Тема: PT2259
Протестировано!!!
PT2259 is an 8-pin 2-channel volume controller which utilizes CMOS technology and incorporates the I2C interface control. The controller features an attenuation range of 0 to -79dB, low noise output, a high degree of stereo separation and requires only a small number of external components. PT2259 is an essential component for modern audio visual systems.
• Attenuation range: 0 to -79dB in 1dB steps
• Operating voltage: 4 to 10V
• Low power consumption
• Low signal noise: S/N > 100dB (A-weighting)
• Stereo separation > 100dB
• Requires few external components
• 2-channel volume individual adjust
• Available in 8 Pins DIP or SOP
http://forum.rcl-radio.ru/uploads/images/2020/06/123c4fb3c56bf97175cf257e26c1f8a0.png
http://forum.rcl-radio.ru/uploads/images/2020/06/6a86956deb98d6be12d7772f8913bf1a.png
Библиотека - https://github.com/liman324/PT2259.git
PT2259.ino
#include <PT2259.h>
 PT2259 pt;
void loop(){}
 pt.setVol_ch2(0, 79); // mute, vol
// mute on  === 1
// mute off === 0
// vol === -79...0 dB === int 0...79
// channel-by-channel adjustment
// pt.setVol_left(0, 79);
// pt.setVol_right(0, 79);
PT2259.h
#ifndef PT2259_H
#define PT2259_H
#define PT2259_address 0b1000100
//Sub addresses
#define CLEAR        0xF0
#define MUTE_OFF     0x74
#define MUTE_ON      0x77
#define MUTE_R      0x75
#define MUTE_L      0x76
#define CH2_1        0b11010000
#define CH2_10       0b11100000
#define LEFT_1       0b10100000
#define LEFT_10      0b10110000
#define RIGHT_1      0b00100000
#define RIGHT_10     0b00110000
#include <Arduino.h>
class PT2259{
public:
PT2259();
void setVol_ch2(bool mute, int vol_ch);
void setVol_left(bool mute, int vol_l);
void setVol_right(bool mute, int vol_r);
void clear();
private:
void writeWire(int8_t a, int8_t b, int8_t c);
#endif //PT2259_H
PT2259.cpp
#include "PT2259.h"
PT2259::PT2259(){
void PT2259::setVol_ch2(bool mute, int vol_ch){
     vol_ch = 79 - vol_ch;
     byte vol_ch_10 = vol_ch/10;
     byte vol_ch_1 = vol_ch%10;
     if(mute==0){writeWire(MUTE_OFF, CH2_10+vol_ch_10, CH2_1+vol_ch_1);}
     if(mute==1){writeWire(MUTE_ON, CH2_10+vol_ch_10, CH2_1+vol_ch_1);}
void PT2259::setVol_left(bool mute, int vol_l){
     vol_l = 79 - vol_l;
     byte vol_l_10 = vol_l/10;
     byte vol_l_1 = vol_l%10;
     if(mute==0){writeWire(MUTE_OFF, LEFT_10+vol_l_10, LEFT_1+vol_l_1);}
     if(mute==1){writeWire(MUTE_L, LEFT_10+vol_l_10, LEFT_1+vol_l_1);}
void PT2259::setVol_right(bool mute, int vol_r){
     vol_r = 79 - vol_r;
     byte vol_r_10 = vol_r/10;
     byte vol_r_1 = vol_r%10;
     if(mute==0){writeWire(MUTE_OFF, RIGHT_10+vol_r_10, RIGHT_1+vol_r_1);}
     if(mute==1){writeWire(MUTE_R, RIGHT_10+vol_r_10, RIGHT_1+vol_r_1);}
void PT2259::clear(){
  Wire.beginTransmission(PT2259_address);
  Wire.write (CLEAR);// clear
  Wire.endTransmission();
void PT2259::writeWire(int8_t a, int8_t b, int8_t c){
  Wire.write (a);    // mute
  Wire.write (b);    // 10 dB
  Wire.write (c);    // 1 dB
Скетч использует 2034 байт (6%) памяти устройства. Всего доступно 32256 байт.
Глобальные переменные используют 219 байт (10%) динамической памяти, оставляя 1829 байт для локальных переменных. Максимум: 2048 байт.
2
Re: PT2259
кнопочное управление
#include <Wire.h> // Входит в состав Arduino IDE
#include <EEPROM.h> // Входит в состав Arduino IDE
#include <PT2259.h> // https://github.com/liman324/PT2259.git
#include <STM32_TM1637.h> // http://forum.rcl-radio.ru/misc.php?action=pan_download&item=452&download=1
 STM32_TM1637 tm(2,3);// CLK, DIO
 PT2259 pt;
 int vol,w=1,w1,mute;
 unsigned long time;
  pinMode(10,INPUT_PULLUP);  // mute
  pinMode(6,INPUT_PULLUP);  // +
  pinMode(7,INPUT_PULLUP);  // -
  tm.brig(7); // ЯРКОСТЬ 0...7
  tm.print_float(0,0,  0b01000000,0b01110011,0b01111000,0b01000000);
  delay(2000);
  tm.print_float(2259,0,  0,0,0,0);
  delay(2000);
  vol = EEPROM.read(0);
////////// VOLUME //////////////
 if(digitalRead(6)==LOW&&mute==0){vol++;delay(300);time=millis();w=1;w1=1;vol_func();}
 if(digitalRead(7)==LOW&&mute==0){vol--;delay(300);time=millis();w=1;w1=1;vol_func();}
 if(w==1){w=0;audio();tm.print_float(vol,1,  0b00001000,0,0,0b00001000);}
///////// MUTE ////////////
  if(digitalRead(10)==LOW&&mute==0){mute=1; audio();tm.print_float(0,0,  0b01000000,0b01000000,0b01000000,0b01000000);delay(500);}
  if(digitalRead(10)==LOW&&mute==1){mute=0; audio();w=1;delay(500);}
///////// EEPROM /////////////
   if(millis()-time>5000 && w1==1){w1=0;EEPROM.update(0,vol);}
   delay(10);
}// loop
 pt.setVol_ch2(mute, vol); // mute, vol
// mute on  === 1
// mute off === 0
void vol_func(){if(vol<0){vol=0;}if(vol>79){vol=79;}}
