Тема: STM32_TM1637
STM32_TM1637.h
//  STM32_TM1637 v2.0
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  STM32_TM1637_H
#define  STM32_TM1637_H
#include <Arduino.h>
#define CODE0    0b10001000
#define CODE1    0x40
#define ADDR0    0xC0
class  STM32_TM1637
    public:
  STM32_TM1637(uint8_t, uint8_t);
  void print_float(float decimal, byte pd,      byte h0, byte h1, byte h2, byte h3);
  void print_time(int t, byte pd_t);
  void brig(byte br);
    private:
  void dec(byte dig);
  void stop();
  void start();
  void del();
  byte qwer;
  uint8_t DIO;
  uint8_t CLK;
#endif
STM32_TM1637.cpp
#include <STM32_TM1637.h>
STM32_TM1637::STM32_TM1637(uint8_t clk, uint8_t dio){
         CLK = clk;
         DIO = dio;
void STM32_TM1637::brig(byte br){
     qwer = br + CODE0;
void STM32_TM1637::del(){delayMicroseconds(100);}
void STM32_TM1637::dec(byte dig){
         for(int i = 0; i < 8; i++) {
           pinMode(CLK, OUTPUT);del();
         if (dig & 0x01)
           pinMode(DIO, INPUT);
         else
           pinMode(DIO, OUTPUT);del();
           pinMode(CLK, INPUT);del();
           dig = dig >> 1;
           pinMode(DIO, INPUT);del();
           uint8_t ack = digitalRead(DIO);
         if (ack == 0)
void STM32_TM1637::stop(){
void STM32_TM1637::start(){
void STM32_TM1637::print_float(float decimal, byte pd,    byte h0, byte h1, byte h2, byte h3){
        start();dec(qwer);stop();start();dec(CODE1);stop();start();
        byte minus;
        int mn;
        switch(pd){
          case 0: mn = 1;break;
          case 1: mn = 10;break;
          case 2: mn = 100;break;
          case 3: mn = 1000;break;
        if(decimal<0){decimal = abs(decimal); minus = 1;}else{minus = 0;}
        //if(decimal/1000>=1){pd = 0;}
        if(decimal/100>=1&&decimal/100<10){decimal = round(decimal*mn);}
        if(decimal/10>=1&&decimal/10<10){decimal = round(decimal*mn);}
        if(decimal>=0&&decimal<10){decimal = round(decimal*mn);}
        int data0 = (int)decimal/1000;
        int data1 = (int)decimal/100%10;
        int data2 = (int)decimal/10%10;
        int data3 = (int)decimal%10;
        for(int n=0;n<4;n++){
        int data;
        if(n==0){data=data0;}
        if(n==1){data=data1;}
        if(n==2){data=data2;}
        if(n==3){data=data3;}
        switch(data){  // XGFEDCBA
        case 0:  data = 0b00111111;break;     // 0
        case 1:  data = 0b00000110;break;     // 1
        case 2:  data = 0b01011011;break;     // 2
        case 3:  data = 0b01001111;break;     // 3
        case 4:  data = 0b01100110;break;     // 4
        case 5:  data = 0b01101101;break;     // 5
        case 6:  data = 0b01111101;break;     // 6
        case 7:  data = 0b00000111;break;     // 7
        case 8:  data = 0b01111111;break;     // 8
        case 9:  data = 0b01101111;break;     // 9
        if(n==0){data0=data;}
        if(n==1){data1=data;}
        if(n==2){data2=data;}
        if(n==3){data3=data;}
        if(minus==0){
        if(pd==3&&decimal<1000){data0 = 0b00111111;}
        if(pd==2&&decimal<100){data0 = 0b00000000;data1 = 0b00111111;}
        if(pd==2&&decimal<1000){data0 = 0b00000000;}
        if(pd==0&&decimal<10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b00000000;}
        if(pd==0&&decimal<100){data0 = 0b00000000;data1 = 0b00000000;}
        if(pd==0&&decimal<1000){data0 = 0b00000000;}
        if(pd==1&&decimal<1000){data0 = 0b00000000;}
        if(pd==1&&decimal<100){data0 = 0b00000000;data1 = 0b00000000;}
        if(pd==1&&decimal<10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b00111111;}
        if(decimal>9999){data0 = 0b01000000;data1 = 0b01000000;data2 = 0b01000000;data3 = 0b01000000;}
        if(minus==1){
        if(pd==0&&decimal<10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b01000000;}
        if(pd==0&&decimal<100&&decimal>9){data0 = 0b00000000;data1 = 0b01000000;}
        if(pd==0&&decimal<1000&&decimal>99){data0 = 0b01000000;}
        if(pd==1&&decimal<100){data0 = 0b00000000;data1 = 0b01000000;}
        if(pd==1&&decimal<1000&&decimal>=100){data0 = 0b01000000;}
        if(pd==2&&decimal<1000){data0 = 0b01000000;}
        if(decimal>1000){data0 = 0b01000000;data1 = 0b01000000;data2 = 0b01000000;data3 = 0b01000000;}
        switch(pd){
        case 1 : data2 = data2+0b10000000;break;
        case 2 : data1 = data1+0b10000000;break;
        case 3 : data0 = data0+0b10000000;break;
        if(h0>0){data0 = h0;}
        if(h1>0){data1 = h1;}
        if(h2>0){data2 = h2;}
        if(h3>0){data3 = h3;}
        dec(ADDR0);dec(data0);dec(data1);dec(data2);dec(data3);stop();
void STM32_TM1637::print_time(int t, byte pd_t){
        int data0 = t/1000;
        int data1 = t/100%10;
        int data2 = t/10%10;
        int data3 = t%10;
        int data;
        if(pd_t==1){data1=data1+0b10000000;}
test.ino
STM32_TM1637 tm(PB0,PB1);// CLK, DIO
float h=0.1;
byte p=1;
  tm.brig(7); // ЯРКОСТЬ 0...7
   tm.print_float(h,p,  0,0,0,0);
   delay(500);
  tm.print_float(h,p,  h0,h1,h2,h3);
  float h = -999...9999 | 0.000...0.999 | -9.99...99.99 | -99.9...999.9
  byte p = 0...3 - число знаков после запятой
      A
  F |   | B
     -G-
  E |   | C
      D
 h0 h1 h2 h3
   XGFEDCBA (X - запятая)
 0b00000000
time.ino
#include <STM32_TM1637.h> // http://forum.rcl-radio.ru/misc.php?action=pan_download&item=403&download=1
#include <uRTCLib.h>//https://github.com/Naguissa/uRTCLib.git
   uRTCLib rtc(0x68);
   // PB7 = SDA DS1307 (DS3231)
   // PB6 = SCL DS1307 (DS3231)
   // PB0 = CLK TM1637
   // PB1 = DIO TM1637
float h;
int i;
  // rtc.set(30, 37, 23, 2, 17, 12, 19);
  // RTCLib::set(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year)
   rtc.refresh();// опрос времни
   h = rtc.hour()*100 + rtc.minute();
   tm.print_time(h, 0);
   delay(500);
   tm.print_time(h, 1);
   delay(500);
i++;
if(i==10){i=0;tm.print_float(rtc.temp()/100,0 ,0b1111000,0,0,0);delay(2000);}// вывод температуры DS3231
