Тема: CS8416 + CS4398
http://forum.rcl-radio.ru/uploads/images/2020/10/37c5adfd11ecd05b8e3fe27375f6dfb0.png
http://forum.rcl-radio.ru/uploads/images/2020/10/b6378a4c37470e531f7ba7a61b60cb52.png
http://forum.rcl-radio.ru/uploads/images/2020/10/8fe6939c7f8677b4cfd35e6c26645d5c.png
http://forum.rcl-radio.ru/uploads/images/2020/10/861746db11c126c1e9e493f624f64de5.png
http://forum.rcl-radio.ru/uploads/images/2020/10/d89c2fc74cb65eeb370f1bf5bd55d1ee.png
Упрощенная схема питания
http://forum.rcl-radio.ru/uploads/images/2020/10/3c8500fa3b74b96cfb13510e1357ede3.png
#include <Encoder.h>  // http://rcl-radio.ru/wp-content/uploads/2019/05/Encoder.zip
 Encoder myEnc(9, 8);//CLK, DT
      byte v5[8] = { 28, 28, 0, 0, 0, 0, 28, 28};//
      int a[3];
 int vol,vol_d;
 bool w,mute;
 lcd.init();lcd.backlight();
 pinMode(10,INPUT);
 lcd.createChar(1, v1);lcd.createChar(2, v2);lcd.createChar(3, v3);
 lcd.createChar(4, v4);lcd.createChar(5, v5);lcd.createChar(6, v6);
 lcd.createChar(7, v7);lcd.createChar(8, v8);
 lcd.setCursor(0,0);lcd.print("     CS4398     ");
 lcd.setCursor(0,1);lcd.print("     CS8416     ");
 delay(1000);
 vol = EEPROM.read(0);
 wireWrite(0x4C, 0x02, 0b00011010);// I2S 24 bit / 48 kHz / 100...200 kHz
 wireWrite(0x4C, 0x03, 0b00001001);// default
 wireWrite(0x4C, 0x04, 0b11000000);// default
 wireWrite(0x4C, 0x05, vol);
 wireWrite(0x4C, 0x06, vol);
 wireWrite(0x4C, 0x07, 0b10110000);// default
 wireWrite(0x4C, 0x08, 0b01000000);// default
 wireWrite(0x4C, 0x09, 0b00001000);// default
 Serial.print("Chip ID 0");
 Serial.println(wireRead(0x4C, 0x01),BIN);
 lcd.clear();
 if(digitalRead(10)==LOW && mute==0){mute=1;wireWrite(0x4C, 0x04, 0b11011000);delay(300);}
 if(digitalRead(10)==LOW && mute==1){mute=0;wireWrite(0x4C, 0x04, 0b11000000);delay(300);}
 if(mute==1){lcd.setCursor(0,1);lcd.print("MUTE");}else{lcd.setCursor(0,1);lcd.print("192k");}
     vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;
      if(vol<0){vol=0;}if(vol>130){vol=130;}
     vol_d=130-vol;
     a[0]=vol_d/100;
     a[1]=vol_d/10%10;
     a[2]=vol_d%10;
      for(i=0;i<3;i++){
        case 0: e1=7,e2=8,e3=9;break;
        case 1: e1=10,e2=11,e3=12;break;
        case 2: e1=13,e2=14,e3=15;break;
      switch(a[i]){
 delay(20);if(millis()-time>5000 && w==1){w=0;EEPROM.write(0,vol);}
 }// loop
void wireWrite(byte addr, byte reg, byte data){
  Wire.beginTransmission(addr);
  Wire.write (reg);
  Wire.write (data);
  Wire.endTransmission();
byte wireRead(int addr, int reg){
  Wire.write (reg);
  Wire.requestFrom(addr,1);
  while(Wire.available()<1);
  byte value = Wire.read();
  return value;
http://forum.rcl-radio.ru/uploads/images/2020/10/530cdfccff46dc1372b3ee443d792c8a.png
http://forum.rcl-radio.ru/uploads/images/2020/10/9b53901e1c90a9f9078e419506d1d1c0.png
Re: CS8416 + CS4398
Коммутация входов
http://forum.rcl-radio.ru/uploads/images/2020/10/4460ffb5db67507440cf877f891d6386.png
      int a[3];
 int vol,vol_d,in;
 bool w,mute;
 pinMode(10,INPUT);   // кнопка энкодера
 pinMode(A0,OUTPUT);  // RSEL1
 pinMode(A1,OUTPUT);  // RSEL0
 pinMode(2,INPUT_PULLUP); // кнопка IN
 delay(1000);
 wireWrite(0x4C, 0x04, 0b11100000);// default
 lcd.clear();
 if(digitalRead(2)==LOW){in++;if(in>2){in=0;}lcd.clear();
 lcd.setCursor(5,0);lcd.print("INPUT");lcd.setCursor(05,1);
 switch(in){
 case 0: digitalWrite(A0, LOW);digitalWrite(A1, LOW);lcd.print("COAX 1");break;// px0
 case 1: digitalWrite(A0, LOW);digitalWrite(A1, HIGH);lcd.print("COAX 2");break;// px1
 case 2: digitalWrite(A0, HIGH);digitalWrite(A1, LOW);lcd.print("COAX 3");break;// px2
 }delay(2000);lcd.clear();}
 if(mute==1){lcd.setCursor(0,1);lcd.print("MUTE  ");}
 else{lcd.setCursor(0,1);lcd.print("COAX ");lcd.print(in+1);
      wireWrite(0x4C, 0x06, vol);}
     vol_d=130-vol;
     a[0]=vol_d/100;
     a[1]=vol_d/10%10;
     a[2]=vol_d%10;
      for(i=0;i<3;i++){
      switch(a[i]){
 }// loop
  Wire.write (reg);
  Wire.write (data);
  Wire.write (reg);
  return value;
3
Re: CS8416 + CS4398
Добавлен баланс
http://forum.rcl-radio.ru/uploads/images/2020/10/8dc35901813e7def3ea798bd50ca0883.png
http://forum.rcl-radio.ru/uploads/images/2020/10/209a18357053cb5d56bc58f221b9c7d9.png
      int a[3];
 int vol,vol_d,in,balanc,balanc_d,menu;
 bool w,mute;
 pinMode(3,INPUT_PULLUP); // кнопка MUTE
 delay(1000);
 vol = EEPROM.read(0);in = EEPROM.read(1);balanc = EEPROM.read(2)-20;
 wireWrite(0x4C, 0x05, vol+balanc+20);
 wireWrite(0x4C, 0x06, vol-balanc+20);
 lcd.clear();
 switch(in){
 /// MENU ///////////////////////////////////////
 if(digitalRead(10)==LOW){menu++;if(menu>1){menu=0;}lcd.clear();time=millis();w=1;delay(200);}
 /// INPUT //////////////////////////////////////
 if(digitalRead(2)==LOW){in++;if(in>2){in=0;}lcd.clear();time=millis();w=1;
 lcd.setCursor(5,0);lcd.print("INPUT");lcd.setCursor(5,1);
 switch(in){
 }delay(1000);lcd.clear();}
 /// MUTE /////////////////////////////
 if(digitalRead(3)==LOW && mute==0){mute=1;wireWrite(0x4C, 0x04, 0b11011000);delay(300);}
 if(digitalRead(3)==LOW && mute==1){mute=0;wireWrite(0x4C, 0x04, 0b11000000);delay(300);}
 /// VOLUME + BALANCE ////////////////
      if(vol<0){vol=0;}if(vol>150){vol=150;}
      wireWrite(0x4C, 0x06, vol-balanc+20);}
     vol_d=150-vol;
     a[0]=vol_d/100;
     a[1]=vol_d/10%10;
     a[2]=vol_d%10;
     balanc=balanc+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;
      if(balanc<-20){balanc=-20;}if(balanc>20){balanc=20;}
      lcd.setCursor(0,0);lcd.print("BALANCE ");
     if(balanc<0){lcd.setCursor(9,0);lcd.write((uint8_t)3);}else{lcd.setCursor(9,0);lcd.print(" ");}
     balanc_d=abs(balanc);
     a[0]=balanc_d/10;
     a[1]=balanc_d%10;
      for(i=0;i<3;i++){
      switch(a[i]){
       for(i=0;i<2;i++){
        case 0: e1=10,e2=11,e3=12;break;
        case 1: e1=13,e2=14,e3=15;break;
      switch(a[i]){
 delay(20);if(millis()-time>10000 && w==1){w=0;EEPROM.write(0,vol);EEPROM.write(1,in);EEPROM.write(2,balanc+20);
 menu=0;}
 }// loop
  Wire.write (reg);
  Wire.write (data);
  Wire.write (reg);
  return value;
4
Re: CS8416 + CS4398
Очень заинтересовал данный проект. Сразу вопрос-мне не нужен коаксиальный вход, планирую использовать выход проигрывателя оптический. проигрыватель Onkyo, у него нет на борту коаксиального выхода. Какие изменения нужно внести в схему?
5
Re: CS8416 + CS4398
Вам нужен модуль приемка TOSLINK, с него подаете на вход cs8416 сигнал через конденсатор 10нФ, резистор 75 Ом не нужен.
http://forum.rcl-radio.ru/uploads/images/2020/10/81d93ce6b5998997213472dc7bd2a4e5.png
6
Re: CS8416 + CS4398
Благодарю, как раз есть донор-мёртвый рессивер и у него на борту этих модулей аж 3 шт. Ну и ещё момент, как говорится шиковать, так шиковать. А можно ли этот ЦАП использовать с шиной USB? Как в крохотных китайских конверторах, подключил к гнезду USB, а на выходе аналоговый звуковой сигнал?
7
Re: CS8416 + CS4398
Нет, нужен отдельный модуль например на PCM2704 который имеет вход USB, выход модуля COAXIAL или TOSLINK подключается ко входу cs8416. CS8416 имеет в этом подключении 4 коммутируемых входа.
8
Re: CS8416 + CS4398
Доброго. А можно сделать регулировку громкости сразу для трёх микросхем ЦАП? Одним энкодером. Одна Ардуина справится?
9
Re: CS8416 + CS4398
CS4398 не поддерживает смену I2C адреса.
10 (2023-03-29 13:55:19 отредактировано dyno)
Re: CS8416 + CS4398
Мне нужно не раздельно три, а три одновременно, чтоб у них громкость менялась синхронно. И оставалась одинаковой у всех трех.
У меня в устройстве 6 аналоговых выходов, цифра на ЦАПы приходит от одного процессора.
11
Re: CS8416 + CS4398
Ни когда не запускал несколько уст-в на шине I2C с одинаковыми адресами, поэтому ответа на Ваш вопрос у меня нет.
Может проще выбрать 6-й канальный DAC, например CS4360
12
Re: CS8416 + CS4398
Не, устройство заводское. Подразумевает регулировку общей громкости по входу. А нужно по выходу, все 6 каналов...
