Тема: ATtiny45 timer1
CTC
DDRB |= (1 << PB0);
PORTB |= (1 << PB0);
OCR1A = 243; // 0...255 8bit
TCCR1 |= (1 << CTC1);   // CTC mode
TCCR1 |= (1 << CS13)|(1 << CS12)|(1 << CS11)|(1 << CS10);// Prescaler 16384
TIMSK |= (1 << OCIE1A);
// (8000000/((243+1)16384))=2,00115266 Hz
void loop(){}
ISR(TIM1_COMPA_vect) {
  PORTB ^= (1 << PB0);
2
Re: ATtiny45 timer1
переполнение
DDRB |= (1 << PB0);
TCCR1 |= (1 << CS12)|(1 << CS11)|(1 << CS10);// Prescaler 64
TIMSK |= (1 << TOIE1);
// 8000000/64/255 = 490,196078 Hz
void loop(){}
ISR(TIMER1_OVF_vect) {
3
Re: ATtiny45 timer1
МЕАНДР PB1
DDRB |= (1 << PB1);
PORTB |= (1 << PB1);
 TCCR1 |= (1 << COM1A0);
// 8000000/(16384*(1+243))= 2,00115266
 OCR1C = 243; // 0...255 8bit
void loop(){}
4
Re: ATtiny45 timer1
МЕАНДР PB4
DDRB |= (1 << PB4);
PORTB |= (1 << PB4);
 GTCCR |= (1 << COM1B0);
// 8000000/(16384*(1+20))= 24,4140625
 OCR1C = 20; // 0...255 8bit
void loop(){}
5
Re: ATtiny45 timer1
PWM TIMER1 PB1
DDRB |= (1 << PB1);
 TCCR1 |= (1 << CTC1)|(1 << PWM1A);   // CTC mode
 TCCR1 |= (1 << CS11)|(1 << CS10);// Prescaler 4
// 8000000/256/4= 7812,5 Hz
 OCR1A = 180; // 0...255 8bit
void loop(){}
6
Re: ATtiny45 timer1
PWM TIMER1 PB4
DDRB |= (1 << PB4);
 GTCCR |= (1 << PWM1B);
 OCR1B = 250; // 0...255 8bit
void loop(){}
