Тема: ЧАСЫ НА VDF1602 + DS3231 + DS18B20
http://forum.rcl-radio.ru/uploads/images/2022/10/ff185312dbc731f8c7b93ded1a81ab04.gif
http://forum.rcl-radio.ru/uploads/images/2022/10/42a101a464bcb346183a37133bbee793.png
http://forum.rcl-radio.ru/uploads/images/2022/10/a5153068bfee7672ed4b28a814a290cc.png
http://forum.rcl-radio.ru/uploads/images/2022/10/f8cac1aea2cf89b70deedb19339c1119.png
http://forum.rcl-radio.ru/uploads/images/2022/10/b83cdd6b030b496060101a8c2662cd75.png
#include <DS3231.h>// http://rcl-radio.ru/wp-content/uploads/2022/08/DS3231.zip
#define ADDR    0b1101000
#define CPU_F   16000000
#define SCL_F   100000
OneWire  ds(8); // Вход датчика 18b20
unsigned long times;
int t_izm,brig_a;
int set_time,set_alarm,year,day, mont, date, hour, minut, secon;
int hh_a,mm_a;
bool alarm;
byte alarm_on;
byte hh,mm;
#define SET_ALARM  PB2
#define SET_TIME   PB1
#define SET_UP     PC0
#define SET_DW     PC1
#define BRIG       PC3
#define BUZZER     PC2
int t_kall = -20;
  PORTB |=(1<<SET_ALARM)|(1<<SET_TIME);
  PORTC |=(1<<SET_UP)|(1<<SET_DW);
  DDRC |= (1<<BUZZER);
  ADMUX |= (1<<REFS0)|(1 << MUX1) | (1 << MUX0);
  ADCSRA |= (1<<ADEN) | (1<<ADSC) | (1<<ADFR) | (1<<ADIF);
  ADCSRA |= (1<<ADPS2) | (1<<ADPS1) | (1<<ADPS0);// Division Factor 128
  PORTC |= (1 << BRIG);
  lcdInit();
  lcdWrite(0, 31, 17, 17, 17, 17, 17, 17, 0);  //П
  lcdWrite(8, 17, 17, 17, 31, 1, 1, 1, 0);     //Ч
  lcdWrite(16, 31, 16, 16, 30, 17, 17, 30, 0); //Б
  lcdWrite(24, 4, 14, 14, 14, 31, 4, 0, 0);// alarm
  TWSR = 0;
  hh_a=EEPROM_read(0);
  mm_a=EEPROM_read(1);
  alarm=EEPROM_read(2);
 // // set_tim(21,3,5,3,0,4,0);// год 00-99,ДН 1-пн 7-вс, месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
  Brightness(100);
  lcdCurs(0,1);lcdString("ALEXANDER");
  lcdCurs(1,1);lcdString("LIMAN");
  _delay_ms(2000);
  lcdClear();
  if(millis()-times>10000&&set_time==0){times=millis();while((ADCSRA & (1 << ADIF)) == 0);brig_a = (ADCL|ADCH << 8);t_izm = dsRead(0)+t_kall;}
  if(brig_a<=200){Brightness(100);}
  if(brig_a>200&&brig_a<=400){Brightness(75);}
  if(brig_a>400&&brig_a<=600){Brightness(50);}
  if(brig_a>600){Brightness(25);}
  if(((PINC >> SET_UP) & 1) == 0&&set_alarm==0&&set_time==0  && alarm_on==0){alarm=1;EEPROM_write(2,alarm);_delay_ms(200);}
  if(((PINC >> SET_DW) & 1) == 0&&set_alarm==0&&set_time==0  && alarm_on==0){alarm=0;EEPROM_write(2,alarm);_delay_ms(200);}
  if(hh_a*100+mm_a!=hh*100+mm){alarm_on=0;}
  if(hh_a*100+mm_a==hh*100+mm && alarm==1 && alarm_on==0){alarm_on=1;}
  if(hh_a*100+mm_a==hh*100+mm && alarm==1 && alarm_on==1){
    for(int b=0;b<200;b++){
    PORTC |=(1<<BUZZER);_delay_us(200);
    PORTC &=~(1<<BUZZER);_delay_us(200);
  if(((PINC >> SET_UP) & 1) == 0 && alarm_on==1){alarm_on=2;_delay_ms(200);}
  if(((PINC >> SET_DW) & 1) == 0 && alarm_on==1){alarm_on=2;_delay_ms(200);}
  if(((PINB >> SET_TIME) & 1) == 0&&set_alarm==0){set_time++;if(set_time>7){set_time=0;}lcdClear(); _delay_ms(200);}
  if(((PINB >> SET_ALARM) & 1) == 0&&set_time==0){set_alarm++;if(set_alarm>2){set_alarm=0;}lcdClear(); _delay_ms(200);}
  if(set_alarm==1){
    lcdCurs(0,0);lcdString("ALARM HOUR ");lcdChar(hh_a/10+'0');lcdChar(hh_a%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){hh_a++;if(hh_a>23){hh_a=23;}EEPROM_write(0,hh_a);_delay_ms(100);}
     if(((PINC >> SET_DW) & 1) == 0){hh_a--;if(hh_a<0){hh_a=0;}EEPROM_write(0,hh_a);_delay_ms(100);}
  if(set_alarm==2){
    lcdCurs(0,0);lcdString("ALARM MIN ");lcdChar(mm_a/10+'0');lcdChar(mm_a%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){mm_a++;if(mm_a>59){mm_a=59;}EEPROM_write(1,mm_a);_delay_ms(100);}
     if(((PINC >> SET_DW) & 1) == 0){mm_a--;if(mm_a<0){mm_a=0;}EEPROM_write(1,mm_a);_delay_ms(100);}
  byte ss =  (i2c_read(ADDR,0) & 0x0F) + (((i2c_read(ADDR,0) & 0x70) >> 4) * 10);
       mm =  (i2c_read(ADDR,1) & 0x0F) + (((i2c_read(ADDR,1) & 0x70) >> 4) * 10);
       hh = ((i2c_read(ADDR,2) & 0x0F) + ((i2c_read(ADDR,2) & 0x70) >> 4) * 10);
  byte wesk =  (i2c_read(ADDR,3) & 0x0F);
  byte dd = ((i2c_read(ADDR,4) & 0x0F) + ((i2c_read(ADDR,4) & 0x70) >> 4) * 10);
  byte mn = ((i2c_read(ADDR,5) & 0x0F) + ((i2c_read(ADDR,5) & 0x70) >> 4) * 10);
  byte yy = ((i2c_read(ADDR,6) & 0x0F) + ((i2c_read(ADDR,6) & 0x70) >> 4) * 10);
  year=yy;mont=mn;date=dd;hour=hh;minut=mm;secon=ss,day=wesk;
  if(set_time==1){
    lcdCurs(0,0);lcdString("SET HOUR  ");lcdChar(hour/10+'0');lcdChar(hour%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){hour++;if(hour>23){hour=23;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){hour--;if(hour<0){hour=0;}set_t();}
  if(set_time==2){
    lcdCurs(0,0);lcdString("SET MIN   ");lcdChar(minut/10+'0');lcdChar(minut%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){minut++;if(minut>59){minut=59;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){minut--;if(minut<0){minut=0;}set_t();}
  if(set_time==3){
    lcdCurs(0,0);lcdString("SET SEC   ");lcdChar(secon/10+'0');lcdChar(secon%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){secon=0;set_t();}
     if(((PINC >> SET_DW) & 1) == 0){secon=0;set_t();}
  if(set_time==4){
    lcdCurs(0,0);lcdString("SET DATE  ");lcdChar(date/10+'0');lcdChar(date%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){date++;if(date>31){date=31;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){date--;if(date<1){date=1;}set_t();}
  if(set_time==5){
    lcdCurs(0,0);lcdString("SET DAY OF WEEK");
    lcdCurs(1,0);
     switch(wesk){
       case 1: lcdChar(0);lcdChar(0x48);break;
       case 2: lcdChar(0x42);lcdChar(0x54);break;
       case 3: lcdChar(0x43);lcdChar(0x50);break;
       case 4: lcdChar(1);lcdChar(0x54);break;
       case 5: lcdChar(0);lcdChar(0x54);break;
       case 6: lcdChar(0x43);lcdChar(2);break;
       case 7: lcdChar(0x42);lcdChar(0x43);break;
     if(((PINC >> SET_UP) & 1) == 0){day++;if(day>7){day=7;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){day--;if(day<1){day=1;}set_t();}
  if(set_time==6){
    lcdCurs(0,0);lcdString("SET MONTH ");lcdChar(mont/10+'0');lcdChar(mont%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){mont++;if(mont>12){mont=12;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){mont--;if(mont<1){mont=1;}set_t();}
  if(set_time==7){
    lcdCurs(0,0);lcdString("SET YEAR  ");lcdChar(year/10+'0');lcdChar(year%10+'0');
     if(((PINC >> SET_UP) & 1) == 0){year++;if(year>100){year=100;}set_t();}
     if(((PINC >> SET_DW) & 1) == 0){year--;if(year<22){year=22;}set_t();}
  if(set_time==0&&set_alarm==0){
  lcdCurs(0,0);
  lcdChar(hh/10+'0');lcdChar(hh%10+'0');lcdChar(0x3A);
  lcdChar(mm/10+'0');lcdChar(mm%10+'0');lcdChar(0x3A);
  lcdChar(ss/10+'0');lcdChar(ss%10+'0');
  lcdCurs(1,0);
  lcdChar(dd/10+'0');lcdChar(dd%10+'0');lcdString("/");
  lcdChar(mn/10+'0');lcdChar(mn%10+'0');lcdString(" ");
 switch(wesk){
  lcdCurs(1,10);lcdChar(t_izm/100+'0');lcdChar(t_izm/10%10+'0');lcdChar(0x2E);lcdChar(t_izm%10+'0');lcdChar(223); lcdString("C ");
  lcdCurs(0,10);lcdChar(hh_a/10+'0');lcdChar(hh_a%10+'0');lcdString(":");lcdChar(mm_a/10+'0');lcdChar(mm_a%10+'0');
  lcdCurs(0,15);if(alarm==1){lcdChar(3);}else{lcdChar(0x20);}
  _delay_ms(100);
void set_t(){set_tim(year,day,mont,date,hour,minut,secon); _delay_ms(100);}
    if(rs==0){PORTD |= (1 << 2);} else{PORTD &= ~(1 << 2);}//RS
    del();
    if(((data >> 7) & 1) ==1){PORTD |= (1 << 7);}else{PORTD &= ~(1 << 7);}
    if(((data >> 6) & 1) ==1){PORTD |= (1 << 6);}else{PORTD &= ~(1 << 6);}
    if(((data >> 5) & 1) ==1){PORTD |= (1 << 5);}else{PORTD &= ~(1 << 5);}
    if(((data >> 4) & 1) ==1){PORTD |= (1 << 4);}else{PORTD &= ~(1 << 4);}
    e_pin();
    if(((data >> 3) & 1) ==1){PORTD |= (1 << 7);}else{PORTD &= ~(1 << 7);}
    if(((data >> 2) & 1) ==1){PORTD |= (1 << 6);}else{PORTD &= ~(1 << 6);}
    if(((data >> 1) & 1) ==1){PORTD |= (1 << 5);}else{PORTD &= ~(1 << 5);}
    if(((data >> 0) & 1) ==1){PORTD |= (1 << 4);}else{PORTD &= ~(1 << 4);}
    e_pin();
void lcdString(const char* str) {while(*str != '\0') {del();lcdChar(*str);str++;}}
void del(){_delay_ms(1);}
void e_pin(){PORTD |= (1 << 3);del();PORTD &= ~(1 << 3);}
void lcdWrite(byte addr_w, byte wr1,byte wr2,byte wr3,byte wr4,byte wr5,byte wr6,byte wr7,byte wr8){
     lcd(0b01000000|addr_w);lcdChar(wr1);lcdChar(wr2);lcdChar(wr3);lcdChar(wr4);lcdChar(wr5);lcdChar(wr6);lcdChar(wr7);lcdChar(wr8);}
void lcdInit(){
    DDRD |= (1 << 2) | (1 << 3)| (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7);
    _delay_ms(100);
    lcd(0x03);_delay_us(4500);
    lcd(0x03);_delay_us(200);
    lcd(0b00000010);del();
    lcd(0b00001100);del();
    lcdClear();
float dsRead(byte x) {
    kol++;
  int raw=(data[1]<<8)|data[0];
  float value = (float)raw / 1.60; return value; // Расчет температуры и вывод
void Brightness(byte brig){
  switch(brig){
    case 25 : lcd(0b00101011);break;
    case 50 : lcd(0b00101010);break;
    case 75 : lcd(0b00101001);break;
    case 100 : lcd(0b00101000);break;
byte i2c_read(byte i2c_addr, byte i2c_reg){
   TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);  // START
  while (!(TWCR & (1<<TWINT)));
   TWDR = i2c_addr << 1;
   TWDR = i2c_reg;
   TWDR = (i2c_addr << 1) | 1;
   byte i2c_data = TWDR;
   return i2c_data;
   TWDR = i2c_reg;
   TWDR = i2c_dat;
void set_tim(byte years, byte days, byte monts, byte datas, byte hours ,byte minute, byte second){
    i2c_write(ADDR,0x00,(second/10<<4)+second%10);
    i2c_write(ADDR,0x01,(minute/10<<4)+minute%10);
    i2c_write(ADDR,0x02,(hours/10<<4)+hours%10);
    i2c_write(ADDR,0x04,(datas/10<<4)+datas%10);
    i2c_write(ADDR,0x05,(monts/10<<4)+monts%10);
    i2c_write(ADDR,0x06,(years/10<<4)+years%10);
    i2c_write(ADDR,0x03,days);
   while(EECR & (1<<EEWE));
     EEAR = uiAddress;
     EECR |= (1<<EERE);
     return EEDR;
    EEAR = uiAddress;
    EEDR = ucData;
    EECR |= (1<<EEMWE);
    EECR |= (1<<EEWE);
