76
Re: Часы на игп-17 (разработка)
// ATMEGA8535 16 MHZ
#define ADDR    0x68
#define CPU_F   16000000 // Clock Speed
#define SCL_F   400000 // // I2C Speed
#define TEMP_KORR 0 // гр.Цельсия
#include <avr/io.h>
#include <util/delay.h>
byte a[16],an,segm,i;
bool w=1,w1;
byte sec,min_,hour,datat,mont,year;
int temper,sett,times;
int set_hour,set_min,set_sec,set_datat,set_mont,set_year;
  DDRA = 0xFF;
  DDRB = 0xFF;
  DDRC = 0xFF;
  DDRD |= (1 << PD6)|(1 << PD7);
  PORTD |= (1 << PD2)|(1 << PD3)|(1 << PD4);
  TWSR = 0;
  DDRD |= (1 << PD5); // PWM +180V TIMER_1
// TIMER_2  F = 16000000/128/100=1250 Hz (800 uS)
  OCR2 = 255;
  TCCR2 |= (1 << WGM21);
  TCCR2 |= (1 << CS22)| (1 << CS21)|(1 << CS20);
  TIMSK |= (1 << OCIE2);
// TIMER_1  F = 16000000/1024/1/1=15625 Hz
  TCCR1A |= (1 << COM1A1);
  TCCR1B |= (1 << WGM12);
  TCCR1A |= (1 << WGM11) | (1 << WGM10);
  TCCR1B |= (1 << CS10);
  ICR1 = 1023;
  OCR1A = 350;
 // set_time(22,2,2,4,22,23,0);// год 00-99, ДН 1-7 (1=ВС), месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
  i2c_write(0x48,0x01,0);
  _delay_ms(200);
  datat = ((i2c_read(ADDR,4) & 0x0F) + ((i2c_read(ADDR,4) & 0x70) >> 4) * 10);
  mont = ((i2c_read(ADDR,5) & 0x0F) + ((i2c_read(ADDR,5) & 0x70) >> 4) * 10);
  year = ((i2c_read(ADDR,6) & 0x0F) + ((i2c_read(ADDR,6) & 0x70) >> 4) * 10);
  hour = (i2c_read(ADDR,2) & 0x0F) + (((i2c_read(ADDR,2) & 0x70) >> 4) * 10);
  min_ =  (i2c_read(ADDR,1) & 0x0F) + (((i2c_read(ADDR,1) & 0x70) >> 4) * 10);
  if(sec==10||sec==40) {temper = i2c_read_i2c_2bit(0x48,0)-TEMP_KORR ;}
  sec =  (i2c_read(ADDR,0) & 0x0F) + (((i2c_read(ADDR,0) & 0x70) >> 4) * 10);
  set_year = year;set_mont = mont;set_datat = datat;set_hour = hour;set_min = min_;set_sec = sec;
/// BUTTON /////////////
  if(((PIND >> PD2) & 1) == 0){sett++;times=0;if(sett>6){sett=0;}wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==1){set_hour++;w1=1; if(set_hour>23){set_hour=23;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==1){set_hour--;w1=1; if(set_hour<0){set_hour=0;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==2){set_min++;w1=1; if(set_mont>59){set_min=59;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==2){set_min--;w1=1; if(set_mont<0){set_min=0;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==3){set_sec=0;w1=1; set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==3){set_sec=0;w1=1; set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==4){set_datat++;w1=1; if(set_datat>31){set_datat=31;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==4){set_datat--;w1=1; if(set_datat<0){set_datat=0;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==5){set_mont++;w1=1; if(set_mont>12){set_mont=12;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==5){set_mont--;w1=1; if(set_mont<0){set_mont=0;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD3) & 1) == 0 && sett==6){set_year++;w1=1; if(set_year>50){set_year=50;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
  if(((PIND >> PD4) & 1) == 0 && sett==6){set_year--;w1=1; if(set_year<22){set_year=22;} set_time(set_year,0,set_mont,set_datat,set_hour,set_min,set_sec);wr();_delay_ms(300);}
 if(sett==0){
 if(min_==30&&sec<10){a[0]=sec%10+20;a[1]=sec%10+20;a[2]=sec%10+20;a[3]=sec%10+20;a[4]=sec%10+20;a[5]=sec%10+20;a[6]=sec%10+20;a[7]=sec%10+20;
  a[8]=sec%10+20;a[9]=sec%10+20;a[10]=sec%10+20;a[11]=sec%10+20;a[12]=sec%10+20;a[13]=sec%10+20;a[14]=sec%10+20;a[15]=sec%10+20;}
 else{
  if((sec>=10&&sec<=20)||(sec>=40&&sec<=50)){
  a[0]=14;
  a[1]=13;
  a[2]=temper%10;
  a[3]=temper/10%10+20;
  a[4]=temper/100;
  a[5]=10;
  a[6]=12;
  else{
  a[0]=10;
  a[1]=year%10;
  a[2]=year/10;
  a[3]=mont%10+20;
  a[4]=mont/10;
  a[5]=datat%10+20;
  a[6]=datat/10;
  a[7]=10;
  a[8]=sec%10;
  a[9]=sec/10;
  a[10]=11;
  a[11]=min_%10;
  a[12]=min_/10;
  a[13]=11;
  a[14]=hour%10;
  a[15]=hour/10;
}// sett=0
 if(sett>0){
  a[0]=10;
  if(sett==6){if(times<=500||w1==1){w1=0;a[1]=year%10+20;a[2]=year/10;}else{a[1]=11;a[2]=11;}}
  if(sett==5){if(times<=500||w1==1){w1=0;a[3]=mont%10+20;a[4]=mont/10;}else{a[3]=11;a[4]=11;}}
  if(sett==4){if(times<=500||w1==1){w1=0;a[5]=datat%10+20;a[6]=datat/10;}else{a[5]=11;a[6]=11;}}
  a[7]=10;
  if(sett==3){if(times<=500||w1==1){w1=0;a[8]=sec%10;a[9]=sec/10;}else{a[8]=11;a[9]=11;}}
  a[10]=11;
  if(sett==2){if(times<=500||w1==1){w1=0;a[11]=min_%10;a[12]=min_/10;}else{a[11]=11;a[12]=11;}}
  a[13]=11;
  if(sett==1){if(times<=500||w1==1){w1=0;a[14]=hour%10;a[15]=hour/10;}else{a[14]=11;a[15]=11;}}
  if(sett!=3){a[8]=sec%10;a[9]=sec/10;}
}// sett>0
if(sett==0){_delay_ms(100);}
void wr(){a[0]=10;a[1]=year%10; a[2]=year/10;a[3]=mont%10+20;a[4]=mont/10;a[5]=datat%10+20;a[6]=datat/10;a[7]=10;a[8]=sec%10;
a[9]=sec/10;a[10]=11;a[11]=min_%10;a[12]=min_/10;a[13]=11;a[14]=hour%10;a[15]=hour/10;}
ISR(TIMER2_COMP_vect){
    case 0:  segm=a[0];  an=16;  anod(); _delay_us(600); segment(); if(a[0]==10)an=16;else an=0;  anod(); break;
    case 1:  segm=a[1];  an=16;  anod(); _delay_us(600); segment(); if(a[1]==10)an=16;else an=1;  anod(); break;
    case 2:  segm=a[2];  an=16;  anod(); _delay_us(600); segment(); if(a[2]==10)an=16;else an=2;  anod(); break;
    case 3:  segm=a[3];  an=16;  anod(); _delay_us(600); segment(); if(a[3]==10)an=16;else an=3;  anod(); break;
    case 4:  segm=a[4];  an=16;  anod(); _delay_us(600); segment(); if(a[4]==10)an=16;else an=4;  anod(); break;
    case 5:  segm=a[5];  an=16;  anod(); _delay_us(600); segment(); if(a[5]==10)an=16;else an=5;  anod(); break;
    case 6:  segm=a[6];  an=16;  anod(); _delay_us(600); segment(); if(a[6]==10)an=16;else an=6;  anod(); break;
    case 7:  segm=a[7];  an=16;  anod(); _delay_us(600); segment(); if(a[7]==10)an=16;else an=7;  anod(); break;
    case 8:  segm=a[8];  an=16;  anod(); _delay_us(400); segment(); an=8;  anod(); break;
    case 9:  segm=a[9];  an=16;  anod(); _delay_us(400); segment(); an=9;  anod(); break;
   case 10:  segm=a[10]; an=16;  anod(); _delay_us(400); segment(); an=10; anod(); break;
   case 11:  segm=a[11]; an=16;  anod(); _delay_us(400); segment(); an=11; anod(); break;
   case 12:  segm=a[12]; an=16;  anod(); _delay_us(400); segment(); an=12; anod(); break;
   case 13:  segm=a[13]; an=16;  anod(); _delay_us(400); segment(); an=13; anod(); break;
   case 14:  segm=a[14]; an=16;  anod(); _delay_us(400); segment(); an=14; anod(); break;
   case 15:  segm=a[15]; an=16;  anod(); _delay_us(400); segment(); an=15; anod(); break;
    }i++;if(i>15){i=0;}times++;if(times>600){times=0;}}
void segment(){
   switch(segm){
             //       GECDXBFA
    case 0: PORTA = 0b01110111;break;
    case 1: PORTA = 0b00100100;break;
    case 2: PORTA = 0b11010101;break;
    case 3: PORTA = 0b10110101;break;
    case 4: PORTA = 0b10100110;break;
    case 5: PORTA = 0b10110011;break;
    case 6: PORTA = 0b11110011;break;
    case 7: PORTA = 0b00100101;break;
    case 8: PORTA = 0b11110111;break;
    case 9: PORTA = 0b10110111;break;
              //       GECDXBFA
    case 20: PORTA = 0b01111111;break;
    case 21: PORTA = 0b00101100;break;
    case 22: PORTA = 0b11011101;break;
    case 23: PORTA = 0b10111101;break;
    case 24: PORTA = 0b10101110;break;
    case 25: PORTA = 0b10111011;break;
    case 26: PORTA = 0b11111011;break;
    case 27: PORTA = 0b00101101;break;
    case 28: PORTA = 0b11111111;break;
    case 29: PORTA = 0b10111111;break;
              //       GECDXBFA
    case 10: PORTA = 0b00000000;break; // пусто
    case 11: PORTA = 0b10000000;break; // -
    case 12: PORTA = 0b11010010;break; // t
    case 13: PORTA = 0b10000111;break; // гр
    case 14: PORTA = 0b01010011;break; // C
void anod(){
 switch(an){
    case 0: PORTC &=~(1<<PC7);PORTB |=(1<<PB0);break;
    case 1: PORTB &=~(1<<PB0);PORTB |=(1<<PB1);break;
    case 2: PORTB &=~(1<<PB1);PORTB |=(1<<PB2);break;
    case 3: PORTB &=~(1<<PB2);PORTB |=(1<<PB3);break;
    case 4: PORTB &=~(1<<PB3);PORTB |=(1<<PB4);break;
    case 5: PORTB &=~(1<<PB4);PORTB |=(1<<PB5);break;
    case 6: PORTB &=~(1<<PB5);PORTB |=(1<<PB6);break;
    case 7: PORTB &=~(1<<PB6);PORTB |=(1<<PB7);break;
    case 8: PORTB &=~(1<<PB7);PORTD |=(1<<PD6);break;
    case 9: PORTD &=~(1<<PD6);PORTD |=(1<<PD7);break;
   case 10: PORTD &=~(1<<PD7);PORTC |=(1<<PC2);break;
   case 11: PORTC &=~(1<<PC2);PORTC |=(1<<PC3);break;
   case 12: PORTC &=~(1<<PC3);PORTC |=(1<<PC4);break;
   case 13: PORTC &=~(1<<PC4);PORTC |=(1<<PC5);break;
   case 14: PORTC &=~(1<<PC5);PORTC |=(1<<PC6);break;
   case 15: PORTC &=~(1<<PC6);PORTC |=(1<<PC7);break;
   case 16: PORTB &=~(1<<PB0);PORTB &=~(1<<PB1);PORTB &=~(1<<PB2);PORTB &=~(1<<PB3);PORTB &=~(1<<PB4);PORTB &=~(1<<PB5);PORTB &=~(1<<PB6);PORTB &=~(1<<PB7);
   PORTD &=~(1<<PD6);PORTD &=~(1<<PD7);PORTC &=~(1<<PC2);PORTC &=~(1<<PC3);PORTC &=~(1<<PC4);PORTC &=~(1<<PC5);PORTC &=~(1<<PC6);PORTC &=~(1<<PC7);break;
byte i2c_read(byte i2c_addr, byte i2c_reg){
   TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);  // START
  while (!(TWCR & (1<<TWINT)));
   TWDR = i2c_addr << 1;
   TWDR = i2c_reg;
   TWDR = (i2c_addr << 1) | 1;
   byte i2c_data = TWDR;
   return i2c_data;
int i2c_read_i2c_2bit(byte i2c_addr, byte i2c_reg){
   TWDR = i2c_reg;
   TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWEA);
  while(~TWCR&(1<<TWINT));
   int i2c_data0 = TWDR;
  int i2c_data1 = TWDR;
  int i2c_data = (i2c_data0*10)+(i2c_data1>>5)*1.25;
  return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
    if(second < 255){i2c_write(ADDR,0x00,(second/10<<4)+second%10);}
    if(minute < 255){i2c_write(ADDR,0x01,(minute/10<<4)+minute%10);}
    if(hours < 255){i2c_write(ADDR,0x02,(hours/10<<4)+hours%10);}
    if(days < 255){i2c_write(ADDR,0x03,days);}
    if(datas < 255){i2c_write(ADDR,0x04,(datas/10<<4)+datas%10);}
    if(monts < 255){i2c_write(ADDR,0x05,(monts/10<<4)+monts%10);}
    if(years < 255){i2c_write(ADDR,0x06,(years/10<<4)+years%10);}
77
эффект бегущего огня: фото сделать не получается, визуально 2 включенных знакоместа перемещаются справа налево
78
Может дело в емкости высоковольного источника, либо в частоте преобразователя высоковольного источника?
Можно увеличить емкость и изменить частоту
Поднял частоту преобразователя
/// ATMEGA8535 16 MHZ
#define ADDR    0x68
#include <avr/io.h>
bool w=1,w1;
  DDRA = 0xFF;
  DDRB = 0xFF;
  DDRC = 0xFF;
  TWSR = 0;
  OCR2 = 100;
  TCCR2 |= (1 << CS22) | (1 << CS20);
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
  TCCR1A |= (1 << WGM10);
  ICR1 = 255;
  OCR1A = 100;
  _delay_ms(200);
 if(sett==0){
 else{
  a[0]=14;
  a[1]=13;
  a[2]=temper%10;
  a[4]=temper/100;
  a[5]=10;
  a[6]=12;
  else{
  a[0]=10;
  a[1]=year%10;
  a[2]=year/10;
  a[3]=mont%10+20;
  a[4]=mont/10;
  a[5]=datat%10+20;
  a[6]=datat/10;
  a[7]=10;
  a[8]=sec%10;
  a[9]=sec/10;
  a[10]=11;
  a[11]=min_%10;
  a[12]=min_/10;
  a[13]=11;
  a[14]=hour%10;
  a[15]=hour/10;
}// sett=0
 if(sett>0){
  a[0]=10;
  a[7]=10;
  a[10]=11;
  a[13]=11;
}// sett>0
void segment(){
   switch(segm){
             //       GECDXBFA
              //       GECDXBFA
              //       GECDXBFA
void anod(){
 switch(an){
   TWDR = i2c_reg;
   return i2c_data;
   TWDR = i2c_reg;
  return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
79 (2024-01-21 20:03:26 отредактировано aprdetali)
Для высоковольтного питания индикатора я использую отдельный источник питания-преобразователь на 34063 с плавной регулировкой величины выходного напряжения. Данный индикатор очень чувствителен к величине питающего напряжения, буквально при повышении на 10 Вольт появляются синие разряды между соседними сегментами, поэтому пришлось городить такой огород
80
Тогда я удалю таймер отвечающий за ШИМ источника
#define ADDR    0x68
#include <avr/io.h>
bool w=1,w1;
  DDRA = 0xFF;
  DDRB = 0xFF;
  DDRC = 0xFF;
  TWSR = 0;
  TCCR2 = 0;
  OCR2 = 100;
  _delay_ms(200);
 if(sett==0){
 else{
  a[0]=14;
  a[1]=13;
  a[2]=temper%10;
  a[4]=temper/100;
  a[5]=10;
  a[6]=12;
  else{
  a[0]=10;
  a[1]=year%10;
  a[2]=year/10;
  a[3]=mont%10+20;
  a[4]=mont/10;
  a[5]=datat%10+20;
  a[6]=datat/10;
  a[7]=10;
  a[8]=sec%10;
  a[9]=sec/10;
  a[10]=11;
  a[11]=min_%10;
  a[12]=min_/10;
  a[13]=11;
  a[14]=hour%10;
  a[15]=hour/10;
}// sett=0
 if(sett>0){
  a[0]=10;
  a[7]=10;
  a[10]=11;
  a[13]=11;
}// sett>0
void segment(){
   switch(segm){
             //       GECDXBFA
              //       GECDXBFA
              //       GECDXBFA
void anod(){
 switch(an){
   TWDR = i2c_reg;
   return i2c_data;
   TWDR = i2c_reg;
  return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
81
Есть гарантия что нет пульсации напряжения в этом источнике?
82
Да, там на выходе RC-фильтр: 10 мкФ и 2,7 кОм.
83
2,7 кОм - через него идет напряжение на схему?
84
http://forum.rcl-radio.ru/viewtopic.php?pid=9306#p9306
ЗАРАБОТАЛО!!!
85
да
86
Отлично, значит просто не хватало ресурсов микроконтроллера.
87
Александр, а можно Вас попросить отключить ШИМ преобразователя в скетче:
http://forum.rcl-radio.ru/viewtopic.php?pid=9255#p9255
возможно и с 18в20 заработает?
88
#define ADDR    0x68
#define TEMP_KORR 20 // -2гр.Цельсия
#include <avr/io.h>
OneWire  ds(8); // Вход датчика 18b20  PD8 PIN_14
bool w=1,w1;
  DDRA = 0xFF;
  DDRB = 0xFF;
  DDRC = 0xFF;
  TWSR = 0;
  OCR2 = 100;
  _delay_ms(200);
  if(sec==10||sec==40) {temper = dsRead(0)-TEMP_KORR ;}
 if(sett==0){
 else{
  a[0]=14;
  a[1]=13;
  a[2]=temper%10;
  a[4]=temper/100;
  a[5]=10;
  a[6]=12;
  else{
  a[0]=10;
  a[1]=year%10;
  a[2]=year/10;
  a[3]=mont%10+20;
  a[4]=mont/10;
  a[5]=datat%10+20;
  a[6]=datat/10;
  a[7]=10;
  a[8]=sec%10;
  a[9]=sec/10;
  a[10]=11;
  a[11]=min_%10;
  a[12]=min_/10;
  a[13]=11;
  a[14]=hour%10;
  a[15]=hour/10;
}// sett=0
 if(sett>0){
  a[0]=10;
  a[7]=10;
  a[10]=11;
  a[13]=11;
}// sett>0
void segment(){
   switch(segm){
             //       GECDXBFA
              //       GECDXBFA
              //       GECDXBFA
void anod(){
 switch(an){
   TWDR = i2c_reg;
   return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
float dsRead(byte x) {
    kol++;
  int raw=(data[1]<<8)|data[0];
  float value = (float)raw / 1.60; return value; // Расчет температуры и вывод
89
Увы, чуда не случилось
Может, эту попробуем:
http://forum.rcl-radio.ru/viewtopic.php?pid=9263#p9263
90
#define ADDR    0x68
#include <avr/io.h>
bool w=1,w1;
  DDRA = 0xFF;
  DDRB = 0xFF;
  DDRC = 0xFF;
  TWSR = 0;
  OCR2 = 100;
  _delay_ms(200);
  if(sec==10||sec==40) {temper = read_temp()-TEMP_KORR ;}
 if(sett==0){
 else{
  a[0]=14;
  a[1]=13;
  a[2]=temper%10;
  a[4]=temper/100;
  a[5]=10;
  a[6]=12;
  else{
  a[0]=10;
  a[1]=year%10;
  a[2]=year/10;
  a[3]=mont%10+20;
  a[4]=mont/10;
  a[5]=datat%10+20;
  a[6]=datat/10;
  a[7]=10;
  a[8]=sec%10;
  a[9]=sec/10;
  a[10]=11;
  a[11]=min_%10;
  a[12]=min_/10;
  a[13]=11;
  a[14]=hour%10;
  a[15]=hour/10;
}// sett=0
 if(sett>0){
  a[0]=10;
  a[7]=10;
  a[10]=11;
  a[13]=11;
}// sett>0
void segment(){
   switch(segm){
             //       GECDXBFA
              //       GECDXBFA
              //       GECDXBFA
void anod(){
 switch(an){
   TWDR = i2c_reg;
   return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
// reset
uint8_t therm_reset(){
    uint8_t i;
    PORTD &= ~(1 << PD0);
    DDRD |= (1 << PD0);
    _delay_us(480);
    DDRD &= ~(1 << PD0);
    _delay_us(60);
    i=((PIND >> PD0) & 1);
    _delay_us(420);
    return i;
// write bit
    DDRD |= (1 << PD0);
    _delay_us(1);
    if(bit) DDRD &= ~(1 << PD0);
    _delay_us(60);
// read bit
uint8_t therm_read_bit(void){
    uint8_t bit=0;
    DDRD |= (1 << PD0);
    _delay_us(1);
    _delay_us(14);
    if(PIND & (1 << PD0)) bit=1;
    _delay_us(45);
    return bit;
// read byte
    uint8_t i=8, n=0;
    return n;
// write byte
    uint8_t i=8;
// read temp
int read_temp(){
    uint8_t temperature[2];
    float temper;
    therm_reset();
    therm_write_byte(0xCC);
    therm_write_byte(0x44);
    while(!therm_read_bit());
    therm_reset();
    therm_write_byte(0xBE);
    therm_reset();
    temper = (temperature[1] << 8 | temperature[0])/1.60;
    return (int)temper;
91
мерцание также не пропало, значит, единственный вариант выносного датчика - LM75.
Большое спасибо за интересный и красивый проект, индикатор выглядит шикарно. Надеюсь на дальнейшее развитие проекта
92
Здравствуйте, Александр. Хотелось бы Вас попросить вот о чем:
1. Внести изменения под датчик температуры и давления BMP180.
2. Убрать показ даты.
3. Чтоб смена показа температуры менялась на показания давления каждые, скажем, 15 секунд.
С уважением.
