1 (2022-05-15 18:40:23 отредактировано bobrusev11)
Тема: Pt2257 + энкодер+ lcd1602 i2c+ ИК пульт
Помогите переделать ваш скетч под комплектующие.
#include <EEPROMex.h>
#include <PT2257.h>
#include <LiquidCrystal.h>
PT2257 rt;
#include <Encoder.h>
Encoder myEnc(10, 11);//CLK, DT
int menu,vol,vol_ram,vol_d,z,balans,balans_ram,balans_d,z1;
byte w,mute;
long oldPosition  = -999;
unsigned long time,time1;
  byte a1[8]={0b00000,0b00000,0b11011,0b11011,0b11011,0b11011,0b00000,0b00000};
  byte a2[8]={0b00000,0b00000,0b11000,0b11000,0b11000,0b11000,0b00000,0b00000};
  byte a3[8]={0b00000,0b00000,0b00000,0b11011,0b11011,0b00000,0b00000,0b00000};
  byte a4[8]={0b00000,0b00000,0b00000,0b11000,0b11000,0b00000,0b00000,0b00000};
  Wire.begin();Serial.begin(9600);lcd.begin(16, 2);
  pinMode(12,INPUT);// кнопка энкодера
  pinMode(A0,INPUT);// кнопка mute
   lcd.createChar(0,a1); lcd.createChar(1,a2);lcd.createChar(2,a3); lcd.createChar(3,a4);
   balans = EEPROM.read(1)-7;
   vol_ram=vol;balans_ram=balans;
   delay(1000);
    if(digitalRead(12)==LOW){menu++;myEnc.write(0);vol_ram=vol;balans_ram=balans;delay(300);if(menu>1||menu<0){menu=0;}}
/////////////////////////////////////// vol /////////////////////////////////////
    long newPosition = myEnc.read()/4+vol_ram;
    oldPosition = newPosition;vol=newPosition;
    audio();time = millis();w=1;
    if(vol>79){myEnc.write(0);vol_ram=79;}
    if(vol<0){myEnc.write(0);vol_ram=0;}
// индикация баланс + управление кнопками +\- 4 дБ ///////
    long newPosition = myEnc.read()/4+balans_ram;
    oldPosition = newPosition;balans=newPosition;
    if(balans>7){myEnc.write(0);balans_ram=7;}
    if(balans<-7){myEnc.write(0);balans_ram=-7;}
   if(millis()-time1>100){lcd.clear();vol_d=vol/3;
   if(vol_d>=0){for(z=0;z<=vol_d;z++){lcd.setCursor(z/2,0);if(menu==0){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}}}
   if((vol_d)%2==0){lcd.setCursor(z/2,0);if(menu==0){lcd.write((uint8_t)1);}else{lcd.write((uint8_t)3);}}
   lcd.setCursor(14,0);lcd.print(vol);time1=millis();
   if(balans<0){lcd.setCursor(balans+7,1);if(menu==1){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}}
   if(balans>0){lcd.setCursor(balans+8,1);if(menu==1){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}}
   if(balans==0){lcd.setCursor(7,1);if(menu==1){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}lcd.setCursor(8,1);
   if(menu==1){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}}else{lcd.setCursor(7,1);if(balans>0){lcd.print("+");}lcd.print(balans);}
///////////// mute ////////////////////////////////
  if(analogRead(A1)>900){mute++;delay(300);if(mute>1){mute=0;}audio();}
///////////// eeprom //////////////////////////////
if(millis()-time>10000 && w==1){// запись всех настроек в EEPROM через 60 сек неактивности
     EEPROM.update(0,vol);EEPROM.update(1,balans+7); w=0;}
  rt.setLeft(vol-8+balans); // int 0...79
  rt.setRight(vol-8-balans);// int 0...79
  rt.setMute(mute);  // int 0...1
2 (2022-05-15 23:52:06 отредактировано bobrusev11)
Re: Pt2257 + энкодер+ lcd1602 i2c+ ИК пульт
немного подправил ,загрузил скеч, ,  подсветки нет появились цифры 40 в верхней строке и +7 в нижней , крутя энкодер все регулируется, как прекрутить пульт теперь?
#include <PT2257.h>
PT2257 rt;
Encoder myEnc(11, 10);//S1, S2
LiquidCrystal_I2C lcd(0x27,16,2);// A4,A5
byte w,mute;
  Wire.begin();Serial.begin(9600);lcd.begin(16,2);
   delay(1000);
3
подскажите пожалуйста , как пульт добавить?
4
Протестируйте пожалуйста скетч, пока без пульта, проверьте режим MUTE.
Изменены пины энкодера 8, 9, 10 = clk, dt, sw
#include <PT2257.h>
  PT2257 rt;
  Encoder myEnc(8, 9);//CLK, DT
  LiquidCrystal_I2C lcd(0x27,16,4);  // Устанавливаем дисплей
  int menu,vol,vol_d,z,balans,balans_d,z1;
  byte w,mute,w1=1;
  long time,time1,oldPosition  = -999,newPosition;
  Wire.begin();Serial.begin(9600);lcd.init();lcd.backlight();
  pinMode(10,INPUT);// кнопка энкодера
  pinMode(A1,INPUT_PULLUP);// кнопка mute
   delay(1000);
    if(digitalRead(10)==LOW){menu++;w1=1;myEnc.write(0);delay(300);if(menu>1||menu<0){menu=0;}}
    oldPosition = newPosition; if(newPosition>1){newPosition=1;}if(newPosition<-1){newPosition=-1;}
    vol=vol-newPosition;myEnc.write(0);newPosition=0;
    audio();time = millis();w=1;w1=1;
    balans=balans-newPosition;myEnc.write(0);newPosition=0;
    if(balans>7){balans=7;}if(balans<-7){balans=-7;}
if(w1==1){w1=0;vol_d=vol/3;
   if(vol_d>=0){for(z=0;z<=vol_d;z++){lcd.setCursor(z/2,0);if(menu==0){lcd.write((uint8_t)0);}else{lcd.write((uint8_t)2);}}lcd.print("  ");}
   if(balans<=-1){lcd.setCursor(6+balans,1);if(menu==1){if(balans<-6){}else{lcd.print(" ");}lcd.write((uint8_t)0);lcd.print(" ");}
      else{if(balans<-6){}else{lcd.print(" ");}lcd.write((uint8_t)2);lcd.print(" ");}}
   if(balans>=1){lcd.setCursor(balans+7,1);if(menu==1){lcd.print(" ");lcd.write((uint8_t)0);lcd.print(" ");}else{lcd.print(" ");lcd.write((uint8_t)2);lcd.print(" ");}}
   if(balans==0){lcd.setCursor(6,1);lcd.print(" ");}
   if(balans>=0){lcd.setCursor(7,1);lcd.print("+");lcd.print(" ");}else{lcd.setCursor(7,1);lcd.print("-");}
   lcd.setCursor(8,1);lcd.print(abs(balans));if(balans==0){lcd.print(" ");}
  if(digitalRead(A1)==LOW && mute==0){mute=1;menu=100;audio();lcd.clear();lcd.setCursor(6,0);lcd.print("MUTE");delay(300);}
  if(digitalRead(A1)==LOW && mute==1){mute=0;w1=1;lcd.clear();menu=0;audio();delay(300);}
if(millis()-time>10000 && w==1){// запись всех настроек в EEPROM через 10 сек неактивности
5 (2022-05-20 23:10:48 отредактировано bobrusev11)
liman324 пишет:
#include <PT2257.h>
  PT2257 rt;
  byte w,mute,w1=1;
   delay(1000);
  • протестировал все работает, только когда звук прибавляешь , идет сразу по 10 , доходит до 90 потом опять 10 и идет до 79
6
Звук я поправил:
#include <PT2257.h>
  PT2257 rt;
  byte w,mute,w1=1;
   delay(1000);
   lcd.setCursor(14,0);if(vol<10){lcd.print(" ");}lcd.print(vol);time1=millis();
7
  • да теперь в норме
liman324 пишет:
Звук я поправил:
#include <PT2257.h>
  PT2257 rt;
  byte w,mute,w1=1;
   delay(1000);
8
Добавлен пульт, впишите в скетч коды своих кнопок пульта
#define IR1    0x33B820DF // button encoder
#define IR2    0x33B8946B // mute
#define IR3    0x33B810EF // >>>
#define IR4    0x33B8E01F // <<<
#include <PT2257.h>
  PT2257 rt;
  byte w,mute,w1=1,gr1,gr2;
  Wire.begin();Serial.begin(9600);lcd.init();lcd.backlight();irrecv.enableIRIn();
   delay(1000);
/// encoder ////////////////////////
    if((digitalRead(10)==LOW || ir.value==IR1) && mute==0){menu++;w1=1;myEnc.write(0);cl();time=millis();w=1;w1=1;delay(300);if(menu>1||menu<0){menu=0;}}
   if(ir.value==IR3){vol++;gr1=1;gr2=0;cl();time=millis();w=1;w1=1;if(vol>79){vol=79;}if(vol<0){vol=0;} audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){vol++;gr2=0;cl();time=millis();w=1;w1=1;if(vol>79){vol=79;}if(vol<0){vol=0;} audio();}// кнопка >>>>>>
   if(ir.value==IR4){vol--;gr1=0;gr2=1;cl();time=millis();w=1;w1=1;if(vol>79){vol=79;}if(vol<0){vol=0;} audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){vol--;gr1=0;cl();time=millis();w=1;w1=1;if(vol>79){vol=79;}if(vol<0){vol=0;} audio();}// кнопка <<<<<<
   if(ir.value==IR3){balans++;gr1=1;gr2=0;cl();time=millis();w=1;w1=1;if(balans>7){balans=7;}if(balans<-7){balans=-7;}  audio();}// кнопка >
   if(ir.value==IR4){balans--;gr1=0;gr2=1;cl();time=millis();w=1;w1=1;if(balans>7){balans=7;}if(balans<-7){balans=-7;}  audio();}// кнопка <
  if((digitalRead(A1)==LOW || ir.value==IR2) && mute==0){mute=1;cl();menu=100;audio();lcd.clear();lcd.setCursor(6,0);lcd.print("MUTE");delay(300);}
  if((digitalRead(A1)==LOW || ir.value==IR2) && mute==1){mute=0;cl();w1=1;lcd.clear();menu=0;audio();delay(300);}
9
  • то работает то не работает пульт, ик приемник на нажатия всегда реагирует, то прибавляет то нет
liman324 пишет:
#include <PT2257.h>
  PT2257 rt;
   delay(1000);
10 (2022-05-21 00:47:41 отредактировано bobrusev11)
прям в плотную всегда работает, дальше отхожу то работает то нет ,светодиод всегда отрабатывает. в мониторе порта четко работает с любого расстояния
11
Что-то у Вас с пультом, у меня отлично работает на расстоянии 2-3 метра
12
На расстоянии коды кнопок соответствуют скетчу?
13
  • не соответствовали, раньше записывал кнопки , сейчас заново посмотрел коды  исправил, вроде работает хорошо
liman324 пишет:
14
Если все работает то я разбираю схему.
15
  • да все хорошо работает, спасибо большое
liman324 пишет:
16
Есть ещё вопрос как писк побороть, не сильный но все же не приятный
17
Поставьте емкости 100-220 мкф (электролит) + 0,1 мкФ по питанию всех модулей.
18
  • поставил 2 стабилизатора на 5 и 9 вольт пленочные и электролиты, пропал писк, но появилась новая проблема,при нажатии mute треск в колонках, звук когда убавляешь доходит до 6 треск и звук громче становится как будто на половину громкости и треск от вращения энкодера от 0-7
liman324 пишет:
19
Ставил все как было, результат такой же плюс писк
20
21
Так же было с моим скетчем во 2м сообщении который, но когда ваш поставил эта проблема ушла , и вот опять появилась , перезаписывал скетчи, ничего не помогает
