Тема: BD37543FS.h
BD37543FS.h
#ifndef BD37543FS_H
#define BD37543FS_H
#define BD37543FS_address 0b1000000
#define SETUP_1 0x01
#define SETUP_2 0x02
#define SETUP_3 0x03
#define INPUT_SELECT 0x05
#define INPUT_GAIN 0x06
#define VOLUME_GAIN 0x20
#define FADER_1_FRONT 0x28
#define FADER_2_FRONT 0x29
#define FADER_1_REAR 0x2A
#define FADER_2_REAR 0x2B
#define FADER_SUB 0x2C
#define MIXING 0x30
#define BASS_SETUP 0x41
#define MIDDLE_SETUP 0x44
#define TREBLE_SETUP 0x47
#define BASS_GAIN 0x51
#define MIDDLE_GAIN 0x54
#define TREBLE_GAIN 0x57
#define LOUDNESS_GAIN 0x75
#include <Arduino.h>
class BD37543FS
public:
BD37543FS();
void setSetup_1(int sw_time_mute, int sw_time, int sw_on_off);
// default (0,2,1) | int 0...3, 0...3, 0...1
void setSetup_2(int sub_f, int sub_out, int level_metr, int lpf_faza);
void setSetup_3(int f_r_hpf, int r_hpf, int f_hpf);
// int f_r_hpf ---- 55Hz 85Hz 120Hz 160Hz = int 0...3
// int r_hpf ------ pass NOT_pass = int 0...1
// int f_hpf ------ pass NOT_pass = int 0...1
void setIn(int in);
// 0...10 | in A B C = int 0 1 2
void setIn_gain(int in_gain, int mute);
// in_gain -- 0...20 = 0...20 dB, mute -- 0 default
void setVol(int vol);
// -79...+15 dB = int -79...15
void setFront_1(int front_1);
void setFront_2(int front_2);
void setRear_1(int rear_1);
void setRear_2(int rear_2);
void setSub(int sub);
void setMix(int mix_gain);
// -79...+7 dB = int -79...7
void setBass_setup(int bass_q, int bass_f);
// 0.5 1.0 1.5 2.0 --- int 0...3, 60Hz 80Hz 100Hz 120Hz --- int 0...3
void setMiddle_setup(int mid_q, int mid_f);
// 0.75 1.0 1.25 1.5 --- int 0...3, 500Hz 1kHz 1.5kHz 2.5kHz --- int 0...3
void setTreble_setup(int treb_q, int treb_f);
// 0.75 1.25 --- int 0...1, 7.5kHz 10kHz 12.5kHz 15kHz --- int 0...3
void setBass_gain(int bass_gain);
// --20 ... +20 dB = int -20 ... 20
void setMiddle_gain(int mid_gain);
void setTreble_gain(int treb_gain);
void setLoudness_gain(int loud_hicut, int loud_gain);
// Hicut1 Hicut2 Hicut3 Hicut4 = int 0...3
// 0 ... 20 dB = int 0 ... 20
private:
#endif //BD37543FS_H
BD37543FS.cpp
#include "BD37543FS.h"
BD37543FS::BD37543FS(){
void BD37543FS::setSetup_1(int sw_time_mute, int sw_time, int sw_on_off){
switch(sw_time){
case 0: sw_time = 0b00000000;break;
case 1: sw_time = 0b00010000;break;
case 2: sw_time = 0b00100000;break;
case 3: sw_time = 0b00110000;break;
switch(sw_on_off){
case 0: sw_on_off = 0b00000000;break;
case 1: sw_on_off = 0b10000000;break;
writeWire(SETUP_1, 0b00000100 + sw_time_mute + sw_time + sw_on_off);
void BD37543FS::setSetup_2(int sub_f, int sub_out, int level_metr, int lpf_faza){
switch(sub_out){
case 0: sub_out = 0b00000000;break;
case 1: sub_out = 0b00010000;break;
case 2: sub_out = 0b00100000;break;
case 3: sub_out = 0b00110000;break;
switch(level_metr){
case 0: level_metr = 0b00000000;break;
case 1: level_metr = 0b01000000;break;
switch(lpf_faza){
case 0: lpf_faza = 0b00000000;break;
case 1: lpf_faza = 0b10000000;break;
writeWire(SETUP_2, sub_f + sub_out + level_metr + lpf_faza);
void BD37543FS::setSetup_3(int f_r_hpf, int r_hpf, int f_hpf){
switch(f_r_hpf){
case 0: f_r_hpf = 0b00000000;break;
case 1: f_r_hpf = 0b00001000;break;
case 2: f_r_hpf = 0b00110000;break;
case 3: f_r_hpf = 0b00010000;break;
switch(r_hpf){
case 0: r_hpf = 0b00000000;break;
case 1: r_hpf = 0b01000000;break;
switch(f_hpf){
case 1: r_hpf = 0b10000000;break;
writeWire(SETUP_3, 0b00000010 + f_r_hpf + r_hpf + f_hpf);
void BD37543FS::setIn(int in){
switch(in){
case 0: in = 0b00000000;break;
case 1: in = 0b00000001;break;
case 2: in = 0b00000010;break;
case 3: in = 0b00000011;break;
case 4: in = 0b00001010;break;
case 5: in = 0b00001011;break;
case 6: in = 0b00001111;break;
case 7: in = 0b00010000;break;
case 8: in = 0b00000110;break;
case 9: in = 0b00001000;break;
case 10: in = 0b00001001;break;
writeWire(INPUT_SELECT, in);
void BD37543FS::setIn_gain(int in_gain, int mute){
switch(mute){
case 0: mute = 0b00000000;break;
case 1: mute = 0b10000000;break;
writeWire(INPUT_GAIN, in_gain + mute);
void BD37543FS::setVol(int vol){
if(vol > 0){vol = 128 - vol;}
if(vol <= 0){vol = abs(vol) + 128;}
writeWire(VOLUME_GAIN, vol);
void BD37543FS::setFront_1(int front_1){
if(front_1 > 0){front_1 = 128 - front_1;}
if(front_1 <= 0){front_1 = abs(front_1) + 128;}
writeWire(FADER_1_FRONT, front_1);
void BD37543FS::setFront_2(int front_2){
if(front_2 > 0){front_2 = 128 - front_2;}
if(front_2 <= 0){front_2 = abs(front_2) + 128;}
writeWire(FADER_2_FRONT, front_2);
void BD37543FS::setRear_1(int rear_1){
if(rear_1 > 0){rear_1 = 128 - rear_1;}
if(rear_1 <= 0){rear_1 = abs(rear_1) + 128;}
writeWire(FADER_1_REAR, rear_1);
void BD37543FS::setRear_2(int rear_2){
if(rear_2 > 0){rear_2 = 128 - rear_2;}
if(rear_2 <= 0){rear_2 = abs(rear_2) + 128;}
writeWire(FADER_2_REAR, rear_2);
void BD37543FS::setSub(int sub){
if(sub > 0){sub = 128 - sub;}
if(sub <= 0){sub = abs(sub) + 128;}
writeWire(FADER_SUB, sub);
void BD37543FS::setMix(int mix_gain){
if(mix_gain > 0){mix_gain = 128 - mix_gain;}
if(mix_gain <= 0){mix_gain = abs(mix_gain) + 128;}
writeWire(MIXING, mix_gain);
void BD37543FS::setBass_setup(int bass_q, int bass_f){
switch(bass_f){
case 0: bass_f = 0b00000000;break;
case 1: bass_f = 0b00010000;break;
case 2: bass_f = 0b00100000;break;
case 3: bass_f = 0b00110000;break;
writeWire(BASS_SETUP, bass_q + bass_f);
void BD37543FS::setMiddle_setup(int mid_q, int mid_f){
switch(mid_f){
case 0: mid_f = 0b00000000;break;
case 1: mid_f = 0b00010000;break;
case 2: mid_f = 0b00100000;break;
case 3: mid_f = 0b00110000;break;
writeWire(MIDDLE_SETUP, mid_q + mid_f);
void BD37543FS::setTreble_setup(int treb_q, int treb_f){
switch(treb_f){
case 0: treb_f = 0b00000000;break;
case 1: treb_f = 0b00010000;break;
case 2: treb_f = 0b00100000;break;
case 3: treb_f = 0b00110000;break;
writeWire(TREBLE_SETUP, treb_q + treb_f);
void BD37543FS::setBass_gain(int bass_gain){
if(bass_gain>0){bass_gain = bass_gain;}
if(bass_gain<=0){bass_gain = abs(bass_gain) + 0b10000000;}
writeWire(BASS_GAIN, bass_gain);
void BD37543FS::setMiddle_gain(int mid_gain){
if(mid_gain>0){mid_gain = mid_gain;}
if(mid_gain<=0){mid_gain = abs(mid_gain) + 0b10000000;}
writeWire(MIDDLE_GAIN, mid_gain);
void BD37543FS::setTreble_gain(int treb_gain){
if(treb_gain>0){treb_gain = treb_gain;}
if(treb_gain<=0){treb_gain = abs(treb_gain) + 0b10000000;}
writeWire(TREBLE_GAIN, treb_gain);
void BD37543FS::setLoudness_gain(int loud_hicut, int loud_gain){
switch(loud_hicut){
case 0: loud_hicut = 0b00000000;break;
case 1: loud_hicut = 0b00100000;break;
case 2: loud_hicut = 0b01000000;break;
case 3: loud_hicut = 0b01100000;break;
writeWire(LOUDNESS_GAIN, loud_hicut + loud_gain);
void BD37543FS::writeWire(char a, char b){
Wire.beginTransmission(BD37543FS_address);
Wire.write (a);
Wire.write (b);
Wire.endTransmission();
test.ino
#include <BD37543FS.h>
BD37543FS bd;
void loop(){}
bd.setSetup_1(0,2,1);
bd.setSetup_2(0,0,0,0);
bd.setSetup_3(0,0,0);
bd.setIn(0);
bd.setIn_gain(0,0);
bd.setVol(0);
bd.setFront_1(0);
bd.setFront_2(0);
bd.setRear_1(0);
bd.setRear_2(0);
bd.setSub(0);
bd.setMix(-79);
bd.setBass_setup(0, 0);
bd.setMiddle_setup(0,0);
bd.setTreble_setup(0,0);
bd.setBass_gain(0);
bd.setMiddle_gain(0);
bd.setTreble_gain(0);
bd.setLoudness_gain(0,0);
