Тема: Термометр на DS18B20 с большими цифрами
Основная статья - http://rcl-radio.ru/?p=112955
#include <avr/io.h>
#include <util/delay.h>
// Project Files (Github):  https://github.com/wagiminator/ATtiny13-TinyOLEDdemo
// License: http://creativecommons.org/licenses/by-sa/3.0/
#define I2C_SDA         PB3
#define I2C_SCL         PB4
#define TEMP            PB0
#define BUTTON          PB2
#define I2C_SDA_HIGH()  DDRB &= ~(1<<I2C_SDA)
#define I2C_SDA_LOW()   DDRB |=  (1<<I2C_SDA)
#define I2C_SCL_HIGH()  DDRB &= ~(1<<I2C_SCL)
#define I2C_SCL_LOW()   DDRB |=  (1<<I2C_SCL)
bool minus;
uint8_t buffer[8];
int main(void) {
    PORTB |=(1 << BUTTON);
    OLED_init();
    OLED_clear();
while(1) {
    if(((PINB >> BUTTON) & 1) == 0){
    int temp = read_temp();
    if(temp<0){minus=1;temp=-temp;}else{minus=0;}
    byte a0 = temp/100;
    byte a1 = temp/10%10;
    byte a2 = temp%10;
    if(minus==0){uint8_t buffer0[8] = {19, a0, a1, 16, a2, 19, 12, 19};OLED_printB(buffer0);}
     else{uint8_t buffer1[8] = {18, a0, a1, 16, a2, 19, 12, 19};OLED_printB(buffer1); }
    _delay_ms(10000);}
    OLED_clear();
///// I2C ///////////////////////////////////////////////////////
void I2C_init(void) {DDRB  &= ~((1<<I2C_SDA)|(1<<I2C_SCL)); PORTB &= ~((1<<I2C_SDA)|(1<<I2C_SCL));}
void I2C_write(uint8_t data) {
  for(uint8_t i = 8; i; i--) {I2C_SDA_LOW();
    if (data & 0x80) I2C_SDA_HIGH();I2C_SCL_HIGH();data<<=1;I2C_SCL_LOW();}
  I2C_SDA_HIGH();I2C_SCL_HIGH();asm("nop");I2C_SCL_LOW();
void I2C_start(uint8_t addr) {I2C_SDA_LOW();I2C_SCL_LOW();I2C_write(addr);}
void I2C_stop(void) {I2C_SDA_LOW();I2C_SCL_HIGH();I2C_SDA_HIGH();}
///// OLED ///////////////////////////////////
#define OLED_ADDR       0x78
#define OLED_CMD_MODE   0x00
#define OLED_DAT_MODE   0x40
#define OLED_INIT_LEN   15
// OLED init settings
const uint8_t OLED_INIT_CMD[] PROGMEM = {
  0xA8, 0x1F,
  0x22, 0x00, 0x03,
  0x20, 0x01,
  0xDA, 0x02,
  0x8D, 0x14,
  0xAF,
  0x00, 0x10, 0xB0,
  0xA1, 0xC8
// Simple reduced 3x8 font
const uint8_t OLED_FONT[] PROGMEM = {
  0x7F, 0x41, 0x7F, // 0  0
  0x00, 0x00, 0x7F, // 1  1
  0x79, 0x49, 0x4F, // 2  2
  0x41, 0x49, 0x7F, // 3  3
  0x0F, 0x08, 0x7E, // 4  4
  0x4F, 0x49, 0x79, // 5  5
  0x7F, 0x49, 0x79, // 6  6
  0x03, 0x01, 0x7F, // 7  7
  0x7F, 0x49, 0x7F, // 8  8
  0x4F, 0x49, 0x7F, // 9  9
  0x7F, 0x09, 0x7F, // A 10
  0x7F, 0x48, 0x78, // b 11
  0x7F, 0x41, 0x63, // C 12
  0x78, 0x48, 0x7F, // d 13
  0x7F, 0x49, 0x41, // E 14
  0x7F, 0x09, 0x01, // F 15
  0x00, 0x60, 0x00, // . 16
  0x00, 0x36, 0x00, // : 17
  0x08, 0x08, 0x08, // - 18
  0x00, 0x00, 0x00  //   19
void OLED_cursor(uint8_t xpos, uint8_t ypos) {
  I2C_start(OLED_ADDR);
  I2C_write(OLED_CMD_MODE);
  I2C_write(xpos & 0x0F);
  I2C_write(0x10 | (xpos >> 4));
  I2C_write(0xB0 | (ypos & 0x07));
  I2C_stop();
void OLED_clear(void) {
  OLED_cursor(0, 0);
  I2C_write(OLED_DAT_MODE);
  for(uint16_t i=512; i; i--) I2C_write(0x00);
  I2C_stop();
void OLED_init(void) {
  I2C_init();
  for (uint8_t i = 0; i < OLED_INIT_LEN; i++) I2C_write(pgm_read_byte(&OLED_INIT_CMD[i]));
  I2C_stop();
uint8_t OLED_stretch(uint8_t b){b=((b & 2)<<3)|(b&1);b|=b<<1;b|=b<<2;return b;}
void OLED_printD(uint8_t ch) {
  uint8_t i, j, k, b;
  uint8_t sb[4];
  ch += ch << 1;
  for(i=8; i; i--) I2C_write(0x00);
  for(i=3; i; i--) {
    b = pgm_read_byte(&OLED_FONT[ch++]);
    for(j=0; j<4; j++, b >>= 2) sb[j] = OLED_stretch(b);
    j=4; if(i==2) j=6;
    while(j--) {
      for(k=0; k<4; k++) I2C_write(sb[k]);
void OLED_printB(uint8_t *buffer) {
  for(uint8_t i=0; i<8; i++) OLED_printD(buffer[i]);
  I2C_stop();
//// DS18B20 //////////////////////////////////////
uint8_t therm_reset(){
    uint8_t i;
    PORTB &= ~(1 << TEMP);
    DDRB |= (1 << TEMP);
    _delay_us(480);
    DDRB &= ~(1 << TEMP);
    _delay_us(60);
    i=((PINB >> TEMP) & 1);
    _delay_us(420);
    return i;
void therm_write_bit(uint8_t bit){
    if(bit) DDRB &= ~(1 << TEMP);
    _delay_us(60);
uint8_t therm_read_bit(void){
    uint8_t bit=0;
    _delay_us(14);
    if(PINB & (1 << TEMP)) bit=1;
    _delay_us(45);
    return bit;
uint8_t therm_read_byte(void){
    uint8_t i=8, n=0;
    while(i--){n>>=1;n|=(therm_read_bit()<<7);}
    return n;
void therm_write_byte(uint8_t byte){
    uint8_t i=8;
    while(i--){therm_write_bit(byte&1);byte >>= 1;
int read_temp(){
    uint8_t temperature[2];
    int temper;
    therm_reset();
    therm_write_byte(0xCC);
    therm_write_byte(0x44);
    while(!therm_read_bit());
    therm_reset();
    therm_write_byte(0xBE);
    temperature[0]=therm_read_byte();
    temperature[1]=therm_read_byte();
    therm_reset();
    return temper = (temperature[1] << 8 | temperature[0])*10/16;
Re: Термометр на DS18B20 с большими цифрами
Спасибо!
Всё работает изумительно!
Сейчас буду пытаться убрать незначащий ноль и добавить вторую цифру после запятой - а то точность хорошая, хочется видеть  две цифры, не знаю зачем smile
3
Не получилось убрать незначащий ноль и добавить вторую цифру после запятой. sad  оставлю так. На днях выложу фото готового устройства.
Ещё раз спасибо за труд! smile
4
доброе время суток!
уважаемый liman324 был бы вам очень признателен если вы могли помочь разобраться как и на что нужно изменить в коде
чтоб избавиться от кнопки. схема идеальная для моих нужд, даже удалось собрать и она заработала не смотря на мои познания в этом деле которые практически равны нулю. но нужно чтобы меряло постоянно и бес кнопки
5
Заменить
    byte a0 = temp/100;
    byte a2 = temp%10;
    _delay_ms(10000);}
на
    byte a0 = temp/100;
    byte a2 = temp%10;
    _delay_ms(10000);
6
уважаемый liman324 огромное СПАСИБО !!!
если честно не ожидал за такую оперативность, попробовал собрал и всё чудно заработало ! ниже минуса не охлаждал что бы минус проверить но надеюсь всё высветит. единственное что моргает, ну хоть так, всё равно вам большое спасибо!!!!
7
Здравствуйте . Собрал все работает отлично , спасибо . Я хотел попросить Вас чтобы Вы помогли мне добавить вторую цифру после запятой, как добавить вторую цифру после запятой я разобрался но там показывает ноль или непонятное значение .
    byte a0 = temp/100;
    byte a2 = temp%10;
    byte a3 = temp%1;       как с этим бороться, показывает всегда ноль.
    uint8_t buffer[8] = {19, a0, a1, 16, a2, a3, 19, 12 };
Может сюда нужно что то дописать я в этом не селён. Помогите пожалуйста. Спасибо.
8
return temper = (temperature[1] << 8 | temperature[0])*100/16;
byte a0 = temp/100;
    byte a2 = temp%10;
    byte a3 = temp%1;
byte a0 = temp/1000;
    byte a1 = temp/100%10;
    byte a2 = temp/10%10;
    byte a3 = temp%10;
9
Спасибо большое , неожиданно быстро помогли , спасибо большое.
10
Здравствуйте , Я вписал код который Вы мне дали , на экране отображается не правильные цифры http://forum.rcl-radio.ru/uploads/images/2024/08/0d9cd16cf6ba428fc681ef00a027db10.jpg
11
#include <avr/io.h>
#define I2C_SDA         PB3
#define I2C_SCL         PB4
#define TEMP            PB0
#define BUTTON          PB2
bool minus;
uint8_t buffer[8];
int main(void) {
    OLED_init();
    OLED_clear();
while(1) {
    byte a0 = temp/1000%10;
    byte a3 = temp%10;
    if(minus==0){uint8_t buffer0[8] = {19, a0, a1, 16, a2, a3, 19, 12};OLED_printB(buffer0);}
     else{uint8_t buffer1[8] = {18, a0, a1, 16, a2, a3, 19, 12};OLED_printB(buffer1); }
    _delay_ms(1000);}
    OLED_clear();
  0xA8, 0x1F,
  0x22, 0x00, 0x03,
  0x20, 0x01,
  0xDA, 0x02,
  0x8D, 0x14,
  0xAF,
  0x00, 0x10, 0xB0,
  0xA1, 0xC8
  I2C_stop();
  OLED_cursor(0, 0);
  I2C_stop();
  I2C_init();
  I2C_stop();
  uint8_t i, j, k, b;
  uint8_t sb[4];
  ch += ch << 1;
  for(i=3; i; i--) {
    j=4; if(i==2) j=6;
    while(j--) {
  I2C_stop();
    uint8_t i;
    _delay_us(480);
    _delay_us(60);
    _delay_us(420);
    return i;
    _delay_us(60);
    uint8_t bit=0;
    _delay_us(14);
    _delay_us(45);
    return bit;
    uint8_t i=8, n=0;
    return n;
    uint8_t i=8;
int read_temp(){
    int temper;
    therm_reset();
    therm_reset();
    therm_reset();
    return temper = (temperature[1] << 8 | temperature[0])*6;
12
Урааа, заработало как хотел. Спасибо огромное .
13 (2025-01-14 10:19:21 отредактировано klause)
Мой вариант термометра с автоотключением через 10с. от ип. На отрицательных температурах не тестировал.
#include <avr/io.h>
unsigned long Alarm =10000; // 10с. индикации
#define I2C_SDA         PB3
#define I2C_SCL         PB4
#define TEMP            PB0
int main(void) {
 DDRB|=(1<<1);
 PORTB = (PORTB | 1<<1);
    OLED_init();
    OLED_clear();
while(1) {
  byte a0,a1,a2,a3;
  while ( millis()< Alarm){
  if(temp<0){abs(temp);
     a0 = 18;
     a1 = temp/100%10;
    if(a1==0){a0=19;a1=18;}
    else{
     a0 = temp/1000;
     a1 = temp/100%10;
     if(a0==1)a0=1;
     else {a0=19;
     if(a1==0)a1=19;}}
     a2 = temp/10%10;
     a3 = temp%10;
     uint8_t buffer[8] = {19, a0, a1, a2, 16,a3 , 20, 12};
    OLED_printB(buffer);
    _delay_ms(1000); }
    OLED_clear();
    PORTB = 0;
  0xA8, 0x1F,
  0x22, 0x00, 0x03,
  0x20, 0x01,
  0xDA, 0x02,
  0x8D, 0x14,
  0xAF,
  0x00, 0x10, 0xB0,
  0xA1, 0xC8
  0x00, 0x02, 0x7F, // 1  1
  0x0F, 0x08, 0x7F, // 4  4
  0x00, 0x00, 0x00,  //   19
  0x02, 0x05, 0x02,  //  degrees
  I2C_stop();
  OLED_cursor(0, 0);
  I2C_stop();
  I2C_init();
  I2C_stop();
  uint8_t i, j, k, b;
  uint8_t sb[4];
  ch += ch << 1;
  for(i=3; i; i--) {
    j=4; if(i==2) j=6;
    while(j--) {
  I2C_stop();
 void DisplayOnOff (byte On) {
  I2C_write(0xAE + On);
  I2C_stop();
    uint8_t i;
    _delay_us(480);
    _delay_us(60);
    _delay_us(420);
    return i;
    _delay_us(60);
    uint8_t bit=0;
    _delay_us(14);
    _delay_us(45);
    return bit;
    uint8_t i=8, n=0;
    return n;
    uint8_t i=8;
int read_temp(){
    int temper;
    therm_reset();
    therm_reset();
    therm_reset();
Работает совместно с транзисторным ключом с выходом PB1 attiny.
http://forum.rcl-radio.ru/uploads/images/2025/01/59d518b57a25e9ccbbe8ed6e07be363a.bmp
