возможно поможет
void setka(){
switch(c){
case 0:ch(C1_SET,0);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 1:ch(C1_SET,1);ch(C2_SET,0);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 2:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,0);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 3:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,0);ch(C5_SET,1);ch(C6_SET,1);break;
case 4:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,0);ch(C6_SET,1);break;
case 5:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,0);break;
замените на
void setka(){
switch(c){
case 6:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
void to_Timer(){
case 0: segm=12; setka();segment(1); delayMicroseconds(brig); segm_dn=wesk; c=5; setka();dn(bud); break;
case 1: segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[0]; c=4; setka();segment(1); break;
case 2: segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[1]; c=3; setka();segment(kolorol); break;
case 3: segm=12; setka();segment(1); delayMicroseconds(brig); segm=s_tic; c=2; setka();tic(); break;
case 4: segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[2]; c=1; setka();segment(prog); break;
case 5: segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[3]; c=0; setka();segment(timers); break;
}i++;if(i>5){i=0;}}
заменить на
void to_Timer(){
case 0: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm_dn=wesk; c=5; setka();dn(bud); break;
case 1: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[0]; c=4; setka();segment(1); break;
case 2: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[1]; c=3; setka();segment(kolorol); break;
case 3: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=s_tic; c=2; setka();tic(); break;
case 4: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[2]; c=1; setka();segment(prog); break;
case 5: c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[3]; c=0; setka();segment(timers); break;
}i++;if(i>5){i=0;}}
