Тема: ИВЛ1–7/5 + PT6312
Основная статья - http://rcl-radio.ru/?p=131652
http://forum.rcl-radio.ru/uploads/images/2024/02/33023a179ed6dbfff43cf2be30c2e74a.png
#define STB 4
#define DIN 2
#define CLK 3
#define SET 5
#define UP  6
#define DW  7
int a[5];
int hour,minut,set;
long times,times0;
bool d,mig;
  Serial.begin(9600);clock.begin();
  ///clock.setDateTime(__DATE__, __TIME__); // Устанавливаем время на часах, основываясь на времени компиляции скетча
  pinMode(STB,OUTPUT);
  pinMode(DIN,OUTPUT);
  pinMode(CLK,OUTPUT);
  pinMode(SET,INPUT_PULLUP);
  pinMode(UP,INPUT_PULLUP);
  pinMode(DW,INPUT_PULLUP);
  delay(100);
  digitalWrite(STB,HIGH);delay(200);
  // PWM OUTPUT D9 TIMER 1
  TCCR1A = 0;TCCR1B = 0;
  TCCR1A = (1 << COM1A1)|(1 << WGM11);
  TCCR1B = (1 << WGM13)|(1 << WGM12)|(1 << CS10);
  DDRB =  1 << DDB1; // OUTPUT PWM (OCR1A)
  OCR1A = 15;
  ICR1 = 40;
  write_byte1_PT6312(0b01000100);// command 2
  write_byte1_PT6312(0b00000100);// command 1 8dig/14seg
  write_byte1_PT6312(0b10001111);// command 4 display on
  hour = DateTime.hour;
  minut = DateTime.minute;
  if(digitalRead(SET)==LOW){set++;if(set>2){set=0;} delay(300);}
  if(digitalRead(UP)==LOW&&set==1){hour++;if(hour>23){hour=23;} clock.setDateTime(2024, 2, 22, hour, minut, 0);delay(100);}
  if(digitalRead(DW)==LOW&&set==1){hour--;if(hour<0){hour=0;} clock.setDateTime(2024, 2, 22, hour, minut, 0);delay(100);}
  if(digitalRead(UP)==LOW&&set==2){minut++;if(minut>59){minut=59;} clock.setDateTime(2024, 2, 22, hour, minut, 0);delay(100);}
  if(digitalRead(DW)==LOW&&set==2){minut--;if(minut<0){minut=0;} clock.setDateTime(2024, 2, 22, hour, minut, 0);delay(100);}
  if(millis()-times0<200){mig=1;}
  if(millis()-times0>200){mig=0;}
  if(millis()-times0>400){times0=millis();}
  if(millis()-times<500){d=1;}
  if(millis()-times>500){d=0;}
  if(millis()-times>1000){times=millis();}
  if(set==0){
  a[0]=minut%10;
  a[1]=minut/10%10;
  a[2]=hour%10;
  a[3]=hour/10%10;}
  if(set!=2){a[0]=minut%10;}
  if(set!=2){a[1]=minut/10%10;}
  if(set==2&&mig==0){a[0]=minut%10;}
  if(set==2&&mig==0){a[1]=minut/10%10;}
  if(set==2&&mig==1){a[0]=10;}
  if(set==2&&mig==1){a[1]=10;}
  if(set!=1){a[2]=hour%10;}
  if(set!=1){a[3]=hour/10%10;}
  if(set==1&&mig==0){a[2]=hour%10;}
  if(set==1&&mig==0){a[3]=hour/10%10;}
  if(set==1&&mig==1){a[2]=10;}
  if(set==1&&mig==1){a[3]=10;}
             //dp g f e d c b a
  write_byte2_PT6312(0b11000000,seg(a[0],0));//GR1
  write_byte2_PT6312(0b11000010,seg(a[1],0));//GR2
  write_byte2_PT6312(0b11000100,seg(a[2],0));//GR3
  write_byte2_PT6312(0b11000110,seg(a[3],0));//GR4
  write_byte2_PT6312(0b11001000,seg(0,d));//GR5
  delay(100);
byte seg(int a, bool dp){
  byte segm;
  switch(a){
    case 0: segm=0b00111111+(dp<<7);break;
    case 1: segm=0b00000110+(dp<<7);break;
    case 2: segm=0b01011011+(dp<<7);break;
    case 3: segm=0b01001111+(dp<<7);break;
    case 4: segm=0b01100110+(dp<<7);break;
    case 5: segm=0b01101101+(dp<<7);break;
    case 6: segm=0b01111101+(dp<<7);break;
    case 7: segm=0b00000111+(dp<<7);break;
    case 8: segm=0b01111111+(dp<<7);break;
    case 9: segm=0b01101111+(dp<<7);break;
    case 10:segm=0b00000000;break;// пусто
    case 11:segm=0b01000000;break;// -
    case 12:segm=0b01100011;break;// градус
    case 13:segm=0b00111001;break;// С
    return segm;
void write_byte1_PT6312(byte data){
     digitalWrite(STB,LOW);
   for(int i = 0; i <= 7; i++){
     digitalWrite(CLK,LOW);
     digitalWrite(DIN, (data >> i) & 1);
     digitalWrite(CLK,HIGH);
     digitalWrite(STB,HIGH);delay(1);
void write_byte2_PT6312(byte reg, byte data){
     digitalWrite(DIN, (reg >> i) & 1);
     delay(1);
Re: ИВЛ1–7/5 + PT6312
Конечно можно, просто меняете указанные биты (сегменты) местами:
3
Здраствуйте.
Заинтерисовала ваша статься.
К сожалению, в программировании я полный ноль.
Можете помочь: что нужно изменить в скетче. чтобы отзеркалить Sg1 ... Sg 8 относительно выводов драйвера  pт6312.
на схеме SG1 на 15 ноге дравера... Как sg1 переместить на 22 ногу, Sg2 на 21  и т.д?
И похожий вопрос , относительно GR1..5?
4
Просто отзеркальте байт
для сегментов
case 0: segm=0b11111100+(dp<<7);break;
для разрядов изменить порядок включения
write_byte2_PT6312(0b11001000,seg(a[0],0));//GR1
  write_byte2_PT6312(0b11000110,seg(a[1],0));//GR2
  write_byte2_PT6312(0b11000010,seg(a[3],0));//GR4
  write_byte2_PT6312(0b11000000,seg(0,d));//GR5
5
огромное спасибо за ответ.. буду думать над вашими словами и пробовать
