Тема: ATtiny13 + LCD1602_I2C + ds18b20
#define ADDR 0x27
#define SDA 3 // PB3
#define SCL 4 // PB4
#define OUT 0 // PB0
#define RS 0
#define E 2
#define LED 3
byte led_b;
int t;
i2c_write(led_b |= (1<<LED));// включаем подсветку
lcdInit();
t = read_temp();
lcdCurs(0,3);
lcdChar(84);lcdChar(69);lcdChar(77);lcdChar(80);
lcdCurs(1,3);
lcdChar(t/100 +'0');
lcdChar(t/10%10 +'0');
lcdChar(46);
lcdChar(t%10 +'0');
lcdChar(32);lcdChar(67);
delay(1000);
void lcdSend(bool rs, byte data) {
if(rs==0){led_b |= (1<<RS);} else {led_b &= ~(1<<RS);}//RS
delay(1);
if(((data >> 7) & 1) ==1){i2c_write(led_b |= (1<<7));} else {i2c_write(led_b &= ~(1<<7));}
if(((data >> 6) & 1) ==1){i2c_write(led_b |= (1<<6));} else {i2c_write(led_b &= ~(1<<6));}
if(((data >> 5) & 1) ==1){i2c_write(led_b |= (1<<5));} else {i2c_write(led_b &= ~(1<<5));}
if(((data >> 4) & 1) ==1){i2c_write(led_b |= (1<<4));} else {i2c_write(led_b &= ~(1<<4));}
e_pin();
if(((data >> 3) & 1) ==1){i2c_write(led_b |= (1<<7));} else {i2c_write(led_b &= ~(1<<7));}
if(((data >> 2) & 1) ==1){i2c_write(led_b |= (1<<6));} else {i2c_write(led_b &= ~(1<<6));}
if(((data >> 1) & 1) ==1){i2c_write(led_b |= (1<<5));} else {i2c_write(led_b &= ~(1<<5));}
if(((data >> 0) & 1) ==1){i2c_write(led_b |= (1<<4));} else {i2c_write(led_b &= ~(1<<4));}
e_pin();
void lcdInit(){
lcd(0x03);delay(5);
lcd(0x03);delay(5);
lcd(0x03);delayMicroseconds(200);
lcd(0b00000010);delay(5);
lcd(0b00001100);delay(5);
lcdClear();
void lcdClear(){lcd(0b00000001);}
void lcd(uint8_t sett) {lcdSend(true, sett);}
void lcdChar(const char chr) {lcdSend(false, (uint8_t)chr);}
void e_pin(){i2c_write(led_b |= (1<<E));delay(1);i2c_write(led_b &= ~(1<<E));}
void lcdCurs(byte str, byte mesto){
///// i2c /////////////
bool i2c_read_bit() {
bool i2c_bit = 1;
DDRB &= ~(1 << SDA);
delayMicroseconds(10);
DDRB &= ~(1 << SCL);
if((PINB >> SDA) & 1) i2c_bit=0;
DDRB |= (1 << SCL);
return i2c_bit;
return i2c_read_bit();
void i2c_write_bit(byte b){
delayMicroseconds(5);
if(b){DDRB |= (1 << SDA);}else{DDRB &= ~(1 << SDA);}
DDRB |= (1 << SCL);
void i2c_start(){
DDRB &= ~(1 << SDA); DDRB &= ~(1 << SCL);
DDRB |= (1 << SDA); PORTB &= ~(1 << SDA);
DDRB |= (1 << SCL); PORTB &= ~(1 << SCL);
void i2c_stop() {
DDRB |= (1 << SDA);
void i2c_write(byte lcd){
i2c_start();
i2c_write_byte(ADDR<<1);
i2c_write_byte(lcd);
i2c_stop();
//////// ds18b20 /////////////
// reset
uint8_t therm_reset(){
uint8_t i;
PORTB &= ~(1 << OUT);
DDRB |= (1 << OUT);
delayMicroseconds(480);
DDRB &= ~(1 << OUT);
delayMicroseconds(60);
i=((PINB >> OUT) & 1);
delayMicroseconds(420);
return i;
// write bit
void therm_write_bit(uint8_t bit){
DDRB |= (1 << OUT);
delayMicroseconds(1);
if(bit) DDRB &= ~(1 << OUT);
// read bit
uint8_t therm_read_bit(void){
uint8_t bit=0;
DDRB |= (1 << OUT);
delayMicroseconds(14);
if(PINB & (1 << OUT)) bit=1;
delayMicroseconds(45);
return bit;
// read byte
uint8_t therm_read_byte(void){
uint8_t i=8, n=0;
while(i--){n>>=1;n|=(therm_read_bit()<<7);}
return n;
// write byte
void therm_write_byte(uint8_t byte){
uint8_t i=8;
while(i--){therm_write_bit(byte&1);byte >>= 1;
// read temp
int read_temp(){
uint8_t temperature[2];
int temper;
therm_reset();
therm_write_byte(0xCC);
therm_write_byte(0x44);
while(!therm_read_bit());
therm_reset();
therm_write_byte(0xBE);
temperature[0]=therm_read_byte();
temperature[1]=therm_read_byte();
therm_reset();
temper = (temperature[1] << 8 | temperature[0])*10/16;
return (int)temper;
Скетч использует 946 байт (92%) памяти устройства. Всего доступно 1024 байт.
Глобальные переменные используют 3 байт (4%) динамической памяти, оставляя 61 байт для локальных переменных. Максимум: 64 байт.
