Тема: DAC CS8416 + CS4398 (Arduino)(2)
Доработка ЦАП
  • Доработан индикатор ERROR - нет звука отображается как "NO SOUND", не подключен кабель COAX отображается как ERROR
 Encoder myEnc(9, 8);//CLK, DT
      int a[3],vol,vol_d,menu,in,dem,form;
      unsigned long times,times1,oldPosition  = -999,newPosition;
      bool w,w1,www=1,mute;
      byte dem_dac,dem_res,for_dac,for_res,err,err_old;
  // Serial.begin(9600);
   lcd.init();lcd.backlight();
   lcd.setCursor(0,0);lcd.print("CS8416  00");lcd.print(wireRead(0x10,0x7F),BIN);
   lcd.setCursor(0,1);lcd.print("CS4398  0");lcd.print(wireRead(0x4C,0x01),BIN);
   delay(2000);
   pinMode(10,INPUT);// SW
   pinMode(11,INPUT_PULLUP); // кнопка MUTE
  vol = EEPROM.read(0);in = EEPROM.read(1);dem_dac = EEPROM.read(2);dem_res = EEPROM.read(3);for_dac = EEPROM.read(4);for_res = EEPROM.read(5);
// Write 8416
  Wire.beginTransmission(0x10);
  Wire.write (0x00);
  Wire.write (0b00000000);
  Wire.write (0b10000010);// 128Fs
  Wire.write (0b00000000 + (dem_res << 4));
  Wire.write (0b10000000 + (in << 3));
  Wire.write (0b10000000 + (for_res));
  Wire.write (0xFF);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.endTransmission();
// End Write ////////////////////////////////////
delay(10);
// Write 4398
  wireWrite(0x4C, 0x02, 0b00000010 + (dem_dac << 2) + (for_dac << 4));
  wireWrite(0x4C, 0x03, 0b00001001);// default
  wireWrite(0x4C, 0x04, 0b11000000);// default
  wireWrite(0x4C, 0x05, vol);
  wireWrite(0x4C, 0x06, vol);
  wireWrite(0x4C, 0x07, 0b10110000);// default
  wireWrite(0x4C, 0x08, 0b01000000);// default
  wireWrite(0x4C, 0x09, 0b00001000);// default
  lcd.clear();
  if(digitalRead(10)==LOW){menu++;if(menu>3){menu=0;};delay(200);lcd.clear();www=1;}
 /// MUTE /////////////////////////////
 if(digitalRead(11)==LOW && mute==0){mute=1;wireWrite(0x4C, 0x04, 0b11011000);delay(300);www=1;}
 if(digitalRead(11)==LOW && mute==1){mute=0;wireWrite(0x4C, 0x04, 0b11000000);delay(300);www=1;}
 /// VOLUME ////////////////////////////
  if (newPosition != oldPosition){oldPosition = newPosition;www=0;
     vol=vol+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
      if(vol<0){vol=0;}if(vol>99){vol=99;}
  if(www==1||w==1){www=0;w=0;
      if(mute==1){         lcd.setCursor(0,0);lcd.print("MUTE    ");}
      if(err==0&&mute==0){ lcd.setCursor(0,0);lcd.print("VOLUME  ");}
      if(err==22&&mute==0){lcd.setCursor(0,0);lcd.print("ERROR   ");}
      if(err==8&&mute==0){ lcd.setCursor(0,0);lcd.print("NO SOUND");}
      lcd.setCursor(0,1);lcd.print("COAX ");lcd.print(in);
     vol_d=99-vol;a[0]=vol_d/10;a[1]=vol_d%10;
      for(i=0;i<2;i++){
      switch(a[i]){
 //////// INPUT ////////////////////////////////////
     in=in-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
      if(in<0){in=0;}if(in>7){in=7;}
  Wire.write (0x00);
  Wire.write (0xFF);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.endTransmission();}
  delay(10);
  lcd.setCursor(0,0);lcd.print("INPUT SELECTOR");
  lcd.setCursor(0,1);lcd.print("COAXIAL "); lcd.print(in);lcd.print(" ");
  /// DE-EMPHASIS //////////////////////////////////
     dem=dem-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
      if(dem<0){dem=0;}if(dem>3){dem=3;}
  Wire.write (0x00);
  Wire.write (0xFF);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.write (0x00);
  delay(10);
  delay(10);
  lcd.setCursor(0,0);lcd.print("DE-EMPHASIS SEL");
  lcd.setCursor(0,1);
  switch(dem){
  case 0: lcd.print("No De-emphasis");dem_dac=0;dem_res=0;break;
  case 1: lcd.print("44.1 kHz      ");dem_dac=1;dem_res=2;break;
  case 2: lcd.print("48.0 kHz      ");dem_dac=2;dem_res=3;break;
  case 3: lcd.print("32.0 kHz      ");dem_dac=3;dem_res=1;break;
  /// Serial Format Select //////////////////////////////////
     form=form-newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;
      if(form<0){form=0;}if(form>2){form=2;}
  Wire.write (0x00);
  Wire.write (0xFF);
  Wire.write (0x00);
  Wire.write (0x00);
  Wire.write (0x00);
  delay(10);
  delay(10);
  lcd.setCursor(0,0);lcd.print("FORMAT SELECT");
  lcd.setCursor(0,1);
  switch(form){
  case 0: lcd.print("L-Just 24 bit");for_dac=0;for_res=0;break;
  case 1: lcd.print("I2S    24 bit");for_dac=1;for_res=5;break;
  case 2: lcd.print("R-Just 24 bit");for_dac=3;for_res=8;break;
  if(millis()-times1>1000){times1=millis();err = wireRead(0x10,0x0C);delay(10);}
  if(err!=err_old){err_old = err;www=1;}
  if(millis()-times>10000 && w1==1){w1=0;EEPROM.update(0,vol);EEPROM.update(1,in);
  EEPROM.update(2,dem_dac);EEPROM.update(3,dem_res);EEPROM.update(4,for_dac);EEPROM.update(5,for_res);
  menu=0;www=1;lcd.clear();}
  Wire.beginTransmission(addr);
  Wire.write (reg);
  Wire.write (data);
byte wireRead(int addr, int reg){
  Wire.write (reg);
  delay(10);
  Wire.requestFrom(addr,1);
  while(Wire.available()<1);
  byte value = Wire.read();
  return value;
Re: DAC CS8416 + CS4398 (Arduino)(2)
отличная работа, спасибо
Прошу простить моё невежество, но - в даташите на CS8416 (страница 35) адрес I2C указан как 0010 AD2 AD1 AD0 0 - бинарный. При выводах 14, 15, 17, посаженных на 0, адрес должен быть 0b00100000 или 0x20.
В авторском скетче при обращении к 8416  "Wire.beginTransmission(0x10);" - и все работает.
Прошу подсказать, в чем моя ошибка ?
4
I2C адрес 7 бит, младший 8-й бит это бит запись\чтение
Я понял картинку из даташита так -
http://forum.rcl-radio.ru/uploads/images/2021/12/c45cfb8c1228775e5e9a6969fb091e93.jpg
Очевидно, где-то недобрал. Благодарю за ответ, пошел курить матчасть.
Вот из Гитхаба https://github.com/StephiB/CS8416/blob/master/CS8416.h
//  Start-of-communication byte
#define CS8416_RD               (0x01)     // Read from a control register
#define CS8416_WR               (0x00)     // Write to a control register
#define CS8416_ADDR                (0x20)     // Identifying address
#define CS8416_WRITE_REG        (CS8416_ADDR | CS8416_WR)     // Start of write sequence
#define CS8416_READ_REG         (CS8416_ADDR | CS8416_RD)     // Start of read sequence
Так что, пока ясности нет...
7
В последних версиях библиотеки Wire.h в функции:
Wire.beginTransmission();
нужно игнорировать младший разряд.
8
Например если взять модуль PCF8574 I2C для дисплеев LCD1602 то во всех скетчах указан адрес от 0x20 до 0x27, но в даташите указано:
http://forum.rcl-radio.ru/uploads/images/2021/12/0ad88b714f0b98c96104acce88ac6132.png
что соответствует адресам от 0x40 до 0x4E
Но если к I2C обращаться через регистры:
void i2c_write_1byte(byte i2c_addr, byte i2c_reg){
   TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);  // START
  while (!(TWCR & (1<<TWINT)));
   TWDR = i2c_addr;
   TWDR = i2c_reg;
То нужно указывать адрес как в даташите, для записи в младшем разряде указывать 0, а для чтения 1.
Наконец-то до меня дошло ! Благодарю за терпение и подробный ответ!!!
