Тема: PWM 0-25V 3A
Основная статья - http://rcl-radio.ru/?p=131081
// 0-25V 3A
#define KALL_U 7.405
#define CLK PB4 // TM1637 D11
#define DIO PB3 // TM1637 D12
float u,u_iz;
int reg;
bool w=1,w1,out=0;
unsigned long times;
u = float(EEPROM.read(0))/10.0;
// TIMER_1 D9 OUTPUT
DDRB |= (1 << PB1)|(1<<PB5); // D9 output pwm | D13 led error
DDRD |= (1<<PD2); // D2 RELE
PORTD |= (1<<PD3)|(1<<PD4)|(1<<PD5);
PORTB |= (1<<PB1);
noInterrupts();
TCCR1A = 0;TCCR1B = 0;
TCCR1A |= (1 << COM1A1) | (1 << COM1A0) | (1 << WGM11);
TCCR1B |= (1 << WGM13) | (1 << WGM12) | (1 << CS10);
TCKCSR = 1 << F2XEN | 1 << TC2XS1;
ICR1 = 5000;
OCR1A =0;
interrupts();
ADMUX = 0b000;
ADCSRD |= 1 << REFS2;
ADCSRA |= 1 << ADEN | 1 << ADSC | 1 << ADATE | 0b111;
delay(300);
PORTD &=~ (1 << PD2);
if(((PIND >> PD3) & 1) == 0){u+=0.1;if(u>25){u=25;}w=1;w1=1;times=millis();delay(100);}
if(((PIND >> PD4) & 1) == 0){u-=0.1;if(u<0){u=0;}w=1;w1=1;times=millis();delay(100);}
if(((PIND >> PD5) & 1) == 0 && out==0){out=1;w=1;delay(300);}
if(((PIND >> PD5) & 1) == 0 && out==1){out=0;w=1;delay(300);}
int u_data = (ADCL|ADCH << 8);
u_iz = float(u_data)/1000.0*KALL_U;
if(u_iz-u>5){reg-=100;}
if(u-u_iz>1){reg+=10;}
if(u_iz-u>1){reg-=10;}
if(u_iz<u){reg++;}
if(u_iz>u){reg--;}
if(reg<0){reg=0;}if(reg>4900 && out==1){reg=0;OCR1A=0;PORTB|=(1<<PB5);out=0;w=1;delay(3000);}
PORTB&=~(1<<PB5);
if(out==0){reg=0;} OCR1A = reg;
if(w==1){w=0;tm_print(u*10,1,5);}
if(millis()-times>5000 && w1==1){EEPROM.update(0,u*10);w1=0;}
void tm_dec(byte dig){
for(byte i = 0; i < 8; i++) {
DDRB |= (1 << CLK);del();
if (dig & 0x01)
DDRB &= ~(1 << DIO);
else
DDRB |= (1 << DIO);del();
DDRB &= ~(1 << CLK);del();
dig = dig >> 1;
DDRB |= (1 << CLK);
DDRB &= ~(1 << DIO);del();
if (((PINB >> DIO) & 1) == 0)
void tm_stop(){
void tm_start(){
void tm_print(int t, byte pd_t, int br){
tm_start();tm_dec(0b10001000 + br);
tm_dec(0x40);tm_stop();tm_start();
int data0 = t / 1000 % 10;
int data1 = t / 100 % 10;
int data2 = t / 10 % 10;
int data3 = t % 10;
for(byte n = 0; n < 4; n++){
int data;
switch(n){
case 0: if(out==1){data = 12;}else{data=10;};break;
case 1: if(u<10){data=10;}else{data = data1;}break;
case 2: data = data2;break;
case 3: data = data3;break;
switch(data){ // XGFEDCBA
case 0: data = 0b00111111;break; // 0
case 1: data = 0b00000110;break; // 1
case 2: data = 0b01011011;break; // 2
case 3: data = 0b01001111;break; // 3
case 4: data = 0b01100110;break; // 4
case 5: data = 0b01101101;break; // 5
case 6: data = 0b01111101;break; // 6
case 7: data = 0b00000111;break; // 7
case 8: data = 0b01111111;break; // 8
case 9: data = 0b01101111;break; // 9
case 10: data = 0b00000000;break; // пусто
case 11: data = 0b01000000;break; // -
case 12: data = 0b00111110;break; // U
if(n == 0){data0 = data;}
if(n == 1){data1 = data;}
if(n == 2){data2 = data;}
if(n == 3){data3 = data;}
switch(pd_t){
case 1 : data2 = data2+0b10000000;break;
case 2 : data1 = data1+0b10000000;break;
case 3 : data0 = data0+0b10000000;break;
tm_dec(0xC0);tm_dec(data0);tm_dec(data1);tm_dec(data2);tm_dec(data3);tm_stop();
void del(){delayMicroseconds(100);}
