Тема: Измеритель скважности и длительности импульсов
#include <OLED_I2C.h>           // http://rcl-radio.ru/wp-content/uploads/2022/01/OLED_I2C.zip
 OLED  myOLED(SDA, SCL, 8);
 extern uint8_t SmallFont[];
 char i;
 unsigned long times0,times1,t0,t1;
 int w=1;
  Wire.setClock(50000L);
  delay(300);
  myOLED.begin();
  myOLED.setBrightness(100);
  DDRB |= PB5; // D13 ARUINO > OUTPUT
  DDRD &= ~(1 << 2);  // D2 ARDUINO > INPUT (INT0)
  EICRA |= (1<<ISC00); // любое изменение на INT0
  EIMSK |= (1<<INT0); // разрешить внешние прерывания INT0
  noInterrupts();
  TCNT1 = 0;
  TCCR1A = 0;
  TCCR1C = 0;
  TCCR1A = 1 << COM1A0;
  TCCR1B = 1 << WGM12 | 1 << CS12 | 1 << CS10;
  DDRB =  1 << DDB1;
  OCR1A = 15624;
  interrupts();
  if(w==1){
  EIMSK &=~ (1<<INT0);
  PORTB |=(1 << PB5);
  Serial.print("T1 ");Serial.print(t0/1000.0,3);Serial.println(" mS");
  Serial.print("T2 ");Serial.print(t1/1000.0,3);Serial.println(" mS");
  Serial.print("T  ");Serial.print((t1+t0)/1000.0,3);Serial.println(" mS");
  Serial.print("F  ");Serial.print(1000000.0/(t1+t0),3);Serial.println(" Hz");
  Serial.println();
  myOLED.clrScr();
  myOLED.setFont(SmallFont);
  myOLED.print(F("T1"),LEFT,0);myOLED.printNumF(t0/1000.000,3, 30, 0);myOLED.print(F("mS"), RIGHT, 0);
  myOLED.print(F("T2"),LEFT,10);myOLED.printNumF(t1/1000.000,3, 30, 10);myOLED.print(F("mS"), RIGHT, 10);
  myOLED.print(F("T "),LEFT,20);myOLED.printNumF((t1+t0)/1000.0,3, 30, 20);myOLED.print(F("mS"), RIGHT, 20);
  myOLED.print(F("F "),LEFT,30);myOLED.printNumF(1000000.0/(t1+t0),3, 30, 30);myOLED.print(F("Hz"), RIGHT, 30);
  myOLED.drawLine(0, 40, 128, 40);
  float t_dl = t0;
  float t_sk = t1;
  float t_pr = t0+t1;
  myOLED.drawLine(0, 60, 5, 60);
  myOLED.drawLine(5, 60, 5, 45);
  myOLED.drawLine(5, 45, 5+(t_dl/t_pr)*120, 45);
  myOLED.drawLine(5+(t_dl/t_pr)*120, 60, 5+(t_dl/t_pr)*120, 45);
  myOLED.drawLine(5+(t_dl/t_pr)*120, 60, 5+(t_dl/t_pr)*120+(t_sk/t_pr)*120, 60);
  myOLED.update();
  PORTB &=~(1 << PB5);
  delay(400);
  EICRA|=(1<<ISC00);w=0;i=0;times0=micros();times1=micros();
  EICRA|=(1<<ISC01);EIMSK |= (1<<INT0);}
ISR(INT0_vect){
  if(i>1){i=0;w=1;}
  if(i==0){EICRA&=~(1<<ISC01);EICRA|=(1<<ISC00);
  times0=micros();t1=micros()-times1;}
  if(i==1){
  times1=micros();t0=micros()-times0;}
  i++;}
Re: Измеритель скважности и длительности импульсов
http://forum.rcl-radio.ru/uploads/images/2023/08/097051ad9cce0eb90d834aa9ee69b95e.png
3
http://forum.rcl-radio.ru/uploads/images/2023/08/a43726d845f6ec44ceae2ebd2829a285.png
4
http://forum.rcl-radio.ru/uploads/images/2023/08/956bcbdb7642e67e0911f4d3b19de5fb.png
http://forum.rcl-radio.ru/uploads/images/2023/08/dc68b0ddd5113bbbc628b72a1723ce63.png
http://forum.rcl-radio.ru/uploads/images/2023/08/da04a7f6f0c0effce59a7183b98a861e.png
http://forum.rcl-radio.ru/uploads/images/2023/08/07a1f2cb78b9785db608ab5b5e000e68.png
http://forum.rcl-radio.ru/uploads/images/2023/08/22a525aee88be3004e48cfddb2fb7d16.png
http://forum.rcl-radio.ru/uploads/images/2023/08/624aaf49241a17a5d4cb3b407e1ada39.png
http://forum.rcl-radio.ru/uploads/images/2023/08/6819a655f657a52093e3b26ed76f9982.png
http://forum.rcl-radio.ru/uploads/images/2023/08/d3550af7c16247b4ef6e87a9173a805f.png
5
Доработка
Добавление внешнего генератора
http://forum.rcl-radio.ru/uploads/images/2023/08/6f1a3f09628677246ac842dffe6ce0e4.png
#define HZ 12  - частота кварцевого генератора
#define HZ 12
 char i;
 unsigned long times0,times1,t0,t1,tic,f;
 int w=1;
  delay(300);
  myOLED.begin();
  PORTD |= (1 << PD5); // подтягивающий резистор на PD5 (вход T1)
  noInterrupts();
// TIMER_1 INPUT T1
  TCCR1A = 0;TCCR1B = 0;TCNT1=0;
  TCCR1B = (1 << CS12) | (1 << CS11) | (1 << CS10);
  TIMSK1 = (1 << TOIE1);
  TCKCSR = (1 << F2XEN) | (1 << TC2XS1);
  interrupts();
  if(w==1){
  PORTB |=(1 << PB5);
  Serial.print("T1 ");Serial.print(t0/(1000.0*HZ),3);Serial.println(" mS");
  Serial.print("T2 ");Serial.print(t1/(1000.0*HZ),3);Serial.println(" mS");
  Serial.print("T  ");Serial.print((t1+t0)/(1000.0*HZ),3);Serial.println(" mS");
  Serial.print("F  ");Serial.print((1000000.0*HZ)/(t1+t0),3);Serial.println(" Hz");
  Serial.println();
  myOLED.clrScr();
  myOLED.print(F("T1"),LEFT,0);myOLED.printNumF(t0/(1000.0*HZ),3, 30, 0);myOLED.print(F("mS"), RIGHT, 0);
  myOLED.print(F("T2"),LEFT,10);myOLED.printNumF(t1/(1000.0*HZ),3, 30, 10);myOLED.print(F("mS"), RIGHT, 10);
  myOLED.print(F("T "),LEFT,20);myOLED.printNumF((t1+t0)/(1000.0*HZ),3, 30, 20);myOLED.print(F("mS"), RIGHT, 20);
  myOLED.print(F("F "),LEFT,30);myOLED.printNumF((1000000.0*HZ)/(t1+t0),3, 30, 30);myOLED.print(F("Hz"), RIGHT, 30);
  float t_dl = t0;
  float t_sk = t1;
  float t_pr = t0+t1;
  myOLED.update();
  delay(400);
  w=0;i=0;f=tic*0xFFFF+TCNT1;times0=f;times1=f;
  EICRA|=(1<<ISC01);EICRA|=(1<<ISC00);EIMSK |= (1<<INT0);}
ISR(INT0_vect){
  if(i>1){i=0;w=1;}
  f=tic*0xFFFF+TCNT1;
  times0=f;t1=f-times1;}
  if(i==1){
  f=(tic*0xFFFF+TCNT1);
  times1=f;t0=f-times0;}
  i++;}
ISR(TIMER1_OVF_vect) {tic++;}
6
Доброго времени. Интересный проект. Хочу повторить. Я вам на емейл написал.
