Тема: Регулятор громкости и тембра на LC75341 + 0.96′ I2C 128X64 OLED LCD
http://forum.rcl-radio.ru/uploads/images/2022/01/ace5fefbc23ec1303babc5d0de727f39.png
http://forum.rcl-radio.ru/uploads/images/2022/01/b5ca7544c573d67e7bdf0a186b7285f8.gif
#define IR2    0x33B820DF // button encoder
#define IR3    0x33B8946B // mute
#define IR4    0x33B810EF // >>>
#define IR5    0x33B8E01F // <<<
#define IR6    0x33B844BB // INPUT
#define POWER  0x33B800FF // STANDBY
#include <LC75341.h>           // http://rcl-radio.ru/wp-content/uploads/2022/01/lc75341.zip
#include <OLED_I2C.h>          // http://rcl-radio.ru/wp-content/uploads/2022/01/OLED_I2C.zip
OLED  myOLED(SDA, SCL, 8);
LC75341 lc(3,4,2);   // CE,DI,CL
long times,oldPosition  = -999,newPosition;
int vol_reg,menu,mute_reg,power,treb_reg,gain0,gain1,gain2,gain3,gain4,gain5,bass_reg,in_reg,ball,vol_old;
bool w,w2,gr1,gr2,www;
  Wire.begin();Wire.setClock(400000L);
  irrecv.enableIRIn();
  myOLED.begin();
  myOLED.setBrightness(100);
  pinMode(10,INPUT);        // encoder SW
  pinMode(7,INPUT_PULLUP);  // mute button
  pinMode(11,INPUT_PULLUP); // input button
  vol_reg = EEPROM.read(0);treb_reg = EEPROM.read(1)-5;bass_reg = EEPROM.read(2);gain1 = EEPROM.read(4);
  gain2 = EEPROM.read(5);gain3 = EEPROM.read(6);gain4 = EEPROM.read(7);gain5 = EEPROM.read(8);
  in_reg = EEPROM.read(9);ball = EEPROM.read(10)-4;
  switch(in_reg){
     case 0: gain0 = gain1;break;
     case 1: gain0 = gain2;break;
     case 2: gain0 = gain3;break;
     case 3: gain0 = gain4;break;
  audio_L();
  audio_R();
   if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);irrecv.resume();times=millis();w=1;w2=1;}// IR приемник - чтение, в мониторе порта отображаются коды кнопок
//////// BUTTON /////////////////////////////////////////////////////////////////////////////////////////////////////////////
 if(mute_reg==0){
   if(digitalRead(10)==LOW||ir.value==IR2){menu++;gr1=0;gr2=0;cl();times=millis();w=1;w2=1;if(menu>3){menu=0;}}
   if((digitalRead(11)==LOW||ir.value==IR6)){in_reg++;menu=4;cl();times=millis();w=1;w2=1;www=1;if(in_reg>3){in_reg=0;}}
   if((digitalRead(7)==LOW||ir.value==IR3)&&mute_reg==0){mute_reg=1;menu=100;cl();vol_old=vol_reg;vol_reg=79;audio_R();audio_L();myOLED.clrScr();myOLED.setFont(SmallFont);myOLED.print(F("MUTE"), CENTER, 25);myOLED.update();}
   if((digitalRead(7)==LOW||ir.value==IR3)&&mute_reg==1){mute_reg=0;w=1;menu=0;cl();vol_reg=vol_old;audio_R();audio_L();}
  vol_reg=vol_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w2=1;vol_func();audio_R();audio_L();}
   if(ir.value==IR5){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w2=1;vol_func();audio_R();audio_L();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){vol_reg++;gr2=0;cl();times=millis();w=1;w2=1;vol_func();audio_R();audio_L();}// кнопка >>>>>>
   if(ir.value==IR4){vol_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w2=1;vol_func();audio_R();audio_L();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){vol_reg--;gr1=0;cl();times=millis();w=1;w2=1;vol_func();audio_R();audio_L();}// кнопка <<<<<<
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("VOLUME"), LEFT, 0);myOLED.setFont(BigNumbers);myOLED.printNumI(79-vol_reg, 65, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("IN"), LEFT, 10);
  myOLED.printNumI(in_reg+1, 20, 10);myOLED.print(F("GAIN"), LEFT, 20);myOLED.printNumI(gain0*2, 30, 20);
  myOLED.drawLine(0, 30, 128, 30);
  myOLED.setFont(SmallFont);myOLED.print(F("TREBLE"), LEFT, 35);myOLED.printNumI(treb_reg*2, 70, 35);myOLED.print(F("dB"), RIGHT, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("BASS"), LEFT, 45);myOLED.printNumI(bass_reg*2, 70, 45);myOLED.print(F("dB"), RIGHT, 45);
  myOLED.setFont(SmallFont);myOLED.print(F("BALANCE"), LEFT, 55);myOLED.printNumI(ball, 70, 55);myOLED.print(F("dB"), RIGHT, 55);
  myOLED.update();
  treb_reg=treb_reg-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w2=1;treb_func();audio_R();audio_L();}
   if(ir.value==IR4){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w2=1;treb_func();audio_R();audio_L();}// кнопка >
   if(ir.value==IR5){treb_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w2=1;treb_func();audio_R();audio_L();}// кнопка <
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("TREBLE"), LEFT, 0);;myOLED.setFont(BigNumbers);myOLED.printNumI(treb_reg*2, 65, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("dB"), RIGHT, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("BASS"), LEFT, 35);myOLED.printNumI(bass_reg*2, 70, 35);myOLED.print(F("dB"), RIGHT, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("BALANCE"), LEFT, 45);myOLED.printNumI(ball, 70, 45);myOLED.print(F("dB"), RIGHT, 45);
  myOLED.setFont(SmallFont);myOLED.print(F("VOLUME"), LEFT, 55);myOLED.printNumI(79-vol_reg, 70, 55);
  myOLED.update();
  bass_reg=bass_reg-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w2=1;bass_func();audio_R();audio_L();}
   if(ir.value==IR4){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w2=1;bass_func();audio_R();audio_L();}// кнопка >
   if(ir.value==IR5){bass_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w2=1;bass_func();audio_R();audio_L();}// кнопка <
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("BASS"), LEFT, 0);;myOLED.setFont(BigNumbers);myOLED.printNumI(bass_reg*2, 65, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("BALANCE"), LEFT, 35);myOLED.printNumI(ball, 70, 35);myOLED.print(F("dB"), RIGHT, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("VOLUME"), LEFT, 45);myOLED.printNumI(79-vol_reg, 70, 45);
  myOLED.setFont(SmallFont);myOLED.print(F("TREBLE"), LEFT, 55);myOLED.printNumI(treb_reg*2, 70, 55);myOLED.print(F("dB"), RIGHT, 55);
  myOLED.update();
//////// BALANCE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
  ball=ball-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w2=1;ball_func();audio_R();audio_L();}
   if(ir.value==IR4){ball++;gr1=1;gr2=0;cl();times=millis();w=1;w2=1;ball_func();audio_R();audio_L();}// кнопка >
   if(ir.value==IR5){ball--;gr1=0;gr2=1;cl();times=millis();w=1;w2=1;ball_func();audio_R();audio_L();}// кнопка <
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("BALANCE"), LEFT, 0);;myOLED.setFont(BigNumbers);myOLED.printNumI(abs(ball), 65, 0);
  if(ball<=0){myOLED.print(F("LCH"), 20, 20);}
  if(ball>=0){myOLED.print(F("RCH"), RIGHT, 20);}
  myOLED.setFont(SmallFont);myOLED.print(F("VOLUME"), LEFT, 35);myOLED.printNumI(79-vol_reg, 70, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("TREBLE"), LEFT, 45);myOLED.printNumI(treb_reg*2, 70, 45);myOLED.print(F("dB"), RIGHT, 45);
  myOLED.setFont(SmallFont);myOLED.print(F("BASS"), LEFT, 55);myOLED.printNumI(bass_reg*2, 70, 55);myOLED.print(F("dB"), RIGHT, 55);
  myOLED.update();
 if(menu==4){
  switch(in_reg){
  if (newPosition != oldPosition){oldPosition = newPosition;gain0=gain0-newPosition;myEnc.write(0);newPosition=0;times=millis();www=1;w=1;w2=1;gain_func();}
   if(ir.value==IR4){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w2=1;gain_func();audio_R();audio_L();}// кнопка >
   if(ir.value==IR5){gain0--;gr1=0;gr2=1;cl();times=millis();w=1;w2=1;gain_func();audio_R();audio_L();}// кнопка <
  switch(in_reg){
     case 0: gain1 = gain0;break;
     case 1: gain2 = gain0;break;
     case 2: gain3 = gain0;break;
     case 3: gain4 = gain0;break;
  if(www==1){audio_R();audio_L();www=0;}
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("INPUT"), LEFT, 0);myOLED.setFont(BigNumbers);myOLED.printNumI(in_reg+1, 65, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("GAIN"), LEFT, 35);myOLED.setFont(BigNumbers);myOLED.printNumI(gain0*2, 65, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("dB"), RIGHT, 35);
  myOLED.update();
 if(millis()-times>10000 && w2==1 && mute_reg==0 && power==0){
     EEPROM.update(0,vol_reg);EEPROM.update(1,treb_reg+5);EEPROM.update(2,bass_reg);EEPROM.update(4,gain1);
     EEPROM.update(5,gain2);EEPROM.update(6,gain3);EEPROM.update(7,gain4);EEPROM.update(8,gain5);
     EEPROM.update(9,in_reg);EEPROM.update(10,ball+4);
     if(menu!=0){menu=0;}w=1;w2=0;}
}// end loop
void treb_func(){if(treb_reg<-5){treb_reg=-5;}if(treb_reg>5){treb_reg=5;}}
void gain_func(){{if(gain0<0){gain0=0;}if(gain0>15){gain0=15;}}}
void ball_func(){if(ball>4){ball=4;}if(ball<-4){ball=-4;}}
void bass_func(){if(bass_reg<0){bass_reg=0;}if(bass_reg>10){bass_reg=10;}}
void vol_func(){if(vol_reg<4){vol_reg=4;}if(vol_reg>79){vol_reg=79;}}
void cl(){myOLED.clrScr();ir.value=0;delay(300);}
void audio_L(){
  lc.addr();
  lc.set_input(in_reg);   // input 1...4 = byte 0...3 (byte 4...7 = All switches off)
  lc.set_gain(gain0);    // gain 0...30 dB step 2 dB = byte 0...15
  lc.set_volume(vol_reg-ball);  // volume 0...-79 dB = byte 0...79
  lc.set_treble(treb_reg);  // treble -10...10 dB step 2 dB = int -5...5
  lc.set_bass(bass_reg);    // bass 0...20 dB step 2 dB = int 0...10
  lc.set_ch(1);      // Channel Selection RCH = byte 2, LCH = byte 1, Left and right together = byte 3
  lc.test();
void audio_R(){
  lc.addr();
  lc.set_volume(vol_reg+ball);  // volume 0...-79 dB = byte 0...79
  lc.set_ch(2);      // Channel Selection RCH = byte 2, LCH = byte 1, Left and right together = byte 3
  lc.test();
Re: Регулятор громкости и тембра на LC75341 + 0.96′ I2C 128X64 OLED LCD
http://forum.rcl-radio.ru/uploads/images/2022/01/db99457cfa1b0e4a95483b7253ce13cb.png
  myOLED.begin();
  myOLED.invert(true);
  switch(in_reg){
  audio_L();
  audio_R();
 if(mute_reg==0){
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("VOLUME"), LEFT, 1);myOLED.setFont(BigNumbers);myOLED.printNumI(79-vol_reg, 65, 1);
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("TREBLE"), LEFT, 1);;myOLED.setFont(BigNumbers);myOLED.printNumI(treb_reg*2, 65, 1);
  myOLED.setFont(SmallFont);myOLED.print(F("dB"), RIGHT, 1);
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("BASS"), LEFT, 1);;myOLED.setFont(BigNumbers);myOLED.printNumI(bass_reg*2, 65, 1);
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("BALANCE"), LEFT, 1);;myOLED.setFont(BigNumbers);myOLED.printNumI(abs(ball), 65, 1);
  myOLED.update();
 if(menu==4){
  switch(in_reg){
  switch(in_reg){
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.setFont(SmallFont);myOLED.print(F("INPUT"), LEFT, 1);myOLED.setFont(BigNumbers);myOLED.printNumI(in_reg+1, 65, 1);
  myOLED.update();
}// end loop
void audio_L(){
  lc.addr();
  lc.test();
void audio_R(){
  lc.addr();
  lc.test();
3
У OLED дисплеев используемых здесь есть эффект выгорания пикселей. Так что есть смысл либо гасить дисплей после некоторого времени , либо использовать динамическое изменения расположения выводимых символов
4
Добавлена функция STANDBY
Активация через кнопку на D6 и кнопку пульта. Выход управления STANDBY D5.
Требуется тестирование!!!
bool w,w2,gr1,gr2,www,standby;
  myOLED.begin();
  pinMode(6,INPUT_PULLUP);  // standby button
  pinMode(5,OUTPUT);        // out standby
  switch(in_reg){
  audio_L();
  audio_R();
 if(standby==0){
 if(mute_reg==0){
   if((digitalRead(6)==LOW||ir.value==POWER)&&standby==0){standby=1;menu=100;cl();;vol_old=vol_reg;vol_reg=79;audio_R();audio_L();myOLED.clrScr();myOLED.setFont(SmallFont);
        myOLED.print(F("POWER OFF"), CENTER, 25);myOLED.update();digitalWrite(5,LOW);delay(2000);myOLED.setBrightness(0);}
   if((digitalRead(6)==LOW||ir.value==POWER)&&standby==1){standby=0;w=1;menu=0;cl();vol_reg=vol_old;audio_R();audio_L();myOLED.setBrightness(100);}
   if(standby==1){digitalWrite(5,LOW);}else{digitalWrite(5,HIGH);}
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.update();
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.update();
 if(menu==4){
  switch(in_reg){
  switch(in_reg){
  if(w==1){w=0;
  myOLED.clrScr();
  myOLED.update();
 if(millis()-times>10000 && w2==1 && mute_reg==0 && standby==0){
}// end loop
void audio_L(){
  lc.addr();
  lc.test();
void audio_R(){
  lc.addr();
  lc.test();
5
Спасибо!
Протестировал.
После нажатия кнопки Power или команды с пульта появляется надпись POWER OFF и через несколько секунд самопроизвольное включение. Подключено всё правильно, ошибок нет...
6
Тот же алгоритм POWER - STANDBY, как я понимаю, можно применять и в других Ваших конструкциях на OLED? По типу этой которые
7
У меня собрана схема, все работает как положено.
8 (2022-05-19 18:48:18 отредактировано Cat777)
Не знаю, что за глюк был. Возможно при прошивке что то пошло не так. Перепрошил заново - всё нормально! Кроме одного - надпись POWER OFF висит на экране всё время. Может это зависит от модели дисплея? У меня сейчас подключен OLED SSD1309 2.42" I2C. Возможно, что с другим дисплеем будет вести себя как надо. Вечером подключу другой (есть несколько более мелких) - сообщу!
9
Добавил в строке для обработки POWER OFF после myOLED.setBrightness(0); следующее:
myOLED.clrScr();myOLED.update();
Надпись POWER OFF после пары секунд гаснет. При повторном приёме команды с пульта или нажатия кнопки STANDBY - всё восстанавливается.
СПАСИБО!!!
10
Здравствуйте, у меня есть в наличии LC75392, подскажите может есть скетч для данного контроллера под такой же проект?
11
Под LC75392 у меня нет проектов.
12
liman324 пишет:
жаль
13
Спасибо liman234  за разработку!
Решил проверить, пока ожидаю LC75341 и IR приемник,  скетч. Загрузил, но информация на дисплее хаотически прыгает. Это из-за отсутствия IR приемника?
14
Из-за не подключенного энкодера
15
liman324 пишет:
Странно. Энкодер подключён. Видимо не того типа.
Спасибо за ответ!
16
На плате энкодера должно быть 3 подтягивающих резистора по 10 кОм, кнопка энкодера инверсная, нажатие = GND, кнопка отпущена на выходе SW = 5V
17
liman324 пишет:
Да. Китайцы на один пожмотились.
Все отлично, припаял и теперь жду микросхему и датчик.
Как доделаю УМ, выложу фото.
Ещё раз - спасибо за проект!
P. S. Вопрос:
Кроме выходов на дисплей, все остальные можно менять, верно? Я использую голую Атмегу, поэтому для удобства и красоты платы надо пару ног переназначить.
18
Можно менять.
19 (2023-05-31 19:31:40 отредактировано Karl2233)
Добрый день!
Прошу помощи с IR блоком.
1. Подключил VS1838, загрузил скетч, открыл монитор порта но там от нажатий пульта ничего не происходит.
2. Загрузил тестовый скетч, открыл монитор, переписал коды (у меня пульт NEC оказался). Внес эти коды в скетч, но он не компилирутся - ругается на мои коды.
Что я не так делаю?
P. S. Мои коды отличаются: например POWER у меня имеет  вид FF0FF0, видимо скетч не принимает такое (в скетче попробовал изменить в коде 0x33B800FF последнюю букву на "А", всё скомпилировалось). Получается мне надо как-то мои коды привести к виду который принимает компилятор.
20
Установите библиотеку IR с источника указанного в скетче или в статье к этому аудиопроцессору.
Опубликуйте код
21
Именно со статьи использовал библиотеку.
Мои коды:
FF2FD0
FFAF50
FF4FB0
FFCF30
FF0FF0
22
0xFF2FD0
23
Скомпилировалось smile
правда ничего не реагирует.
Теперь запускаю тестовый скетч и ничего не происходит, как вроде сгорел VS1838.
Чудеса.
24
25 (2023-05-31 23:03:35 отредактировано Karl2233)
Понял, завтра попробую. Но изначально использовал библиотеку из скетча. Видимо что-то не так делал, перепроверю
Спасибо!
Вопрос: правильно ли я понимаю - скетч с правильной библиотекой и открытым монитором порта должен показывать коды кнопок пульта?
