#include <si4703.h>
 si4703 radio(3,2,4,5); // SDIO, SCLK, SEN, RST
 LiquidCrystal_I2C lcd(0x27,20,4);
 byte d1,d2,d3,d4,d5,d6,e1,e2,e3;
 int a[6],x;
 bool w=1,save_ch,w1;
 int canel,vol;
 unsigned long times,times1;
 byte t;
 char  old[8];
 char * print_rds;
  //Serial.begin(9600);
  radio.init();
  pinMode(7,INPUT_PULLUP);// button up
  pinMode(8,INPUT_PULLUP);// button down
  pinMode(9,INPUT_PULLUP);// button volume UP
  pinMode(10,INPUT_PULLUP);// button volume DOWN
  canel = ((EEPROM.read(400)<<8))|EEPROM.read(401);vol=EEPROM.read(402);
  if(canel>320){canel=0;}if(vol>15){vol=10;}
  Serial.print("Device ID: ");Serial.println(radio.read_device_id(),HEX);
  Serial.print("Chip ID: ");Serial.println(radio.read_chip_id(),HEX);
  radio.si_volume(vol);
//////// BUTTON /////////////////////////////////////////////////
 if(digitalRead(7)==LOW){radio.seek_up();save_ch=1;times=millis();delay(100);}
 if(digitalRead(8)==LOW){radio.seek_down();save_ch=1;times=millis();delay(100);}
 if(digitalRead(9)==LOW){vol++;save_ch=1;times=millis();if(vol>15){vol=15;}radio.si_volume(vol);delay(100);}
 if(digitalRead(10)==LOW){vol--;save_ch=1;times=millis();if(vol<0){vol=0;}radio.si_volume(vol);delay(100);}
/////// EEPROM //////////////////////////////////////////////////
 if(millis()-times>60000&&save_ch==1){save_ch=0;canel = radio.nom_ch();
 EEPROM.update(400,(canel>>8) & 0b11);EEPROM.update(401,canel & 0xFF);EEPROM.update(402,vol);}
/////// LCD STEREO/MONO SIGNAL VOLUME /////////////////////////////////////////////////
 if(w==1){w=0;radio.fm_start(canel);}
 if(millis()-times1>1000){times1=millis();lcd.setCursor(13,2);lcd.print("SIG ");lcd.print(radio.rss());lcd.print(" ");
 if(radio.st_mn()==0){lcd.setCursor(13,1);lcd.print("MONO  ");}
  else{lcd.setCursor(13,1);lcd.print("STEREO");}}
  lcd.setCursor(13,0);lcd.print("VOL ");lcd.print(vol);lcd.print(" ");
  lcd.setCursor(2,2);lcd.print("FM RADIO");
////// LCD PRINT RDS ST_NAME ///////////////////////////////////////////////
if(radio.seach()==1 && radio.rss()>30){print_rds = radio.readRDS();}
  if(t==0){for(int i=0;i<8;i++){old[i]=print_rds[i];}}t++;
  if(radio.seach()==0){
  for(int i=0;i<8;i++){print_rds[i]=61;}t=0;lcd.setCursor(6,3);lcd.print(" No RDS ");}
  byte d=0;for(int i=0;i<8;i++){if(old[i]==print_rds[i]){}else{d++;}}
  if(d==0 && t==5){t=0;
  for(int i=0;i<8;i++){lcd.setCursor(6+i,3);lcd.print(print_rds[i]);}}
  if(t>8){t=0;}
  lcd.setCursor(0,3);lcd.print("======");
  lcd.setCursor(14,3);lcd.print("======");
///////// LCD BIG ///////////////////////////////////////////////
 int f_ch = radio.nom_ch() + 760;
     a[0]=f_ch/1000;
     a[1]=f_ch/100%10;
     a[2]=f_ch/10%10;
     a[3]=f_ch%10;
     if(f_ch<1000){a[0]=10;}
   for(x=0;x<4;x++){
    switch(x){
        case 0: e1=0;e2=0,e3=1;break;
        case 1: e1=2,e2=3,e3=4;break;
        case 2: e1=5,e2=6,e3=7;break;
        case 3: e1=9,e2=10,e3=11;break;
   }digit();}
   lcd.setCursor(8,1);lcd.print(".");
delay(1);
}// loop
void digit(){switch(a[x]){
case 8: d1=1,d2=4,d3=6,d4=1,d5=3,d6=6;break;case 9: d1=1,d2=4,d3=6,d4=7,d5=3,d6=6;break;
case 10:d1=150,d2=150,d3=150,d4=150,d5=150,d6=150;break;}
if(x>0){lcd.setCursor(e1,0);lcd.write((uint8_t)d1);}
lcd.setCursor(e2,0);lcd.write((uint8_t)d2);lcd.setCursor(e3,0);lcd.write((uint8_t)d3);
