#define IR1 16478351 // INPUT
#define IR2 16459991 // MUTE
#define IR3 16492631 // 3D
#define IR4 16494671 // EQ
#define IR5 16449791 // UP VOL
#define IR6 16482431 // DW VOL
#define IR7 16476311 // STANDBY
#define IR8 16474271 // TREBLE
#define IR9 16457951 // BASS
#define IR10 16470191 // FRONT
#define IR11 16453871 // REAR
#define IR12 16490591 // CENTER
#define IR13 16486511 // SUB
#define IR14 16462031 // OUTPUT
#define IR15 3772793023 // STANDBY TV
//#define IR16 0xE0E0F20D // GUIDE TV
#include <PT2322.h>
#include <PT2323.h>
#include <Encoder.h>
#include <MsTimer2.h>
#include <boarddefs.h>
#include <IRremote.h>
PT2322 pt; PT2323 pt0;
Encoder myEnc(7, 8);//CLK, DT подключение энкодера
unsigned long newPosition,time,oldPosition = -999,times_ir;
bool g1,g2;
bool w1=1,power;
int att_front, att_rear;
int w_ir,iii;
Wire.begin();Serial.begin(9600);irrecv.enableIRIn(); // запускаем модуль IR
lcd.init();lcd.backlight();
pinMode(12,INPUT_PULLUP); // MUTE
pinMode(10,INPUT_PULLUP); // IN
pinMode(11,INPUT_PULLUP); // STANDBY
pinMode(3,OUTPUT); // OUTPUT STANDBY AND MUTE
att_front = EEPROM.read(14)-14;att_rear = EEPROM.read(14)-14;
delay(500);
if(tembro==1){bass=4,mid=-2;treb=5;}
if(tembro==2){bass=-3,mid=3;treb=-2;}
if(tembro==3){bass=6,mid=0;treb=7;}
if(tembro==4){bass=0,mid=0;treb=0;}
audio();audio_in();
////////////////////////////////////////////////////////////// INPUT SELECTOR //////////////////////////////
if(power==0){
if(mute==0){
if(digitalRead(10)==LOW || ir.value==IR1){in++;g1=1;g2=0;menu=8;if(in>4){in=0;}if(in==3){in=4;}audio_in();cl1();time=millis();w=1;w1=1;}// in
if(menu==8){
lcd.setCursor(0,0);lcd.print(" INPUT SELECTOR ");
switch(in){
case 0: lcd.setCursor(0,1);lcd.print(" CD ");break;
case 1: lcd.setCursor(0,1);lcd.print(" TAPE ");break;
case 2: lcd.setCursor(0,1);lcd.print(" TV");break;
//case 3: lcd.setCursor(0,1);lcd.print(" IN ");break;
case 4: lcd.setCursor(0,1);lcd.print(" AC-3 ");break;
if(ir.value==IR3){ddd++;menu=11;g1=1;g2=0;cl1();time=millis();w=1;ddd_conf();audio();}
if(ir.value==IR4){tembro++;menu=4;g1=1;g2=0;cl1();time=millis();w=1;w1=1;tembr();audio();}
if(ir.value==IR8){menu=3;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // treble
if(ir.value==IR9){menu=1;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // bass
if(ir.value==IR10){menu=5;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // front
if(ir.value==IR11){menu=6;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // rear
if(ir.value==IR12){menu=9;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // center
if(ir.value==IR13){menu=10;g1=1;g2=0;cl1();time=millis();w=1;w1=1;} // sub
} // mute
if((digitalRead(12)==LOW || ir.value==IR2) && mute==0){mute=1;menu=100;g1=0;g2=0;cl1();time=millis();w=1;w1=1;audio();lcd.setCursor(6,0);lcd.print("MUTE");delay(500);}
if((digitalRead(12)==LOW || ir.value==IR2) && mute==1){mute=0;menu=0; g1=0;g2=0;cl1();time=millis();w=1;w1=1;audio();}
// power
if(mute==1||power==1){digitalWrite(3,HIGH);}else{digitalWrite(3,LOW);}// standby out pin D3
if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);w=0;w1=1;irrecv.resume();}
if(ir.value==IR15){iii++;times_ir=millis();}
if((digitalRead(11)==LOW || ir.value==IR7 || ir.value==IR15 && iii==1) && power==0){power=1;menu=100;g1=0;g2=0;cl1();w=0;w1=1;mute=1;audio();lcd.setCursor(3,0);lcd.print("POWER OFF");delay(1000);lcd.noBacklight();cl1();}
if((digitalRead(11)==LOW || ir.value==IR7 || ir.value==IR15 && iii==1) && power==1){power=0;menu=0; g1=0;g2=0;cl1();w=0;w1=1;mute=0;audio();lcd.backlight();lcd.setCursor(3,0);lcd.print("POWER ON ");delay(1000);cl1();}
if(millis()-times_ir>2000){iii=0;}
//if((digitalRead(11)==LOW || ir.value==IR7) && power==0){power=1;menu=100;g1=0;g2=0;cl1();time=millis();w=1;w1=1;mute=1;audio();lcd.setCursor(3,0);lcd.print("POWER OFF");delay(1000);lcd.noBacklight();cl1();}
//if((digitalRead(11)==LOW || ir.value==IR7) && power==1){power=0;menu=0; g1=0;g2=0;cl1();time=millis();w=1;w1=1;mute=0;audio();lcd.backlight();lcd.setCursor(3,0);lcd.print("POWER ON ");delay(1000);cl1();}
if(ir.value==IR5){vol++;g1=1;g2=0;cl();time=millis();w=1;w1=1;vol_conf();audio();}// кнопка VOL+ 16449791
if(ir.value==4294967295 and g1==1){vol++;g2=0;cl();time=millis();w=1;w1=1;vol_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){vol--;g1=0;g2=1;cl();time=millis();w=1;w1=1;vol_conf();audio();}// кнопка VOL- 16482431
if(ir.value==4294967295 and g2==1){vol--;g1=0;cl();time=millis();w=1;w1=1;vol_conf();audio();}// кнопка <<<<<<
oldPosition = newPosition;
vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;vol_conf();audio();}
lcd.print(vol);lcd.print(" ");vol_d=map(vol, 0,79, 0, 48);
switch(in){
case 0: lcd.print(" CD");break;
case 1: lcd.print("TAPE");break;
case 2: lcd.print(" TV");break;
//case 3: lcd.print(" IN");break;
case 4: lcd.print("AC-3");break;
if(w1==1){w1=0;
if(z1==2){lcd.setCursor(z0,1);lcd.write((uint8_t)2);}}}
//////////////////////////////////////// Тембр НЧ +-14 дБ //////////////////////////////////////
if(ir.value==IR5){bass++;g1=1;g2=0;cl();time=millis();w=1;w1=1;bass_conf();audio();}// кнопка VOL+ 16449791
if(ir.value==4294967295 and g1==1){bass++;g2=0;cl();time=millis();w=1;w1=1;bass_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){bass--;g1=0;g2=1;cl();time=millis();w=1;w1=1;bass_conf();audio();}// кнопка VOL- 16449791
if(ir.value==4294967295 and g2==1){bass--;g1=0;cl();time=millis();w=1;w1=1;bass_conf();audio();}// кнопка <<<<<<
bass=bass+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;bass_conf();audio();}
lcd.print(" ");lcd.print(bass);lcd.print(" ");lcd.setCursor(13,0);bass_d=(bass+7)*2;
if(w1==1){w1=0;
if(z1==2){lcd.setCursor(z0+3,1);lcd.write((uint8_t)2);}}}
//////////////////////////////////////// Тембр CЧ +-14 дБ //////////////////////////////////////
if(ir.value==IR5){mid++;g1=1;g2=0;cl();time=millis();w=1;w1=1;mid_conf();audio();}// кнопка VOL+
if(ir.value==4294967295 and g1==1){mid++;g2=0;cl();time=millis();w=1;w1=1;mid_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){mid--;g1=0;g2=1;cl();time=millis();w=1;w1=1;mid_conf();audio();}// кнопка VOL-
if(ir.value==4294967295 and g2==1){mid--;g1=0;cl();time=millis();w=1;w1=1;mid_conf();audio();}// кнопка <<<<<<
mid=mid+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;mid_conf();audio();}
lcd.setCursor(0,0);lcd.print("MIDDLE ");
lcd.print(" ");lcd.print(mid);lcd.print(" ");lcd.setCursor(13,0);mid_d=(mid+7)*2;
if(w1==1){w1=0;
//////////////////////////////////////// Тембр BЧ +-14 дБ //////////////////////////////////////
if(ir.value==IR5){treb++;g1=1;g2=0;cl();time=millis();w=1;w1=1;treb_conf();audio();}// кнопка VOL+
if(ir.value==4294967295 and g1==1){treb++;g2=0;cl();time=millis();w=1;w1=1;treb_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){treb--;g1=0;g2=1;cl();time=millis();w=1;w1=1;treb_conf();audio();}// кнопка VOL-
if(ir.value==4294967295 and g2==1){treb--;g1=0;cl();time=millis();w=1;w1=1;treb_conf();audio();}// кнопка <<<<<<
treb=treb+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;treb_conf();audio();}
lcd.setCursor(0,0);lcd.print("TREBLE ");
lcd.print(" ");lcd.print(treb);lcd.print(" ");lcd.setCursor(13,0);treb_d=(treb+7)*2;
if(w1==1){w1=0;
if(menu==4){
if(ir.value==IR5){tembro++;g1=1;g2=0;cl();time=millis();w=1;w1=1;tembr();audio();}// кнопка VOL+
if(ir.value==IR6){tembro--;g1=0;g2=1;cl();time=millis();w=1;w1=1;tembr();audio();}// кнопка VOL-
tembro=tembro+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;tembr();}
if(w1==1){w1=0;
lcd.setCursor(3,0);lcd.print("Preset EQ");
if(tembro==0){lcd.setCursor(0,1);lcd.print(" manual mode ");}
if(tembro==1){lcd.setCursor(0,1);lcd.print(" ROCK ");bass=4,mid=-2;treb=5;x=1;}
if(tembro==2){lcd.setCursor(0,1);lcd.print(" POP ");bass=-3,mid=3;treb=-2;x=1;}
if(tembro==3){lcd.setCursor(0,1);lcd.print(" DISCO ");bass=6,mid=0;treb=7;x=1;}
if(tembro==4){lcd.setCursor(0,1);lcd.print(" default ");bass=0,mid=0;treb=0;x=1;}
if(x==1){audio();x=0;}
/////////////////////// ATT FRONT ///////////////////
if(menu==5){
if(ir.value==IR5){att_front++;g1=1;g2=0;cl();time=millis();w=1;w1=1;att_front_conf();audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){att_front++;g2=0;cl();time=millis();w=1;w1=1;att_front_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){att_front--;g1=0;g2=1;cl();time=millis();w=1;w1=1;att_front_conf();audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){att_front--;g1=0;cl();time=millis();w=1;w1=1;att_front_conf();audio();}// кнопка <<<<<<
att_front=att_front+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;att_front_conf();audio();}
lcd.setCursor(3,0);lcd.print("FRONT ");
lcd.print(att_front);lcd.print(" ");lcd.setCursor(13,0);attfl_d=(att_front+14)*2;
if(w1==1){w1=0;
/////////////////////// ATT REAR ///////////////////
if(menu==6){
if(ir.value==IR5){att_rear++;g1=1;g2=0;cl();time=millis();w=1;w1=1;att_rear_conf();audio();}// кнопка VOL+
if(ir.value==0xFFFFFFFF and g1==1){att_rear++;g2=0;cl();time=millis();w=1;w1=1;att_rear_conf();audio();}// кнопка >>>>>>
if(ir.value==IR6){att_rear--;g1=0;g2=1;cl();time=millis();w=1;w1=1;att_rear_conf();audio();}// кнопка VOL-
if(ir.value==0xFFFFFFFF and g2==1){att_rear--;g1=0;cl();time=millis();w=1;w1=1;att_rear_conf();audio();}// кнопка <<<<<<
att_rear=att_rear+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;att_rear_conf();audio();}
lcd.setCursor(3,0);lcd.print("REAR ");
lcd.print(att_rear);lcd.print(" ");lcd.setCursor(13,0);atttl_d=(att_rear+14)*2;
if(w1==1){w1=0;
if(menu==9){
if(ir.value==IR5){attcn++;g1=1;g2=0;cl();time=millis();w=1;w1=1;att_cn();audio();}// кнопка VOL+
if(ir.value==4294967295 and g1==1){attcn++;g2=0;cl();time=millis();w=1;w1=1;att_cn();audio();}// кнопка >>>>>>
if(ir.value==IR6){attcn--;g1=0;g2=1;cl();time=millis();w=1;w1=1;att_cn();audio();}// кнопка VOL-
if(ir.value==4294967295 and g2==1){attcn--;g1=0;cl();time=millis();w=1;w1=1;att_cn();audio();}// кнопка <<<<<<
attcn=attcn+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;att_cn();audio();}
lcd.setCursor(3,0);lcd.print("CENTER ");
lcd.print(" ");lcd.print(attcn);lcd.print(" ");lcd.setCursor(13,0);attcn_d=(attcn+14)*2;
if(w1==1){w1=0;
if(menu==10){
if(ir.value==IR5){attsub++;g1=1;g2=0;cl();time=millis();w=1;w1=1;att_sub();audio();}// кнопка VOL+
if(ir.value==4294967295 and g1==1){attsub++;g2=0;cl();time=millis();w=1;w1=1;att_sub();audio();}// кнопка >>>>>>
if(ir.value==IR6){attsub--;g1=0;g2=1;cl();time=millis();w=1;w1=1;att_sub();audio();}// кнопка VOL-
if(ir.value==4294967295 and g2==1){attsub--;g1=0;cl();time=millis();w=1;w1=1;att_sub();audio();}// кнопка <<<<<<
attsub=attsub+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w1=1;att_sub();audio();}
lcd.setCursor(3,0);lcd.print("SUB ");
lcd.print(" ");lcd.print(attsub);lcd.print(" ");lcd.setCursor(13,0);attsub_d=(attsub+14)*2;
if(w1==1){w1=0;
if(menu==11){
ddd=ddd+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;ddd_conf();audio();}
lcd.setCursor(0,0);lcd.print(" Surround ");
lcd.setCursor(0,1);if(ddd==0){lcd.print(" 3D ON ");}else{lcd.print(" 3D OFF ");}}
//////////////////////////// EEPROM /////////////////////////////////////////////////////////////
//if(millis()-time>5000&& w==1&&mute==0 && power==0)
EEPROM.update(14,att_front+14);EEPROM.update(15,att_rear+14);
menu=0;w=0;w1=1;cl();}
}//loop
void ddd_conf(){if(ddd<0){ddd=1;}if(ddd>1){ddd=0;}}
void att_sub(){if(attsub<-14){attsub=-14;}if(attsub>0){attsub=0;}}
void att_cn(){if(attcn<-14){attcn=-14;}if(attcn>0){attcn=0;}}
void att_rear_conf(){if(att_rear<-14){att_rear=-14;}if(att_rear>0){att_rear=0;}}
void att_front_conf(){if(att_front<-14){att_front=-14;}if(att_front>0){att_front=0;}}
void tembr(){if(tembro>4){tembro=0;}if(tembro<0){tembro=4;}}
void treb_conf(){if(treb<-14){treb=-14;}if(treb>14){treb=14;}}
void mid_conf(){if(mid<-14){mid=-14;}if(mid>14){mid=14;}}
void bass_conf(){if(bass<-14){bass=-14;}if(bass>14){bass=14;}}
void vol_conf(){if(vol>79){vol=79;}if(vol<0){vol=0;}}
void audio_in(){
pt0.setInput(in);
pt0.setMute(0,0,0,0,0,0,0);
pt0.setFeature(1,1);
pt.setCenter_att(abs(attcn)); // att center
pt.setSub_att(abs(attsub)); // att sub
pt.setFunc(mute,ddd,0); // mute,3d,тембр on/off
pt.setBass(bass); // BASS -14...0...14 dB (int -7...0...7)
pt.setMiddle(mid); // MIDDLE -14...0...14 dB (int -7...0...7)
pt.setTreble(treb); // TREBLE -14...0...14 dB (int -7...0...7)
