Тема: BD37534FV+LCD2004+энкодер+ИК пульт
Требуется тестирование!!!
http://forum.rcl-radio.ru/uploads/images/2020/02/26b7f73864060ccf03497d2dcec4dff9.png
http://forum.rcl-radio.ru/uploads/images/2020/02/74233ee2e01523decfd870e0bbfdf138.png
http://forum.rcl-radio.ru/uploads/images/2020/02/ee419c48d81f46d0ac48e5856b791b3b.png
http://forum.rcl-radio.ru/uploads/images/2020/02/6674efc79d64aae112f667f169dd6cee.png
http://forum.rcl-radio.ru/uploads/images/2020/02/200d1319dd16efdc760b7a0561ed4db1.png
http://forum.rcl-radio.ru/uploads/images/2020/02/0f71f7c50aafaa6d3d476a5402b3839c.png
Управление энкодер, 2 кнопки (IN и SET) и ИК пульт.
#define IR_6 0x2FD6A95 // Кнопка MENU
#include <BD37534FV.h>          // https://github.com/liman324/BD37534FV/archive/master.zip
   BD37534FV bd;
   byte a4[8] = {0b10000,0b11000,0b11100,0b11110,0b11100,0b11000,0b10000,0b00000};
   unsigned long time,times_in,oldPosition  = -999,newPosition;
   byte in,in_x,w,w1,w2[4],w3,z,z0,z1,q,i,www,gr1,gr2;
   int menu,menu0,menu_1,menu_2,vol,bass,treb,mid,vol_d,bass_d,treb_d,mid_d;
   int temp0,gain0,gain1,gain2,gain3,gain_d;
   int bass_f,bass_q,treb_f,treb_q,mid_f,mid_q,loud_f,loud_g;
   int lf,rf,lr,rr,sub,sub_f,faza;
   byte mesto[8]={4,13,4,13,4,13,4,13};
   byte mesto1[8]={0,0,1,1,2,2,3,3};
   byte mesto2[7]={0,11,0,11,11,0,11};
   byte mesto3[7]={0,0,1,1,2,3,3};
   String bass_nam[4]={"60   Hz", "80   Hz", "100  Hz", "120  Hz"};
   String treb_nam[4]={"7.5 kHz", "10  kHz", "12.5kHz", "15  kHz"};
   String mid_nam[4] ={"500  Hz", "1   kHz", "1.5 kHz", "2.5 kHz"};
   String lon_nam[4] ={"250  Hz", "400  Hz", "800  Hz", "disable"};
   String sub_nam[5] ={" OFF   ", " 55  Hz", " 85  Hz", " 120 Hz", " 160 Hz"};
   float bass_nam_1[4]={0.5, 1.0, 1.5, 2.0};
   float mid_nam_1[4]={0.75, 1.0, 1.25, 1.5};
   float treb_nam_1[2]={0.75, 1.25};
void setup() {Serial.begin(9600);
  lcd.setCursor(0,1);lcd.print(" Sound Processor");lcd.setCursor(0,2);lcd.print(" BD37534FV"); delay(2000);
  lcd.createChar(0,a1);lcd.createChar(1,a2);lcd.createChar(2,a3);lcd.createChar(3,a4);
  pinMode(2,INPUT);   // МЕНЮ НАСТРОЕК
  pinMode(3,INPUT);   // IN
  vol = EEPROM.read(0)-79;treb = EEPROM.read(1)-20;mid = EEPROM.read(2)-20;bass = EEPROM.read(3)-20;
  bass_f = EEPROM.read(8);bass_q = EEPROM.read(9);treb_f = EEPROM.read(10);treb_q = EEPROM.read(11);
  lf = EEPROM.read(16)-79;rf = EEPROM.read(17)-79;lr = EEPROM.read(18)-79;rr = EEPROM.read(19)-79;sub = EEPROM.read(20)-79;sub_f = EEPROM.read(21);
  faza = EEPROM.read(22);
  w2_arr();audio();cl();
  if(digitalRead(10)==LOW&&menu0==0){menu++;delay(200);time=millis();w=1;w2_arr();if(menu>3){menu=0;}}// меню 0
  if(digitalRead(10)==LOW&&menu0==1){menu_1++;delay(200);time=millis();w=1;if(menu_1>7){menu_1=0;}}// меню 1
  if(digitalRead(10)==LOW&&menu0==2){menu_2++;delay(200);time=millis();w=1;if(menu_2>6){menu_2=0;}}// меню 2
  if(digitalRead(2)==HIGH){menu0++;cl();delay(200);time=millis();w=1;w2_arr();menu=0;menu_1;menu_2;if(menu0>2){menu0=0;}}// меню
  if(digitalRead(3)==HIGH){in++;cl();times_in=millis();in_x=1;w3=1;www=1;menu0=100;if(in>2){in=0;}}// IN
   if(ir.value==IR_2&&menu0==0){menu++;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu>3){menu=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==0){menu--;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu<0){menu=3;}}//  кнопка вниз
   if(ir.value==IR_2&&menu0==1){menu_1++;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu_1>7){menu_1=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==1){menu_1--;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu_1<0){menu_1=7;}}//  кнопка вниз
   if(ir.value==IR_2&&menu0==2){menu_2++;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu_2>6){menu_2=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==2){menu_2--;gr1=0;gr2=0;cl1();time=millis();w=1;if(menu_2<0){menu_2=6;}}//  кнопка вниз
   if(ir.value==IR_6){menu0++;gr1=0;gr2=0;cl();time=millis();w=1;w2_arr();menu=0;menu_1;menu_2;if(menu0>2){menu0=0;}}//  кнопка MENU
   if(ir.value==IR_5){in++;gr1=0;gr2=0;cl();times_in=millis();in_x=1;w3=1;www=1;menu0=100;if(in>2){in=0;}}//  кнопка IN
  if(menu0==0){
    switch(menu){
      case 3: temp0 = treb;q=3;break;}
     if(ir.value==IR_3){temp0++;gr1=1;gr2=0;cl1();time=millis();w=1;w2[q]=1;www=1;}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){temp0++;gr2=0;cl1();time=millis();;w=1;w2[q]=1;www=1;}// кнопка >>>>>>
     if(ir.value==IR_4){temp0--;gr1=0;gr2=1;cl1();time=millis();;w=1;w2[q]=1;www=1;}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){temp0--;gr1=0;cl1();time=millis();w=1;w2[q]=1;www=1;}// кнопка <<<<<<
     temp0=temp0+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2[q]=1;www=1;}
     switch(menu){
   au();
   for(i=0;i<4;i++){if(menu==i){lcd.setCursor(0,i);lcd.write((uint8_t)3);}else{lcd.setCursor(0,i);lcd.print(" ");}}
   lcd.setCursor(1,0);lcd.print("VOLUME ");if(vol>=0){lcd.print(" ");}lcd.print(vol);lcd.print(" ");vol_d=map(vol,-79,15,0,24);
   lcd.setCursor(1,1);lcd.print("BASS   ");if(bass>=0){lcd.print(" ");}lcd.print(bass);lcd.print(" ");bass_d=map(bass,-20,20,0,24);
   lcd.setCursor(1,2);lcd.print("MIDDLE ");if(mid>=0){lcd.print(" ");}lcd.print(mid);lcd.print(" ");mid_d=map(mid,-20,20,0,24);
   lcd.setCursor(1,3);lcd.print("TREBLE ");if(treb>=0){lcd.print(" ");}lcd.print(treb);lcd.print(" ");treb_d=map(treb,-20,20,0,24);
   if(w2[0]==1){
   if(z1==1){lcd.setCursor(z0+12,0);lcd.write((uint8_t)0);lcd.setCursor(z0+1+12,0);lcd.print(" ");}}
   if(z1==3){lcd.setCursor(z0+12,0);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+12,0);lcd.write((uint8_t)2);}w2[0]=0;}
   if(w2[1]==1){
   if(z1==1){lcd.setCursor(z0+12,1);lcd.write((uint8_t)0);lcd.setCursor(z0+1+12,1);lcd.print(" ");}}
   if(z1==3){lcd.setCursor(z0+12,1);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+12,1);lcd.write((uint8_t)2);}w2[1]=0;}
   if(w2[2]==1){
   if(z1==1){lcd.setCursor(z0+12,2);lcd.write((uint8_t)0);lcd.setCursor(z0+1+12,2);lcd.print(" ");}}
   if(z1==3){lcd.setCursor(z0+12,2);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+12,2);lcd.write((uint8_t)2);}w2[2]=0;}
   if(w2[3]==1){
   if(z1==1){lcd.setCursor(z0+12,3);lcd.write((uint8_t)0);lcd.setCursor(z0+1+12,3);lcd.print(" ");}}
   if(z1==3){lcd.setCursor(z0+12,3);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+12,3);lcd.write((uint8_t)2);}w2[3]=0;}
   }// menu0 = 0
 if(menu0==1){
  switch(menu_1){
      case 0: temp0 = bass_f;break;
      case 1: temp0 = bass_q;break;
      case 2: temp0 = mid_f;break;
      case 3: temp0 = mid_q;break;
      case 4: temp0 = treb_f;break;
      case 5: temp0 = treb_q;break;
      case 6: temp0 = loud_f;break;
     if(ir.value==IR_3){temp0++;gr1=1;gr2=0;cl1();time=millis();w=1;www=1;}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){temp0++;gr2=0;cl1();time=millis();w=1;www=1;}// кнопка >>>>>>
     if(ir.value==IR_4){temp0--;gr1=0;gr2=1;cl1();time=millis();;w=1;www=1;}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){temp0--;gr1=0;cl1();time=millis();w=1;www=1;}// кнопка <<<<<<
     temp0=temp0+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;www=1;}
     switch(menu_1){
      case 5: treb_q = temp0;treb_q_func();break;
  au();
  for(i=0;i<8;i++){if(menu_1==i){lcd.setCursor(mesto[i],mesto1[i]);lcd.write((uint8_t)3);}else{lcd.setCursor(mesto[i],mesto1[i]);lcd.print(" ");}}
  lcd.setCursor(0,0);lcd.print("BASS");lcd.setCursor(5,0);lcd.print(bass_nam[bass_f]);lcd.setCursor(14,0);lcd.print("Q ");lcd.print(bass_nam_1[bass_q]);
  lcd.setCursor(0,1);lcd.print("MIDD");lcd.setCursor(5,1);lcd.print(mid_nam[mid_f]);lcd.setCursor(14,1);lcd.print("Q ");lcd.print(mid_nam_1[mid_q]);
  lcd.setCursor(0,2);lcd.print("TREB");lcd.setCursor(5,2);lcd.print(treb_nam[treb_f]);lcd.setCursor(14,2);lcd.print("Q ");lcd.print(treb_nam_1[treb_q]);
  lcd.setCursor(0,3);lcd.print("LOUD");lcd.setCursor(5,3);lcd.print(lon_nam[loud_f]);lcd.setCursor(14,3);lcd.print("G ");lcd.print(loud_g/10);lcd.print(loud_g%10);lcd.setCursor(18,3);lcd.print("dB");
  }// menu0 = 1
  if(menu0==2){
     switch(menu_2){
      case 0: temp0 = lf;break;
      case 1: temp0 = rf;break;
      case 2: temp0 = lr;break;
      case 3: temp0 = rr;break;
      case 4: temp0 = faza;break;
      case 5: temp0 = sub;break;
      case 6: temp0 = sub_f;break;}
     switch(menu_2){
      case 4: faza = temp0;faza_func();break;
      case 5: sub = temp0;sub_func();break;
      case 6: sub_f = temp0;sub_f_func();break;}
  au();
  for(i=0;i<7;i++){if(menu_2==i){lcd.setCursor(mesto2[i],mesto3[i]);lcd.write((uint8_t)3);}else{lcd.setCursor(mesto2[i],mesto3[i]);lcd.print(" ");}}
  lcd.setCursor(1,0);lcd.print("LF");lcd.setCursor(4,0);lcd.print(lf);lcd.print(" ");lcd.setCursor(7,0);lcd.print("dB ");lcd.setCursor(12,0);lcd.print("RF ");lcd.print(rf);lcd.print(" ");lcd.setCursor(18,0);lcd.print("dB");
  lcd.setCursor(1,1);lcd.print("LR");lcd.setCursor(4,1);lcd.print(lr);lcd.print(" ");lcd.setCursor(7,1);lcd.print("dB ");lcd.setCursor(12,1);lcd.print("RR ");lcd.print(rr);lcd.print(" ");lcd.setCursor(18,1);lcd.print("dB");
  lcd.setCursor(1,2);lcd.print("Subwoofer");lcd.setCursor(12,2);lcd.print("Faza ");if(faza==0){lcd.print("  0");}else{lcd.print("180");}
  lcd.setCursor(1,3);lcd.print("G ");lcd.setCursor(4,3);lcd.print(sub);lcd.print(" ");lcd.setCursor(7,3);lcd.print("dB ");lcd.setCursor(12,3);lcd.print(sub_nam[sub_f]);
 } // menu0 = 2
if(in_x==1){ menu0=100;
     case 0: gain0 = gain1;break;
     case 1: gain0 = gain2;break;
     case 2: gain0 = gain3;break;}
     if(ir.value==IR_3){gain0++;gr1=1;gr2=0;cl1();time=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr2=0;cl1();time=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка >>>>>>
     if(ir.value==IR_4){gain0--;gr1=0;gr2=1;cl1();time=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl1();time=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка <<<<<<
    gain0=gain0+newPosition;myEnc.write(0);newPosition=0;time=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}
     case 0: gain1 = gain0;break;
     case 1: gain2 = gain0;break;
     case 2: gain3 = gain0;break;}
  au();
  lcd.setCursor(2,1);lcd.print("Gain IN ");lcd.print(in+1);lcd.setCursor(12,1);lcd.print(" ");lcd.print(gain0);lcd.print(" ");lcd.setCursor(16,1);lcd.print("dB");gain_d=gain0+1;
   if(w3==1){
   if(z1==1){lcd.setCursor(z0+7,2);lcd.write((uint8_t)0);lcd.setCursor(z0+1+7,2);lcd.print("   ");}}
   if(millis()-times_in>3000){in_x=0;cl();menu0=0;w2_arr();}}
     EEPROM.update(0,vol+79);EEPROM.update(1,treb+20);EEPROM.update(2,mid+20);EEPROM.update(3,bass+20);
     EEPROM.update(8,bass_f);EEPROM.update(9,bass_q);EEPROM.update(10,treb_f);EEPROM.update(11,treb_q),
     EEPROM.update(16,lf+79);EEPROM.update(17,rf+79);EEPROM.update(18,lr+79);EEPROM.update(19,rr+79);EEPROM.update(20,sub+79);EEPROM.update(21,sub_f);
     EEPROM.update(22,faza);
     menu=0;menu_1=0;menu_2=0;w=0;w2_arr();}
  }// loop
void sub_f_func(){if(sub_f>4){sub_f=0;}if(sub_f<0){sub_f=4;}}
void lf_func(){if(lf<-79){lf=-79;}if(lf>15){lf=15;}};
void rf_func(){if(rf<-79){rf=-79;}if(rf>15){rf=15;}};
void lr_func(){if(lr<-79){lr=-79;}if(lr>15){lr=15;}};
void rr_func(){if(rr<-79){rr=-79;}if(rr>15){rr=15;}};
void sub_func(){if(sub<-79){sub=-79;}if(sub>15){sub=15;}};
void loud_f_func(){if(loud_f>3){loud_f=0;}if(loud_f<0){loud_f=3;}}
void loud_g_func(){if(loud_g>20){loud_g=20;}if(loud_g<0){loud_g=0;}}
void bass_q_func(){if(bass_q>3){bass_q=0;}if(bass_q<0){bass_q=3;}}
void mid_f_func(){if(mid_f>3){mid_f=0;}if(mid_f<0){mid_f=3;}}
void treb_f_func(){if(treb_f>3){treb_f=0;}if(treb_f<0){treb_f=3;}}
void bass_f_func(){if(bass_f>3){bass_f=0;}if(bass_f<0){bass_f=3;}}
void mid_func(){if(mid>20){mid=20;}if(mid<-20){mid=-20;}}
   bd.setSetup_1(1,2,0); // default (1,2,0)
   bd.setSetup_2(sub_f,1,0,faza);
   bd.setLoudness_f(loud_f); // 250Hz 400Hz 800Hz Prohibition = int 0...3
   bd.setIn(in); // 0...2
   bd.setIn_gain(gain0,0); // in_gain -- 0...20 = 0...20 dB, mute -- 0 default
   bd.setVol(vol); // -79...+15 dB = int -79...15
   bd.setFront_1(rf); // -79...+15 dB = int -79...15
   bd.setFront_2(lf); // -79...+15 dB = int -79...15
   bd.setRear_1(rr); // -79...+15 dB = int -79...15
   bd.setRear_2(lr); // -79...+15 dB = int -79...15
   bd.setSub(sub); // -79...+15 dB = int -79...15
   bd.mix();
   bd.setBass_setup(bass_q,bass_f); // 0.5 1.0 1.5 2.0 --- int 0...3, 60Hz 80Hz 100Hz 120Hz --- int 0...3
   bd.setMiddle_setup(mid_q,mid_f); // 0.75 1.0 1.25 1.5 --- int 0...3, 500Hz 1kHz 1.5kHz 2.5kHz --- int 0...3
   bd.setTreble_setup(treb_q,treb_f); // 0.75 1.25  --- int 0...1, 7.5kHz 10kHz 12.5kHz 15kHz --- int 0...3
   bd.setBass_gain(bass); // --20 ... +20 dB = int -20 ... 20
   bd.setMiddle_gain(mid); // --20 ... +20 dB = int -20 ... 20
   bd.setTreble_gain(treb); // --20 ... +20 dB = int -20 ... 20
   bd.setLoudness_gain(loud_g); // 0 ... 20 dB = int 0 ... 20
2
Добавлена функция MUTE (кнопка+IR) и STANDBY (POWER) (кнопка+IR+выход управления standby D7)
#define IR_8 0x2FDB24D // Кнопка STANDBY (POWER)
   BD37534FV bd;
   byte in,in_x,w,w1,w2[4],w3,z,z0,z1,q,i,n,www,gr1,gr2,mute,power;
   int lf,rf,lr,rr,sub,sub_f,faza,par;
  pinMode(4,INPUT);// КНОПКА MUTE
  pinMode(5,INPUT);// КНОПКА STANDBY
  pinMode(7,OUTPUT);//  STANDBY
  if(mute==0){
  if(digitalRead(2)==HIGH){menu0++;cl();delay(200);time=millis();w=1;w2_arr();menu=0;menu_1=0;menu_2=0;if(menu0>2){menu0=0;}}// меню
  if(digitalRead(4)==HIGH&&mute==0&&power==0){mute=1;cl();w=1;w2_arr();lcd.setCursor(8,1);lcd.print("MUTE");menu0=100;audio();}// mute on
  if(digitalRead(4)==HIGH&&mute==1&&power==0){mute=0;cl();time=millis();w=1;w2_arr();menu0=0;myEnc.write(0);audio();}// mute off
  if(digitalRead(5)==HIGH&&power==0){power=1;mute=1;audio();lcd.clear();lcd.setCursor(5,1);lcd.print("POWER  OFF");menu0=100;delay(3000);lcd.noBacklight();}// power off
  if(digitalRead(5)==HIGH&&power==1){power=0;mute=0;audio();lcd.backlight();lcd.clear();lcd.setCursor(5,1);lcd.print("POWER   ON ");w=1;w2_arr();menu0=0;myEnc.write(0);audio();delay(3000);lcd.clear();}// power on
  if(power==0){digitalWrite(7,HIGH);}if(power==1){digitalWrite(7,LOW);} // выход STANDBY
   if(mute==0){
   if(ir.value==IR_7&&mute==0&&power==0){mute=1;cl();w=1;w2_arr();lcd.setCursor(8,1);lcd.print("MUTE");menu0=100;audio();}// mute on
   if(ir.value==IR_7&&mute==1&&power==0){mute=0;cl();time=millis();w=1;w2_arr();menu0=0;myEnc.write(0);audio();}// mute off
   if(ir.value==IR_8&&power==0){power=1;mute=1;audio();cl();lcd.setCursor(5,1);lcd.print("POWER  OFF");menu0=100;delay(3000);lcd.noBacklight();}// power off
   if(ir.value==IR_8&&power==1){power=0;mute=0;audio();lcd.backlight();cl();lcd.setCursor(5,1);lcd.print("POWER   ON ");w=1;w2_arr();menu0=0;myEnc.write(0);audio();delay(3000);lcd.clear();}// power on
  if(menu0==0){
    switch(menu){
     switch(menu){
   au();
   for(n=0;n<4;n++){if(w2[n]==1){
   switch(n){
    case 0: par = vol_d;break;
    case 1: par = bass_d;break;
    case 2: par = mid_d;break;
    case 3: par = treb_d;break;
   if(z1==1){lcd.setCursor(z0+12,n);lcd.write((uint8_t)0);lcd.setCursor(z0+1+12,n);lcd.print(" ");}}
   }}// menu0 = 0
 if(menu0==1){
  switch(menu_1){
     switch(menu_1){
  au();
  }// menu0 = 1
  if(menu0==2){
     switch(menu_2){
     switch(menu_2){
  au();
 } // menu0 = 2
  au();
   if(w3==1){
  }// loop
   bd.setIn_gain(gain0,mute); // in_gain -- 0...20 = 0...20 dB, mute -- 0 default
   bd.mix();
3
Добавлены часы (DS1307) в режиме STANDBY
Ручная корректировка времени:
Перейти в режим STANDBY (POWER OFF), нажать и удерживать кнопку IN, далее для корректировки часов нажать кнопку MENU, для корректировки минут нажать кнопку MUTE, для обнуления секунд нажать кнопку STANDBY.
http://forum.rcl-radio.ru/uploads/images/2020/02/d3612fcc59f8b0b46d9bdba8eca57c52.png
#include <iarduino_RTC.h>       // http://rcl-radio.ru/wp-content/uploads/2020/01/iarduino_RTC.zip
   BD37534FV bd;
   iarduino_RTC timer(RTC_DS1307);
   unsigned long time0,times_in,oldPosition  = -999,newPosition;
   int lf,rf,lr,rr,sub,sub_f,faza,par,hour,minut,secon;
   const PROGMEM byte mesto[8] ={4,13,4,13,4,13,4,13};
   const PROGMEM byte mesto1[8]={0,0,1,1,2,2,3,3};
   const PROGMEM byte mesto2[7]={0,11,0,11,11,0,11};
   const PROGMEM byte mesto3[7]={0,0,1,1,2,3,3};
   char * bass_nam[4] ={"60   Hz", "80   Hz", "100  Hz", "120  Hz"};
   char * treb_nam[4]= {"7.5 kHz", "10  kHz", "12.5kHz", "15  kHz"};
   char * mid_nam[4] ={"500  Hz", "1   kHz", "1.5 kHz", "2.5 kHz"};
   char * lon_nam[4] ={"250  Hz", "400  Hz", "800  Hz", "disable"};
   char * sub_nam[5] ={" OFF   ", " 55  Hz", " 85  Hz", " 120 Hz", " 160 Hz"};
  const PROGMEM float bass_nam_1[4]={0.5, 1.0, 1.5, 2.0};
  const PROGMEM float mid_nam_1[4]={0.75, 1.0, 1.25, 1.5};
  const PROGMEM float treb_nam_1[2]={0.75, 1.25};
  timer.begin();
  // УСТАНОВКА ВРЕМЕНИ
  //  timer.settime(0,56,15,30,1,20,4);  // 0  сек, 5 мин, 11 час, 30, января, 2020 года, четверг
  timer.gettime();hour = timer.Hours;minut = timer.minutes;secon = timer.seconds;
  if(mute==0){
  if(digitalRead(10)==LOW&&menu0==0){menu++;delay(200);time0=millis();w=1;w2_arr();if(menu>3){menu=0;}}// меню 0
  if(digitalRead(10)==LOW&&menu0==1){menu_1++;delay(200);time0=millis();w=1;if(menu_1>7){menu_1=0;}}// меню 1
  if(digitalRead(10)==LOW&&menu0==2){menu_2++;delay(200);time0=millis();w=1;if(menu_2>6){menu_2=0;}}// меню 2
  if(digitalRead(2)==HIGH){menu0++;cl();delay(200);time0=millis();w=1;w2_arr();menu=0;menu_1=0;menu_2=0;if(menu0>2){menu0=0;}}// меню
  if(digitalRead(4)==HIGH&&mute==1&&power==0){mute=0;cl();time0=millis();w=1;w2_arr();menu0=0;myEnc.write(0);audio();}// mute off
  if(digitalRead(5)==HIGH&&power==0&&digitalRead(3)==LOW){power=1;mute=1;audio();lcd.clear();lcd.setCursor(5,1);lcd.print("POWER  OFF");menu0=100;delay(3000);lcd.noBacklight();}// power off
  if(digitalRead(5)==HIGH&&power==1&&digitalRead(3)==LOW){power=0;mute=0;audio();lcd.backlight();lcd.clear();lcd.setCursor(5,1);lcd.print("POWER   ON ");w=1;w2_arr();menu0=0;myEnc.write(0);audio();delay(3000);lcd.clear();}// power on
   byte a[6];
     a[0]=timer.Hours/10;
     a[1]=timer.Hours%10;
     a[2]=timer.minutes/10;
     a[3]=timer.minutes%10;
     a[4]=timer.seconds/10;
     a[5]=timer.seconds%10;
 for(i=0;i<6;i++){
        case 0: e1=0,e2=1,e3=2;break;
        case 1: e1=3,e2=4,e3=5;break;
        case 2: e1=7,e2=8,e3=9;break;
      switch(a[i]){
  lcd.setCursor(5,3);lcd.print("POWER  OFF");lcd.noBacklight();
  if(digitalRead(3)==HIGH&&digitalRead(2)==HIGH){hour++;if(hour>23){hour=0;} timer.settime(-1,-1,hour,-1,-1,-1,-1);delay(100);}
  if(digitalRead(3)==HIGH&&digitalRead(4)==HIGH){minut++;if(minut>59){minut=0;} timer.settime(-1,minut,-1,-1,-1,-1,-1);delay(100); }
  if(digitalRead(3)==HIGH&&digitalRead(5)==HIGH){secon=0; timer.settime(secon,-1,-1,-1,-1,-1,-1);delay(100); }
   if(mute==0){
   if(ir.value==IR_2&&menu0==0){menu++;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu>3){menu=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==0){menu--;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu<0){menu=3;}}//  кнопка вниз
   if(ir.value==IR_2&&menu0==1){menu_1++;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu_1>7){menu_1=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==1){menu_1--;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu_1<0){menu_1=7;}}//  кнопка вниз
   if(ir.value==IR_2&&menu0==2){menu_2++;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu_2>6){menu_2=0;}}//  кнопка вверх
   if(ir.value==IR_1&&menu0==2){menu_2--;gr1=0;gr2=0;cl1();time0=millis();w=1;if(menu_2<0){menu_2=6;}}//  кнопка вниз
   if(ir.value==IR_6){menu0++;gr1=0;gr2=0;cl();time0=millis();w=1;w2_arr();menu=0;menu_1;menu_2;if(menu0>2){menu0=0;}}//  кнопка MENU
   if(ir.value==IR_7&&mute==1&&power==0){mute=0;cl();time0=millis();w=1;w2_arr();menu0=0;myEnc.write(0);audio();}// mute off
  if(menu0==0){
    switch(menu){
     switch(menu){
   au();
   switch(n){
   }}// menu0 = 0
 if(menu0==1){
  switch(menu_1){
     switch(menu_1){
  au();
  for(i=0;i<8;i++){if(menu_1==i){lcd.setCursor(pgm_read_byte(&mesto[i]),pgm_read_byte(&mesto1[i]));lcd.write((uint8_t)3);}else{lcd.setCursor(pgm_read_byte(&mesto[i]),pgm_read_byte(&mesto1[i]));lcd.print(" ");}}
  lcd.setCursor(0,0);lcd.print("BASS");lcd.setCursor(5,0);lcd.print(bass_nam[bass_f]);lcd.setCursor(14,0);lcd.print("Q ");lcd.print(pgm_read_float(&bass_nam_1[bass_q]));
  lcd.setCursor(0,1);lcd.print("MIDD");lcd.setCursor(5,1);lcd.print(mid_nam[mid_f]);lcd.setCursor(14,1);lcd.print("Q ");lcd.print(pgm_read_float(&mid_nam_1[mid_q]));
  lcd.setCursor(0,2);lcd.print("TREB");lcd.setCursor(5,2);lcd.print(treb_nam[treb_f]);lcd.setCursor(14,2);lcd.print("Q ");lcd.print(pgm_read_float(&treb_nam_1[treb_q]));
  }// menu0 = 1
  if(menu0==2){
     switch(menu_2){
     switch(menu_2){
  au();
  for(i=0;i<7;i++){if(menu_2==i){lcd.setCursor(pgm_read_byte(&mesto2[i]),pgm_read_byte(&mesto3[i]));lcd.write((uint8_t)3);}else{lcd.setCursor(pgm_read_byte(&mesto2[i]),pgm_read_byte(&mesto3[i]));lcd.print(" ");}}
 } // menu0 = 2
     if(ir.value==IR_3){gain0++;gr1=1;gr2=0;cl1();time0=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr2=0;cl1();time0=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка >>>>>>
     if(ir.value==IR_4){gain0--;gr1=0;gr2=1;cl1();time0=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl1();time0=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}// кнопка <<<<<<
    gain0=gain0+newPosition;myEnc.write(0);newPosition=0;time0=millis();times_in=millis();www=1;w=1;w3=1;gain_func();}
  au();
   if(w3==1){
  if(millis()-time0>10000 && w==1){
  }// loop
   bd.mix();
4
Добавлены часы (DS3231) в режиме STANDBY
#include <DS3231.h>             //https://github.com/jarzebski/Arduino-DS3231/archive/master.zip
   BD37534FV bd;
  clock.begin();// Инициализируем работу с объектом библиотеки DS3231
  // clock.setDateTime(2016, 9, 15, 0, 0, 0);// Установка времени вручную (Год, Месяц, День, Час, Минута, Секунда)
  if(mute==0){
   byte a[6];
     a[0]=DateTime.hour/10;
     a[1]=DateTime.hour%10;
     a[2]=DateTime.minute/10;
     a[3]=DateTime.minute%10;
     a[4]=DateTime.second/10;
     a[5]=DateTime.second%10;
 for(i=0;i<6;i++){
      switch(a[i]){
  if(digitalRead(3)==HIGH&&digitalRead(2)==HIGH){hour++;if(hour>23){hour=0;} clock.setDateTime(2020, 9, 15, hour, minut, secon);delay(100);}
  if(digitalRead(3)==HIGH&&digitalRead(4)==HIGH){minut++;if(minut>59){minut=0;} clock.setDateTime(2020, 9, 15, hour, minut, secon);delay(100); }
  if(digitalRead(3)==HIGH&&digitalRead(5)==HIGH){secon=0; clock.setDateTime(2020, 9, 15, hour, minut, secon);delay(100); }
   if(mute==0){
  if(menu0==0){
    switch(menu){
     switch(menu){
   au();
   switch(n){
   }}// menu0 = 0
 if(menu0==1){
  switch(menu_1){
     switch(menu_1){
  au();
  }// menu0 = 1
  if(menu0==2){
     switch(menu_2){
     switch(menu_2){
  au();
 } // menu0 = 2
  au();
   if(w3==1){
  }// loop
   bd.mix();
5 (2020-04-17 23:37:34 отредактировано OlegK)
Спасибо автору за скетч, собрал, всё работает (я проверял код из "шапки")
Индикацию уровня сигнала сложно ли добавить? Если никто ничего не крутит и не нажимает, то переход в режим индикации.
Четырёхстрочный дисплей, КМК, хорошо бы подошёл - две центральные строки для отображения уровня, а верхняя/нижняя - для рисок шкалы в дБ.
6
Не получится, памяти совсем мало свободной. Так же с i2c подключением экрана все будет тормозить.
7
Понятно, спасибо.
8
загрузил последний скетч с часами (DS3231),на дисплее пусто.
9
Загрузите i2c сканер http://forum.rcl-radio.ru/viewtopic.php?id=64
Проверьте адреса уст-в i2c.
10
я не правильно выразился,при включении на экране надпись (соунд процессор BD37534FV) и дальше пусто просто светится,предыдущий скетч работает нормально.
11
Проверить смогу только завтра, но скетч был рабочим, без тестирования я бы смог бы его написать.
Библиотека IRemote  установлена с этой ссылки  http://rcl-radio.ru/wp-content/uploads/ … remote.zip ?
12
все библиотеки с внутренних ссылок! переместил всё что относится к часам (DS3231)в предыдущий скетч,перестал работать! стало как в последнем при загрузке надпись потом пустота.
13
DS3231 не запустилась, библиотека в последнем скетче другая для часов. У Вас модуль часов DS3231?
14 (2020-08-30 22:26:07 отредактировано pulase)
без модуля часов DS3231 меню должно быть!а у меня пишет (соунд процессор BD37534FV) и дальше пусто просто светится,предыдущий скетч часы (DS1307) работает нормально.Я в курсе что если часы другие то и библиотека должна быть другая.я хотел сказать что скетч перестаёт работать после внедрения DS3231 в программу.
15
Без часов DS3231 не будет работать, это точно, уже проверено!
16
а без  (DS1307) всё работает!кроме часов.
17
Библиотека DS3132 не позволяет запустить скетч без часов.
18
Доброго времени суток. Собрал все, но столкнулся с проблемой... постоянно листается меню (( Что нужно поправить? Грешил на энкодер... но 3 штуки себя так ведут.
19
На плате энкодера должны быть установлены 3 подтягивающих резистора по 10 кОм (к +5 В) к выходам clk dt sw. Если у Вас энкодер без платы, то установите эти резисторы. Выход sw - кнопка, на выходе в нормальном состоянии 5 В, при нажатии 0 В.
20
Есть там резисторы и даже нового образца энкодер , где кроме резисторов еще есть и кондерчики. Ведут себя одинаково ((
21
На выходе SW энкодера должно быть 5 В, при нажатии 0. Проверьте.
22
Есть 4.76В при нажатии 0В.
23
Какой скетч используете, укажите ссылку или номер сообщения форума
24
Пытаюсь этот использовать http://forum.rcl-radio.ru/viewtopic.php?pid=1028#p1028
А вот этот скетч работает http://rcl-radio.ru/?p=66914&cpage=1#comments
25
SW точно подключена к D10?
