#define MASTER 345623
#define TIME_OPEN 3000
#include <iarduino_KB.h> // https://github.com/tremaru/iarduino_KB.git
#include <TM1637_6_LED.h>
TM1637_6_LED tm(9, 10); // CLK, DIO
iarduino_KB KB(8,7,6,5,4,3,2); /// 8765 432
long code[8],ccc,i,i1,times,master,user;
int start;
bool w,w1,cod;
pinMode(13,OUTPUT);// output
pinMode(11,OUTPUT);// tone
KB.begin(KB3);
tm.brig(1); // ЯРКОСТЬ 0...7
tm.print(0, 0, 0b01000000, 0b00111001, 0b01011100, 0b01011110, 0b01111001, 0b01000000);
EEPROM.get(0, user);
if(KB.check(KEY_DOWN )){
if(KB.getNum==15){i=0;ccc=0;for(i1=0;i1<8;i1++){code[i]=0;}Serial.println(ccc);
tone(11, 400, 100);tm.print(ccc, 0, -1, -1, -1, -1, -1, -1);} // # стереть число
if(KB.getNum==14&&cod==1){Serial.println(ccc);delay(200);cod=0;start=1;user=EEPROM.put(0, ccc);
times=millis();w=1;tone(11, 400, 300);} // start master
if(KB.getNum==14&&cod==0){Serial.println(ccc);delay(200);w1=1;start=1;tone(11, 400, 300);} // start user
if(KB.getNum<10&&i<8){times=millis();w=1;
code[i] = KB.getNum; tone(11, 500+code[i]*50, 200);
case 0: ccc = code[0];break;
case 1: ccc = code[0]*10 + code[1];break;
case 2: ccc = code[0]*100 + code[1]*10 + code[2];break;
case 3: ccc = code[0]*1000 + code[1]*100 + code[2]*10 + code[3];break;
case 4: ccc = code[0]*10000 + code[1]*1000 + code[2]*100 + code[3]*10 + code[4];break;
case 5: ccc = code[0]*100000 + code[1]*10000 + code[2]*1000 + code[3]*100 + code[4]*10 + code[5];break;
}i++; if(i>5){i=7;}delay(200);Serial.println(ccc); tm.print(ccc, 0, -1, -1, -1, -1, -1, -1);}
if(millis()-times>5000&&w==1){w=0;
i=0;ccc=0;w=0;for(i1=0;i1<8;i1++){code[i]=0;
tm.print(0, 0, 0b01000000, 0b00111001, 0b01011100, 0b01011110, 0b01111001, 0b01000000);}
Serial.println(ccc);} // -code-
if(start==1&&ccc==MASTER){start=0;cod=1;i=0;ccc=0;w=0;for(i1=0;i1<8;i1++){code[i]=0;}
tm.print(0, 0, 0b01000000, 0b01110110, 0b01110110, 0b01110110, 0b01110110, 0b01000000);
} // -hhhh-
if(start==1&&ccc==user&&w1==1){start=0;w1=0;digitalWrite(13,HIGH);
tm.print(0, 0, 0b01000000, 0b00111111, 0b01110011, 0b01111001, 0b01010100, 0b01000000);
tone(11, 1000, 1000);delay(TIME_OPEN);digitalWrite(13,LOW);times=millis()-5000;w=1;}// -open-
if(start==1&&ccc!=user&&w1==1){start=0;w1=0;
times=millis()-4000;w=1;
tm.print(0, 0, 0b01000000, 0b01000000, 0b01000000, 0b01000000, 0b01000000, 0b01000000);}// ------
}//loop
