Тема: квадратурный генератор
Здравствуйте
Не могу найти почему нет второго сигнала на PB6,это STM32f103
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag = 0;
int flag1 = 0;
int out = PB6;
int out1 = PB7;
int val[SAMPLES];
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev = PIN_MAP[out].timer_device;
uint8 cc_channel = PIN_MAP[out].timer_channel;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
flag++;
void fun1()
flag1++;
void timer_conf()
timer_dma_set_base_addr(dev, TIMER_DMA_BASE_CCR2);
timer_dma_set_burst_len(dev1, 1);
timer_dma_enable_req(dev, cc_channel1);
timer_set_reload(dev, 102);
timer_set_prescaler(dev, 0);
timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
timer_dma_enable_req(dev1, cc_channel1);
timer_set_reload(dev1, 102);
timer_set_prescaler(dev1, 0);
void dma_conf()
dma_init(DMA1);
/* T4C2 DMA C4 */
dma_cfg.tube_dst = &(dev->regs.gen->DMAR);
dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
dma_cfg.tube_src = val;
dma_cfg.tube_src = val1;
dma_cfg.tube_src_size = DMA_SIZE_32BITS;
dma_cfg.tube_nr_xfers = SAMPLES;
dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
dma_cfg.target_data = 0;
ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
dma_attach_interrupt(DMA1, DMA_CH4, fun);
dma_enable(DMA1, DMA_CH4);
timer_resume(dev1);
dma_enable(DMA1, DMA_CH1);
dma_enable(DMA1, DMA_CH2);
void init_wave()
int i;
for (i = 0; i < SAMPLES; i++)
val[i] = 40 + amp * sin(stp * i);
val1[i] = 40 + amp * sin(stp * i);
// val1[i] = 40 + amp * cos(stp * i);// квадратурный выход
void setup()
int i;
// pinMode(out1, PWM);
pinMode(out, OUTPUT);
pinMode(out1, OUTPUT);
timer_conf();
dma_conf();
dma_start();
init_wave();
void loop()
int i;
//if ( val1[i] > 40)
if ( val1[i] > 38)
digitalWrite(PB7, HIGH);
else
digitalWrite(PB7, LOW);
