Тема: ATtiny45 ADC
Single Ended Input
Voltage Reference VCC
#define CLK  PB2 // TM1637
#define DIO  PB1 // TM1637
// PB4 INPUT
cli();
 ADMUX |= (1 << MUX1);
 ADCSRA |= (1<<ADEN)|(1 << ADATE)|(1<<ADSC)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
sei();
  long u=0;
  for(int n=0;n<10;n++){
     int u_data = (ADCL|ADCH << 8);
     u += u_data;delay(100);
     u=u/10;
     tm_print(500*u/1023,1,5);
void tm_dec(byte dig){
       for(byte i = 0; i < 8; i++) {
         DDRB |= (1 << CLK);del();
       if (dig & 0x01)
         DDRB &= ~(1 << DIO);
       else
         DDRB |= (1 << DIO);del();
         DDRB &= ~(1 << CLK);del();
         dig = dig >> 1;
         DDRB |= (1 << CLK);
         DDRB &= ~(1 << DIO);del();
       if (((PINB >> DIO) & 1) == 0)
void tm_stop(){
void tm_start(){
void tm_print(int t, bool pd_t, byte br){
        tm_start();tm_dec(0b10001000 + br);
        int data0 =10;
        int data1 = t / 100 % 10;
        int data2 = t / 10 % 10;
        int data3 = t % 10;
      for(byte n = 0; n < 4; n++){
        int data;
      switch(n){
        case 0: data = data0;break;
        case 1: data = data1;break;
        case 2: data = data2;break;
        case 3: data = data3;break;
      switch(data){    // XGFEDCBA
        case 10: data = 0b00000000;break;     // пусто
        if(n == 0){data0 = data;}
        if(n == 1){data1 = data;}
        if(n == 2){data2 = data;}
        if(n == 3){data3 = data;}
      if(pd_t==1){data1 = data1+0b10000000;}
void del(){delay(1);}
Re: ATtiny45 ADC
Single Ended Input
Voltage Reference 2.56V
// PB4 INPUT
cli();
 ADMUX |= (1 << MUX1)|(1 << REFS2)|(1 << REFS1);
sei();
  long u=0;
     u=u/10;
     tm_print(256*u/1023,1,5);
       if (dig & 0x01)
       else
         dig = dig >> 1;
         DDRB |= (1 << CLK);
void tm_stop(){
void tm_start(){
        int data0 =10;
        int data3 = t % 10;
        int data;
      switch(n){
3
Re: ATtiny45 ADC
Single Ended Input
Voltage Reference 1.10V
// PB4 INPUT
cli();
 ADMUX |= (1 << MUX1)|(1 << REFS1);
sei();
  long u=0;
     u=u/10;
     tm_print(1100*u/1023,3,5);
       if (dig & 0x01)
       else
         dig = dig >> 1;
         DDRB |= (1 << CLK);
void tm_stop(){
void tm_start(){
void tm_print(int t, byte pd_t, int br){
        int data0 = t / 1000 % 10;
        int data3 = t % 10;
        int data;
      switch(n){
        case 11: data = 0b01000000;break;     // -
      switch(pd_t){
4
Re: ATtiny45 ADC
Temperature Measurement
cli();
 ADMUX |= (1 << MUX3)|(1 << MUX2)|(1 << MUX1)|(1 << MUX0)|(1 << REFS1);
sei();
  long u=0;
     u=u/10;
     tm_print(u-25,1,5);
       if (dig & 0x01)
       else
         dig = dig >> 1;
         DDRB |= (1 << CLK);
void tm_stop(){
void tm_start(){
        int data0 = 10;
        int data3 = t % 10;
        int data;
      switch(n){
      switch(pd_t){
5
Re: ATtiny45 ADC
Differential ref 1.1V x1
input PB3 PB4
// INPUT PB3 PB4
cli();
 ADMUX |= (1 << MUX2)|(1 << MUX1)|(1 << REFS1);
 ADCSRB |= (1 << 7);
sei();
     long u=0;
     unsigned int u_data,pol;
     int k0 = 35;// kall 0
     u += u_data;
     delay(100);
   u=u/10+k0;
   if((u>>9)==1){pol=11;u = 1023-u;}
    else{pol=10;}
   tm_print(110*u/512,2,pol,5);
       if (dig & 0x01)
       else
         dig = dig >> 1;
         DDRB |= (1 << CLK);
void tm_stop(){
void tm_start(){
void tm_print(int t, byte pd_t,int polar, int br){
        int data0 = polar;
        int data3 = t % 10;
        int data;
      switch(n){
      switch(pd_t){
6
Re: ATtiny45 ADC
VBG - внутреннее опорное
// PB4 INPUT
cli();
 ADMUX |= (1 << MUX3)|(1 << MUX2)|(1 << REFS1)|(1 << REFS2);
sei();
  long u=0;
     u=u/10;
     tm_print(2560*u/1023,3,5);
       if (dig & 0x01)
       else
         dig = dig >> 1;
         DDRB |= (1 << CLK);
void tm_stop(){
void tm_start(){
        int data0 = t/1000;
        int data3 = t % 10;
        int data;
      switch(n){
      switch(pd_t){
7
Re: ATtiny45 ADC
Фунцией  analogRead(12) можно измерять примерное напряжение питания мк. Осуществляется через стабильный, но неточный источник опорного напряжения 1.1 в. Расчет напряжения U = 11*1024/analogRead(12). Произведение
11*1024 нужно корректировать из-за неточного ИОН.
