#include <LiquidCrystal.h>
#include <Encoder.h>
#include <TDA7313.h>
#include <IRremote.h>
TDA7313 tda;decode_results ir;
unsigned long newPosition,time,time1,oldPosition = -999;
int vol,w1,w2=1,gr1,gr2,vol_d,menu,w,z,z0,z1,bass_d,bass,treb_d,treb,i,menu1,in,gain,gain1,gain2,gain3,loud,lr,rr,lf,rf,power,vol_old;
lcd.begin(16, 2);lcd.createChar(0,a1);lcd.createChar(1,a2);lcd.createChar(2,a3);
pinMode(A0,INPUT);// КНОПКА ЭНКОДЕРA
pinMode(12,INPUT);// КНОПКА IN
pinMode(11,INPUT);// КНОПКА POWER
pinMode(13,OUTPUT);// выход управления STANDBY
vol = EEPROM.read(0);bass = EEPROM.read(1)-7;treb = EEPROM.read(2)-7;in = EEPROM.read(3);
gain1 = EEPROM.read(4);gain2 = EEPROM.read(5);gain3 = EEPROM.read(6);loud = EEPROM.read(7);
lr = EEPROM.read(8);rr = EEPROM.read(9);lf = EEPROM.read(10);rf = EEPROM.read(11);
if(in==0){gain=gain1;}
if(in==1){gain=gain2;}
if(in==2){gain=gain3;}
digitalWrite(13,LOW);
lcd.setCursor(0,0);lcd.print(" TDA 7313 ");
lcd.setCursor(0,1);lcd.print(" V2.0 ");
digitalWrite(13,HIGH);
if ( irrecv.decode( &ir )) {Serial.print("0x");Serial.println( ir.value,HEX);time1=millis();time=millis();w=1;w1=1;irrecv.resume();}// IR приемник
if(ir.value==0){gr1=0;gr2=0;}
if((analogRead(A0)<900)&&menu1==0){menu++;cl();myEnc.write(0);i++;time=millis();w=1;w2=1;if(menu>2){menu=0;}}// меню
if((analogRead(A0)>900)){i=0;}if(i>3){cl();lcd.print(" MENU 2 ");delay(500);cl();menu1=1;menu=100;}
if((analogRead(A0)<900)&&menu1>0){menu1++;cl();myEnc.write(0);time=millis();w=1;w2=1;if(menu1>6){cl();menu1=0;menu=0;}}// меню 1
if(ir.value==0x2FDD02F){menu++;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;if(menu>2){menu=0;}}// меню кнопка вверх
if(ir.value==0x2FD32CD){menu--;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;if(menu<0){menu=2;}}// меню кнопка вниз
if(ir.value==0x2FDEA15){in++;gr1=0;gr2=0;cl();time=millis();w=1;w2=1;if(in>2){in=0;}audio();lcd.setCursor(0,0);lcd.print("IN ");lcd.print(in+1);delay(1000);}// кнопка IN
if(digitalRead(11)==HIGH && power==0){power=1;vol_old=vol;vol=0;menu = 100;audio();digitalWrite(13,LOW);cl();lcd.setCursor(0,0);lcd.print(" POWER OFF ");}
if(digitalRead(11)==HIGH && power==1){power=0;vol=vol_old;menu=0;digitalWrite(13,HIGH);lcd.setCursor(0,0);lcd.print(" POWER ON ");delay(2000);audio();cl();}
//////////////////////////////////////// Volume 0...63 дБ //////////////////////////////////////
if(ir.value==0x2FD906F){vol++;gr1=1;gr2=0;cl1();w2=1;if(vol<0){vol=0;}if(vol>63){vol=63;}audio();}// кнопка >
if(ir.value==0xFFFFFFFF and gr1==1){vol++;gr2=0;cl1();w2=1;if(vol<0){vol=0;}if(vol>63){vol=63;}audio();}// кнопка >>>>>>
if(ir.value==0x2FDF20D){vol--;gr1=0;gr2=1;cl1();w2=1;if(vol<0){vol=0;}if(vol>63){vol=63;}audio();}// кнопка <
if(ir.value==0xFFFFFFFF and gr2==1){vol--;gr1=0;cl1();w2=1;if(vol<0){vol=0;}if(vol>63){vol=63;}audio();}// кнопка <<<<<<
oldPosition = newPosition;
vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;if(vol>63){vol=63;}if(vol<0){vol=0;}audio();}
lcd.setCursor(0,0);lcd.print("Volume ");lcd.print(" ");
lcd.print(-78.75+(float)vol*1.25,2);lcd.print(" ");lcd.setCursor(14,0);lcd.print("dB");vol_d=vol-15;
if(w2==1){
/////////////////////// индикация тембр НЧ -14...14 дБ ///////////////////
if(w2==1){
/////////////////////// индикация тембр ВЧ -14...14 дБ ///////////////////
if(w2==1){
if(digitalRead(12)==HIGH){in++;;cl();myEnc.write(0);time=millis();w=1;w2=1;if(in>2){in=0;}if(in<0){in=2;}audio();lcd.setCursor(0,0);lcd.print("IN ");lcd.print(in+1);delay(1000);}
///////////////////////////////////// GAIN //////////////////////////////////////////
if(menu1==1){
gain=gain+newPosition;myEnc.write(0);newPosition=0;lcd.clear();time=millis();w=1;w2=1;if(gain>3){gain=3;}if(gain<0){gain=0;}audio();}
if(in==0){gain1=gain;}
if(in==1){gain2=gain;}
if(in==2){gain3=gain;}
lcd.setCursor(0,0);lcd.print(" INPUT ");lcd.print(in+1);lcd.setCursor(0,1);lcd.print(" Gain ");lcd.print((float)gain*3.75);lcd.print(" dB ");
/////////////////////////////// LOUDNESS //////////////////////////////////////////
if(menu1==2){
loud=loud+newPosition;myEnc.write(0);newPosition=0;lcd.clear();time=millis();w=1;w2=1;if(loud>1){loud=0;}if(loud<0){loud=1;}audio();}
lcd.setCursor(0,0);lcd.print("LOUDNESS ");if(loud==1){lcd.print("ON ");}else{lcd.print("OFF");}
////////////////////////////////// att LR //////////////////////////////////////////////
if(menu1==3){
lr=lr-newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;if(lr>31){lr=31;}if(lr<0){lr=0;}audio();}
lcd.setCursor(0,0);lcd.print("Speaker ");lcd.print((float)-lr*1.25,2);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("LR");lcd.setCursor(14,1);lcd.print("dB");
if(w2==1){
for(z=0,z0=0,z1=0;z<=-lr+31;z++,z1++){if(z1>2){z1=0;z0++;}
////////////////////////////////// att LF //////////////////////////////////////////////
if(menu1==4){
lf=lf-newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;if(lf>31){lf=31;}if(lf<0){lf=0;}audio();}
lcd.setCursor(0,0);lcd.print("Speaker ");lcd.print((float)-lf*1.25,2);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("LF");lcd.setCursor(14,1);lcd.print("dB");
if(w2==1){
for(z=0,z0=0,z1=0;z<=-lf+31;z++,z1++){if(z1>2){z1=0;z0++;}
////////////////////////////////// att RF //////////////////////////////////////////////
if(menu1==5){
rf=rf-newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;if(rf>31){rf=31;}if(rf<0){rf=0;}audio();}
lcd.setCursor(0,0);lcd.print("Speaker ");lcd.print((float)-rf*1.25,2);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("RF");lcd.setCursor(14,1);lcd.print("dB");
if(w2==1){
for(z=0,z0=0,z1=0;z<=-rf+31;z++,z1++){if(z1>2){z1=0;z0++;}
////////////////////////////////// att RR //////////////////////////////////////////////
if(menu1==6){
rr=rr-newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;if(rr>31){rr=31;}if(rr<0){rr=0;}audio();}
lcd.setCursor(0,0);lcd.print("Speaker ");lcd.print((float)-rr*1.25,2);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("RR");lcd.setCursor(14,1);lcd.print("dB");
if(w2==1){
for(z=0,z0=0,z1=0;z<=-rr+31;z++,z1++){if(z1>2){z1=0;z0++;}
EEPROM.update(0,vol);
EEPROM.update(1,bass+7);
EEPROM.update(2,treb+7);
EEPROM.update(3,in);
EEPROM.update(4,gain1);EEPROM.update(5,gain2);EEPROM.update(6,gain3);
EEPROM.update(7,loud);
EEPROM.update(8,lr);EEPROM.update(9,rr);EEPROM.update(10,lf);EEPROM.update(11,rf);
menu1=0;lcd.clear();w=0,w2=1;menu=0;}
tda.setAttLR(lr); // аттенюатор LR 0...31
tda.setAttRR(rr); // аттенюатор RR 0...31
tda.setAttLF(lf); // аттенюатор LF 0...31
tda.setAttRF(rf); // аттенюатор RF 0...31
tda.setSwitch(in,loud,gain); // вход 0...2, тонкомпенсация 1 вкл 0 выкл, усиление 0...3
tda.setBass(bass); // тембр НЧ -7...+7
tda.setTreble(treb); // тембр ВЧ -7...+7
