Тема: w2812
#define L_BIT    PORTB &= ~(1<<0)
#define H_BIT    PORTB |=  (1<<0)
byte times;
   DDRB |= (1<<0);
   delayMicroseconds(1000);
   if(times>254){times=0;}
   led(0x000000+times);
   led(0x000000);
   led(0x010000);
   led(0x000100);
   delayMicroseconds(100);
   times++;
   delay(10);
void bit_0(){H_BIT;asm("nop");asm("nop");   L_BIT;asm("nop");asm("nop");asm("nop");   asm("nop");}
void bit_1(){H_BIT;asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");   L_BIT;}
void bit_w(bool x){if(x) bit_1(); else bit_0();}
void led(unsigned long data){
  cli();
bit_w(data  & 0b100000000000000000000000);
bit_w(data  & 0b010000000000000000000000);
bit_w(data  & 0b001000000000000000000000);
bit_w(data  & 0b000100000000000000000000);
bit_w(data  & 0b000010000000000000000000);
bit_w(data  & 0b000001000000000000000000);
bit_w(data  & 0b000000100000000000000000);
bit_w(data  & 0b000000010000000000000000);
bit_w(data  & 0b000000000000000010000000);
bit_w(data  & 0b000000000000000001000000);
bit_w(data  & 0b000000000000000000100000);
bit_w(data  & 0b000000000000000000010000);
bit_w(data  & 0b000000000000000000001000);
bit_w(data  & 0b000000000000000000000100);
bit_w(data  & 0b000000000000000000000010);
bit_w(data  & 0b000000000000000000000001);
bit_w(data  & 0b000000001000000000000000);
bit_w(data  & 0b000000000100000000000000);
bit_w(data  & 0b000000000010000000000000);
bit_w(data  & 0b000000000001000000000000);
bit_w(data  & 0b000000000000100000000000);
bit_w(data  & 0b000000000000010000000000);
bit_w(data  & 0b000000000000001000000000);
bit_w(data  & 0b000000000000000100000000);
   sei();
delayMicroseconds(20);
Re: w2812
byte times;
   DDRB |= (1<<0);
   led(255,0,0);
   led(0,255,0);
   led(0,0,255);
   led(255-times,255-times,50);
   times++;
   delay(10);
void led(byte rrr, byte ggg, byte bbb){
  unsigned long data = ((rrr << 8) & 0xFF0000) | ((ggg << 8) & 0xFF00) | bbb;
  cli();
   sei();
delayMicroseconds(10);
3
Re: w2812
byte times;
int i=0;
   DDRB |= (1<<0);
    led(10, 0, 0);
     led(0, 10, 0);
      led(0, 0, 10);
       led(10, 0, 0);
    res();
  delay(500);
void res(){delayMicroseconds(100);}
void led(long rrr, int ggg, byte bbb){
  unsigned long data = ((rrr << 16) & 0xFF0000) + ((ggg << 8) & 0xFF00) + bbb;
  cli();
   sei();
4
Re: w2812
#define LED_MAX  4
byte times;
int i=0;
unsigned long data;
unsigned long dat[LED_MAX];
   DDRB |= (1<<0);
res();
  for(int i1=0; i<LED_MAX; i++)
  for(int i=0; i<LED_MAX; i++) {
  if(i%2==1)data_led(i,50,0,0);
  else data_led(i,0,0,50);
  led();
  delay(500);
void data_led(int num, long rrr, int ggg, byte bbb){
  dat[num] = data;
  return dat[num];
void led(){
  for(i=0;i<LED_MAX;i++){data=dat[i];
  cli();
   sei();
5
Re: w2812
#define LED_MAX  4
unsigned long data, dat[LED_MAX];
   DDRB |= (1<<0);
   for(int i1=0;i1<LED_MAX;i1++){
  for(int i=0;i<50;i++){
  data_led(i1,  50,50-i1*3,50-i);
  led_rgb();res();
  delay(10);
  data_led(i1,0,0,0);
  led_rgb();res();
  delay(500);
  dat[num] = data;
void led_rgb(){
  for(int num_i=0;num_i<LED_MAX;num_i++){data=dat[num_i];
  cli();
bit_w(data & 0x80);
bit_w(data & 0x40);
bit_w(data & 0x20);
bit_w(data & 0x10);
bit_w(data & 0x08);
bit_w(data & 0x04);
bit_w(data & 0x02);
bit_w(data & 0x01);
bit_w(data & 0x800000);
bit_w(data & 0x400000);
bit_w(data & 0x200000);
bit_w(data & 0x100000);
bit_w(data & 0x080000);
bit_w(data & 0x040000);
bit_w(data & 0x020000);
bit_w(data & 0x010000);
bit_w(data & 0x8000);
bit_w(data & 0x4000);
bit_w(data & 0x2000);
bit_w(data & 0x1000);
bit_w(data & 0x0800);
bit_w(data & 0x0400);
bit_w(data & 0x0200);
bit_w(data & 0x0100);
   sei();
