Тема: VU meter + oled 0.96'
#include <OLED_I2C.h> // http://rcl-radio.ru/wp-content/uploads/2022/01/OLED_I2C.zip
#define GAIN 100
#define STEP 3
#define LOW_SOUND 100
#define MAX_SOUND 600
OLED myOLED(SDA, SCL, 8);
extern uint8_t SmallFont[];
int strela=-45;
int hMeter = 65;
int vMeter = 85;
int rMeter = 80;
int ur,urr;
unsigned long times;
Wire.begin();Wire.setClock(400000L);
myOLED.begin();
myOLED.setBrightness(100);
// myOLED.invert(true);// invert
myOLED.clrScr();
myOLED.setFont(SmallFont);
analogReference(INTERNAL); // если очень маленький уровень сигнала
pinMode(A0,INPUT);
// times=millis();
strela = map(log(analogRead(A0))*GAIN, LOW_SOUND,MAX_SOUND, -45,45);
strela = constrain(strela, -45, 45);
urr = strela;if(urr<ur){ur=ur-STEP;}else{ur = strela;}
/////// PRINT ////////////////////////////////////////////////////////////////
myOLED.clrScr();
myOLED.drawLine(10, 20, 85, 20);// line 1
myOLED.drawLine(88, 20, 125, 20);myOLED.drawLine(88, 19, 125, 19);// line 2
myOLED.drawLine(3, 23, 85, 23);// line3
byte b1_2[10]{95,108,124,10,33,60,84,50,68,77};
byte c1_2[10]{15,17,15,15,15,15,15,17,18,18};
for(int i=0;i<10;i++){myOLED.drawLine(b1_2[i], 20, b1_2[i], c1_2[i]);}
byte b3[5]{3,25,48,67,84};
for(int i=0;i<5;i++){myOLED.drawLine(b3[i], 23, b3[i], 27);}
myOLED.print(F("20 10 3 0 1"), 3, 5);
myOLED.print(F("0 25"), 0, 30);
myOLED.print(F("50"), 42, 30);
myOLED.print(F("75"), 61, 30);
myOLED.print(F("100"), 75, 30);
myOLED.print(F("2"), 106, 5);
myOLED.print(F("3"), 120, 5);
myOLED.print(F("-"), 3, 50);myOLED.print(F("+"), 119, 50);
myOLED.print(F("VU meter"), CENTER, 50);
int a1 = (hMeter + (sin(ur / 57.296) * rMeter)); // meter needle horizontal coordinate
int a2 = (vMeter - (cos(ur / 57.296) * rMeter)); // meter needle vertical coordinate
myOLED.drawLine(a1, a2, hMeter, vMeter);
myOLED.update();
// Serial.println(millis()-times);
//////// END PRINT /////////////////////////////////////////////////////////
