Тема: DAC CS8416 + AD1852 — 24bit 192kHz (Arduino)
Основная статья - http://rcl-radio.ru/?p=86998
#include <SPI.h>
#include <STM32_TM1637.h> // http://rcl-radio.ru/wp-content/uploads/2020/02/STM32_TM1637_V1_3.zip
Encoder myEnc(8, 9);//CLK, DT
STM32_TM1637 tm(3,2);// CLK, DIO
// AD1852 SPI
// SS 10 // CLATCH
// MOSI 11 // CDATA
// SCK 13 // CCLK
unsigned long times,oldPosition = -999,newPosition;
int w,vol,mute,code_mute,in;
Serial.begin(9600);tm.brig(7); // ЯРКОСТЬ 0...7
pinMode(A0,OUTPUT); // RSEL1 CS8416
pinMode(A1,OUTPUT); // RSEL0 CS8416
pinMode(7,INPUT); // кнопка SW энкодера
pinMode(6,INPUT_PULLUP); // кнопка IN
vol = EEPROM.read(0);in = EEPROM.read(1);
case 0: digitalWrite(A0, LOW);digitalWrite(A1, LOW);tm.print_float(1,0 ,0b00000100,0b01010100,0,0);break;// px0
case 1: digitalWrite(A0, LOW);digitalWrite(A1, HIGH);tm.print_float(2,0 ,0b00000100,0b01010100,0,0);break;// px1
case 2: digitalWrite(A0, HIGH);digitalWrite(A1, LOW);tm.print_float(3,0 ,0b00000100,0b01010100,0,0);break;// px2
}// setup
if(digitalRead(7)==LOW&&mute==0){mute=1;code_mute = 0b1000000;tm.print_float(vol,0 ,0b01000000,0b01000000,0b01000000,0b01000000);delay(200);}
if(digitalRead(7)==LOW&&mute==1){mute=0;code_mute = 0;tm.print_float(vol,0 ,0,0,0,0);delay(200);}
if(digitalRead(6)==LOW){in++;if(in>2){in=0;}times=millis();w=1;
delay(2000);tm.print_float(vol,0 ,0,0,0,0);}
vol=vol+newPosition;myEnc.write(0);newPosition=0;w=1;times=millis();
if(vol>127){vol=127;}if(vol<0){vol=0;}
Serial.println(vol);
if(mute==0){tm.print_float(vol,0 ,0,0,0,0);}
SPI.begin();
WriteAD1852(0b100010010001+code_mute); // register control
WriteAD1852(0b00+(vol<<9)); // register volume left
WriteAD1852(0b10+(vol<<9)); // register volume right
delay(10);
if(millis()-times>5000 && w==1){w=0;EEPROM.write(0,vol);EEPROM.write(1,in);}
}// loop
void WriteAD1852(uint16_t Data){
SPI.beginTransaction(SPISettings(SPI_CLOCK_DIV2, MSBFIRST, SPI_MODE3));
digitalWrite(SS, HIGH);
delayMicroseconds(1);
SPI.transfer16(Data);
digitalWrite(SS, LOW);
SPI.endTransaction();
void to_Timer(){newPosition = myEnc.read()/4;} SPI
REGISTER ADDRESSES
The lowest two bits of the 16-bit serial control data word are
decoded as the address of the register into which the upper
14 bits are written.
VOLUME LEFT AND VOLUME RIGHT REGISTERS
A write operation to the left or right volume registers activates
the autoramp, clickless volume control feature of the AD1852.
The upper 10 bits of the volume control word increment or
decrement by 1 at a rate equal to the input sample rate.
int vol = 0...127
DATA VOLUME REGISTR 16 bit = 0b00+(vol<<9) = 0b1111111000000010 = 0 дБ
0b0000000000000001 - min. volume
DATA CONTROL REGISTER = 0b100010010001
25 bit / I2S / Reset / no filter
