Тема: Аудиопроцессор R2S15902FP
http://forum.rcl-radio.ru/uploads/images/2019/10/e0863727a223ed5b7ecbfdded7f10ae6.gif
http://forum.rcl-radio.ru/uploads/images/2019/10/6ffb404b990bcab8e2fb14a7dd1b87ae.png
Скетч рабочий
R2S15902FP is an audio signal processor for home audio. This IC contains 6 channels electronic volume, gain control,
input selector and 2 band tone control.
Features
• 6 channels independent electronic volume (0 to –99dB/1dBstep, –∞dB)
• 6 channels independent gain control (0 to +14dB/ 2dB step)
• L/R channel 4 input selector (Input gain: 0 to +14dB/ 2dB step)
• Multi channel input: 6 channels input
• Tone control Bass: –14 to + 14dB(2dB step),
Treble: –14 to + 14dB(2dB step)
• Can use 1 input for REC output (REC output gain: 0, +2, +4, +6dB)
• Built-in ADC output (Input Att: 0/ –6/ –12/ –18dB)
• Built-in L+R/ L–R block
• Built-in digital power supply
Recommended Operating Condition
Supply voltage range VCC = 8.0V to 10.0V: 9.0V(typ)
Re: Аудиопроцессор R2S15902FP
test.ino
#include <R2S15902FP.h>
void setup(){ Serial.begin(9600);
  pinMode(DATA, OUTPUT); // D2
  pinMode(CLK, OUTPUT);   // D3
  delay(100);
  delay(1000);
  Slot1(0,3,0,5,5,0);
    // input selector  1...3 === int 0...2
    //REC-Output Gain Control int 0...6 dB === int 0...3
    //ADC Input ATT 0...-6 dB === int 0...3
    //bass int 0 === +14dB int 8 === 0dB int 15 === -14dB
    //treble int 0 === +14dB int 8 === 0dB int 15 === -14dB
    //Input Gain 0...14 dB === int 0...7
  Slot2(3,10,3,10); // gain0, volume0, gain1, volume1
  Slot3(3,10,3,10); // gain2, volume2, gain3, volume3
  Slot4(3,10,3,10); // gain4, volume4, gain5, volume5
  // gain 0...14 dB === int 0...7
  // volume 0...-99 dB === int 0...100
R2S15902FP.h
#include <Arduino.h>
#define DATA 2 // pin DATA
#define CLK  3 // pin CLK
  void Slot1(int in, int out_gain, int att, int bass, int treb, int in_gain);
           // input selector, REC-Output Gain Control, ADC Input ATT, bass (0=+14dB,8=0dB,15=-14dB), treble (0=+14dB,8=0dB,15=-14dB), Input Gain
  void Slot2(int gain0, int vol0, int gain1, int vol1); // gain0, volume0, gain1, volume1
  void Slot3(int gain2, int vol2, int gain3, int vol3); // gain2, volume2, gain3, volume3
  void Slot4(int gain4, int vol4, int gain5, int vol5); // gain4, volume4, gain5, volume5
R2S15902FP.cpp
#include "R2S15902FP.h"
const boolean input[3][3]={{0,1,0},{1,0,0},{1,1,0}}; //  Input Selector
const boolean rec_out[4][2]={{0,0},{0,1},{1,0},{1,1}}; //  REC-Output Gain Control
const boolean input_att[4][2]={{0,0},{0,1},{1,0},{1,1}};//ADC Input ATT
const boolean bass_data[15][4]={{1,1,1,1},{1,1,1,0},{1,1,0,1},{1,1,0,0},{1,0,1,1},{1,0,1,0},{1,0,0,1},{1,0,0,0},{0,0,0,1},{0,0,1,0},{0,0,1,1},{0,1,0,0},{0,1,0,1},{0,1,1,0},{0,1,1,1}}; // bass
const boolean treb_data[15][4]={{1,1,1,1},{1,1,1,0},{1,1,0,1},{1,1,0,0},{1,0,1,1},{1,0,1,0},{1,0,0,1},{1,0,0,0},{0,0,0,1},{0,0,1,0},{0,0,1,1},{0,1,0,0},{0,1,0,1},{0,1,1,0},{0,1,1,1}}; // treble
const boolean input_gain_data[8][3]={{0,0,0},{0,0,1},{0,1,0},{0,1,1},{1,0,0},{1,0,1},{1,1,0},{1,1,1}};//Input Gain
const boolean input_control_data[8][3] ={{0,0,0},{0,0,1},{0,1,0},{0,1,1},{1,0,0},{1,0,1},{1,1,0},{1,1,1}};//Gain Control
const boolean volume[100][7]  ={{0,0,0,0,0,0,0},{0,0,0,0,0,0,1},{0,0,0,0,0,1,0},{0,0,0,0,0,1,1},{0,0,0,0,1,0,0},{0,0,0,0,1,0,1},{0,0,0,0,1,1,0},{0,0,0,0,1,1,1},{0,0,0,1,0,0,0},{0,0,0,1,0,0,1},{0,0,0,1,0,1,0},{0,0,0,1,0,1,1},{0,0,0,1,1,0,0},{0,0,0,1,1,0,1},{0,0,0,1,1,1,0},{0,0,0,1,1,1,1},{0,0,1,0,0,0,0},{0,0,1,0,0,0,1},{0,0,1,0,0,1,0},{0,0,1,0,0,1,1},{0,0,1,0,1,0,0},{0,0,1,0,1,0,1},{0,0,1,0,1,1,0},{0,0,1,0,1,1,1},{0,0,1,1,0,0,0},{0,0,1,1,0,0,1},{0,0,1,1,0,1,0},{0,0,1,1,0,1,1},{0,0,1,1,1,0,0},{0,0,1,1,1,0,1},{0,0,1,1,1,1,0},{0,0,1,1,1,1,1},{0,1,0,0,0,0,0},{0,1,0,0,0,0,1},{0,1,0,0,0,1,0},{0,1,0,0,0,1,1},{0,1,0,0,1,0,0},{0,1,0,0,1,0,1},{0,1,0,0,1,1,0},{0,1,0,0,1,1,1},{0,1,0,1,0,0,0},{0,1,0,1,0,0,1},{0,1,0,1,0,1,0},{0,1,0,1,0,1,1},{0,1,0,1,1,0,0},{0,1,0,1,1,0,1},{0,1,0,1,1,1,0},{0,1,0,1,1,1,1},{0,1,1,0,0,0,0},{0,1,1,0,0,0,1},{0,1,1,0,0,1,0},{0,1,1,0,0,1,1},{0,1,1,0,1,0,0},{0,1,1,0,1,0,1},{0,1,1,0,1,1,0},{0,1,1,0,1,1,1},{0,1,1,1,0,0,0},{0,1,1,1,0,0,1},{0,1,1,1,0,1,0},{0,1,1,1,0,1,1},{0,1,1,1,1,0,0},{0,1,1,1,1,0,1},{0,1,1,1,1,1,0},{0,1,1,1,1,1,1},{1,0,0,0,0,0,0},{1,0,0,0,0,0,1},{1,0,0,0,0,1,0},{1,0,0,0,0,1,1},{1,0,0,0,1,0,0},{1,0,0,0,1,0,1},{1,0,0,0,1,1,0},{1,0,0,0,1,1,1},{1,0,0,1,0,0,0},{1,0,0,1,0,0,1},{1,0,0,1,0,1,0},{1,0,0,1,0,1,1},{1,0,0,1,1,0,0},{1,0,0,1,1,0,1},{1,0,0,1,1,1,0},{1,0,0,1,1,1,1},{1,0,1,0,0,0,0},{1,0,1,0,0,0,1},{1,0,1,0,0,1,0},{1,0,1,0,0,1,1},{1,0,1,0,1,0,0},{1,0,1,0,1,0,1},{1,0,1,0,1,1,0},{1,0,1,0,1,1,1},{1,0,1,1,0,0,0},{1,0,1,1,0,0,1},{1,0,1,1,0,1,0},{1,0,1,1,0,1,1},{1,0,1,1,1,0,0},{1,0,1,1,1,0,1},{1,0,1,1,1,1,0},{1,0,1,1,1,1,1},{1,1,0,0,0,0,0},{1,1,0,0,0,0,1},{1,1,0,0,0,1,0},{1,1,0,0,0,1,1}}; // volume
void Slot1(int in, int out_gain, int att, int bass, int treb, int in_gain){
  // input selector  ||  0-2 bit
  for(int i=0;i<3;i++){
    digitalWrite(DATA, input[in][i]);
    digitalWrite(CLK, HIGH);
    digitalWrite(DATA, LOW);
    digitalWrite(CLK, LOW);}
  //  REC Output  ||  3 bit
    digitalWrite(DATA, LOW); // 0
  //  REC-Output Gain Control  ||  4-5 bit
  for(int i=0;i<2;i++){
    digitalWrite(DATA, rec_out[out_gain][i]);
  //  ADC Input ATT  ||  6-7 bit
    digitalWrite(DATA, input_att[att][i]);
  //   L/R Input   || 8 bit
  // BASS  ||   9 - 12 bit
  for(int i=0;i<4;i++){
    digitalWrite(DATA, bass_data[bass][i]);
  // TREBLE   ||  13 - 16 bit
    digitalWrite(DATA, treb_data[treb][i]);
  //   SL/ SR/ C/ SW Input  || 17 bit
   // Input Gain  ||  18 - 20 bit
    digitalWrite(DATA, input_gain_data[in_gain][i]);
    // 21 bit
    // 22 bit
    // 23 bit
    digitalWrite(DATA, HIGH);// CLOCK
void Slot2(int gain0, int vol0, int gain1, int vol1){
 // Gain Control 0  ||  0-2 bit
    digitalWrite(DATA, input_control_data[gain0][i]);
 // volume 0  ||  3 - 9 bit
  for(int i=0;i<7;i++){
    digitalWrite(DATA, volume[vol0][i]);
 // Gain Control 1  ||  10-12 bit
    digitalWrite(DATA, input_control_data[gain1][i]);
 // volume 1  ||  13 - 19 bit
    digitalWrite(DATA, volume[vol1][i]);
    //  20 bit
    //  21 bit
    // 22 bit
    // 23 bit
    digitalWrite(DATA, HIGH); // 1
    digitalWrite(DATA, HIGH); // CLOCK
void Slot3(int gain2, int vol2, int gain3, int vol3){
 // Gain Control 2  ||  0-2 bit
    digitalWrite(DATA, input_control_data[gain2][i]);
 // volume 2  ||  3 - 9 bit
    digitalWrite(DATA, volume[vol2][i]);
 // Gain Control 3  ||  10-12 bit
    digitalWrite(DATA, input_control_data[gain3][i]);
 // volume 3  ||  13 - 19 bit
    digitalWrite(DATA, volume[vol3][i]);
    // 20 bit
    //  21 bit
    // 22 bit LOW
    // 23 bit  HIGH
void Slot4(int gain4, int vol4, int gain5, int vol5){
 // Gain Control 4  ||  0-2 bit
    digitalWrite(DATA, input_control_data[gain4][i]);
 // volume 4  ||  3 - 9 bit
    digitalWrite(DATA, volume[vol4][i]);
 // Gain Control 5  ||  10-12 bit
    digitalWrite(DATA, input_control_data[gain5][i]);
 // volume 5  ||  13 - 19 bit
    digitalWrite(DATA, volume[vol5][i]);
    // 20 bit
    //  21 bit
    // 22 bit LOW
    // 23 bit  HIGH
3
Основная статья - https://rcl-radio.ru/?p=67106
Библиотека:
http://forum.rcl-radio.ru/uploads/images/2019/10/57983eec1eb18d9af06c1c0ed78de335.png
http://forum.rcl-radio.ru/uploads/images/2019/10/dd3aaafdbf6a75ccdbe6b78e5fd9e392.png
http://forum.rcl-radio.ru/uploads/images/2019/10/b7ae543a9a1a44cae04969bbb4917467.png
http://forum.rcl-radio.ru/uploads/images/2019/10/057de98c10ca6d5fe10159aed69e1324.png
Компоненты:
1. Аудиопроцессор R2S15902FP
2. LCD1602 I2C
3. Энкодер
Подключение:
D2 - DATA
D3 - CLK
Подключение можно изменить отредактировав файл R2S15902FP.h библиотеки
R2S15902FP.ino
#include <Encoder.h>
#include <MsTimer2.h>
#include <boarddefs.h>
#include <IRremote.h>
 int menu,vol,vol_d,treb,treb_d,bass,bass_d,in;
 byte w,w2,z,z0,z1;
void setup(){ irrecv.enableIRIn(); // запускаем модуль IR
  lcd.init();lcd.backlight();// Включаем подсветку дисплея
  lcd.setCursor(0,0);lcd.print("   R2S15902FP   ");delay(2000);
  Serial.begin(9600); lcd.createChar(0,a1);lcd.createChar(1,a2);lcd.createChar(2,a3);
   vol = EEPROM.read(0);treb = EEPROM.read(1);bass = EEPROM.read(2);in = EEPROM.read(3);
  delay(100);cl();
   if(digitalRead(10)==LOW){menu++;cl();time=millis();w=1;w2=1;if(menu>3){menu=0;}}// меню
     lcd.print(" ");lcd.print(-vol);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");vol_d=48-vol;
   if(w2==1){
///////////////////////// TREBLE +/-14 dB /////////////////////////////////////////////////////////
   lcd.setCursor(0,0);lcd.print("TREBLE  ");
   lcd.print(" ");lcd.print(14-treb*2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");treb_d=28-treb*2;
   if(w2==1){
///////////////////////// BASS +/-14 dB /////////////////////////////////////////////////////////
   lcd.setCursor(0,0);lcd.print("BASS    ");
   lcd.print(" ");lcd.print(14-bass*2);lcd.print(" ");lcd.setCursor(13,0);lcd.print("dB");bass_d=28-bass*2;
   if(w2==1){
///////////////////// IN /////////////////////////////////////////////////////////////////////////
    in=in-newPosition;myEnc.write(0);newPosition=0;time=millis();cl();w=1;w2=1;in_func();audio();}
   lcd.setCursor(0,0);lcd.print("INPUT  ");lcd.print(in+1);
     EEPROM.update(0,vol);EEPROM.update(1,treb);EEPROM.update(2,bass);EEPROM.update(3,in);
     menu=0;w=0;w2=1;cl();}
void in_func(){if(in>2){in=0;}if(in<0){in=2;}}
void bass_func(){if(bass>14){bass=14;}if(bass<0){bass=0;}}
void treb_func(){if(treb>14){treb=14;}if(treb<0){treb=0;}}
void vol_func(){if(vol<0){vol=0;}if(vol>99){vol=99;}}
  Slot1(in,0,0,bass,treb,0);
  Slot2(0,vol,0,vol); // gain0, volume0, gain1, volume1
  Slot3(0,vol,0,vol); // gain2, volume2, gain3, volume3
  Slot4(0,vol,0,vol); // gain4, volume4, gain5, volume5
4
Активация 6 - канального входа. Выбрать вход IN4.
Установить разделительные конденсаторы на выводы с 6 по 11 по 2,2 мкФ
http://forum.rcl-radio.ru/uploads/images/2019/10/f21dd5c4e6ed5209a5d7dd3c2df379bc.png
Скетч не тестировался!!!
Внесены изменения в библиотеку - Данный контент доступен только зарегистрированным пользователям.
Измененный скетч:
 byte w,w2,z,z0,z1,r_l;
  delay(100);cl();
   if(w2==1){
   if(w2==1){
   if(w2==1){
    in=in-newPosition;myEnc.write(0);newPosition=0;time=millis();cl();w=1;w2=1;in_func(); if(in==3){r_l=1;}else{r_l=0;}audio();}
void in_func(){if(in>3){in=0;}if(in<0){in=3;}}
  Slot1(in,0,r_l,0,bass,treb,0);
    // input selector  1...4 === int 0...3, in4 === multi in
    //L/R Input 0 === IN1...3, 1 === IN4 MULTI
Имеется готовая плата для этого процессора ,будет полезно к этой библиотеке!Данный контент доступен только зарегистрированным пользователям. Данный контент доступен только зарегистрированным пользователям. Данный контент доступен только зарегистрированным пользователям.
6
Не тестировано!!!
Добавлены усилителя выходов, перебор выходов кнопкой IN
http://forum.rcl-radio.ru/uploads/images/2020/01/2868e94881eff52bd06c5047709117ab.png
  byte a1[8] ={0b00000,0b10101,0b10101,0b10101,0b10101,0b10101,0b10101,0b00000};
  byte a2[8] ={0b00000,0b10100,0b10100,0b10100,0b10100,0b10100,0b10100,0b00000};
  byte a3[8] ={0b00000,0b10000,0b10000,0b10000,0b10000,0b10000,0b10000,0b00000};
  byte w,w2,z,z0,z1,www,gr1,gr2;
  int out,vol_out,rf,lf,rt,lt,sab1,sab2;
   pinMode(11,INPUT);// КНОПКА IN
    MsTimer2::set(3, to_Timer);MsTimer2::start(); // АКТИВИРУЕМПРЕРЫВАНИЯ ДЛЯ ЭНКОДЕРА
    vol = EEPROM.read(0);treb = EEPROM.read(1);bass = EEPROM.read(2);in= EEPROM.read(3);
    rf = EEPROM.read(10);lf = EEPROM.read(11);rt = EEPROM.read(12);lt =EEPROM.read(13);sab1 = EEPROM.read(14);sab2 = EEPROM.read(24);
   delay(100);cl();
if(digitalRead(10)==LOW){menu++;cl();time=millis();w=1;w2=1;if(menu>4){menu=0;}}//меню
if(digitalRead(11)==HIGH){in++;;cl();time=millis();w=1;w2=1;www=1;in_func();lcd.setCursor(0,0);lcd.print("    INPUT");lcd.print(in+1);audio();delay(2000);}// КНОПКА ВЫБОРА ВХОДА I
    if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println(ir.value,HEX);irrecv.resume();time=millis();w=1;}// IR приемник -чтение, в мониторе порта отображаются коды кнопок
if(ir.value==IR_1){menu++;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;if(menu>4){menu=0;}}//меню кнопка вверх
if(ir.value==IR_2){menu--;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;if(menu<0){menu=4;}}//меню кнопка вниз
if(ir.value==IR_3){vol++;gr1=1;gr2=0;cl1();w2=1;vol_func();audio();}//кнопка >
if(ir.value==IR_4){vol--;gr1=0;gr2=1;cl1();w2=1;vol_func();audio();}//кнопка <
    if (newPosition != oldPosition){oldPosition = newPosition;vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;vol_func();audio();}
      lcd.print(" ");lcd.print(-vol);lcd.print("");lcd.setCursor(13,0);lcd.print("dB");vol_d=48-vol;
    if(w2==1){
if(ir.value==IR_3){treb++;gr1=1;gr2=0;cl1();w2=1;treb_func();audio();}//кнопка >
gr1==1){treb++;gr2=0;cl1();w2=1;treb_func();audio();}// кнопка >>>>>>
if(ir.value==IR_4){treb--;gr1=0;gr2=1;cl1();w2=1;treb_func();audio();}//кнопка <
gr2==1){treb--;gr1=0;cl1();w2=1;treb_func();audio();}// кнопка <<<<<<
    if(w2==1){
if(ir.value==IR_3){bass++;gr1=1;gr2=0;cl1();w2=1;bass_func();audio();}//кнопка >
      if(ir.value==0xFFFFFFFF and gr1==1){bass++;gr2=0;cl1();w2=1;bass_func();audio();}// кнопка >>>>>>
if(ir.value==IR_4){bass--;gr1=0;gr2=1;cl1();w2=1;bass_func();audio();}//кнопка <
      if(ir.value==0xFFFFFFFF and gr2==1){bass--;gr1=0;cl1();w2=1;bass_func();audio();}// кнопка <<<<<<
    if(w2==1){
  if(ir.value==IR_5){in++;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;www=1;
   in_func();lcd.setCursor(0,0);lcd.print("    INPUT ");lcd.print(in+1);audio();delay(2000);}// КНОПКА ВЫБОРА ВХОДА IN
    lcd.setCursor(0,0);lcd.print("INPUT  ");lcd.print(in+1);}
////////////////////////////////////////// out
  if(menu==4){
if(digitalRead(11)==HIGH){out++;cl();time=millis();www=1;w=1;if(out>5){out=0;}audio();}
// перебор выходов кнопкой IN
if(ir.value==IR_5){out++;cl();time=millis();www=1;w=1;if(out>5){out=0;}audio();}
        switch(out){
           case 0:vol_out=rf;break;
           case 1:vol_out=lf;break;
           case 2:vol_out=rt;break;
           case 3:vol_out=lt;break;
           case 4:vol_out=sab1;break;
           case 5:vol_out=sab2;break;
if(ir.value==IR_3){vol_out++;gr1=1;gr2=0;cl1();w2=1;vol_out_func();audio();}//кнопка >
      if(ir.value==0xFFFFFFFF and gr1==1){vol_out++;gr2=0;cl1();w2=1;vol_out_func();audio();}// кнопка >>>>>>
if(ir.value==IR_4){vol_out--;gr1=0;gr2=1;cl1();w2=1;vol_out_func();audio();}//кнопка <
      if(ir.value==0xFFFFFFFF and gr2==1){vol_out--;gr1=0;cl1();w2=1;vol_out_func();audio();}// кнопка <<<<<<
vol_out=vol_out+newPosition;myEnc.write(0);newPosition=0;time=millis();www=1;w=1;w2=1;vol_out_func();audio();}
       switch(out){
    case 0:rf=vol_out;lcd.print("RF:  ");lcd.print(rf);break;
    case 1:lf=vol_out;lcd.print("LF:  ");lcd.print(lf);break;
    case 2:rt=vol_out;lcd.print("RT:  ");lcd.print(rt);break;
    case 3:lt=vol_out;lcd.print("LT:  ");lcd.print(lt);break;
    case 4:sab1=vol_out;lcd.print("SUBW_1: ");lcd.print(sab1);break;
    case 5:sab2=vol_out;lcd.print("SUBW_2: ");lcd.print(sab2);break;
     if(www==1){audio();www=0;}
   lcd.print(" dB      ");}
EEPROM.update(10,rf);EEPROM.update(11,lf);EEPROM.update(12,rt);EEPROM.update(13,lt);EEPROM.update(14,sab1);EEPROM.update(24,sab2);
void vol_out_func(){if(vol_out>7){vol_out=7;}if(vol_out<0){vol_out=0;}}
   Slot2(rf,vol,lf,vol); // gain0, volume0, gain1, volume1
   Slot3(rt,vol,lt,vol); // gain2, volume2, gain3, volume3
   Slot4(sab1,vol,sab2,vol); // gain4, volume4, gain5, volume5
7
Большие цифры
http://forum.rcl-radio.ru/uploads/images/2020/01/72618337a0404b95e25a7172b31dd898.png
http://forum.rcl-radio.ru/uploads/images/2020/01/138f25fae9568c90a8da0c9f62766446.png
http://forum.rcl-radio.ru/uploads/images/2020/01/d75cf529e59b0f1e9c4525641c58c5c1.png
  byte w,w2,www,gr1,gr2;
  byte a[2];
lcd.createChar(1, v1);lcd.createChar(2, v2);lcd.createChar(3, v3);lcd.createChar(4, v4);lcd.createChar(5, v5);lcd.createChar(7, v7);
   delay(100);cl();
if(digitalRead(11)==HIGH){in++;;cl();time=millis();w=1;w2=1;www=1;in_func();lcd.setCursor(0,0);lcd.print("    INPUT");lcd.print(in+1);audio();delay(2000);cl();}// КНОПКА ВЫБОРА ВХОДА I
///////////////////////  vol
    vol_d = abs(vol-99);
    a[0]= vol_d/10;a[1]=vol_d%10;
    for(i=0;i<2;i++){
        case 1: e1=13,e2=14,e3=15;break;}
      switch(a[i]){
       case 11: d1=5,d2=5,d3=5,d4=5,d5=5,d6=5;break;
      lcd.setCursor(0,0);lcd.print("VOLUME");
      lcd.setCursor(0,1);;lcd.print("INPUT ");lcd.print(in+1);
    treb_d = abs(treb-14);
    a[0]= treb_d/10;a[1]=treb_d%10;
    for(i=0;i<2;i++){
      switch(a[i]){
      lcd.setCursor(0,0);lcd.print("TREBLE");
     // lcd.setCursor(0,1);;lcd.print("INPUT ");lcd.print(in+1);
   bass_d = abs(bass-14);
    a[0]= bass_d/10;a[1]=bass_d%10;
    for(i=0;i<2;i++){
      switch(a[i]){
      lcd.setCursor(0,0);lcd.print("BASS");
  if(menu==4){
        switch(out){
vol_out=vol_out-newPosition;myEnc.write(0);newPosition=0;time=millis();www=1;w=1;w2=1;vol_out_func();audio();}
       switch(out){
   lcd.print(" dB      ");}
8
Исправленная библиотека
https://github.com/liman324/R2S15902FP
Тестовый скетч
  delay(100);
  delay(1000);
  Slot1(0,0,0,0,5,5,0);
  // volume 0...-99 dB === int 0...99
9
Активация IN4(AUX4) - замените в библиотеке файл - Данный контент доступен только зарегистрированным пользователям.
AUX1...AUX4 IN6
10
what encoder can i use. i hv tried but failed! Help me!
11
ky-040 (модуль)
12
thank you!
