;
vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(vol>79){vol=79;}if(vol<0){vol=0;}audio();}
//////////////////////////////////////// Bass tone + -14 dB//////////////////////////////////////
if(ir.value==0x4DB5DAAA){bass++;g1=1;g2=0;cl();time=millis();w=1;audio();}// VOL+ remote button
if(ir.value==0xFFFFFFFF and g1==1){bass++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){bass--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){bass--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(bass<-7){bass=-7;}if(bass>7){bass=7;}
bass=bass+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(bass<-7){bass=-7;}if(bass>7){bass=7;}audio();}
lcd.print(" ");lcd.print(bass*2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");bass_d=(bass+7)*2;
if(z1==2){lcd.setCursor(z0+3,1);lcd.write((uint8_t)2);}}
//////////////////////////////////////// Tone middle + -14 dB //////////////////////////////////////
if(ir.value==0x4DB5DAAA){mid++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){mid++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){mid--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){mid--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(mid<-7){mid=-7;}if(mid>7){mid=7;}
mid=mid+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(mid<-7){mid=-7;}if(mid>7){mid=7;}audio();}
lcd.print(" ");lcd.print(mid*2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");mid_d=(mid+7)*2;
//////////////////////////////////////// Treble tone +-14 dB //////////////////////////////////////
if(ir.value==0x4DB5DAAA){treb++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){treb++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){treb--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){treb--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(treb<-7){treb=-7;}if(treb>7){treb=7;}
treb=treb+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(treb<-7){treb=-7;}if(treb>7){treb=7;}audio();}
lcd.print(" ");lcd.print(treb*2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");treb_d=(treb+7)*2;
if(menu==4){
if(ir.value==0x4DB5DAAA){tembro++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){tembro++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){tembro--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){tembro--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(tembro>4){tembro=0;}if(tembro<0){tembro=4;}
tembro=tembro+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(tembro>4){tembro=0;}if(tembro<0){tembro=4;}}
lcd.setCursor(0,0);lcd.print(" Preset timbre ");
if(tembro==0){lcd.setCursor(0,1);lcd.print(" Manual Mode ");}
if(tembro==1){lcd.setCursor(0,1);lcd.print(" ROCK ");bass=4,mid=-2;treb=5;x=1;}
if(tembro==2){lcd.setCursor(0,1);lcd.print(" POP ");bass=-3,mid=3;treb=-2;x=1;}
if(tembro==3){lcd.setCursor(0,1);lcd.print(" CLASSIC ");bass=0,mid=0;treb=-2;x=1;}
if(tembro==4){lcd.setCursor(0,1);lcd.print(" default ");bass=0,mid=0;treb=0;x=1;}
if(x==1){audio();x=0;}
if(menu==5){
if(ir.value==0x4DB5DAAA){attfl++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){attfl++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){attfl--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){attfl--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(attfl<-14){attfl=-14;}if(attfl>0){attfl=0;}
attfl=attfl+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attfl<-14){attfl=-14;}if(attfl>0){attfl=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT FL ");
lcd.print(" ");lcd.print(attfl);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");attfl_d=(attfl+14)*2;
if(menu==6){
if(ir.value==0x4DB5DAAA){attfr++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){attfr++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){attfr--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){attfr--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(attfr<-14){attfr=-14;}if(attfr>0){attfr=0;}
attfr=attfr+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attfr<-14){attfr=-14;}if(attfr>0){attfr=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT FR ");
lcd.print(" ");lcd.print(attfr);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");attfr_d=(attfr+14)*2;
for(z=0,z0=0,z1=0;z<=attfr_d;z++,z1++){if(z1>2){z1=0;z0++;}
/////////////////////// ATT TL ///////////////////
if(menu==7){
if(ir.value==0x4DB5DAAA){atttl++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){atttl++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){atttl--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){atttl--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(atttl<-14){atttl=-14;}if(atttl>0){atttl=0;}
atttl=atttl+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(atttl<-14){atttl=-14;}if(atttl>0){atttl=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT TL ");
lcd.print(" ");lcd.print(atttl);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");atttl_d=(atttl+14)*2;
/////////////////////// ATT TR ///////////////////
if(menu==8){
if(ir.value==0x4DB5DAAA){atttr++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){atttr++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){atttr--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){atttr--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(atttr<-14){atttr=-14;}if(atttr>0){atttr=0;}
atttr=atttr+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(atttr<-14){atttr=-14;}if(atttr>0){atttr=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT TR ");
lcd.print(" ");lcd.print(atttr);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");atttr_d=(atttr+14)*2;
for(z=0,z0=0,z1=0;z<=atttr_d;z++,z1++){if(z1>2){z1=0;z0++;}
if(menu==9){
if(ir.value==0x4DB5DAAA){attcn++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){attcn++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){attcn--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){attcn--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(attcn<-14){attcn=-14;}if(attcn>0){attcn=0;}
attcn=attcn+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attcn<-14){attcn=-14;}if(attcn>0){attcn=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT CN ");
lcd.print(" ");lcd.print(attcn);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");attcn_d=(attcn+14)*2;
if(menu==10){
if(ir.value==0x4DB5DAAA){attsub++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){attsub++;g2=0;cl();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){attsub--;g1=0;g2=1;cl();audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){attsub--;g1=0;cl();time=millis();w=1;audio();}// кнопка <<<<<<
if(attsub<-14){attsub=-14;}if(attsub>0){attsub=0;time=millis();}
attsub=attsub+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attsub<-14){attsub=-14;}if(attsub>0){attsub=0;}audio();}
lcd.setCursor(0,0);lcd.print("ATT SUB ");
lcd.print(" ");lcd.print(attsub);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");attsub_d=(attsub+14)*2;
if(menu==11){
if(ir.value==0x4DB5DAAA){ddd++;g1=1;g2=0;cl1();time=millis();w=1;audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){ddd++;g2=0;cl1();time=millis();w=1;audio();}// кнопка >>>>>>
if(ir.value==0xFF18E7){ddd--;g1=0;g2=1;cl1();audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){ddd--;g1=0;cl1();time=millis();w=1;audio();}// кнопка <<<<<<
if(ddd<0){ddd=1;}if(ddd>1){ddd=0;}
ddd=ddd+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(ddd<0){ddd=1;}if(ddd>1){ddd=0;}audio();}
lcd.setCursor(0,0); if(ddd==0){lcd.print(" 3D ON ");}else{lcd.print(" 3D OFF ");} }
if(mute==1&&(digitalRead(12)==HIGH)){mute=0;menu=0;audio();cl1();}
if(digitalRead(12)==HIGH){mute=1;menu=100;audio();cl1();}
if(mute==1){lcd.setCursor(0,0);lcd.print(" MUTE ");delay(300);}
if(digitalRead(11)==HIGH||inn==1){in++;if(in>4){in=0;}audio_in();cl1();lcd.setCursor(0,0);lcd.print(" INPUT ");lcd.print(in+1);delay(2000);time=millis();w=1;inn=0;}// in
menu=0;w=0;cl();}
}//loop
void audio_in(){
pt0.setInput(in);
pt0.setMute(0,0,0,0,0,0,0);
pt0.setFeature(1,1);
pt.setCenter_att(abs(attcn)); // att center
pt.setSub_att(abs(attsub)); // att sub
pt.setFunc(mute,ddd,0); // mute,3d,тембр on/off
pt.setBass(bass); // BASS -14...0...14 dB (int -7...0...7)
pt.setMiddle(mid); // MIDDLE -14...0...14 dB (int -7...0...7)
pt.setTreble(treb); // TREBLE -14...0...14 dB (int -7...0...7)
