Тема: CS8416 + CS4398
Упрощенная схема питания
#include <LiquidCrystal_I2C.h> //Библиотека - http://forum.rcl-radio.ru/misc.php?action=pan_download&item=45&download=1
Encoder myEnc(9, 8);//CLK, DT
byte v5[8] = { 28, 28, 0, 0, 0, 0, 28, 28};//
int a[3];
int vol,vol_d;
bool w,mute;
lcd.init();lcd.backlight();
pinMode(10,INPUT);
lcd.createChar(1, v1);lcd.createChar(2, v2);lcd.createChar(3, v3);
lcd.createChar(4, v4);lcd.createChar(5, v5);lcd.createChar(6, v6);
lcd.createChar(7, v7);lcd.createChar(8, v8);
lcd.setCursor(0,0);lcd.print(" CS4398 ");
lcd.setCursor(0,1);lcd.print(" CS8416 ");
vol = EEPROM.read(0);
wireWrite(0x4C, 0x02, 0b00011010);// I2S 24 bit / 48 kHz / 100...200 kHz
wireWrite(0x4C, 0x03, 0b00001001);// default
wireWrite(0x4C, 0x04, 0b11000000);// default
wireWrite(0x4C, 0x05, vol);
wireWrite(0x4C, 0x06, vol);
wireWrite(0x4C, 0x07, 0b10110000);// default
wireWrite(0x4C, 0x08, 0b01000000);// default
wireWrite(0x4C, 0x09, 0b00001000);// default
Serial.print("Chip ID 0");
Serial.println(wireRead(0x4C, 0x01),BIN);
lcd.clear();
if(digitalRead(10)==LOW && mute==0){mute=1;wireWrite(0x4C, 0x04, 0b11011000);delay(300);}
if(digitalRead(10)==LOW && mute==1){mute=0;wireWrite(0x4C, 0x04, 0b11000000);delay(300);}
if(mute==1){lcd.setCursor(0,1);lcd.print("MUTE");}else{lcd.setCursor(0,1);lcd.print("192k");}
vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;
if(vol<0){vol=0;}if(vol>130){vol=130;}
vol_d=130-vol;
a[0]=vol_d/100;
a[1]=vol_d/10%10;
a[2]=vol_d%10;
for(i=0;i<3;i++){
case 0: e1=7,e2=8,e3=9;break;
case 2: e1=13,e2=14,e3=15;break;
switch(a[i]){
delay(20);if(millis()-time>5000 && w==1){w=0;EEPROM.write(0,vol);}
}// loop
Wire.beginTransmission(addr);
Wire.write (reg);
Wire.write (data);
Wire.endTransmission();
byte wireRead(int addr, int reg){
Wire.write (reg);
Wire.requestFrom(addr,1);
while(Wire.available()<1);
byte value = Wire.read();
return value;
