Тема: CS8416 + WM8740
#define CS 2 // ML WM8740
#define CLK 3 // MC WM8740
#define DATA 4 // MD WM8740
#include <LiquidCrystal_I2C.h> //Библиотека - http://forum.rcl-radio.ru/misc.php?action=pan_download&item=45&download=1
Encoder myEnc(9, 8);//CLK, DT
int a[3],vol,vol_d,menu,in,dem,form;
unsigned long times,times1,oldPosition = -999,newPosition;
bool w,w1,www=1,mute;
byte rol,dac_i2s,dac_iw,dem_res,for_dac,for_res,err,err_old;
lcd.init();lcd.backlight();
pinMode(10,INPUT); // SW энкодер
pinMode(11,INPUT_PULLUP); // кнопка MUTE
pinMode(CS,OUTPUT); // ML WM8740
pinMode(CLK,OUTPUT); // MC WM8740
pinMode(DATA,OUTPUT);// MD WM8740
vol = EEPROM.read(0);in = EEPROM.read(1);dem_res = EEPROM.read(3);for_dac = EEPROM.read(4);for_res = EEPROM.read(5);
dac_i2s = EEPROM.read(6);dac_iw = EEPROM.read(7);rol = EEPROM.read(8);
lcd.setCursor(0,0);lcd.print(" CS8416 WM8740 ");
lcd.setCursor(0,1);lcd.print(" 24 bit 192kHz ");
// Write WM8740 SPI
wireWrite(0b000100000000);//reg0
wireWrite(0b001100000000);//reg1
wireWrite(0b010000000000 + (dac_iw << 3));//reg2
wireWrite(0b011000000000 + dac_i2s + (rol << 3));//reg3
wireWrite(0b110000000000);//reg4
// Write 8416 I2C
Wire.beginTransmission(0x10);
Wire.write (0x00);
Wire.write (0b00000000);
Wire.write (0b10000010);
Wire.write (0b00000000 + (dem_res << 4));
Wire.write (0b10000000 + (in << 3));
Wire.write (0b10000000 + (for_res));
Wire.write (0xFF);
Wire.write (0x00);
Wire.write (0x00);
Wire.write (0x00);
Wire.endTransmission();
delay(2000);lcd.clear();
// Write WM8740 SPI
wireWrite(0b000100000000 + vol);//reg0
wireWrite(0b001100000000 + vol);//reg1
/// MENU //////////////////////////////
if(digitalRead(10)==LOW){menu++;if(menu>4){menu=0;};delay(200);lcd.clear();times=millis();w=1;w1=1;www=1;}
/// MUTE /////////////////////////////
if(digitalRead(11)==LOW && mute==0){mute=1; wireWrite(0b010000000001 + (dac_iw << 3));delay(300);www=1;}
if(digitalRead(11)==LOW && mute==1){mute=0; wireWrite(0b010000000000 + (dac_iw << 3));delay(300);www=1;}
if (newPosition != oldPosition){oldPosition = newPosition;www=0;
vol=vol-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(vol<155){vol=155;}if(vol>255){vol=255;}
Serial.println(vol);// vol = 155...255 step 0.5 dB
if(www==1||w==1){www=0;w=0;
if(mute==1){ lcd.setCursor(0,0);lcd.print("MUTE ");}
if(err==0&&mute==0){ lcd.setCursor(0,0);lcd.print("VOLUME ");}
if(err==22&&mute==0){lcd.setCursor(0,0);lcd.print("ERROR ");}
if(err==8&&mute==0){ lcd.setCursor(0,0);lcd.print("NO SOUND");}
lcd.setCursor(0,1);lcd.print("COAX ");lcd.print(in);
vol_d=vol-156;a[0]=vol_d/10;a[1]=vol_d%10;
for(i=0;i<2;i++){
case 1: e1=12,e2=13,e3=14;break;
switch(a[i]){
//////// INPUT ////////////////////////////////////
in=in-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(in<0){in=0;}if(in>7){in=7;}
Wire.write (0x00);
Wire.write (0xFF);
Wire.write (0x00);
Wire.write (0x00);
Wire.write (0x00);
Wire.endTransmission();}
delay(10);
lcd.setCursor(0,0);lcd.print("INPUT SELECTOR");
lcd.setCursor(0,1);lcd.print("COAXIAL "); lcd.print(in);lcd.print(" ");
/// DE-EMPHASIS //////////////////////////////////
dem=dem-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(dem<0){dem=0;}if(dem>3){dem=3;}
Wire.write (0x00);
Wire.write (0xFF);
Wire.write (0x00);
Wire.write (0x00);
Wire.write (0x00);
delay(10);
lcd.setCursor(0,0);lcd.print("DE-EMPHASIS SEL");
lcd.setCursor(0,1);
switch(dem){
case 0: lcd.print("No De-emphasis");dem_res=0;break;
case 1: lcd.print("44.1 kHz ");dem_res=2;break;
case 2: lcd.print("48.0 kHz ");dem_res=3;break;
case 3: lcd.print("32.0 kHz ");dem_res=1;break;
/// FILTER ROLL-OFF //////////////////////////////////
rol=rol-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(rol<0){rol=0;}if(rol>1){rol=1;}
delay(10);
lcd.setCursor(0,0);lcd.print("ROLL-OFF SELECT ");
lcd.setCursor(0,1);
switch(rol){
case 0: lcd.print("Sharp");break;
case 1: lcd.print("Slow ");break;
/// Serial Format Select //////////////////////////////////
if(menu==4){
form=form-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
if(form<0){form=0;}if(form>2){form=2;}
Wire.write (0x00);
Wire.write (0xFF);
Wire.write (0x00);
Wire.write (0x00);
Wire.write (0x00);
delay(10);
delay(10);
lcd.setCursor(0,0);lcd.print("FORMAT SELECT");
lcd.setCursor(0,1);
switch(form){
case 0: lcd.print("L-Just 24 bit");dac_i2s=0;dac_iw=3;for_res=0;break;
case 1: lcd.print("I2S 24 bit");dac_i2s=1;dac_iw=1;for_res=5;break;
case 2: lcd.print("R-Just 24 bit");dac_i2s=0;dac_iw=2;for_res=8;break;
/// read registr error
if(millis()-times1>1000){times1=millis();err = wireRead(0x10,0x0C);delay(10);}
if(err!=err_old){err_old = err;www=1;}
/// EEPROM write
if(millis()-times>10000 && w1==1){w1=0;EEPROM.update(0,vol);EEPROM.update(1,in);
EEPROM.update(3,dem_res);EEPROM.update(4,for_dac);EEPROM.update(5,for_res);
EEPROM.update(6,dac_i2s);EEPROM.update(7,dac_iw);EEPROM.update(8,rol);
menu=0;www=1;if(menu!=0){lcd.clear();}}
delay(100);
}// loop
void wireWrite(int data){ // SPI
digitalWrite(CLK,HIGH);digitalWrite(CS,HIGH);delay(1);
for(int i = 15; i >= 0; i--){
digitalWrite(CLK,LOW);
digitalWrite(DATA, (data >> i) & 0x01);delay(1);
digitalWrite(CLK,HIGH);delay(1);}
digitalWrite(CS,LOW);delay(1);digitalWrite(CS,HIGH);
byte wireRead(int addr, int reg){ // I2C
Wire.beginTransmission(addr);
Wire.write (reg);
delay(10);
Wire.requestFrom(addr,1);
while(Wire.available()<1);
byte value = Wire.read();
return value;
