Тема: Простые часы на семисегментных индикаторах (Arduino Nano+ds3231)
индикаторы - 5161AS - http://www.xlitx.com/datasheet/5161AS.pdf
http://forum.rcl-radio.ru/uploads/images/2023/09/499292c4bb8938984ba7abc9577eea7c.png
http://forum.rcl-radio.ru/uploads/images/2023/09/c3c8a1e3cde1668446975d083a92811c.png
#define K3 A3
#define K2 A2
#define K1 A1
#define K0 A0
#define SEG_A       8
#define SEG_B       7
#define SEG_C       4
#define SEG_D       5
#define SEG_E       2
#define SEG_F       6
#define SEG_G       9
#define SEG_DP      3
#define SET  10
#define UP   11
#define DW   12
#define NIGHT 1
byte an,segm,a[4],i,dp;
int hour,minut,secon,old_sec,hh,mm,set=0;
unsigned long times,times1;
int brig,br;
  clock.begin();
  TCCR2A = 0;
  TCCR2B = 0;
  TCNT2 = 0;
// (16000000/((155+1)x256))=400.64102564103 Hz
  OCR2A = 155;
  TCCR2A |= (1 << WGM21);
// Prescaler 256
  TCCR2B |= (1 << CS22) | (1 << CS21);
  TIMSK2 |= (1 << OCIE2A);
  pinMode(K3,OUTPUT);
  pinMode(K2,OUTPUT);
  pinMode(K1,OUTPUT);
  pinMode(K0,OUTPUT);
  pinMode(SEG_A, OUTPUT);
  pinMode(SEG_B, OUTPUT);
  pinMode(SEG_C, OUTPUT);
  pinMode(SEG_D, OUTPUT);
  pinMode(SEG_E, OUTPUT);
  pinMode(SEG_F, OUTPUT);
  pinMode(SEG_G, OUTPUT);
  pinMode(SEG_DP, OUTPUT);
  pinMode (SET,INPUT_PULLUP);
  pinMode (UP,INPUT_PULLUP);
  pinMode (DW,INPUT_PULLUP);
  brig = EEPROM.read(100);
  if(brig>20){brig=1;EEPROM.update(100,brig);}
  if((hour<7||hour>=22)&&NIGHT==1){br=20;}else{br=brig;}
  if(digitalRead(SET)==LOW){set++;if(set>2){set=0;}delay(200);}
  hh=hour;mm=minut;
  if(set==1 && digitalRead(UP)==LOW){hh++;if(hh>23){hh=0;}clock.setDateTime(2023, 9, 5, hh, minut, 0);delay(200);}
  if(set==1 && digitalRead(DW)==LOW){hh--;if(hh<0){hh=0;}clock.setDateTime(2023, 9, 5, hh, minut, 0);delay(200);}
  if(set==2 && digitalRead(UP)==LOW){mm++;if(mm>59){mm=0;}clock.setDateTime(2023, 9, 5, hour, mm, 0);delay(200);}
  if(set==2 && digitalRead(DW)==LOW){mm--;if(mm<0){mm=0;}clock.setDateTime(2023, 9, 5, hour, mm, 0);delay(200);}
  if(set==0 && digitalRead(UP)==LOW){brig--;if(brig<1){brig=1;}EEPROM.update(100,brig);delay(200);}
  if(set==0 && digitalRead(DW)==LOW){brig++;if(brig>20){brig=20;}EEPROM.update(100,brig);delay(200);}
  if(set==1&&millis()-times<200){a[0]=10;a[1]=10;}
    else{a[0] = hour/10%10; a[1] = hour%10; }
  if(set==2&&millis()-times<200){a[2]=10;a[3]=10;}
    else{a[2] = minut/10%10; a[3] = minut%10; }
  if(set==0){
    a[0]=hour/10%10;
    a[1]=hour%10;
    a[2]=minut/10%10;
    a[3]=minut%10;
  if(millis()-times1<500){dp=1;}else{dp=0;}
  if(old_sec!=secon){old_sec=secon;times1=millis();}
void segment() {
  switch (segm) {
            //  A          B             C              D             E            F            G
    case 0: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 1); ch(SEG_F, 1); ch(SEG_G, 0); break; // 0
    case 1: ch(SEG_A, 0); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 0); ch(SEG_E, 0); ch(SEG_F, 0); ch(SEG_G, 0); break; // 1
    case 2: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 0); ch(SEG_D, 1); ch(SEG_E, 1); ch(SEG_F, 0); ch(SEG_G, 1); break; // 2
    case 3: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 0); ch(SEG_F, 0); ch(SEG_G, 1); break; // 3
    case 4: ch(SEG_A, 0); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 0); ch(SEG_E, 0); ch(SEG_F, 1); ch(SEG_G, 1); break; // 4
    case 5: ch(SEG_A, 1); ch(SEG_B, 0); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 0); ch(SEG_F, 1); ch(SEG_G, 1); break; // 5
    case 6: ch(SEG_A, 1); ch(SEG_B, 0); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 1); ch(SEG_F, 1); ch(SEG_G, 1); break; // 6
    case 7: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 0); ch(SEG_E, 0); ch(SEG_F, 0); ch(SEG_G, 0); break; // 7
    case 8: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 1); ch(SEG_F, 1); ch(SEG_G, 1); break; // 8
    case 9: ch(SEG_A, 1); ch(SEG_B, 1); ch(SEG_C, 1); ch(SEG_D, 1); ch(SEG_E, 0); ch(SEG_F, 1); ch(SEG_G, 1); break; // 9
   case 10: ch(SEG_A, 0); ch(SEG_B, 0); ch(SEG_C, 0); ch(SEG_D, 0); ch(SEG_E, 0); ch(SEG_F, 0); ch(SEG_G, 0); break; // пусто
ISR(TIMER2_COMPA_vect){
   switch (i) {
    case 0: segm = 10; segment();an = 10;kat();delayMicroseconds(br*100);segm = a[0];segment();an = 0;kat();ch(SEG_DP, 0);break;
    case 1: segm = 10; segment();an = 10;kat();delayMicroseconds(br*100);segm = a[1];segment();an = 1;kat();ch(SEG_DP, dp);break;
    case 2: segm = 10; segment();an = 10;kat();delayMicroseconds(br*100);segm = a[2];segment();an = 2;kat();ch(SEG_DP, dp);break;
    case 3: segm = 10; segment();an = 10;kat();delayMicroseconds(br*100);segm = a[3];segment();an = 3;kat();ch(SEG_DP, 0);break;
  i++;if (i > 3) {i = 0;}
void kat() {
  switch (an) {
    case 0: ch(K3, 1); ch(K2, 0); ch(K1, 0); ch(K0, 0); break;
    case 1: ch(K3, 0); ch(K2, 1); ch(K1, 0); ch(K0, 0); break;
    case 2: ch(K3, 0); ch(K2, 0); ch(K1, 1); ch(K0, 0); break;
    case 3: ch(K3, 0); ch(K2, 0); ch(K1, 0); ch(K0, 1); break;
   case 10: ch(K3, 0); ch(K2, 0); ch(K1, 0); ch(K0, 0); break;
void ch(int pin, int logic){digitalWrite(pin, logic);}
2
Re: Простые часы на семисегментных индикаторах (Arduino Nano+ds3231)
http://forum.rcl-radio.ru/uploads/images/2023/09/b21bfa7f9a01bbf7fd586ddea79a32bd.png
http://forum.rcl-radio.ru/uploads/images/2023/09/c90338abf27c039057236cf9c7873dc9.png
3
http://forum.rcl-radio.ru/uploads/images/2023/09/d1e5ac610e6ef63fe59eaa4ccbf99880.gif
4
Добрый день!
А что нужно переделать в скетче, что бы можно было подключить индикаторы с общим анодом?
5
В функциях kat() и segment() инвертировать выходы
В скетче вместо
предлагаю писать :
if(set==2 && digitalRead(DW)==LOW){mm--;if(mm<0){mm=59;}clock.setDateTime(2023, 9, 5, hour, mm, 0);delay(200);}
и вместо
писать :
if(set==1 && digitalRead(DW)==LOW){hh--;if(hh<0){hh=23;}clock.setDateTime(2023, 9, 5, hh, minut, 0);delay(200);}
иначе при нажатии кнопки "минус" отсчет "упирается" в 0 и дальше не идет.
Также не смог победить такой баг- при установке времени в "ночные" часы (т.е. когда индикация притушена) - частота , с которой меняются цифры раза в два меньше, чем в "дневное" время. Т.е. каким -то образом частота смены цифр при установке времени завязана на яркость. В этой части программы разобраться образования не хватило, поэтому просто сделал "костыль"- при установке времени яркость индикации приравнял br=brig.
7
Здравствуйте, Liman324!
Возможно ли для этой схемы реализовать так называемый BackLight, который бы имел возможность понижать яркость вместе с понижением яркости индикаторов в зависимости о времени суток? Вроде и пин 13 свободен и можно было бы на него повесить эту функцию...
Хочу взять за основу эту схему ввиду ее простоты и сделать часы, индикаторы которых поместить в отдельные стеклянные колбы. И для визуального эффекта хотелось бы подсвечивать колбы через отполированный торец. Подобно, как подсвечивают ИН-ки или ИВ-шки.
С уважением, Eugen.
8
номера пинов с поддержкой ШИМ - 3, 5, 6, 9, 10, 11 для Nano
9
А если кнопки сделать  на 10, 12 и 13 пины, а 11-й пин освободить для подсветки... Так возможно?
10
#define K3 A3
#define K2 A2
#define K1 A1
#define K0 A0
#define SEG_A       8
#define SEG_B       7
#define SEG_C       4
#define SEG_D       5
#define SEG_E       2
#define SEG_F       6
#define SEG_G       9
#define SEG_DP      3
#define SET  10
#define UP   12
#define DW   12
#define OUT_PWM     11  // пин ШИМ подсветки LED
#define BRIG_LOW    50  // яркость ШИМ подсветки LED минимум
#define BRIG_HIGH  255  // яркость ШИМ подсветки LED максимум
#define NIGHT 1
int brig,br;
  clock.begin();
  TCCR2A = 0;
  TCCR2B = 0;
  TCNT2 = 0;
  OCR2A = 155;
// Prescaler 256
  pinMode(K3,OUTPUT);
  pinMode(K2,OUTPUT);
  pinMode(K1,OUTPUT);
  pinMode(K0,OUTPUT);
  pinMode(OUT_PWM, OUTPUT);
  if((hour<7||hour>=22)&&NIGHT==1){br=20;analogWrite(OUT_PWM, BRIG_LOW);}else{br=brig;analogWrite(OUT_PWM, BRIG_HIGH);}
  hh=hour;mm=minut;
  if(set==0){
    a[0]=hour/10%10;
    a[1]=hour%10;
    a[2]=minut/10%10;
    a[3]=minut%10;
void segment() {
  switch (segm) {
            //  A          B             C              D             E            F            G
   switch (i) {
void kat() {
  switch (an) {
11
Спасибо, Liman324!!!
Попробую, отпишусь.
