Тема: VU meter + oled 0.96'
http://forum.rcl-radio.ru/uploads/images/2022/08/0fb0df97983b79c2044776b7a42f9687.png
#include <OLED_I2C.h>           // http://rcl-radio.ru/wp-content/uploads/2022/01/OLED_I2C.zip
#define GAIN      100
#define STEP      3
#define LOW_SOUND 100
#define MAX_SOUND 600
  OLED  myOLED(SDA, SCL, 8);
  extern uint8_t SmallFont[];
  int strela=-45;
  int hMeter = 65;
  int vMeter = 85;
  int rMeter = 80;
  int ur,urr;
  unsigned long times;
  Wire.begin();Wire.setClock(400000L);
  myOLED.begin();
  myOLED.setBrightness(100);
  //  myOLED.invert(true);// invert
  myOLED.clrScr();
  myOLED.setFont(SmallFont);
  analogReference(INTERNAL);  // если очень маленький уровень сигнала
  pinMode(A0,INPUT);
 // times=millis();
  strela = map(log(analogRead(A0))*GAIN, LOW_SOUND,MAX_SOUND, -45,45);
  strela = constrain(strela, -45, 45);
  urr = strela;if(urr<ur){ur=ur-STEP;}else{ur = strela;}
/////// PRINT ////////////////////////////////////////////////////////////////
  myOLED.clrScr();
  myOLED.drawLine(10, 20, 85, 20);// line 1
  myOLED.drawLine(88, 20, 125, 20);myOLED.drawLine(88, 19, 125, 19);// line 2
  myOLED.drawLine(3, 23, 85, 23);// line3
  byte b1_2[10]{95,108,124,10,33,60,84,50,68,77};
  byte c1_2[10]{15,17,15,15,15,15,15,17,18,18};
  for(int i=0;i<10;i++){myOLED.drawLine(b1_2[i], 20, b1_2[i], c1_2[i]);}
  byte b3[5]{3,25,48,67,84};
  for(int i=0;i<5;i++){myOLED.drawLine(b3[i], 23, b3[i], 27);}
  myOLED.print(F("20  10   3   0 1"), 3, 5);
  myOLED.print(F("0  25"), 0, 30);
  myOLED.print(F("50"), 42, 30);
  myOLED.print(F("75"), 61, 30);
  myOLED.print(F("100"), 75, 30);
  myOLED.print(F("2"), 106, 5);
  myOLED.print(F("3"), 120, 5);
  myOLED.print(F("-"), 3, 50);myOLED.print(F("+"), 119, 50);
  myOLED.print(F("VU meter"), CENTER, 50);
  int a1 = (hMeter + (sin(ur / 57.296) * rMeter)); // meter needle horizontal coordinate
  int a2 = (vMeter - (cos(ur / 57.296) * rMeter)); // meter needle vertical coordinate
  myOLED.drawLine(a1, a2, hMeter, vMeter);
  myOLED.update();
 // Serial.println(millis()-times);
//////// END PRINT /////////////////////////////////////////////////////////
2 (2022-09-28 08:54:20 отредактировано highprofi)
Re: VU meter + oled 0.96'
Здравствуйте.
А стерео сигнал и два дисплея одна ардуина потянет?
Возможно это сделать?
3
Точно не могу ответить, надо пробовать, но у меня нет второго экрана. С интерфейсом SPI точно можно 2 использовать, а I2C не знаю.
4
Могу проверить, у меня как раз два дисплея в наличии)
Если скетч допишете...
5
Изучил вопрос, с интерфейсом i2c ни чего не выйдет, библиотека рассчитана на работу только с одним дисплеем.
6
Печаль конечно (
А какой чип минимально можно использовать?
Чтоб памяти хватило
Жалко две не дешёвых ардуинки
7
Ни чего кроме lgt8f328p atmega168 и atmega328 не подойдет.
8
Понял, спасибо вам)
