ТЕРМОРЕГУЛЯТОР DS18B20 +TM1637 +ЭНКОДЕР
ВЫХОД РЕЛЕ PD5
ЭНКОДЕР CLK = PB2 , DT = PB3 , SW = PD6
TM1637 DIO = PB1 , CLK = PB0
DS18B20 OUT = PB4
ТЕМПЕРАТУРА
РЕГУЛИРОВАНИЕ
byte bb,w;
volatile uint8_t _prevValueAB = 0;
volatile uint8_t _currValueAB = 0;
volatile int16_t _counter = 0;
int position = -999;
int t_reg,t_dig;
unsigned long time_i=0,time_i2=0,time_i3=0;
const int gis = 1;//0.1 гр. Цельсия
cli();
////// timer 1 //////////
TCCR1A = 0;
TCCR1B = 0;
OCR1A = 18750; // 0.1 s
TCCR1B |= (1 << WGM12);
TCCR1B |= (1 << CS11) | (1 << CS10); // 64
TIMSK |= (1 << OCIE1A);
DDRB &= ~(1 << 2) | (1 << 3);
DDRD &= ~(1 << 6);
DDRD |= (1 << 5);
GIMSK |= (1 << PCIE);
PCMSK |= (1 << PCINT2) | (1 << PCINT3);
t_reg = EEPROM_read(0)*10+EEPROM_read(1);
sei();
if(((PIND >> 6) & 1) == 0){time_i2=0;time_i3=0;}
if(getPosition() != position){
position = getPosition();
t_reg = t_reg+getPosition();setPosition(0);w=1;time_i=0;time_i2=0;time_i3=0;
if(t_reg<0){t_reg=0;}if(t_reg>1250){t_reg=1250;}}
if(time_i2<=50){
if(t_reg>999){print_time(t_reg, 1, 7, 0);}else{print_time(t_reg, 1, 7, 1);}}
if(time_i3>50){t_dig = read_temp();time_i3=0;}
if(w==1&&time_i>50){w=0;EEPROM_write(0,t_reg/10);EEPROM_write(1,t_reg%10);delay(100);}
if(time_i2>50){
if(t_dig>999){print_time(t_dig, 1, 7, 0);}else{print_time(t_dig, 1, 7, 1);}}
if(t_reg >= t_dig + gis){PORTD |= (1 << 5);}
if(t_reg <= t_dig - gis){PORTD &= ~(1 << 5);}
//////// encoder ////////////////////////
ISR(PCINT_vect){
bool pinA = ((PINB >> 2) & 1);
bool pinB = ((PINB >> 3) & 1);
_currValueAB = pinA << 1;
_currValueAB |= pinB;
switch ((_prevValueAB | _currValueAB)){
case 0b0001: _counter++;break;
case 0b0100: _counter--;break;
_prevValueAB = _currValueAB << 2;
int16_t getPosition(){
return _counter;
void setPosition(int16_t position){
_counter = position;
//////////// tm ///////////////////
void tm_dec(byte dig) {
for (int i = 0; i < 8; i++) {
DDRB |= (1 << 0); del();
if (dig & 0x01) DDRB &= ~(1 << 1);
else DDRB |= (1 << 1); del();DDRB &= ~(1 << 0); del();
dig = dig >> 1;}
DDRB |= (1 << 0);
DDRB &= ~(1 << 1); del();
if (((PINB >> 1) & 1) == 0) DDRB |= (1 << 1); del();DDRB |= (1 << 0); del();
void tm_stop() {
void tm_start() {
void print_time(int t, byte pd_t, int br, byte mn) {
tm_start(); tm_dec(0b10001000 + br); //tm_stop();tm_start();
tm_dec(0x40); tm_stop(); tm_start();
int data0;
if(mn==1){data0 = 10;}
else if(mn==2){data0 = 11;}
else data0 = t / 1000;
int data1 = t / 100 % 10;
int data2 = t / 10 % 10;
int data3 = t % 10;
for (byte n = 0; n < 4; n++) {
int data;
switch (n) {
case 0: data = data0; break;
case 1: data = data1; break;
case 2: data = data2; break;
case 3: data = data3; break;
switch (data) { // XGFEDCBA
case 0: data = 0b00111111; break; // 0
case 1: data = 0b00000110; break; // 1
case 2: data = 0b01011011; break; // 2
case 3: data = 0b01001111; break; // 3
case 4: data = 0b01100110; break; // 4
case 5: data = 0b01101101; break; // 5
case 6: data = 0b01111101; break; // 6
case 7: data = 0b00000111; break; // 7
case 8: data = 0b01111111; break; // 8
case 9: data = 0b01101111; break; // 9
case 10: data = 0b00000000; break; // пусто
case 11: data = 0b01000000; break; // -
if (n == 0) {data0 = data;}
if (n == 1) {data1 = data;}
if (n == 2) {data2 = data;}
if (n == 3) {data3 = data;}
switch (pd_t) {
case 1 : data2 = data2 + 0b10000000; break;
case 2 : data1 = data1 + 0b10000000; break;
case 3 : data0 = data0 + 0b10000000; break;
tm_dec(0xC0); tm_dec(data0); tm_dec(data1); tm_dec(data2); tm_dec(data3); tm_stop();
void del() {delayMicroseconds(200);}
////////// eeprom ////////////////////
unsigned char EEPROM_read(unsigned int uiAddress){
while(EECR & (1<<EEPE));
EEAR = uiAddress;
EECR |= (1<<EERE);
return EEDR;
void EEPROM_write(unsigned int uiAddress, unsigned char ucData){
EEAR = uiAddress;
EEDR = ucData;
EECR |= (1<<EEMPE);
EECR |= (1<<EEPE);
//////////// timer 1 /////////////
ISR(TIMER1_COMPA_vect){time_i++; time_i2++;time_i3++;}
///////////// 18b20 ////////////////
uint8_t therm_reset(){
uint8_t i;
PORTB &= ~(1 << 4);
DDRB |= (1 << 4);
delayMicroseconds(480);
DDRB &= ~(1 << 4);
delayMicroseconds(60);
i=((PINB >> 4) & 1);
delayMicroseconds(420);
return i;
// write bit
void therm_write_bit(uint8_t bit){
PORTB &= ~(1 << 4);
DDRB |= (1 << 4);
delayMicroseconds(1);
if(bit) DDRB &= ~(1 << 4);
DDRB &= ~(1 << 4);
// read bit
uint8_t therm_read_bit(void){
uint8_t bit=0;
PORTB &= ~(1 << 4);
DDRB |= (1 << 4);
DDRB &= ~(1 << 4);
delayMicroseconds(14);
if(PINB & (1 << 4)) bit=1;
delayMicroseconds(45);
return bit;
// read byte
uint8_t therm_read_byte(void){
uint8_t i=8, n=0;
while(i--){n>>=1;n|=(therm_read_bit()<<7);}
return n;
// write byte
void therm_write_byte(uint8_t byte){
uint8_t i=8;
while(i--){therm_write_bit(byte&1);byte >>= 1;
// read temp
int read_temp(){
uint8_t temperature[2];
float temper;
therm_reset();
therm_write_byte(0xCC);
therm_write_byte(0x44);
while(!therm_read_bit());
therm_reset();
therm_write_byte(0xBE);
temperature[0]=therm_read_byte();
temperature[1]=therm_read_byte();
therm_reset();
temper = (temperature[1] << 8 | temperature[0])*10/16;
return (int)temper;
Скетч использует 1682 байт (82%) памяти устройства. Всего доступно 2048 байт.
Глобальные переменные используют 23 байт (17%) динамической памяти, оставляя 105 байт для локальных переменных. Максимум: 128 байт.
