Attiny 2313 частотомер 9МГц
#define DIN PD2
#define CS PD3
#define CLK PD4
#define T1 PD5
volatile int x;
unsigned int timer0;
float f;
float pop_k = 0.996237;
DDRD |= (1 << DIN) | (1 << CS) | (1 << CLK);
PORTD |= (1 << CS);
PORTD &= ~(1 << CLK) | (1 << DIN);
PORTD |= (1 << T1);
WriteBit16(0x0F,0x00); // Тест выкл.
WriteBit16(0x0C,0x01); // Вкл. индик.
WriteBit16(0x0B,0x07); // кол-во разрядов
WriteBit16(0x09,0xFF); // Дешифраторы вкл.
WriteBit16(0x0A,0x04); // яркость
cli();
// TIMER1
TCCR1A = 0;
TCCR1B = 0;
TCCR1B = (1 << CS12)|(1 << CS11)|(1 << CS10);
TIMSK |= (1 << TOIE1);
// TIMER0
TCCR0A = 0;
TCCR0B = 0;
OCR0A = 250;
TCCR0A |= (1 << WGM01);
TCCR0B |= (1 << CS01);
TIMSK |= (1 << OCIE0A);
sei();
void loop() {}
void dec(long decimal){
WriteBit16(0x08,15);
WriteBit16(0x07,decimal/1000000%10+0x80);
WriteBit16(0x06,decimal/100000%10);
WriteBit16(0x05,decimal/10000%10);
WriteBit16(0x04,decimal/1000%10+0x80);
WriteBit16(0x03,decimal/100%10);
WriteBit16(0x02,decimal/10%10);
WriteBit16(0x01,decimal%10);
PORTD &= ~(1 << CLK);PORTD &= ~(1 << CS);
for(int i = 7; i >= 0; i--){
if(((reg >> i) & 1) == 1){PORTD |= (1 << DIN);}else{PORTD &= ~(1 << DIN);}
PORTD |=(1 << CLK);PORTD &= ~(1 << CLK);
if(((data >> i) & 1) == 1){PORTD |= (1 << DIN);}else{PORTD &= ~(1 << DIN);}
PORTD |=(1 << CS);PORTD &= ~(1 << CLK);PORTD &= ~(1 << DIN);
ISR(TIMER0_COMPA_vect){
timer0++;
if(timer0 == 1){
x = 0;TCNT1 = 0;
TCCR1B = (1 << CS12)|(1 << CS11)|(1 << CS10);}
if(timer0 == 10001){
TCCR1B &= ~(1 << CS12)|(1 << CS11)|(1 << CS10);
f = ((x * 65535) + TCNT1)*pop_k; dec(f); timer0 = 0; }
ISR (TIMER1_OVF_vect){x++;}
