Тема: atmega8_in-16
#define ADDR_DS3231 0b1101000
#define CPU_F 12000000 // Clock Speed
#define SCL_F 100000 // // I2C Speed
unsigned long times_sec,millis_time;
int i,segm,times,hh,mm;
byte a[4],an,sec,min,hour,set;
TWSR = 0;
DDRB &=~(1 << PB0);DDRD &=~(1<<PD6)|(1<<PD7);
DDRB |= (1 << PB1);// pin 15 output pwm
DDRB |= (1 << PB2);// pin 16 output second in-3
DDRC |= (1 << PC0)|(1 << PC1)|(1 << PC2)|(1 << PC3);// H0-H3 ANOD
DDRD |= (1 << PD0)|(1 << PD1)|(1 << PD2)|(1 << PD3);// 1 2 4 8 K155ID1
PORTB |= (1 << PB0);PORTD |= (1 << PD6)|(1 << PD7);
// F=12000000/512/1/1=23437.5 Hz
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
TCCR1A |= (1<<COM1A1);
TCCR1B |= (1<<WGM12);
TCCR1A |= (1<<WGM11);
TCCR1B |= (1 << CS10);
ICR1 = 511;
OCR1A = 505; // Ureg_180V
// (12000000/((233+1)x256))=200.32051282051 Hz
OCR2 = 233;
TCCR2 |= (1 << WGM21);
TCCR2 |= (1 << CS22) | (1 << CS21);
TIMSK |= (1 << OCIE2);
// set time
// set_time(21,1,12,26,8,9,0);// год 00-99, ДН 1-7 (1=ВС), месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
/// read time
sec = (i2c_read_1bit(ADDR_DS3231,0) & 0x0F) + (((i2c_read_1bit(ADDR_DS3231,0) & 0x70) >> 4) * 10);
min = (i2c_read_1bit(ADDR_DS3231,1) & 0x0F) + (((i2c_read_1bit(ADDR_DS3231,1) & 0x70) >> 4) * 10);
hour = ((i2c_read_1bit(ADDR_DS3231,2) & 0x0F) + ((i2c_read_1bit(ADDR_DS3231,2) & 0x70) >> 4) * 10);
// temper = (i2c_read_1bit(ADDR_DS3231,0x11)*100 + ((i2c_read_1bit(ADDR_DS3231,0x12) & 0b11000000) >> 6)*25) ;
/// set time
hh=hour;mm=min;
if(((PINB >> PB0) & 1) == 0){set++;if(set>2){set=0;}_delay_ms(200);}
if(set==1&&((PIND >> PD6)&1)==0){hh++;if(hh>23){hh=23;}set_time(21,1,12,26,hh,mm,0);_delay_ms(100);}
if(set==1&&((PIND >> PD7)&1)==0){hh--;if(hh<0){hh=0;}set_time(21,1,12,26,hh,mm,0);_delay_ms(100);}
if(set==2&&((PIND >> PD6)&1)==0){mm++;if(mm>59){mm=59;}set_time(21,1,12,26,hh,mm,0);_delay_ms(100);}
if(set==2&&((PIND >> PD7)&1)==0){mm--;if(mm<0){mm=0;}set_time(21,1,12,26,hh,mm,0);_delay_ms(100);}
/// output sec in-3
if(millis_time-times_sec<100){PORTB |= (1 << PB2);}
if(millis_time-times_sec>=100){PORTB &=~(1 << PB2);}
if(millis_time-times_sec>200){times_sec=millis_time;}
times = hour*100+min;
if(min == 30 && sec < 10 && set == 0){
switch(sec){
case 0: times=0;break;
case 1: times=1111;break;
case 2: times=2222;break;
case 3: times=3333;break;
case 4: times=4444;break;
case 5: times=5555;break;
case 6: times=6666;break;
case 7: times=7777;break;
case 8: times=8888;break;
case 9: times=9999;break;
a[0]=times/1000%10;
a[1]=times/100%10;
a[2]=times/10%10;
a[3]=times%10;
//_delay_ms(50);
void segment(){
switch(segm){
case 0: PORTD &= ~(1 << PD3);PORTD &=~ (1 << PD2);PORTD &= ~(1 << PD1);PORTD &= ~(1 << PD0);break; // DEC 0 = 0b0000
case 1: PORTD &= ~(1 << PD3);PORTD &=~ (1 << PD2);PORTD &= ~(1 << PD1);PORTD |=(1 << PD0); break; // DEC 1 = 0b0001
case 2: PORTD &= ~(1 << PD3);PORTD &=~ (1 << PD2);PORTD |= (1 << PD1);PORTD &= ~(1 << PD0);break; // DEC 2 = 0b0010
case 3: PORTD &= ~(1 << PD3);PORTD &=~ (1 << PD2);PORTD |= (1 << PD1);PORTD |= (1 << PD0);break; // DEC 3 = 0b0011
case 4: PORTD &= ~(1 << PD3);PORTD |= (1 << PD2);PORTD &= ~(1 << PD1);PORTD &= ~(1 << PD0);break; // DEC 4 = 0b0100
case 5: PORTD &= ~(1 << PD3);PORTD |= (1 << PD2);PORTD &= ~(1 << PD1);PORTD |= (1 << PD0);break; // DEC 5 = 0b0101
case 6: PORTD &= ~(1 << PD3);PORTD |= (1 << PD2);PORTD |= (1 << PD1);PORTD &= ~(1 << PD0);break; // DEC 6 = 0b0110
case 7: PORTD &= ~(1 << PD3);PORTD |= (1 << PD2);PORTD |= (1 << PD1);PORTD |= (1 << PD0);break; // DEC 7 = 0b0111
case 8: PORTD |= (1 << PD3);PORTD &=~ (1 << PD2);PORTD &= ~(1 << PD1);PORTD &= ~(1 << PD0);break; // DEC 8 = 0b1000
case 9: PORTD |= (1 << PD3);PORTD &=~ (1 << PD2);PORTD &= ~(1 << PD1);PORTD |= (1 << PD0);break; // DEC 9 = 0b1001
void anod(){
switch(an){
case 0: PORTC |= (1 << PC0);PORTC &= ~(1 << PC1);PORTC &= ~(1 << PC2);PORTC &= ~(1 << PC3);break;
case 1: PORTC &= ~(1 << PC0);PORTC |= (1 << PC1);PORTC &= ~(1 << PC2);PORTC &= ~(1 << PC3);break;
case 2: PORTC &= ~(1 << PC0);PORTC &= ~(1 << PC1);PORTC |= (1 << PC2);PORTC &= ~(1 << PC3);break;
case 3: PORTC &= ~(1 << PC0);PORTC &= ~(1 << PC1);PORTC &= ~(1 << PC2);PORTC |= (1 << PC3);break;
void cl(){PORTC &= ~(1 << PC0);PORTC &= ~(1 << PC1);PORTC &= ~(1 << PC2);PORTC &= ~(1 << PC3);}
ISR(TIMER2_COMP_vect){
case 0: segm=a[0]; an=0; cl(); if(set==2){_delay_ms(5);}_delay_ms(1); segment();anod();break;
case 1: segm=a[1]; an=1; cl(); if(set==2){_delay_ms(5);}_delay_ms(1); segment();anod();break;
case 2: segm=a[2]; an=2; cl(); if(set==1){_delay_ms(5);}_delay_ms(1); segment();anod();break;
case 3: segm=a[3]; an=3; cl(); if(set==1){_delay_ms(5);}_delay_ms(1); segment();anod();break;
i++;if(i>3){i=0;}
millis_time++;
int i2c_read_i2c_2bit(byte i2c_addr, byte i2c_reg){
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // START
while (!(TWCR & (1<<TWINT)));
TWDR = i2c_addr << 1;
TWDR = i2c_reg;
TWDR = (i2c_addr << 1) | 1;
TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWEA);
while(~TWCR&(1<<TWINT));
int i2c_data0 = TWDR;
int i2c_data1 = TWDR;
int i2c_data = (i2c_data0<<8)+i2c_data1;
return i2c_data;
TWDR = i2c_reg;
byte i2c_data = TWDR;
return i2c_data;
TWDR = i2c_reg;
TWDR = i2c_dat;
void i2c_write_1bit(byte i2c_addr, byte i2c_reg){
TWDR = i2c_reg;
if(second < 255){i2c_write(ADDR_DS3231,0x00,(second/10<<4)+second%10);}
if(minute < 255){i2c_write(ADDR_DS3231,0x01,(minute/10<<4)+minute%10);}
if(hours < 255){i2c_write(ADDR_DS3231,0x02,(hours/10<<4)+hours%10);}
if(days < 255){i2c_write(ADDR_DS3231,0x03,days);}
if(datas < 255){i2c_write(ADDR_DS3231,0x04,(datas/10<<4)+datas%10);}
if(monts < 255){i2c_write(ADDR_DS3231,0x05,(monts/10<<4)+monts%10);}
if(years < 255){i2c_write(ADDR_DS3231,0x06,(years/10<<4)+years%10);}
