Тема: DAC WM8805 + WM8740 (Arduino)
Основная тема - http://rcl-radio.ru/?p=90769
#define CS 2 // ML WM8740
#define CLK 3 // MC WM8740
#define DATA 4 // MD WM8740
#define CSB 5 // CSB WM8805
#define SCLK 6 // SCLK WM8805
#define SDIN 7 // SDIN WM8805
#define SDOUT 11 // SDOUT WM8805
// 9 // CLK ENCODER
// 8 // DT ENCODER
// 10 // SW ENCODER
// 12 // MUTE BUTTON
Encoder myEnc(9, 8);//CLK, DT
unsigned long times,times1,oldPosition = -999,newPosition;
byte menu,w,w1,www=1,mute;
int vol,vol_d,ball,err,err_old,a[3],in;
lcd.init();lcd.backlight();
lcd.setCursor(0,0);lcd.print(" WM8805 WM8740 ");
lcd.setCursor(0,1);lcd.print("2IS-24bit-192kHz");
pinMode(10,INPUT); // SW энкодер
pinMode(12,INPUT_PULLUP); // кнопка MUTE
pinMode(CS,OUTPUT); // ML WM8740
pinMode(CLK,OUTPUT); // MC WM8740
pinMode(DATA,OUTPUT);// MD WM8740
pinMode(CSB,OUTPUT); // CSB WM8805
pinMode(SCLK,OUTPUT); // SCLK WM8805
pinMode(SDIN,OUTPUT); // SDIN WM8805
pinMode(SDOUT,INPUT); // SDOUT WM8805
vol = EEPROM.read(0);in = EEPROM.read(1);ball = EEPROM.read(9)-10;
// Write WM8740 SPI
WM8740Write(0b000100000000 + vol + ball);//reg0
WM8740Write(0b001100000000 + vol - ball);//reg1
WM8740Write(0b010000001000);//reg2
WM8740Write(0b011000000001);//reg3
WM8740Write(0b110000000000);//reg4
// Write WM8805 SPI
WM8805Write(0x00, 0x01); // RESET
WM8805Write(0x03, 0xBA); // PPL_K 0xBA
WM8805Write(0x04, 0x49); // PPL_K 0x49
WM8805Write(0x05, 0x0C); // PPL_K 0x0C
WM8805Write(0x06, 0x08); // PLL_N 0x08
WM8805Write(0x07, 0b00101000);// 00 CLKOUTDIV[1:0] MCLKDIV FRACEN>!!! FREQMODE[1:0]
WM8805Write(0x08, 0b01110000 + in);// MCLKSRC ALWAYSVALID FILLMODE CLKOUTDIS CLKOUTSRC RXINSEL[2:0]>000:PX0
WM8805Write(0x09, 0b11111111);// SPDIFINMODE[7:0]>gain
WM8805Write(0x0A, 0b00000000);// MASK[7:0]
WM8805Write(0x12, 0b00000000);// CHSTMODE[1:0] DEEMPH[2:0] CPY_N AUDIO_N CON/PRO
WM8805Write(0x13, 0b00000000);// CATCODE[7:0]
WM8805Write(0x14, 0b00000000);// CHNUM2[1:0] CHNUM1[1:0] SRCNUM[3:0]
WM8805Write(0x15, 0b00110001);// TXSTATSRC TXSRC CLKACU[1:0] FREQ[3:0] // default
WM8805Write(0x16, 0b00001011);// ORGSAMP[3:0] TXWL[2:0]>101:24bit MAXWL>1:24bit_max
WM8805Write(0x1B, 0b00001010);// 00 AIFTX_LRP AIFTX_BCP AIFTX_WL[1:0] AIFTX_FMT[1:0]
WM8805Write(0x1C, 0b01001110);// SYNC_OFF>0:no_sound AIF_MS>1:master AIFRX_LRP AIFRX_BCP AIFRX_WL[1:0]>11:24bit AIFRX_FMT[1:0]>10:I2S
WM8805Write(0x1D, 0b01000000);// SPD_192K_EN WL_MASK SPDGPO WITHFLAG CONT READMUX[2:0]
WM8805Write(0x1E, 0b00000100);// 00 TRIOP AIFPD OSCPD SPDIFTXPD SPDIFRXPD PLLPD
delay(1000);lcd.clear();
if(digitalRead(10)==LOW){menu++;if(menu>2){menu=0;};delay(200);lcd.clear();times=millis();w=1;w1=1;www=1;}
/// MUTE /////////////////////////////
if(digitalRead(12)==LOW && mute==0){mute=1; WM8740Write(0b010000001001);delay(300);www=1;}
if(digitalRead(12)==LOW && mute==1){mute=0; WM8740Write(0b010000001000);delay(300);www=1;}
/// VOLUME ///////////////////////////////////
if (newPosition != oldPosition){oldPosition = newPosition;www=0;
vol=vol-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(vol<145){vol=145;}if(vol>245){vol=245;}
Serial.print("VOLUME ");Serial.println(vol);// vol = 145...245 step 0.5 dB + 10 balance
if(www==1||w==1){www=0;w=0;
if(mute==1){ lcd.setCursor(0,0);lcd.print("MUTE ");}
if(err==0&&mute==0){lcd.setCursor(0,0);lcd.print("VOLUME ");}
if(err>0&&mute==0){ lcd.setCursor(0,0);lcd.print("NO SOUND");}
lcd.setCursor(0,1);lcd.print("COAX ");lcd.print(in);
vol_d=vol-146;a[0]=vol_d/10;a[1]=vol_d%10;
for(i=0;i<2;i++){
switch(a[i]){
/// BALANCE ////////////////////////////
ball=ball-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(ball<-10){ball=-10;}if(ball>10){ball=10;}
Serial.print("BALANCE ");Serial.println(ball);
if(ball<0){lcd.setCursor(8,1);lcd.write((uint8_t)0);
lcd.setCursor(0,1);lcd.print("L > R");}
if(ball>0){lcd.setCursor(8,1);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("L < R");}
if(ball==0){lcd.setCursor(8,1);lcd.print(" ");
lcd.setCursor(0,1);lcd.print("L = R");}
lcd.setCursor(0,0);lcd.print("BALANCE ");
a[0]=abs(ball)/10;a[1]=abs(ball)%10;
for(i=0;i<2;i++){
switch(a[i]){
//////// INPUT ////////////////////////////////////
in=in-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(in<0){in=0;}if(in>3){in=3;}
delay(10);
lcd.setCursor(0,0);lcd.print("INPUT SELECTOR");
lcd.setCursor(0,1);lcd.print("COAXIAL "); lcd.print(in);lcd.print(" ");
/// NO SOUND /////////////////////
if(millis()-times1>500){times1=millis();err = WM8805Read(0x0B);
Serial.print("0x0b ");Serial.println(WM8805Read(0x0b),BIN);
Serial.print("0x0c ");Serial.println(WM8805Read(0x0c),BIN);
Serial.print("0x0d ");Serial.println(WM8805Read(0x0d),BIN);
Serial.print("0x0e ");Serial.println(WM8805Read(0x0e),BIN);
Serial.print("0x0f ");Serial.println(WM8805Read(0x0f),BIN);
Serial.print("0x10 ");Serial.println(WM8805Read(0x10),BIN);
Serial.print("0x11 ");Serial.println(WM8805Read(0x11),BIN);
Serial.println();}
if(err!=err_old){err_old = err;www=1;}
/// EEPROM write /////////////////
if(millis()-times>10000 && w1==1){w1=0;EEPROM.update(0,vol);EEPROM.update(1,in);EEPROM.update(9,ball+10);
www=1;if(menu!=0){lcd.clear();}menu=0;}
}// loop
void WM8740Write(int data){
digitalWrite(CLK,HIGH);digitalWrite(CS,HIGH);delay(1);
for(int i = 15; i >= 0; i--){
digitalWrite(CLK,LOW);
digitalWrite(DATA, (data >> i) & 0x01);delay(1);
digitalWrite(CLK,HIGH);delay(1);}
digitalWrite(CS,LOW);delay(1);digitalWrite(CS,HIGH);
void WM8805Write(byte reg, byte dout){ // WRITE_REG
digitalWrite(SCLK,LOW);digitalWrite(CSB,LOW);
for(int i = 7; i >= 0; i--){
digitalWrite(SDIN, (reg >> i) & 0x01);
digitalWrite(SCLK,HIGH);
digitalWrite(SDIN, (dout >> i) & 0x01);
digitalWrite(SCLK,LOW);digitalWrite(CSB,HIGH);
byte WM8805Read(byte reg){ // READ_REG
byte dat[8],data = 0;
reg = reg + (1 << 7);
dat[i] = digitalRead(SDOUT);
data = data + (dat[i] << i);
return data;
