Тема: Часы на адресной ленте WS2812 (Разработка)
forum.rcl-radio.ru → Законченные проекты → Часы на адресной ленте WS2812 (Разработка)
Тест распайки
// Atmega328, Atmega8 16MHz
#include <avr/io.h>
#include <util/delay.h>
#define L_BIT PORTB &= ~(1<<PB0)
#define H_BIT PORTB |= (1<<PB0)
#define LED_MAX 88
#define BRIG 2 // яркость 2...255
byte rr[LED_MAX],gg[LED_MAX],bb[LED_MAX],r,g,b;
int i;
int main(void){
DDRB |= (1<<PB0); // INPUT WS2812B (D8 - ARDUINO)
while(1){
////////// RGB ////////////////////////////////////////////////
case 0: ws(0,1);ws(3,1);ws(6,1);ws(9,0);ws(12,1);ws(15,1);ws(18,1);break;
case 1: ws(0,0);ws(3,0);ws(6,1);ws(9,0);ws(12,0);ws(15,0);ws(18,1);break;
case 2: ws(0,0);ws(3,1);ws(6,1);ws(9,1);ws(12,1);ws(15,1);ws(18,0);break;
case 3: ws(0,0);ws(3,1);ws(6,1);ws(9,1);ws(12,0);ws(15,1);ws(18,1);break;
case 4: ws(0,1);ws(3,0);ws(6,1);ws(9,1);ws(12,0);ws(15,0);ws(18,1);break;
case 5: ws(0,1);ws(3,1);ws(6,0);ws(9,1);ws(12,0);ws(15,1);ws(18,1);break;
case 6: ws(0,1);ws(3,1);ws(6,0);ws(9,1);ws(12,1);ws(15,1);ws(18,1);break;
case 7: ws(0,0);ws(3,1);ws(6,1);ws(9,0);ws(12,0);ws(15,0);ws(18,1);break;
case 8: ws(0,1);ws(3,1);ws(6,1);ws(9,1);ws(12,1);ws(15,1);ws(18,1);break;
case 9: ws(0,1);ws(3,1);ws(6,1);ws(9,1);ws(12,0);ws(15,1);ws(18,1);break;
i++;
if(i>9){i=0;}
led_rgb();res();
_delay_ms(1000);
for(int i1=0;i1<LED_MAX;i1++){data_led(i1, 1,1,1);}led_rgb();res();
_delay_ms(1000);
}} // end loop
void ws(int ind, bool datt){
if(datt==1){data_led(ind, BRIG, BRIG, BRIG);data_led(ind+1, BRIG, BRIG, BRIG);data_led(ind+2, BRIG, BRIG, BRIG);}
if(datt==0){data_led(ind, 0, 0, 0);data_led(ind+1, 0, 0, 0);data_led(ind+2, 0, 0, 0);}
void bit_0(){H_BIT;asm("nop");asm("nop"); L_BIT;asm("nop");asm("nop");asm("nop"); asm("nop");}
void bit_1(){H_BIT;asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop"); L_BIT;}
void res(){_delay_us(100);}
void data_led(int num, byte rrr, byte ggg, byte bbb){
bb[num]=bbb;rr[num]=rrr;gg[num]=ggg;
void led_rgb(){
for(int num_i=0;num_i<LED_MAX;num_i++){
bit_w((bb[num_i] & 0x80)>>7);
bit_w((bb[num_i] & 0x40)>>6);
bit_w((bb[num_i] & 0x20)>>5);
bit_w((bb[num_i] & 0x10)>>4);
bit_w((bb[num_i] & 0x08)>>3);
bit_w((bb[num_i] & 0x04)>>2);
bit_w((bb[num_i] & 0x02)>>1);
bit_w((bb[num_i] & 0x01)>>0);
bit_w((rr[num_i] & 0x80)>>7);
bit_w((rr[num_i] & 0x40)>>6);
bit_w((rr[num_i] & 0x20)>>5);
bit_w((rr[num_i] & 0x10)>>4);
bit_w((rr[num_i] & 0x08)>>3);
bit_w((rr[num_i] & 0x04)>>2);
bit_w((rr[num_i] & 0x02)>>1);
bit_w((rr[num_i] & 0x01)>>0);
bit_w((gg[num_i] & 0x80)>>7);
bit_w((gg[num_i] & 0x40)>>6);
bit_w((gg[num_i] & 0x20)>>5);
bit_w((gg[num_i] & 0x10)>>4);
bit_w((gg[num_i] & 0x08)>>3);
bit_w((gg[num_i] & 0x04)>>2);
bit_w((gg[num_i] & 0x02)>>1);
bit_w((gg[num_i] & 0x01)>>0);
Тест 2
Счет от 0 до 9999
#include <avr/io.h>
#define LED_MAX 88
#define BRIG 1 // яркость 2...255
int i;
int main(void){
while(1){
switch(i/1000){
switch(i/100%10){
case 0: ws(21,1);ws(24,1);ws(27,1);ws(30,0);ws(33,1);ws(36,1);ws(39,1);break;
case 1: ws(21,0);ws(24,0);ws(27,1);ws(30,0);ws(33,0);ws(36,0);ws(39,1);break;
case 2: ws(21,0);ws(24,1);ws(27,1);ws(30,1);ws(33,1);ws(36,1);ws(39,0);break;
case 3: ws(21,0);ws(24,1);ws(27,1);ws(30,1);ws(33,0);ws(36,1);ws(39,1);break;
case 4: ws(21,1);ws(24,0);ws(27,1);ws(30,1);ws(33,0);ws(36,0);ws(39,1);break;
case 5: ws(21,1);ws(24,1);ws(27,0);ws(30,1);ws(33,0);ws(36,1);ws(39,1);break;
case 6: ws(21,1);ws(24,1);ws(27,0);ws(30,1);ws(33,1);ws(36,1);ws(39,1);break;
case 7: ws(21,0);ws(24,1);ws(27,1);ws(30,0);ws(33,0);ws(36,0);ws(39,1);break;
case 8: ws(21,1);ws(24,1);ws(27,1);ws(30,1);ws(33,1);ws(36,1);ws(39,1);break;
case 9: ws(21,1);ws(24,1);ws(27,1);ws(30,1);ws(33,0);ws(37,1);ws(39,1);break;
data_led(42, BRIG, BRIG, BRIG);data_led(43, BRIG, BRIG, BRIG);
data_led(44, BRIG, BRIG, BRIG);data_led(45, BRIG, BRIG, BRIG);
switch(i/10%10){
case 0: ws(46,1);ws(49,1);ws(52,1);ws(55,0);ws(58,1);ws(61,1);ws(64,1);break;
case 1: ws(46,0);ws(49,0);ws(52,1);ws(55,0);ws(58,0);ws(61,0);ws(64,1);break;
case 2: ws(46,0);ws(49,1);ws(52,1);ws(55,1);ws(58,1);ws(61,1);ws(64,0);break;
case 3: ws(46,0);ws(49,1);ws(52,1);ws(55,1);ws(58,0);ws(61,1);ws(64,1);break;
case 4: ws(46,1);ws(49,0);ws(52,1);ws(55,1);ws(58,0);ws(61,0);ws(64,1);break;
case 5: ws(46,1);ws(49,1);ws(52,0);ws(55,1);ws(58,0);ws(61,1);ws(64,1);break;
case 6: ws(46,1);ws(49,1);ws(52,0);ws(55,1);ws(58,1);ws(61,1);ws(64,1);break;
case 7: ws(46,0);ws(49,1);ws(52,1);ws(55,0);ws(58,0);ws(61,0);ws(64,1);break;
case 8: ws(46,1);ws(49,1);ws(52,1);ws(55,1);ws(58,1);ws(61,1);ws(64,1);break;
case 9: ws(46,1);ws(49,1);ws(52,1);ws(55,1);ws(58,0);ws(61,1);ws(64,1);break;
switch(i%10){
case 0: ws(67,1);ws(70,1);ws(73,1);ws(76,0);ws(79,1);ws(82,1);ws(85,1);break;
case 1: ws(67,0);ws(70,0);ws(73,1);ws(76,0);ws(79,0);ws(82,0);ws(85,1);break;
case 2: ws(67,0);ws(70,1);ws(73,1);ws(76,1);ws(79,1);ws(82,1);ws(85,0);break;
case 3: ws(67,0);ws(70,1);ws(73,1);ws(76,1);ws(79,0);ws(82,1);ws(85,1);break;
case 4: ws(67,1);ws(70,0);ws(73,1);ws(76,1);ws(79,0);ws(82,0);ws(85,1);break;
case 5: ws(67,1);ws(70,1);ws(73,0);ws(76,1);ws(79,0);ws(82,1);ws(85,1);break;
case 6: ws(67,1);ws(70,1);ws(73,0);ws(76,1);ws(79,1);ws(82,1);ws(85,1);break;
case 7: ws(67,0);ws(70,1);ws(73,1);ws(76,0);ws(79,0);ws(82,0);ws(85,1);break;
case 8: ws(67,1);ws(70,1);ws(73,1);ws(76,1);ws(79,1);ws(82,1);ws(85,1);break;
case 9: ws(67,1);ws(70,1);ws(73,1);ws(76,1);ws(79,0);ws(82,1);ws(85,1);break;
i++;
if(i>9999){i=0;}
led_rgb();res();
_delay_ms(1000);
}} // end loop
void data_led(int num, byte rrr, byte ggg, byte bbb){bb[num]=bbb;rr[num]=rrr;gg[num]=ggg;}
void led_rgb(){
Запуск часов DS3231
#include <avr/io.h>
#define ADDR_DS3231 0b1101000
#define CPU_F 16000000 // Clock Speed
#define SCL_F 100000 // // I2C Speed
#define LED_MAX 88
int i;
byte sec,min,hour,datat,mont,year,day;
int main(void){
TWSR = 0;
DDRD &= ~(1<<PD2);// INPUT SQW DS3231
_delay_ms(100);
i2c_write(ADDR_DS3231,0x0E,0b00000000);
//set_time(21,1,12,26,12,12,0);// год 00-99, ДН 1-7 (1=ВС), месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
while(1){
sec = (i2c_read_1bit(ADDR_DS3231,0) & 0x0F) + (((i2c_read_1bit(ADDR_DS3231,0) & 0x70) >> 4) * 10);
min = (i2c_read_1bit(ADDR_DS3231,1) & 0x0F) + (((i2c_read_1bit(ADDR_DS3231,1) & 0x70) >> 4) * 10);
hour = ((i2c_read_1bit(ADDR_DS3231,2) & 0x0F) + ((i2c_read_1bit(ADDR_DS3231,2) & 0x70) >> 4) * 10);
// day = (i2c_read_1bit(ADDR_DS3231,3) & 0x0F);
// datat = ((i2c_read_1bit(ADDR_DS3231,4) & 0x0F) + ((i2c_read_1bit(ADDR_DS3231,4) & 0x70) >> 4) * 10);
// mont = ((i2c_read_1bit(ADDR_DS3231,5) & 0x0F) + ((i2c_read_1bit(ADDR_DS3231,5) & 0x70) >> 4) * 10);
// year = ((i2c_read_1bit(ADDR_DS3231,6) & 0x0F) + ((i2c_read_1bit(ADDR_DS3231,6) & 0x70) >> 4) * 10);
// temper = (i2c_read_1bit(ADDR_DS3231,0x11)*100 + ((i2c_read_1bit(ADDR_DS3231,0x12) & 0b11000000) >> 6)*25) ;
i = hour*100+min;
switch(i/1000){
switch(i/100%10){
if(((PIND >> PD2) & 1) == 0){data_led(42, BRIG, BRIG, BRIG);data_led(43, BRIG, BRIG, BRIG);data_led(44, BRIG, BRIG, BRIG);data_led(45, BRIG, BRIG, BRIG);}
else{data_led(42, 0, 0, 0);data_led(43, 0, 0, 0);data_led(44, 0, 0, 0);data_led(45, 0, 0, 0);}
switch(i/10%10){
switch(i%10){
i++;
if(i>9999){i=0;}
led_rgb();res();
_delay_ms(100);
}} // end loop
void led_rgb(){
if(second < 255){i2c_write(ADDR_DS3231,0x00,(second/10<<4)+second%10);}
if(minute < 255){i2c_write(ADDR_DS3231,0x01,(minute/10<<4)+minute%10);}
if(hours < 255){i2c_write(ADDR_DS3231,0x02,(hours/10<<4)+hours%10);}
if(days < 255){i2c_write(ADDR_DS3231,0x03,days);}
if(datas < 255){i2c_write(ADDR_DS3231,0x04,(datas/10<<4)+datas%10);}
if(monts < 255){i2c_write(ADDR_DS3231,0x05,(monts/10<<4)+monts%10);}
if(years < 255){i2c_write(ADDR_DS3231,0x06,(years/10<<4)+years%10);}
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // START
while (!(TWCR & (1<<TWINT)));
TWDR = i2c_addr << 1;
TWDR = i2c_reg;
TWDR = (i2c_addr << 1) | 1;
while(~TWCR&(1<<TWINT));
byte i2c_data = TWDR;
return i2c_data;
TWDR = i2c_reg;
TWDR = i2c_dat;
Схема часов
Финальный скетч
#include <avr/io.h>
#define LED_MAX 88
int i,up,down,brig=1,hh,mm;
byte r_led=0,g_led=1,b_led=0;
byte mode;
bool sett,w,w1;
unsigned long times,times0;
int main(void){
TWSR = 0;
DDRD &= ~(1<<PD3);// INPUT BUTTON MODE
DDRD &= ~(1<<PD4);// INPUT BUTTON UP
DDRD &= ~(1<<PD5);// INPUT BUTTON DOWN
DDRD &= ~(1<<PD6);// INPUT BUTTON SET
PORTD |= (1<<PD3);PORTD |= (1<<PD4);PORTD |= (1<<PD5);PORTD |= (1<<PD6);
DDRD &= ~(1<<PD2);// BUTTON (D2 - ARDUINO)
PORTD |=(1<<PD2); // INPUT_PULLUP
/// TIMER 0 = 1ms
ADCSRA = 0b10000100;
TCCR0A = 0;TCCR0B = 0;TCNT0 = 0;
OCR0A = 249;
TCCR0A |= (1 << WGM01);
TCCR0B |= (1 << CS01) | (1 << CS00);
TIMSK0 |= (1 << OCIE0A);
_delay_ms(100);
if(EEPROM_read(100)!=0){for(int i1=0;i1<101;i1++){EEPROM_write(i1,0);}}// очистка памяти при первом включении
mode = EEPROM_read(0);brig = EEPROM_read(1);
while(1){
/////// BUTTON ///////////////////////////////////////////////
if(((PIND >> PD3) & 1) == 0){mode++;if(mode>7){mode=0;}_delay_ms(300);w=1;times0=times;}
switch(mode){
case 0: r_led=1,g_led=1,b_led=1; break;
case 1: r_led=1,g_led=0,b_led=0; break;
case 2: r_led=0,g_led=1,b_led=0; break;
case 3: r_led=0,g_led=0,b_led=1; break;
case 4: r_led=1,g_led=1,b_led=0; break;
case 5: r_led=1,g_led=0,b_led=1; break;
case 6: r_led=0,g_led=1,b_led=1; break;
case 7: r_led=0,g_led=0,b_led=0; break;
if(((PIND >> PD4) & 1) == 0 && sett==0){brig++;if(brig>255){brig=255;}_delay_ms(1);w=1;times0=times;}
if(((PIND >> PD5) & 1) == 0 && sett==0){brig--;if(brig<1){brig=1;}_delay_ms(1);w=1;times0=times;}
if(((PIND >> PD6) & 1) == 0 && sett==0){sett=1;_delay_ms(300);}
if(((PIND >> PD6) & 1) == 0 && sett==1){sett=0;_delay_ms(300);}
/////// READ TIME ////////////////////////////////////////////
i = hour*100+min;
//////////// SET TIME //////////////////////////////////////////////////////////////////////
if(sett==1){
hh=hour;
mm=min;
if(((PIND >> PD4) & 1) == 0){hh++;if(hh>23){hh=0;}_delay_ms(100);w1=1;}
if(((PIND >> PD5) & 1) == 0){mm++;if(mm>59){mm=1;}_delay_ms(100);w1=1;}
if(w1==1){w1=0;set_time(21,1,12,26,hh,mm,0);}
i = hh*100+mm;
switch(i/1000){
switch(i/100%10){
if(((PIND >> PD2) & 1) == 0 && sett==0){data_led(42, r_led*brig, g_led*brig, b_led*brig);data_led(43, r_led*brig, g_led*brig, b_led*brig);
data_led(44, r_led*brig, g_led*brig, b_led*brig);data_led(45, r_led*brig, g_led*brig, b_led*brig);}
if(sett==1){data_led(42, 0, brig, 0);data_led(43, brig, 0, 0);data_led(44, 0, brig, 0);data_led(45, brig, 0, 0);}
switch(i/10%10){
switch(i%10){
led_rgb();res();
_delay_ms(100);
////// EEPROM ///////////////////
if(times-times0>10000&&w==1){EEPROM_write(0,mode);EEPROM_write(1,brig);w=0;}
}} // end loop
if(datt==1){data_led(ind, r_led*brig, g_led*brig, b_led*brig);data_led(ind+1, r_led*brig, g_led*brig, b_led*brig);data_led(ind+2, r_led*brig, g_led*brig, b_led*brig);}
if(datt==0){data_led(ind, 0, 0, 0);data_led(ind+1, 0, 0, 0);data_led(ind+2, 0, 0, 0);}}
void led_rgb(){
TWDR = i2c_reg;
return i2c_data;
TWDR = i2c_reg;
TWDR = i2c_dat;
ISR(TIMER0_COMPA_vect) {times++;}// millis = 1 ms
while(EECR & (1<<EEPE)); // проверка готовности EEPROM
Термометр бы ещё добавить и убрать нолик в десятках часов
для того чтобы убрать ноль нужно заменить строку:
на
case 0: ws(0,0);ws(3,0);ws(6,0);ws(9,0);ws(12,0);ws(15,0);ws(18,0);break;
По термометру, если будет собирать часы то добавлю такую функцию.
Я желающий собрать)))
Термометр будете использовать который встроен в DS3231?
У меня цифры распечаны на 3д принтере,туда хочу ленту запихать
Ds18B20
Показания датчика выводить с десятыми долями?
Целыми цифрами,без запятой.Не нужна такая прям точность.Датчик на улице будет
Формат вывода:
**27
t*27
27°C
* - пустое место
Сколько раз минуту выводить, сколько секунд показывать температуру, на какой секунде начать показывать температуру?
Добавлен датчик температуры DS18B20 (протестирован на отрицательную температуру)
Температура показывается с 20 до 25 секунду и с 40 по 45 секунду
#include <avr/io.h>
#define LED_MAX 88
byte mode;
bool sett,w,w1,t_iz;
int temper;
byte a0,a1,a2,a3;
int main(void){
TWSR = 0;
/// TIMER 0 = 1ms
OCR0A = 249;
_delay_ms(100);
temper = read_temp();
while(1){
switch(mode){
a0 = hour/10;
a1 = hour%10;
a2 = min/10;
a3 = min%10;
if(sett==0 && (sec>=20&&sec<=25 || sec>=40&&sec<=45)){t_iz=1;temper = read_temp();
a0 = 10;
if(temper<0){temper=temper*-1;a1=11;}else{a1 = 10;}
a2 = temper/10;
a3 = temper%10;
r_led=1;g_led=1;b_led=1;
}else{t_iz=0;}
if(sett==1){
hh=hour;
mm=min;
a0 = hh/10;
a1 = hh%10;
a2 = mm/10;
a3 = mm%10;
switch(a0){
case 10: ws(0,0);ws(3,0);ws(6,0);ws(9,0);ws(12,0);ws(15,0);ws(18,0);break;// пусто
switch(a1){
case 9: ws(21,1);ws(24,1);ws(27,1);ws(30,1);ws(33,0);ws(36,1);ws(39,1);break;
case 10: ws(21,0);ws(24,0);ws(27,0);ws(30,0);ws(33,0);ws(36,0);ws(39,0);break;// пусто
case 11: ws(21,0);ws(24,0);ws(27,0);ws(30,1);ws(33,0);ws(36,0);ws(39,0);break;// минус
if(t_iz==1){data_led(42, 0, 0, 0);data_led(43, 0, 0, 0);data_led(44, 0, 0, 0);data_led(45, 0, 0, 0);}
switch(a2){
switch(a3){
led_rgb();res();
_delay_ms(100);
}} // end loop
void led_rgb(){
TWDR = i2c_reg;
return i2c_data;
TWDR = i2c_reg;
TWDR = i2c_dat;
uint8_t therm_reset(){
uint8_t i;
PORTD &= ~(1 << PD7);
DDRD |= (1 << PD7);
_delay_us(480);
DDRD &= ~(1 << PD7);
_delay_us(60);
i=((PIND >> PD7) & 1);
_delay_us(420);
return i;
// write bit
DDRD |= (1 << PD7);
_delay_us(1);
if(bit) DDRD &= ~(1 << PD7);
_delay_us(60);
// read bit
uint8_t therm_read_bit(void){
uint8_t bit=0;
DDRD |= (1 << PD7);
_delay_us(1);
_delay_us(14);
if(PIND & (1 << PD7)) bit=1;
_delay_us(45);
return bit;
// read byte
uint8_t i=8, n=0;
return n;
// write byte
uint8_t i=8;
// read temp
int read_temp(){
uint8_t temperature[2];
int temper;
therm_reset();
therm_write_byte(0xCC);
therm_write_byte(0x44);
while(!therm_read_bit());
therm_reset();
therm_write_byte(0xBE);
therm_reset();
temper = (temperature[1] << 8 | temperature[0])/16;
return temper;
Будем тестить,спасибо)))
Добавлен знак t при выводе температуры
#include <avr/io.h>
#define SCL_F 50000 // // I2C Speed
#define LED_MAX 88
byte mode;
int temper;
byte a0,a1,a2,a3;
int main(void){
TWSR = 0;
/// TIMER 0 = 1ms
OCR0A = 249;
_delay_ms(100);
while(1){
switch(mode){
a0 = hour/10;
a1 = hour%10;
a2 = min/10;
a3 = min%10;
a0 = 12;
a2 = temper/10;
a3 = temper%10;
}else{t_iz=0;}
if(sett==1){
hh=hour;
mm=min;
a0 = hh/10;
a1 = hh%10;
a2 = mm/10;
a3 = mm%10;
switch(a0){
case 12: ws(0,1);ws(3,0);ws(6,0);ws(9,1);ws(12,1);ws(15,1);ws(18,0);break;// t
switch(a1){
switch(a2){
switch(a3){
led_rgb();res();
_delay_ms(100);
}} // end loop
void led_rgb(){
TWDR = i2c_reg;
return i2c_data;
TWDR = i2c_reg;
TWDR = i2c_dat;
uint8_t i;
DDRD |= (1 << PD7);
_delay_us(480);
_delay_us(60);
_delay_us(420);
return i;
// write bit
DDRD |= (1 << PD7);
_delay_us(1);
_delay_us(60);
// read bit
uint8_t bit=0;
DDRD |= (1 << PD7);
_delay_us(1);
_delay_us(14);
_delay_us(45);
return bit;
// read byte
uint8_t i=8, n=0;
return n;
// write byte
uint8_t i=8;
// read temp
int read_temp(){
int temper;
therm_reset();
therm_reset();
therm_reset();
return temper;
Привет! Видео часов с температурой можно посмотреть?
Я уже все разобрал.
Печалька, что уже всё разобрано. Недавно начал знакомиться с адресной лентой.
Хотелки:
1. Что подправить в итоговом скетче, если в разделительных точках по одному светодиоду?
2. Формат вывода температуры - ХХ*С. Данные - с модуля часов, вывод раз в минуту с 40 по 50 секунду
3. Формат вывода: с 50 до 00, далее - с 00 до 30 секунды время, с 31 по 39 - дата в формате ДД:ММ
У Вас уже все собрано?
Пока только шаблон цыферок. Вчера только курьер привёз.
https://disk.yandex.ru/i/jwyh__bkLYmpzg
Как будет все готово, оставьте сообщение. Я внесу правки в код, а Вы протестируете.
Наконец-то я закончил паять сие чудо (то отпуск, то руки не доходят).
В моей версии пока нет кнопок и всех прочих наворотов (собрано по схеме http://forum.rcl-radio.ru/viewtopic.php?pid=4988#p4988). В скетче не нашёл пин подключения И в разделительных точках по одному светодиоду
