Тема: TDA7317
TDA7317.h
// liman324@yandex.ru rcl-radio.ru
#ifndef TDA7317_H
#define TDA7317_H
#define TDA7317_address 0x43 // 18 вывод ADDR не замкнут на землю
#include <Arduino.h>
class TDA7317
public:
TDA7317();
void setVolume(int vol); // 0...47
void setBand(int band, int db); // 0...4 (1...5 полоса) , -7...+7 (-14...+14 дБ)
private:
void writeWire(char a);
#endif //TDA7317_HTDA7317.cpp
#include "TDA7317.h"
TDA7317::TDA7317(){
void TDA7317::setVolume(int vol){
vol = 47 - vol;
writeWire(vol);
void TDA7317::setBand(int band, int db){
switch(band){
case 0: band = 0b10000000; break;
case 1: band = 0b10010000; break;
case 2: band = 0b10100000; break;
case 3: band = 0b10110000; break;
case 4: band = 0b11000000; break;
switch(db){
case -0: db = 0b00001000; break;
case -1: db = 0b00001001; break;
case -2: db = 0b00001010; break;
case -3: db = 0b00001011; break;
case -4: db = 0b00001100; break;
case -5: db = 0b00001101; break;
case -6: db = 0b00001110; break;
case -7: db = 0b00001111; break;
case 1: db = 0b00000001; break;
case 2: db = 0b00000010; break;
case 3: db = 0b00000011; break;
case 4: db = 0b00000100; break;
case 5: db = 0b00000101; break;
case 6: db = 0b00000110; break;
case 7: db = 0b00000111; break;
int ekv = band + db;
writeWire(ekv);
void TDA7317::writeWire(char a){
Wire.beginTransmission(TDA7317_address);
Wire.write (a);
Wire.endTransmission();
}TDA7317.ino
#include <TDA7317.h>
TDA7317 tda;
void loop(){}
tda.setVolume(35); // громкость 0...47
/////////// номер полосы, дБ (-7...+7) //////////
tda.setBand(0,0); // 10000 Hz
tda.setBand(1,0); // 260 Hz
tda.setBand(2,0); // 1000 Hz
tda.setBand(3,0); // 3000 Hz
tda.setBand(4,0); // 60 Hz
