Тема: TDA7449
TDA7449.h
//VS Supply voltage 6 9 10.2 V
//VCL Max input signal handling 2 VRMS
//THD Total harmonic distortion V = 0.1 Vrms f = 1 kHz 0.01 0.1 %
//S/N Signal-to-noise ratio Vout = 1 Vrms (mode = OFF) 106 dB
//SC Channel separation f = 1 KHz 90 dB
//Input gain (2 dB step) 0 30 dB
//Volume control (1 dB step) -47 0 dB
//Treble control (2 dB step) -14 14 dB
//Bass control (2 dB step) -14 14 dB
//Balance control 1 dB step -79 0 dB
//Mute attenuation 100 dB
// TDA7449 | rcl-radio.ru | liman324@yandex.ru | Автор: Лиман А.А.
// Пример использования - http://rcl-radio.ru/?p=56015
#ifndef TDA7449_H
#define TDA7449_H
// address 7 bit
#define TDA7449_address 0x44 // адрес HEX 88 > 0b10001000 > 7 bit = 0b1000100 = 0x44
//Sub addresses
#define TDA7449_INP_SEL 0b00000000
#define TDA7449_INP_GAIN 0b00000001
#define TDA7449_VOLUME 0b00000010
#define TDA7449_BASS 0b00000100
#define TDA7449_TREBLE 0b00000101
#define TDA7449_ATT_RIGHT 0b00000110
#define TDA7449_ATT_LEFT 0b00000111
#include <Arduino.h>
class TDA7449
public:
TDA7449();
void setInput(int input); // int 1...2 //// номер входа
void inputGain(int gain); // int 0...15 (шаг 2дБ) 0...30 дБ //// усиление
void setVolume(int volume); // int 0...47 (шаг 1 дБ) -47...0 дБ //// громкость
void setBass(int bass); // int -7...+7 (шаг 2 дБ) -14...14 дБ //// тембр НЧ
void setTreble(int treble); // int -7...+7 (шаг 2 дБ) -14...14 дБ //// тембр ВЧ
/////////////////////// для регулировки баланса до -79 дБ /////////////////////////////////
void setAttL(int att_l); // int 0...72 (шаг 1дБ) -72...0 дБ
void setAttR(int att_r); // int 0...72 (шаг 1дБ) -72...0 дБ
private:
#endif //TDA7449_HTDA7449.cpp
#include "TDA7449.h"
TDA7449::TDA7449(){
void TDA7449::setVolume(int volume){
volume = 47 - volume;
writeWire(TDA7449_VOLUME, volume);
void TDA7449::setBass(int bass){
switch (bass){
case -7:bass = 0;break;
case -6:bass = 1;break;
case -5:bass = 2;break;
case -4:bass = 3;break;
case -3:bass = 4;break;
case -2:bass = 5;break;
case -1:bass = 6;break;
case 0 :bass = 15;break;
case 1 :bass = 14;break;
case 2 :bass = 13;break;
case 3 :bass = 12;break;
case 4 :bass = 11;break;
case 5 :bass = 10;break;
case 6 :bass = 9;break;
case 7 :bass = 8;break;}
writeWire(TDA7449_BASS, bass);
void TDA7449::setTreble(int treble){
switch (treble){
case -7:treble = 0;break;
case -6:treble = 1;break;
case -5:treble = 2;break;
case -4:treble = 3;break;
case -3:treble = 4;break;
case -2:treble = 5;break;
case -1:treble = 6;break;
case 0 :treble = 15;break;
case 1 :treble = 14;break;
case 2 :treble = 13;break;
case 3 :treble = 12;break;
case 4 :treble = 11;break;
case 5 :treble = 10;break;
case 6 :treble = 9;break;
case 7 :treble = 8;break;}
writeWire(TDA7449_TREBLE, treble);
void TDA7449::setInput(int input){
switch (input) {
case 1: input = 0x02;break;
case 2: input = 0x03;break;}
writeWire(TDA7449_INP_SEL,input);
void TDA7449::inputGain(int gain){
writeWire(TDA7449_INP_GAIN, gain);
void TDA7449::setAttR(int att_r){
writeWire(TDA7449_ATT_RIGHT, att_r);
void TDA7449::setAttL(int att_l){
writeWire(TDA7449_ATT_LEFT, att_l);
void TDA7449::writeWire(char a, char b){
Wire.beginTransmission(TDA7449_address);
Wire.write (a);
Wire.write (b);
Wire.endTransmission();
}tda7449.ino
#include <TDA7449.h>
TDA7449 tda;
delay(1000);
tda.setInput(1); // int 1...2 //// номер входа
tda.inputGain(0); // int 0...15 (шаг 2дБ) 0...30 дБ //// усиление
tda.setVolume(30); // int 0...47 (шаг 1 дБ) -47...0 дБ //// громкость
tda.setBass(0); // int -7...+7 (шаг 2 дБ) -14...14 дБ //// тембр НЧ
tda.setTreble(0); // int -7...+7 (шаг 2 дБ) -14...14 дБ //// тембр ВЧ
tda.setAttL(10); // int 0...72 (шаг 1дБ) -72...0 дБ
tda.setAttR(10); // int 0...72 (шаг 1дБ) -72...0 дБ
}Библиотека по работе с микросхемой TDA7449 из среды Arduino Пример использования http://rcl-radio.ru/?p=56015
