Тема: ИП 0-25B 0-2A | СТАБИЛИЗАЦИЯ ПО ТОКУ
Основная статья - http://rcl-radio.ru/?p=130243
РАЗРАБОТКА
http://forum.rcl-radio.ru/uploads/images/2023/03/d1296b832a6b45628836397a6e8a7980.gif
Тест
#define ANALOG_I A3
#define U_OUT_K 508
#define I_OUT_K 2160
#define I_STAB_K 4900
#define I_0 105
unsigned long i_sum,times;
int ads_i,i;
float u_out = 2;
float i_stab = 2.0;
  analogReadResolution(12);
  analogReference(INTERNAL4V096);//INTERNAL4V096 DEFAULT(Uп)
// TIMER_1 D9 OUTPUT
  DDRB = 1 << PB1;
  noInterrupts();
  TCCR1A=0;TCCR1B=0;
  TCCR1A = 1 << COM1A1 | 1 << WGM11;
  TCCR1B = 1 << WGM13 | 1 << WGM12 | 1 << CS10;
  OCR1A = u_out*U_OUT_K;
  ICR1 = 10000;
// TIMER_3 D2 OUTPUT
  TCCR3A=0;TCCR3B=0;
  DDRF |= (1<<PF2);
  HDR = 1 << HDR3;
  TCCR3A = 1 << COM3B1 | 1 << WGM31;
  TCCR3B = 1 << WGM33 | 1 << WGM32 | 1 << CS30;
  OCR3B = I_STAB_K*i_stab;// 4700 1A
  ICR3 = 10000;
  interrupts();
  if(millis()-times>100){times=millis();ads_i++;i_sum = i_sum + analogRead(ANALOG_I);}
  if(ads_i>9){ads_i=0;i = i_sum/10;i_sum=0;
  Serial.println(abs(float(i-I_0)/I_OUT_K),2);
  Serial.println(analogRead(ANALOG_I)-I_0);
Re: ИП 0-25B 0-2A | СТАБИЛИЗАЦИЯ ПО ТОКУ
http://forum.rcl-radio.ru/uploads/images/2023/03/aeeaf6900c4c13ae23f3987b389fa52c.png
http://forum.rcl-radio.ru/uploads/images/2023/03/efa68d784906f7f06c10a0bb92587b37.gif
#define ANALOG_I A3
#define ANALOG_U A6
#define U_OUT_K 508
#define I_OUT_K 1970
#define I_STAB_K 1210
#define U_OUT_IND 157
#include <OLED_I2C.h>           // http://rcl-radio.ru/wp-content/uploads/2022/01/OLED_I2C.zip
OLED  myOLED(SDA, SCL, 8);
Encoder myEnc(6, 5);// DT, CLK
unsigned long u_sum,i_sum,times,times0,oldPosition  = -999,newPosition;
int u_,ads_i,i_,menu;
int u_out,i_stab;
bool w=1,w2,out=1;
  delay(200);Wire.begin();myOLED.begin();
  myOLED.setBrightness(100);// ЯРКОСТЬ ДИСПЛЕЯ
  analogReadResolution(12);// АЦП 12 БИТ
  analogReference(DEFAULT);//INTERNAL4V096 DEFAULT(Uп)
  pinMode(7,INPUT);        // SW ENCODER
  pinMode(4,INPUT_PULLUP); // OUT_ON_OFF
  DDRB = 1 << PB1;
  noInterrupts();
  TCCR1A=0;TCCR1B=0;
  OCR1A = 0;
  ICR1 = 10000;
  TCCR3A=0;TCCR3B=0;
  DDRF |= (1<<PF2);
  HDR = 1 << HDR3;
  OCR3B = 0;
  ICR3 = 2500;
  interrupts();
  myOLED.clrScr();
  myOLED.setFont(SmallFont);
  myOLED.print(F("Power unit"), CENTER, 10);
  myOLED.print(F("0-25V"), CENTER, 30);
  myOLED.print(F("0-2A"), CENTER, 50);
  myOLED.update();
  delay(1000);
  u_out = EEPROM.read(0);i_stab = EEPROM.read(1);
  OCR1A = float(u_out)/10.00*U_OUT_K;
  OCR3B = I_STAB_K*float(i_stab)/100;
  if(digitalRead(7)==LOW){menu++;delay(300);times0=millis();w=1;w2=1;if(menu>1){menu=0;}}
  if(digitalRead(4)==LOW && out==1){out=0;;delay(300);OCR1A=0;OCR3B = 0;}
  if(digitalRead(4)==LOW && out==0){out=1;;delay(300);w=1;}
  if(millis()-times>100){times=millis();ads_i++;i_sum = i_sum + analogRead(ANALOG_I);u_sum = u_sum + analogRead(ANALOG_U);}
  if(ads_i>9){ads_i=0;i_ = i_sum/10;i_sum=0; u_ = u_sum/10;u_sum=0;
    Serial.print("I_out = ");Serial.println(abs(float(i_)/I_OUT_K),2);
    Serial.print("I_dig = ");Serial.println(analogRead(ANALOG_I));
    Serial.print("U_out = ");Serial.println(abs(float(u_)/U_OUT_IND),2);
    Serial.print("U_dig = ");Serial.println(analogRead(ANALOG_U));
    w=1;}
  if(newPosition != oldPosition){oldPosition = newPosition;u_out=u_out+newPosition;myEnc.write(0);newPosition=0;
  if(u_out<0){u_out=0;}if(u_out>250){u_out=250;}times0=millis();w=1;w2=1;}}
  if(newPosition != oldPosition){oldPosition = newPosition;i_stab=i_stab+newPosition;myEnc.write(0);newPosition=0;
  if(i_stab<10){i_stab=10;}if(i_stab>200){i_stab=200;}times0=millis();w=1;w2=1;}}
  if(w==1){w=0;
  if(out==1){
  myOLED.clrScr();
  // U /////////
  myOLED.setFont(BigNumbers);if(u_out/100>0){myOLED.printNumI(u_out/100, 5, 0);}
  myOLED.printNumI(u_out/10%10, 20, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("."), 33, 18);myOLED.setFont(BigNumbers);myOLED.printNumI(u_out%10, 38, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("V"), 57, 0);
  if(menu==0){myOLED.setFont(SmallFont);myOLED.print(F("*"), 57, 18);}
  myOLED.drawLine(0, 30, 128, 30);
  if(out==1){
  long u_iz = (abs(long(u_))*10)/U_OUT_IND;
  myOLED.setFont(BigNumbers);if(u_iz/100>0){myOLED.printNumI(u_iz/100, 70, 0);}
  myOLED.printNumI(u_iz/10%10, 85, 0);
  myOLED.setFont(SmallFont);myOLED.print(F("."), 98, 18);myOLED.setFont(BigNumbers);myOLED.printNumI(u_iz%10, 104, 0);}
  else{myOLED.setFont(SmallFont);myOLED.print(F("OUT_OFF"), 75, 10);}
  // I //////////
  myOLED.setFont(BigNumbers);myOLED.printNumI(i_stab/100, 5, 35);myOLED.printNumI(i_stab/10%10, 23, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("."), 18, 53);myOLED.setFont(BigNumbers);myOLED.printNumI(i_stab%10, 38, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("A"), 57, 35);
  if(menu==1){myOLED.print(F("*"), 57, 53);}
  long i_iz = (abs(long(i_))*100)/I_OUT_K;
  if(i_iz<=5){i_iz=0;}
  myOLED.setFont(BigNumbers);myOLED.printNumI(i_iz/100, 70, 35);myOLED.printNumI(i_iz/10%10, 90, 35);
  myOLED.setFont(SmallFont);myOLED.print(F("."), 84, 53);myOLED.setFont(BigNumbers);myOLED.printNumI(i_iz%10, 105, 35);
  myOLED.update();
 if(millis()-times0>10000 && w2==1){EEPROM.update(0,u_out);EEPROM.update(1,i_stab);menu=0;w2=0;w=1;}
3
Рекомендации:
Если в режиме OUT_OFF на выходе баз нагрузки присутствует напряжение порядка 2-3 В, уменьшите сопротивление R4 (0,25-0,5 Вт) и уменьшите сопротивление R17(1,0 кОм-2,2 кОм 0,5 Вт).
Транзистор VT2 должен быть установлен на достаточно большой теплоотвод.
http://forum.rcl-radio.ru/uploads/images/2023/03/d8d289cdd2a9a9e7c266fea5b6754c76.jpg
При большом выходном токе при длительном использовании желательно применить принудительную вентиляцию
4 (2023-03-12 22:23:58 отредактировано Sergey-77)
Доброго времени суток! Эта версия БП получила персональную страницу)
Мне пришла плата LGT:  https://aliexpress.ru/item/100500423117 … 8462905418
Не получается установить драйвер для win7, драйвер беру  тут https://www.holtek.com/productdetail/-/vg/42B534-x
без него тестовый скетч загрузить не получается
Такой порт  выбрать не могу:
http://forum.rcl-radio.ru/uploads/images/2023/03/57926be80b3120b06dbc6d87efbd28b6.jpg
Несколько вопросов по вашему варианту схемы:
1) Какое минимальное значение тока стабилизации можно установить? (я в своем варианте меньше 80мА добиться не смог);
2) Присутствует ли "дребезг" напряжения на выводе: "напряжение шунта А3"?
3) КТ-837 используется потом что есть в наличии?
4) Почему решили уйти от "старого" дисплея?
5
У меня Linux, такого порта у Вас не будет.
С драйвером помочь не смогу, для Linux они не нужны
от 0
Нет, показания тока очень стабильные
Был в наличии
У меня много проектов на этом дисплее
Обратите внимание на схему которую я использую, она немного изменена и отличается от Вашей.
6
Еще вопрос, в основной статье написано: "Индикатор тока нагрузки начинает работать при токе выше 0,05 А." Я правильно понимаю, ток меньше 50 мА не отображается? Но, если допустим, выставить  ток стабилизации 20 мА, ток в нагрузке ограничится до этого значения, но на экране не отобразится?
7
Да, ток будет ограничиваться.
Ограничение связано с работой ОУ, у некоторых экземпляров, большое напряжение нуля, плюс коэффициент усиления ОУ увеличивает напряжение нуля, но если подобрать ОУ с низким напряжением нуля то можно мерить ток от 0 А.
Для снятия ограничения достаточно удалить эту строчку:
8
Увеличение сопротивления шунта частично решит проблему? Как практически подбирать ОУ по напряжению нуля?
9
Открыть монитор порта, там ток отображается без ограничений. Без нагрузки ток должен быть не более 0,02-0,01 А. Если ток больше больше, заменить LM358.
Да. Напряжение нуля ОУ будет меньше.
10
То есть, напряжение ноля каждого экземпляра ОУ индивидуально и постоянно, а почему его нельзя корректировать программно?
11
Я пробовал, получается нелинейность измерения тока. По факту, ОУ с нулем например 0,05 А, не видит ток до 0,05 А, даже если он реально есть.  Эта разница видна в результате измерения.
Так же мне попадался ОУ с идеальным нулем, но он не видел ток до 0,06 А, как только ток доходит до 0,07 на экране появлялся ток 0,01 А.
При шунте 0,1 я думаю таких проблем не будет, К_усил_ОУ = 20, напряжение нуля будет в 10 раз меньше чем у меня.
Обратите внимание на обратную связь ОУ измерителя тока, при неправильном подобранном сопротивлении напряжение на выходе ОУ может превысить 5 В, что может сжеч вход микроконтроллера.
12
liman324 пишет:
Да... бюджетные решения требуют жертв)
Да, это ценное замечание, спасибо! Ждать еще месяц платку не улыбается.
13
Кстати,  Эдди-71 реализовывал амперметр повышенной точности с шунтом 0,01 Ом и ЛМ358 https://www.eddy.com.ua/archives/377, схему я не повторял поэтому о качестве реализации судить не могу.
14
Не думаю что точность очень высокая, микроконтроллер PIC16F690 имеет АЦП 10 бит.
15
LCD1602
ОГРАНИЧЕНИЕ 1А ПОСЛЕ 20В, ДО 20В МАКСИМАЛЬНЫЙ ТОК 2А
http://rcl-radio.ru/wp-content/uploads/2023/03/%D0%A1%D0%BD%D0%B8%D0%BC%D0%BE%D0%BA-%D1%8D%D0%BA%D1%80%D0%B0%D0%BD%D0%B0-%D0%BE%D1%82-2023-03-16-17-31-30.png
#define ANALOG_I A3
#define ANALOG_U A6
#define U_OUT_K 418
int u_out,i_stab;
bool w=1,w2,out=1;
long u_iz;
  delay(200);Wire.begin();lcd.init();lcd.backlight();// Включаем подсветку дисплея
  DDRB = 1 << PB1;
  noInterrupts();
  TCCR1A=0;TCCR1B=0;
  OCR1A = 0;
  ICR1 = 10500;
  TCCR3A=0;TCCR3B=0;
  DDRF |= (1<<PF2);
  HDR = 1 << HDR3;
  OCR3B = 0;
  ICR3 = 2500;
  interrupts();
  lcd.setCursor(3, 0);lcd.print(F("Power unit"));
  lcd.setCursor(3, 1);lcd.print(F("0-25V 0-2A"));
  delay(1000);lcd.clear();
    Serial.println(OCR1A);
    w=1;}
  if(u_out>200&&i_stab>100){i_stab=100;}}
  if(w==1){w=0;
  if(out==1){
  // U /////////
  lcd.setCursor(1, 0);lcd.print(float(u_out)/10,1);lcd.print("V  ");
  if(menu==0){lcd.setCursor(0, 0);lcd.print(F("*"));}else{lcd.setCursor(0, 0);lcd.print(F(" "));}
  lcd.setCursor(7, 0);lcd.print(F("> "));
  if(out==1){
  lcd.setCursor(9, 0);lcd.print(float(u_iz)/10,1);lcd.print("V  ");}
  else{lcd.setCursor(7, 0);lcd.print(" OUT_OFF");}
  // I //////////
  lcd.setCursor(1, 1);lcd.print(float(i_stab)/100,2);lcd.print("A ");
  if(menu==1){lcd.setCursor(0, 1);lcd.print(F("*"));}else{lcd.setCursor(0, 1);lcd.print(F(" "));}
  lcd.setCursor(7, 1);lcd.print(F(">"));
  //if(i_iz<=5){i_iz=0;}
  lcd.setCursor(9, 1);lcd.print(float(i_iz)/100,2);lcd.print("A ");
http://forum.rcl-radio.ru/uploads/images/2023/03/9d87e7417bede1f8179925aba40c487f.png
http://forum.rcl-radio.ru/uploads/images/2023/03/9f25f5e01d37483423233bbcfd2461a6.png
http://forum.rcl-radio.ru/uploads/images/2023/03/2b69e9c13d7de1407897708703d919c8.png
http://forum.rcl-radio.ru/uploads/images/2023/03/98e0468b56fd246584aaa7557070c811.png
http://forum.rcl-radio.ru/uploads/images/2023/03/b917421c81b9667a93ca995f45cf5e5d.png
http://forum.rcl-radio.ru/uploads/images/2023/03/0f16c3790bbfa1c622741f33a141ef7f.png
Схема источника питания
Описание - http://rcl-radio.ru/?p=130314
http://forum.rcl-radio.ru/uploads/images/2023/03/c2a9d4cb73b8d57cfb4169ca91447966.gif
16
[Почему не магу загрузит скеча - STK 500 no synk.?
17
Один раз загрузил,второй раз не получается!
18
Опубликуйте текст ошибок название платы с микроконтроллером, и скриншот настроек платы
19
de]Arduino: 1.8.16 (Windows 10), Board: "LGT8F328, Default (64), External (assumes 32MHz crystal), 32 MHz, 328P-LQFP32 (e.g. MiniEVB nano-style or WAVGAT)"
         Using Port                    : COM12
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 5.0
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrd
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\RR\AppData\Local\Temp\arduino_build_487281/Power_Unit.ino.hex"
avrdude: writing flash (14878 bytes):
Writing |
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_cmd(): programmer is out of syncude: stk500_cmd(): programmer is out of synce: stk500_cmd(): programmer is out of sync
20
У Вас не ATmega328P, а LGT8F328, через что прошиваете микроконтроллер?
21
Да, LGT8F328,Arduino Ide 1.8
22
Вы добавили поддержку платы в ARDUINO IDE - http://rcl-radio.ru/?p=129966 ?
23
Да- на первом строке  code error написано
24
У Вас плата LGT8F328P-LQFP32 MiniEVB?
25
