26
Re: Измерение напряжения STM32 (Arduino IDE)
http://forum.rcl-radio.ru/uploads/images/2021/01/613e1d4fbc6b514961cdc15fbdb45217.png
27
Начал с начала, вот попроще  программа, подумал что надо добавить sum3 , но не работает.
#include "arduinoFFT.h"
#define SAMPLES 128             //Must be a power of 2
#define SAMPLING_FREQUENCY 40000 //Hz, must be less than 10000 due to ADC
#include <STM32ADC.h>
STM32ADC myADC(ADC1);
//uint8 pins[] = {PA6, PA7};
uint8 pins[] = {PA6, PA7, PB0};
const int maxSamples = 2;
uint16_t dataPoints[maxSamples];
//long sum1, sum2;
long sum1, sum2, sum3;
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
  Serial.begin(115200);
  myADC.calibrate();
  rcc_set_prescaler(RCC_PRESCALER_ADC, RCC_ADCPRE_PCLK_DIV_8);
  pinMode(PA6, INPUT_ANALOG);
  pinMode(PA7, INPUT_ANALOG);
  pinMode(PB0, INPUT_ANALOG);
  myADC.setSampleRate(ADC_SMPR_239_5);
  myADC.setScanMode();
 // myADC.setPins(pins, 2);
 myADC.setPins(pins, 3);
  myADC.setContinuous();
  //myADC.setDMA(dataPoints, 2, (DMA_MINC_MODE | DMA_CIRC_MODE), NULL);
    myADC.setDMA(dataPoints, 3, (DMA_MINC_MODE | DMA_CIRC_MODE), NULL);
  myADC.startConversion();
  sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
  for (int j = 0; j < 10; j++) {
    sum1 = sum1 + dataPoints[0];
    sum2 = sum2 + dataPoints[1];
    sum3 = sum3 + dataPoints[2];
    delay(1);
  /*SAMPLING*/
  for (int t = 0; t < SAMPLES; t++)
    microseconds = micros();    //Overflows after around 70 minutes!
    //vReal[t] = analogRead(PB0);
    vImag[t] = 0;
    while (micros() < (microseconds + sampling_period_us)) {
  /*FFT*/
  FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
  double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
  Serial.print(vReal[34], 1);
  Serial.print("   ");
  Serial.print(sum1 / 10); sum1 = 0;
  Serial.print("   ");
  Serial.print(sum2 / 10); sum2 = 0;
  Serial.print("   ");
  Serial.println(sum3 / 10); sum3 = 0;
28
vReal[t] = sum1 / 10;
29
сделал sum3 потому что  sum1  принадлежит для PA .
PA6  и PA7 = хорошо, PB0 = не хорошо .
PB0 регирует на любую частоту = оранцовая линия, голубая линия = 0 должна регировать на одну частоту.
http://forum.rcl-radio.ru/uploads/images/2021/01/c5bbef0a23bcb353488983f16d4e2b13.png
//long sum1, sum2;
  myADC.calibrate();
    delay(1);
  /*SAMPLING*/
  for (int j = 0; j < SAMPLES; j++)
    //. vReal[t] = sum1 / 10;
    vReal[j] = sum3 / 10;
    vImag[j] = 0;
  /*SAMPLING*/
    vReal[t] = sum3 / 10;
    vImag[t] = 0;
  /*FFT*/
  Serial.print(vReal[34], 1); //orange
  Serial.print("   ");
  Serial.print(sum1 / 10); sum1 = 0;//PA6, green
  Serial.print("   ");
  Serial.print(sum2 / 10); sum2 = 0;//PA7, red
  Serial.print("   ");
  Serial.println(sum3 / 10); sum3 = 0;// blue
  //delay(100);
30
Вот пытаюсь переделать fft чтобы работало с sum3, пока не получилось.
Оригинал  = работает.
  /*SAMPLING*/
  for (int t  = 0; t  < SAMPLES; t ++)
    vReal[t ] = analogRead(PB0);
    vImag[t ] = 0;
  /*FFT*/
  for (int t = 10; t  < (SAMPLES / 2);t++)
    Serial.print(vReal[t ], 1);
    Serial.print(" ");
    Serial.println(vReal[34], 1);    //View only this line in serial plotter to visualize the bins
  //delay(1000);  //Repeat the process every second OR:
  //while(1);       //Run code once
Переделка = не работает.
#define SAMPLES 128
uint8 pins[] = {PB0};
long sum3;
  myADC.calibrate();
  /*SAMPLING*/
   // vReal[t] = analogRead(PB0);
    vImag[t] = 0;
  /*FFT*/
  for (int t = 5; t < 10; t++) {
    sum3 = sum3 + dataPoints[0];
    delay(1);
  for (int t = 5; t < (SAMPLES / 2); t++)
    Serial.print(sum3 / 10); sum3 = 0;
    Serial.print(" ");
    //Serial.print(vReal[t], 1);
    //Serial.print(" ");
  delay(10);  //Repeat the process every second OR:
31
#define SAMPLES 128
const int maxSamples = 1;
long sum3;
  myADC.calibrate();
  myADC.setPins(pins, 1);
  myADC.setDMA(dataPoints, 1, (DMA_MINC_MODE | DMA_CIRC_MODE), NULL);
  /*SAMPLING*/
    vReal[t] = dataPoints[0];
    vImag[t] = 0;
  /*FFT*/
  for (int t = 5; t < (SAMPLES / 1); t++)
 /// delay(10);  //Repeat the process every second OR:
32
Получилось так, без сигнала номера прыгают от 8 до 42, с сигналом 280 до 320. Надо добавить усреднение = sum  ?
http://forum.rcl-radio.ru/uploads/images/2021/01/cf4504d4a45f9ef3e123a03d1a2732d2.png
http://forum.rcl-radio.ru/uploads/images/2021/01/28fb6cd5e1493b110f84e336b879f867.png
33
Почему то на LCD два нуля ?
На сериал монитор 28 и 30 а на LCD 0 и  0.
http://forum.rcl-radio.ru/uploads/images/2021/01/32df6557f69aed42f3a0bd1480b17e33.png
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
long sum1, sum2;
  lcd.begin(16, 2);
  myADC.calibrate();
    delay(1);
  Serial.print("   ");
  Serial.println(sum2 / 10); sum2 = 0;
  lcd.setCursor(0, 0);
  lcd.print(sum1 / 10); sum1 = 0;
  lcd.setCursor(0, 1);
  lcd.print(sum2 / 10); sum2 = 0;
34
Serial.print(sum1 / 10); //sum1 = 0;
  Serial.print("   ");
  Serial.println(sum2 / 10); //sum2 = 0;
35
Большое спасибо
36
В первых двух колонках почему то после запятой одни нуля ?
http://forum.rcl-radio.ru/uploads/images/2021/01/358076d008bb5e347fc788c8228cda34.png
float  UxValue = 0;
float  UxValue2 ;
int  UxValue = 0;
int  UxValue2 = 0;
#include <LCD5110_Graph.h>
//LCD5110 lcd(PA4, PA3, PA2, PA0, PA1);
LCD5110 lcd(PA0, PA1, PA2, PA4, PA3);
extern unsigned char SmallFont[];
char UxString [6];
char UxString2 [6];
char MString3 [6];
char EString4 [6];
String str;
String str2;
String str3;
String str4;
float  UxValue = 0;
float  UxValue2 ;
int  UxValue = 0;
int  UxValue2 = 0;
int  M = 0;
int E = 0;
long sum1, sum2;
  lcd.InitLCD();
  lcd.setFont(SmallFont);
  myADC.calibrate();
  lcd.clrScr();
  lcd.update();
  float  M = sqrt(UxValue * UxValue + UxValue2 * UxValue2);
  float E = (float) RAD_TO_DEG * (atan2(UxValue, UxValue2));
  UxValue = sum1 / 10; sum1 = 0;// UxValue = analogRead(PA6);
  UxValue2 = sum2 / 10; sum2 = 0;// UxValue2 = analogRead(PA7);
  UxValue = map( UxValue, 0, 4095, 0, 65);
  UxValue2 = map( UxValue2, 0, 4095, 0, 65);
  //M = map( M, 0, 4095, 0, 94);
  str = String(UxValue) ;
  str2 = String(UxValue2) ;
  str3 = String(M) + "°";
  str4 = String(E) + "%";
  str.toCharArray(UxString, 6);
  str2.toCharArray(UxString2, 6);
  str3.toCharArray(MString3, 6);
  str4.toCharArray(EString4, 6);
  fillBar( UxValue);   //displays line
  lcd.print(UxString, 2, 0); // displays # in %, position x, y
  fillBar2( UxValue2);   //displays line
  lcd.print(UxString2, 22, 0); // displays # in %, position x, y
  fillBar3( M);
  lcd.print(MString3, 46, 0); // magnitude in #
  fillBar4( E);
  lcd.print(EString4, 46, 10);
  lcd.update();
    delay(1);
  Serial.print(UxValue);
  Serial.print("   ");
  Serial.print(UxValue2);
  Serial.print("   ");
  Serial.print(M);
  Serial.print("   ");
  Serial.println(E, 3); // = x/y
void fillBar(int percent)
  percent = map(percent, 0, 100, 0, 90);
  lcd.drawLine(2, 42, percent, 42);//x, y
void fillBar2(int percent2)
  percent2 = map(percent2, 0, 100, 0, 90);
  lcd.drawLine(2, 46, percent2, 46); //x, y
void fillBar3(int percent3)
  percent3 = map(percent3, 0, 100, 0, 90);//magnitude bar
  lcd.drawLine(2, 44, percent3, 44); //x, y
void fillBar4(int percent4)
  percent4 = map(percent4, 0, 100, 0, 90);//magnitude bar
  lcd.drawLine(2, 20, percent4, 20); //x, y
37
UxValue = sum1 / 10.00; sum1 = 0;// UxValue = analogRead(PA6);
UxValue2 = sum2 / 10.00; sum2 = 0;// UxValue2 = analogRead(PA7);
38
ничего не изменилось
  // UxValue = sum1 / 10; sum1 = 0;// UxValue = analogRead(PA6);
  // UxValue2 = sum2 / 10; sum2 = 0;// UxValue2 = analogRead(PA7);
39
UxValue и UxValue2 это данные измерения входов PА6 PА7, а это int, только целое число.
40
int было в начале, пробовал float но не получилось.
float  UxValue = 0;
float  UxValue2 ;
  int  UxValue = 0;
  int  UxValue2 = 0;
