Тема: TDA7419
TDA7419.h
// Александр Лиман
// liman324@yandex.ru
// Пример использования - http://rcl-radio.ru/?p=57658
#ifndef TDA7419_H
#define TDA7419_H
// address 7 bit
#define TDA7419_address 0x44 // адрес HEX 88 > 0b10001000 > 7 bit = 0b1000100 = 0x44
//Sub addresses
#define TDA7419_INPUT 0b01000000 // Main Source Selector
#define TDA7419_LOUDNESS 0b01000001 // Main Loudness
#define TDA7419_SOFT 0b01000010 // Soft Mute / Clock Generator
#define TDA7419_VOLUME 0b01000011 // Volume
#define TDA7419_TREBLE 0b01000100 // Treble
#define TDA7419_MIDDLE 0b01000101 // Middle
#define TDA7419_BASS 0b01000110 // Bass
#define TDA7419_INPUT2 0b01000111 // Second Source Selector
#define TDA7419_SUB_M_B 0b01001000 // Subwoofer / Middle / Bass
#define TDA7419_MIX_G_EFF 0b01001001 // Mixing / Gain / Effect
#define TDA7419_ATT_LF 0b01001010 // Speaker Attenuator Left Front
#define TDA7419_ATT_RF 0b01001011 // Speaker Attenuator Right Front
#define TDA7419_ATT_LT 0b01001100 // Speaker Attenuator Left Rear
#define TDA7419_ATT_RT 0b01001101 // Speaker Attenuator Right Rear
#define TDA7419_MIX_LEV 0b01001110 // Mixing Level Control
#define TDA7419_ATT_SUB 0b01001111 // Subwoofer Attenuator
#define TDA7419_SPECTRUM 0b01010000 // Spectrum Analyzer / Clock Source / AC Mode
#include <Arduino.h>
class TDA7419
public:
TDA7419();
/// Main Source Selector ///
void setInput(int input, int gain, int auto_z); // int (Source Selector, Input Gain, Auto Zero)
//Source Selector: 0...5 (QD/SE: QD, SE1, SE2, SE3, QD/SE: SE, mute)
//Input Gain: 0...15 (0...+15 dB)
//Auto Zero: 0...1 (on, off)
/// Main Loudness ///
void setAtt_loudness(int loud_att, int center_f, int h_boost, int loud_step); // (Attenuation, Center Frequency, High Boost, Loudness Soft Step)
//Attenuation: 0...15 (0...-15 dB)
//Center Frequency: 0...3 (Flat, 400 Hz, 800 Hz, 2400 Hz)
//High Boost: 0...1 (on, off)
//Loudness Soft Step: 0...1 (on, off)
/// Soft Mute / Clock Generator ///
void setSoft(int s_mute, int pin, int s_m_time, int s_time, int clock); // (Soft Mute, Pin Influence for Mute, Soft Mute Time, Soft Step Time, Clock Fast Mode)
//Soft Mute: 0...1 (on, off)
//Pin Influence for Mute: 0...1 (Pin and IIC, IIC)
//Soft Mute Time: 0...2 (0.48ms, 0.96ms, 123ms)
//Soft Step Time: 0...7 (0.160ms, 0.321ms, 0.642ms, 1.28ms, 2.26ms, 5.12ms, 10.24ms, 20.48ms)
//Clock Fast Mode: 0...1 (on, off)
/// Volume (Gain/Attenuation, Soft Step) ///
void setVolume(int volume, int soft0); // Volume
void setAtt_LF(int left_f, int soft1); // Volume LF
void setAtt_RF(int right_f, int soft2); // Volume RF
void setAtt_LT(int left_t, int soft3); // Volume LT
void setAtt_RT(int right_t, int soft4); // Volume RT
void setAtt_SUB(int subwoofer, int soft5); // Volume SUBWOOFER
void setAtt_Mix(int mixing, int soft6); // Volume MIXING
//Gain/Attenuation: 0...80 (80...0) 0 - mute
//Soft Step: 0...1 (on, off)
/// Filter ///
void setFilter_Treble(int treble_g, int treble_c, int treble_ref);
// (-15...15, 0...3, 0...1) (-15 dB....15 dB, 10kHz 12.5kHz 15 kHz 17.5 kHz , Vref = 4V Vref = 3.3V )
//(Gain/Attenuation, Treble Center Frequency, Reference Output Select)
void setFilter_Middle(int middle_g, int middle_q, int middle_s );
// (-15...15, 0...3, 0...1) (-15 dB....15 dB, 0.5 0.75 1 1.25, on off)
// (Gain/Attenuation, Middle Q Factor, Middle Soft Step)
void setFilter_Bass(int bass_g, int bass_q, int bass_s);
//Gain/Attenuation: -15...15 db (int -15...15)
//Bass Q Factor: 1.0 1.25 1.5 2.0 (int 0...3)
// Bass Soft Step: on/off (int 0...1)
/// Second Source Selector ///
void setInput2(int input2, int gain2, int auto_z2); // int (Source Selector, Input Gain, Auto Zero)
/// Subwoofer /Middle / Bass ///
void setSub_M_B(int sub, int mid, int bas, int bas_d, int s_filter); // (0...3, 0...3, 0...1, 0...1)
// (int sub) Subwoofer Cut-off Frequency: flat, 80Hz, 120Hz, 160Hz
// (int mid) Middle Center Frequency: 500Hz, 1000Hz, 1500Hz, 2500Hz
// (int bas) Bass Center Frequency: 60Hz, 80Hz, 100Hz, 200Hz
// (int bas_d) Bass DC Mode: on, off
// (int s_filter) Smoothing Filter: on, off (bypass)
void setMix_Gain_Eff(int mix_l, int mix_r, int mix_en, int sub_en, int gain_eff); //(on/off, on/off, on/off, on/off, 0...10 = 0...22 dB)
void setSpektor(int spek_q, int spek_res, int spek_an_s, int spek_an_r, int spek_reset, int spek_cl, int spek_mode);
// on/off, on/off, on/off, on/off, on/off, on/off, 0...3
private:
#endif //TDA7419_HTDA7419.cpp
#include "TDA7419.h"
TDA7419::TDA7419(){
void TDA7419::setInput(int input, int gain, int auto_z){
switch (input) {
case 0: input = 0b00000000;break;
case 1: input = 0b00000001;break;
case 2: input = 0b00000010;break;
case 3: input = 0b00000011;break;
case 4: input = 0b00000100;break;
case 5: input = 0b00000101;break;
switch (gain) {
case 0: gain = 0b00000000;break;
case 1: gain = 0b00001000;break;
case 2: gain = 0b00010000;break;
case 3: gain = 0b00011000;break;
case 4: gain = 0b00100000;break;
case 5: gain = 0b00101000;break;
case 6: gain = 0b00110000;break;
case 7: gain = 0b00111000;break;
case 8: gain = 0b01000000;break;
case 9: gain = 0b01001000;break;
case 10: gain = 0b01010000;break;
case 11: gain = 0b01011000;break;
case 12: gain = 0b01100000;break;
case 13: gain = 0b01101000;break;
case 14: gain = 0b01110000;break;
case 15: gain = 0b01111000;break;
switch (auto_z) {
case 0: auto_z = 0b00000000;break;
case 1: auto_z = 0b10000000;break;
int selector = input + gain + auto_z;
writeWire(TDA7419_INPUT, selector);
void TDA7419::setAtt_loudness(int loud_att, int center_f, int h_boost, int loud_step){
switch (loud_att) {
case 0: loud_att = 0b00000000;break;
case 1: loud_att = 0b00000001;break;
case 2: loud_att = 0b00000010;break;
case 3: loud_att = 0b00000011;break;
case 4: loud_att = 0b00000100;break;
case 5: loud_att = 0b00000101;break;
case 6: loud_att = 0b00000110;break;
case 7: loud_att = 0b00000111;break;
case 8: loud_att = 0b00001000;break;
case 9: loud_att = 0b00001001;break;
case 10: loud_att = 0b00001010;break;
case 11: loud_att = 0b00001011;break;
case 12: loud_att = 0b00001100;break;
case 13: loud_att = 0b00001101;break;
case 14: loud_att = 0b00001110;break;
case 15: loud_att = 0b00001111;break;
switch (center_f) {
case 0: center_f = 0b00000000;break;
case 1: center_f = 0b00010000;break;
case 2: center_f = 0b00100000;break;
case 3: center_f = 0b00110000;break;
switch (h_boost) {
case 0: h_boost = 0b00000000;break;
case 1: h_boost = 0b01000000;break;
switch (loud_step) {
case 0: loud_step = 0b00000000;break;
case 1: loud_step = 0b10000000;break;
int main_loudness = loud_att + center_f + h_boost + loud_step;
writeWire(TDA7419_LOUDNESS, main_loudness);
void TDA7419::setSoft(int s_mute, int pin, int s_m_time, int s_time, int clock){
switch (s_mute) {
case 0: s_mute = 0b00000000;break;
case 1: s_mute = 0b00000001;break;
switch (pin) {
case 0: pin = 0b00000000;break;
case 1: pin = 0b00000010;break;
switch (s_m_time) {
case 0: s_m_time = 0b00000000;break;
case 1: s_m_time = 0b00000100;break;
case 2: s_m_time = 0b00001000;break;
switch (s_time) {
case 0: s_time = 0b00000000;break;
case 1: s_time = 0b00010000;break;
case 2: s_time = 0b00100000;break;
case 3: s_time = 0b00110000;break;
case 4: s_time = 0b01000000;break;
case 5: s_time = 0b01010000;break;
case 6: s_time = 0b01100000;break;
case 7: s_time = 0b01110000;break;
switch (clock) {
case 0: clock = 0b00000000;break;
case 1: clock = 0b10000000;break;
int soft_mute_gen = s_mute + pin + s_m_time + s_time + clock;
writeWire(TDA7419_SOFT, soft_mute_gen);
void TDA7419::setVolume(int volume, int soft0){
if(volume >= 0){} // 0 ... +15 dB
if(volume < 0){volume = abs(volume) + 16;} //-79 ... 0 dB
switch (soft0) {
case 0: soft0 = 0b00000000;break;
case 1: soft0 = 0b10000000;break;
writeWire(TDA7419_VOLUME, volume + soft0);
void TDA7419::setAtt_LF(int left_f, int soft1){
left_f = 95 - left_f;
switch (soft1) {
case 0: soft1 = 0b00000000;break;
case 1: soft1 = 0b10000000;break;
writeWire(TDA7419_ATT_LF, left_f + soft1);
void TDA7419::setAtt_RF(int right_f, int soft2){
right_f = 95 - right_f;
switch (soft2) {
case 0: soft2 = 0b00000000;break;
case 1: soft2 = 0b10000000;break;
writeWire(TDA7419_ATT_RF, right_f + soft2);
void TDA7419::setAtt_LT(int left_t, int soft3){
left_t = 95 - left_t;
switch (soft3) {
case 0: soft3 = 0b00000000;break;
case 1: soft3 = 0b10000000;break;
writeWire(TDA7419_ATT_LT, left_t + soft3);
void TDA7419::setAtt_RT(int right_t, int soft4){
right_t = 95 - right_t;
switch (soft4) {
case 0: soft4 = 0b00000000;break;
case 1: soft4 = 0b10000000;break;
writeWire(TDA7419_ATT_RT, right_t + soft4);
void TDA7419::setAtt_SUB(int subwoofer, int soft5){
subwoofer = 95 - subwoofer;
switch (soft5) {
case 0: soft5 = 0b00000000;break;
case 1: soft5 = 0b10000000;break;
writeWire(TDA7419_ATT_SUB, subwoofer + soft5);
void TDA7419::setAtt_Mix(int mixing, int soft6){
mixing = 95 - mixing;
switch (soft6) {
case 0: soft6 = 0b00000000;break;
case 1: soft6 = 0b10000000;break;
writeWire(TDA7419_MIX_LEV, mixing + soft6);
void TDA7419::setFilter_Treble(int treble_g, int treble_c, int treble_ref) {
switch (treble_g) {
case -1: treble_g = 0b00000001;break;
case -2: treble_g = 0b00000010;break;
case -3: treble_g = 0b00000011;break;
case -4: treble_g = 0b00000100;break;
case -5: treble_g = 0b00000101;break;
case -6: treble_g = 0b00000110;break;
case -7: treble_g = 0b00000111;break;
case -8: treble_g = 0b00001000;break;
case -9: treble_g = 0b00001001;break;
case -10: treble_g = 0b00001010;break;
case -11: treble_g = 0b00001011;break;
case -12: treble_g = 0b00001100;break;
case -13: treble_g = 0b00001101;break;
case -14: treble_g = 0b00001110;break;
case -15: treble_g = 0b00001111;break;
case 0: treble_g = 0b00000000;break;
case 1: treble_g = 0b00010001;break;
case 2: treble_g = 0b00010010;break;
case 3: treble_g = 0b00010011;break;
case 4: treble_g = 0b00010100;break;
case 5: treble_g = 0b00010101;break;
case 6: treble_g = 0b00010110;break;
case 7: treble_g = 0b00010111;break;
case 8: treble_g = 0b00011000;break;
case 9: treble_g = 0b00011001;break;
case 10: treble_g = 0b00011010;break;
case 11: treble_g = 0b00011011;break;
case 12: treble_g = 0b00011100;break;
case 13: treble_g = 0b00011101;break;
case 14: treble_g = 0b00011110;break;
case 15: treble_g = 0b00011111;break;
switch (treble_c) {
case 0: treble_c = 0b00000000;break;
case 1: treble_c = 0b00100000;break;
case 2: treble_c = 0b01000000;break;
case 3: treble_c = 0b01100000;break;
switch (treble_ref) {
case 0: treble_ref = 0b00000000;break;
case 1: treble_ref = 0b10000000;break;
int treble_sum = treble_g + treble_c + treble_ref;
writeWire(TDA7419_TREBLE, treble_sum);
void TDA7419::setFilter_Middle(int middle_g, int middle_q, int middle_s) {
switch (middle_g) {
case -1: middle_g = 0b00000001;break;
case -2: middle_g = 0b00000010;break;
case -3: middle_g = 0b00000011;break;
case -4: middle_g = 0b00000100;break;
case -5: middle_g = 0b00000101;break;
case -6: middle_g = 0b00000110;break;
case -7: middle_g = 0b00000111;break;
case -8: middle_g = 0b00001000;break;
case -9: middle_g = 0b00001001;break;
case -10: middle_g = 0b00001010;break;
case -11: middle_g = 0b00001011;break;
case -12: middle_g = 0b00001100;break;
case -13: middle_g = 0b00001101;break;
case -14: middle_g = 0b00001110;break;
case -15: middle_g = 0b00001111;break;
case 0: middle_g = 0b00000000;break;
case 1: middle_g = 0b00010001;break;
case 2: middle_g = 0b00010010;break;
case 3: middle_g = 0b00010011;break;
case 4: middle_g = 0b00010100;break;
case 5: middle_g = 0b00010101;break;
case 6: middle_g = 0b00010110;break;
case 7: middle_g = 0b00010111;break;
case 8: middle_g = 0b00011000;break;
case 9: middle_g = 0b00011001;break;
case 10: middle_g = 0b00011010;break;
case 11: middle_g = 0b00011011;break;
case 12: middle_g = 0b00011100;break;
case 13: middle_g = 0b00011101;break;
case 14: middle_g = 0b00011110;break;
case 15: middle_g = 0b00011111;break;
switch (middle_q) {
case 0: middle_q = 0b00000000;break;
case 1: middle_q = 0b00100000;break;
case 2: middle_q = 0b01000000;break;
case 3: middle_q = 0b01100000;break;
switch (middle_s) {
case 0: middle_s = 0b00000000;break;
case 1: middle_s = 0b10000000;break;
int middle_sum = middle_g + middle_s + middle_s;
writeWire(TDA7419_MIDDLE , middle_sum);
void TDA7419::setFilter_Bass(int bass_g, int bass_q, int bass_s) {
switch (bass_g) {
case -1: bass_g = 0b00000001;break;
case -2: bass_g = 0b00000010;break;
case -3: bass_g = 0b00000011;break;
case -4: bass_g = 0b00000100;break;
case -5: bass_g = 0b00000101;break;
case -6: bass_g = 0b00000110;break;
case -7: bass_g = 0b00000111;break;
case -8: bass_g = 0b00001000;break;
case -9: bass_g = 0b00001001;break;
case -10: bass_g = 0b00001010;break;
case -11: bass_g = 0b00001011;break;
case -12: bass_g = 0b00001100;break;
case -13: bass_g = 0b00001101;break;
case -14: bass_g = 0b00001110;break;
case -15: bass_g = 0b00001111;break;
case 0: bass_g = 0b00000000;break;
case 1: bass_g = 0b00010001;break;
case 2: bass_g = 0b00010010;break;
case 3: bass_g = 0b00010011;break;
case 4: bass_g = 0b00010100;break;
case 5: bass_g = 0b00010101;break;
case 6: bass_g = 0b00010110;break;
case 7: bass_g = 0b00010111;break;
case 8: bass_g = 0b00011000;break;
case 9: bass_g = 0b00011001;break;
case 10: bass_g = 0b00011010;break;
case 11: bass_g = 0b00011011;break;
case 12: bass_g = 0b00011100;break;
case 13: bass_g = 0b00011101;break;
case 14: bass_g = 0b00011110;break;
case 15: bass_g = 0b00011111;break;
switch (bass_q) {
case 0: bass_q = 0b00000000;break;
case 1: bass_q = 0b00100000;break;
case 2: bass_q = 0b01000000;break;
case 3: bass_q = 0b01100000;break;
switch (bass_s) {
case 0: bass_s = 0b00000000;break;
case 1: bass_s = 0b10000000;break;
int bass_sum = bass_g + bass_s + bass_s;
writeWire(TDA7419_BASS , bass_sum);
void TDA7419::setInput2(int input2, int gain2, int auto_z2){
switch (input2) {
case 0: input2 = 0b00000000;break;
case 1: input2 = 0b00000001;break;
case 2: input2 = 0b00000010;break;
case 3: input2 = 0b00000011;break;
case 4: input2 = 0b00000100;break;
case 5: input2 = 0b00000101;break;
switch (gain2) {
case 0: gain2 = 0b00000000;break;
case 1: gain2 = 0b00001000;break;
case 2: gain2 = 0b00010000;break;
case 3: gain2 = 0b00011000;break;
case 4: gain2 = 0b00100000;break;
case 5: gain2 = 0b00101000;break;
case 6: gain2 = 0b00110000;break;
case 7: gain2 = 0b00111000;break;
case 8: gain2 = 0b01000000;break;
case 9: gain2 = 0b01001000;break;
case 10: gain2 = 0b01010000;break;
case 11: gain2 = 0b01011000;break;
case 12: gain2 = 0b01100000;break;
case 13: gain2 = 0b01101000;break;
case 14: gain2 = 0b01110000;break;
case 15: gain2 = 0b01111000;break;
switch (auto_z2) {
case 0: auto_z2 = 0b00000000;break;
case 1: auto_z2 = 0b10000000;break;
int selector2 = input2 + gain2 + auto_z2;
writeWire(TDA7419_INPUT2, selector2);
void TDA7419::setSub_M_B(int sub, int mid, int bas, int bas_d, int s_filter){
switch (sub) {
case 0: sub = 0b00000000;break;//flat
case 1: sub = 0b00000001;break;//80 Hz
case 2: sub = 0b00000010;break;//120 Hz
case 3: sub = 0b00000011;break;//160 Hz
switch (mid) {
case 0: mid = 0b00000000;break;//500 Hz
case 1: mid = 0b00000100;break;//1000 Hz
case 2: mid = 0b00001000;break;//1500 Hz
case 3: mid = 0b00001100;break;//2500 Hz
switch (bas) {
case 0: bas = 0b00000000;break;//60 Hz
case 1: bas = 0b00010000;break;//80 Hz
case 2: bas = 0b00100000;break;//100 Hz
case 3: bas = 0b01100000;break;//200 Hz
switch (bas_d) {
case 0: bas_d = 0b00000000;break;//bass dc on
case 1: bas_d = 0b01000000;break;//bass dc off
switch (s_filter) {
int smb = sub + mid + bas + bas_d + s_filter;
writeWire(TDA7419_SUB_M_B, smb);
void TDA7419::setMix_Gain_Eff(int mix_l, int mix_r, int mix_en, int sub_en, int gain_eff){
switch (mix_l) {
case 0: mix_l = 0b00000000;break;
case 1: mix_l = 0b00000001;break;
switch (mix_r) {
case 0: mix_r = 0b00000000;break;
case 1: mix_r = 0b00000010;break;
switch (mix_en) {
case 0: mix_en = 0b00000000;break;
case 1: mix_en = 0b00000100;break;
switch (sub_en) {
case 0: sub_en = 0b00000000;break;
case 1: sub_en = 0b00001000;break;
switch (gain_eff) {
case 0: gain_eff = 0b11000000;break;
case 1: gain_eff = 0b00000000;break;
case 2: gain_eff = 0b00010000;break;
case 3: gain_eff = 0b00100000;break;
case 4: gain_eff = 0b00110000;break;
case 5: gain_eff = 0b01000000;break;
case 6: gain_eff = 0b01010000;break;
case 7: gain_eff = 0b01100000;break;
case 8: gain_eff = 0b01110000;break;
case 9: gain_eff = 0b10000000;break;
case 10: gain_eff = 0b10010000;break;
int mix_sum = mix_l + mix_r + mix_en + sub_en + gain_eff;
writeWire(TDA7419_MIX_G_EFF, mix_sum);
void TDA7419::setSpektor(int spek_q, int spek_res, int spek_an_s, int spek_an_r, int spek_reset, int spek_cl, int spek_mode){
switch (spek_q) {
case 0: spek_q = 0b00000000;break;
case 1: spek_q = 0b00000001;break;
switch (spek_res) {
case 0: spek_res = 0b00000000;break;
case 1: spek_res = 0b00000010;break;
switch (spek_an_s) {
case 0: spek_an_s = 0b00000000;break;
case 1: spek_an_s = 0b00000100;break;
switch (spek_an_r) {
case 0: spek_an_r = 0b00000000;break;
case 1: spek_an_r = 0b00001000;break;
switch (spek_reset) {
case 0: spek_reset = 0b00000000;break;
case 1: spek_reset = 0b00010000;break;
switch (spek_cl) {
case 0: spek_cl = 0b00000000;break;
case 1: spek_cl = 0b00100000;break;
switch (spek_mode) {
case 0: spek_mode = 0b00000000;break;
case 1: spek_mode = 0b01000000;break;
case 2: spek_mode = 0b10000000;break;
case 3: spek_mode = 0b11000000;break;
int spek_sum = spek_q + spek_res + spek_an_s + spek_an_r + spek_reset + spek_cl + spek_mode;
writeWire(TDA7419_SPECTRUM, spek_sum);
void TDA7419::writeWire(char a, char b){
Wire.beginTransmission(TDA7419_address);
Wire.write (a);
Wire.write (b);
Wire.endTransmission();
