Тема: Амперметр ADS1110 Atmega8L
#define ADDR 0x48
#define CPU_F 4000000 // Clock Speed
#define SCL_F 50000 // // I2C Speed
#define CLK 2// PD2
#define DIO 3// PD3
#define KALL_0 18
#define KALL_I 25887//(25600)
long dig_sum,dig,u;
TWSR = 0;
for(int i=0;i<10;i++){
dig_sum = dig_sum+read_u(ADDR,0b10001111);delay(20);}
dig = dig_sum/10;dig_sum=0;
u = dig*KALL_I/0x7FFF-KALL_0;
if(u<5){u=0;}
print_time(u,3,7);
int read_u(byte i2c_addr, byte i2c_reg){
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // START
while (!(TWCR & (1<<TWINT)));
TWDR = i2c_addr << 1;
TWDR = i2c_reg;
TWDR = (i2c_addr << 1) | 1;
TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWEA);
while(~TWCR&(1<<TWINT));
int i2c_data0 = TWDR;
int i2c_data1 = TWDR;
TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO); // СТОП
int i2c_data = (i2c_data0<<8)+i2c_data1;
return i2c_data;
void tm_dec(byte dig){
for(int i = 0; i < 8; i++) {
DDRD |= (1 << CLK);del();
if (dig & 0x01)
DDRD &= ~(1 << DIO);
else
DDRD |= (1 << DIO);del();
DDRD &= ~(1 << CLK);del();
dig = dig >> 1;
DDRD |= (1 << CLK);
DDRD &= ~(1 << DIO);del();
if (((PIND >> DIO) & 1) == 0)
void tm_stop(){
void tm_start(){
void print_time(int t, byte pd_t, int br){
int data0 = t / 1000 % 10;
int data1 = t / 100 % 10;
int data2 = t / 10 % 10;
int data3 = t % 10;
for(byte n = 0; n < 4; n++){
int data;
switch(n){
case 0: data = data0;break;
case 1: data = data1;break;
case 2: data = data2;break;
case 3: data = data3;break;
switch(data){ // XGFEDCBA
case 0: data = 0b00111111;break; // 0
case 1: data = 0b00000110;break; // 1
case 2: data = 0b01011011;break; // 2
case 3: data = 0b01001111;break; // 3
case 4: data = 0b01100110;break; // 4
case 5: data = 0b01101101;break; // 5
case 6: data = 0b01111101;break; // 6
case 7: data = 0b00000111;break; // 7
case 8: data = 0b01111111;break; // 8
case 9: data = 0b01101111;break; // 9
case 10: data = 0b00000000;break; // пусто
case 11: data = 0b01000000;break; // -
if(n == 0){data0 = data;}
if(n == 1){data1 = data;}
if(n == 2){data2 = data;}
if(n == 3){data3 = data;}
switch(pd_t){
void del(){delayMicroseconds(200);} Как прошить - http://rcl-radio.ru/?p=82486
