Тема: ESP32 генератор, регулировка частоты
Пытаюсь менять частоту грнератора используя кнопк, но делаю чо то не так . Может кто то знает что делаю неправельно.
//https://www.i-programmer.info/programming/148-hardware/17804-programming-the-esp32-in-c-pwm-first-example.html?start=4#google_vignette
#include <driver/ledc.h>
int k;
//const int btn_inc = 16;
//const int btn_dec = 17;
const int maxFreq = 18000;
const int minFreq = 5000;
//unsigned long tim_btn_inc, tim_btn_dec;
// variables will change:
int freq = maxFreq;
int interval = 1; // variables will change:
Serial.begin(115200);
pinMode(32, INPUT_PULLUP); //k++
pinMode(33, INPUT_PULLUP); //k--
ledc_timer_config_t timerConfig = {
.speed_mode = LEDC_LOW_SPEED_MODE,
.duty_resolution = LEDC_TIMER_10_BIT,
.timer_num = LEDC_TIMER_0,
.freq_hz = 10000, //+++++++++++++++++++++++++++++
.clk_cfg = LEDC_AUTO_CLK
ledc_timer_config(&timerConfig);
ledc_channel_config_t channelConfig1 = {
.gpio_num = 12,
.channel = LEDC_CHANNEL_0,
.timer_sel = LEDC_TIMER_0,
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig1);
ledc_channel_config_t channelConfig2 = {
.gpio_num = 27,
.channel = LEDC_CHANNEL_1,
.duty = 512,
.hpoint = 256
ledc_channel_config(&channelConfig2);
void loop()
void frequencyChange() //void somefunc()
// your variable here
if (digitalRead(32) == LOW) {
k++;
if (k > 18000) k = 18000;
// Serial.println(k); //for debugging purposes
if (digitalRead(33) == LOW) {
k--;
if (k < 5000) k = 5000;
.freq_hz = k, //+++++++++++++++++++++++++++++
Serial.print(" k3 = ");
Serial.println(k);
delay( 2 );
