#define C1_SET 0
#define C2_SET 1
#define C3_SET 2
#define C4_SET 3
#define C5_SET 4
#define C6_SET 5
#define A_SEG 6
#define B_SEG 7
#define C_SEG 8
#define D_SEG 9
#define E_SEG 10
#define F_SEG 11
#define G_SEG 12
#define H_SEG 13
#include <DS3231.h> //https://github.com/jarzebski/Arduino-DS3231/archive/master.zip
int i,segm,c,segm_dn, ss,mm,hh,dd,mon,gg,wesk,times;
int a[4],s_tic, bud,kolorol, prog, timers;
int fff;
unsigned long times_0, times_1;
MsTimer2::set(4, to_Timer);MsTimer2::start(); // timer2 period 4 ms
pinMode(C1_SET,OUTPUT); pinMode(C2_SET,OUTPUT);pinMode(C3_SET,OUTPUT);
pinMode(C4_SET,OUTPUT);pinMode(C5_SET,OUTPUT);pinMode(C6_SET,OUTPUT);
pinMode(A_SEG,OUTPUT); pinMode(B_SEG,OUTPUT);pinMode(C_SEG,OUTPUT);
pinMode(D_SEG,OUTPUT);pinMode(E_SEG,OUTPUT);pinMode(F_SEG,OUTPUT);
pinMode(G_SEG,OUTPUT);pinMode(H_SEG,OUTPUT);
Wire.begin();clock.begin();
if(millis()-times_1>=1000){ times_1=millis();
ss = DateTime.second;
mm = DateTime.minute;
hh = DateTime.hour;
dd = DateTime.day;
mon = DateTime.month;
gg = DateTime.year; // Год
wesk = DateTime.dayOfWeek; // День недели (1 - воскресенье, 7 - суббота)
if(millis()-times_0<=500){s_tic = 0;}
if(millis()-times_0>500){s_tic = 1;}
if(millis()-times_0>1000){times_0=millis();}
times = hh*100+mm;
a[0]=times/1000;
a[1]=times/100%10;
a[2]=times/10%10;
a[3]=times%10;
delay(100);
void to_Timer(){
bud = 1;
kolorol = 1;
prog = 1;
timers = 1;
case 0: segm_dn=wesk; c=0; setka();dn(bud); break;
case 1: segm=a[0]; c=1; setka();segment(1); break;
case 2: segm=a[1]; c=2; setka();segment(kolorol); break;
case 3: segm=s_tic; c=3; setka();tic(); break;
case 4: segm=a[2]; c=4; setka();segment(prog); break;
case 5: segm=a[3]; c=5; setka();segment(timers); break;
}i++;if(i>5){i=0;}}
void segment(bool hhh){
switch(segm){
case 0: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,0);ch(F_SEG,0);ch(G_SEG,1);ch(H_SEG,hhh);break;// 0
case 1: ch(A_SEG,1);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,1);ch(E_SEG,1);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,hhh);break;// 1
case 2: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,1);ch(D_SEG,0);ch(E_SEG,0);ch(F_SEG,1);ch(G_SEG,0);ch(H_SEG,hhh);break;// 2
case 3: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,1);ch(F_SEG,1);ch(G_SEG,0);ch(H_SEG,hhh);break;// 3
case 4: ch(A_SEG,1);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,1);ch(E_SEG,1);ch(F_SEG,0);ch(G_SEG,0);ch(H_SEG,hhh);break;// 4
case 5: ch(A_SEG,0);ch(B_SEG,1);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,1);ch(F_SEG,0);ch(G_SEG,0);ch(H_SEG,hhh);break;// 5
case 6: ch(A_SEG,0);ch(B_SEG,1);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,0);ch(F_SEG,0);ch(G_SEG,0);ch(H_SEG,hhh);break;// 6
case 7: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,1);ch(E_SEG,1);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,hhh);break;// 7
case 8: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,0);ch(F_SEG,0);ch(G_SEG,0);ch(H_SEG,hhh);break;// 8
case 9: ch(A_SEG,0);ch(B_SEG,0);ch(C_SEG,0);ch(D_SEG,0);ch(E_SEG,1);ch(F_SEG,0);ch(G_SEG,0);ch(H_SEG,hhh);break;// 9
void dn(bool ind_bud){
switch(segm_dn){
case 1: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,0);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,1);break;// ВС
case 2: ch(A_SEG,0);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,1);break;// ПН
case 3: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,0);break;// ВТ
case 4: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,0);ch(G_SEG,1);ch(H_SEG,1);break;// СР
case 5: ch(A_SEG,1);ch(B_SEG,0);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,1);break;// ЧТ
case 6: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,0);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,1);break;// ПТ
case 7: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,ind_bud);ch(F_SEG,1);ch(G_SEG,0);ch(H_SEG,1);break;// СБ
void tic(){
switch(s_tic){
case 0: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,1);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,1);break;// _
case 1: ch(A_SEG,1);ch(B_SEG,1);ch(C_SEG,1);ch(D_SEG,1);ch(E_SEG,1);ch(F_SEG,1);ch(G_SEG,1);ch(H_SEG,0);break;// :
void setka(){
switch(c){
case 5:ch(C1_SET,0);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 4:ch(C1_SET,1);ch(C2_SET,0);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 3:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,0);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break;
case 2:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,0);ch(C5_SET,1);ch(C6_SET,1);break;
case 1:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,0);ch(C6_SET,1);break;
case 0:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,0);break;
