Тема: w2812 attiny2313
//  ATtiny2313 12MHz
#define L_BIT    PORTB &= ~(1<<0)
#define H_BIT    PORTB |=  (1<<0)
byte times;
int i=0;
   DDRB |= (1<<0);
    led(10, 0, 0);
    led(0, 10, 0);
    led(0, 0, 10);
    led(0, 0, 0);
    res();
 // delay(500);
void bit_0(){H_BIT;asm("nop");   L_BIT;asm("nop");asm("nop");}
void bit_1(){H_BIT;asm("nop");asm("nop");asm("nop");asm("nop");  L_BIT;}
void bit_w(bool x){if(x) bit_1(); else bit_0();}
void res(){delayMicroseconds(100);}
void led(long rrr, int ggg, byte bbb){
  unsigned long data = ((rrr << 16) & 0xFF0000) + ((ggg << 8) & 0xFF00) + bbb;
  cli();
bit_w(data & 0x80);
bit_w(data & 0x40);
bit_w(data & 0x20);
bit_w(data & 0x10);
bit_w(data & 0x08);
bit_w(data & 0x04);
bit_w(data & 0x02);
bit_w(data & 0x01);
bit_w(data & 0x800000);
bit_w(data & 0x400000);
bit_w(data & 0x200000);
bit_w(data & 0x100000);
bit_w(data & 0x080000);
bit_w(data & 0x040000);
bit_w(data & 0x020000);
bit_w(data & 0x010000);
bit_w(data & 0x8000);
bit_w(data & 0x4000);
bit_w(data & 0x2000);
bit_w(data & 0x1000);
bit_w(data & 0x0800);
bit_w(data & 0x0400);
bit_w(data & 0x0200);
bit_w(data & 0x0100);
   sei();
delayMicroseconds(10);
Re: w2812 attiny2313
//  ATtiny2313 12MHz
#define LED_MAX  4
unsigned long data, dat[LED_MAX];
   DDRB |= (1<<0);
   for(int i1=0;i1<LED_MAX;i1++){
  for(int i=0;i<50;i++){
  data_led(i1,  50,50-i1*3,50-i);
  led_rgb();res();
  delay(10);
  data_led(i1,0,0,0);
  led_rgb();res();
  delay(500);
void data_led(int num, long rrr, int ggg, byte bbb){
  dat[num] = data;
void led_rgb(){
  for(int num_i=0;num_i<LED_MAX;num_i++){data=dat[num_i];
  cli();
bit_w(data & 0x80);
bit_w(data & 0x40);
bit_w(data & 0x20);
bit_w(data & 0x10);
bit_w(data & 0x08);
bit_w(data & 0x04);
bit_w(data & 0x02);
bit_w(data & 0x01);
   sei();
3
//  ATtiny2313 12MHz
#define LED_MAX  4
unsigned long dat[LED_MAX];
byte aa,bb,cc;
   DDRB |= (1<<0);
  for(int i1=LED_MAX;i1>=0;i1--){
  for(int i=0;i<100;i++){
   switch(i1){
    case 0:  aa=i;bb=0;cc=0;break;
    case 1:  aa=0;bb=i;cc=0;break;
    case 2:  aa=0;bb=0;cc=i;break;
    case 3:  aa=i;bb=i;cc=i;break;
  data_led(i1,  aa,bb,cc);
  led_rgb();res();
  delay(2);
  for(int i=100;i>=0;i--){
   switch(i1){
  led_rgb();res();
  delay(2);
 delay(50);
   switch(i1){
  led_rgb();res();
  delay(2);
   switch(i1){
  led_rgb();res();
  delay(2);
 delay(50);
void data_led(int num, unsigned long rrr, int ggg, byte bbb){
  dat[num] = ((rrr << 16) & 0xFF0000) + ((ggg << 8) & 0xFF00) + bbb;
void led_rgb(){
  for(unsigned char num_i=0;num_i<LED_MAX;num_i++){unsigned long data=dat[num_i];
  cli();
bit_w(data & 0x80);
bit_w(data & 0x40);
bit_w(data & 0x20);
bit_w(data & 0x10);
bit_w(data & 0x08);
bit_w(data & 0x04);
bit_w(data & 0x02);
bit_w(data & 0x01);
   sei();
Скетч использует 1638 байт (79%) памяти устройства. Всего доступно 2048 байт.
Глобальные переменные используют 28 байт (21%) динамической памяти, оставляя 100 байт для локальных переменных. Максимум: 128 байт.
