Тема: oled 1.3 sh1106 + Attiny
установить подтягивающие резисторы 4.7 кОм на шину I2C
#include <avr/io.h>
#include <util/delay.h>
#define I2C_SDA         PB3
#define I2C_SCL         PB4
long ttt;
#define I2C_SDA_HIGH()  DDRB &= ~(1<<I2C_SDA)
#define I2C_SDA_LOW()   DDRB |=  (1<<I2C_SDA)
#define I2C_SCL_HIGH()  DDRB &= ~(1<<I2C_SCL)
#define I2C_SCL_LOW()   DDRB |=  (1<<I2C_SCL)
const char Message1[] PROGMEM = "RCL-RADIO.RU";
const char Message2[] PROGMEM = "ABCDEFGH";
int main(void) {
  OLED_init();
  OLED_clear();
  while(1) {
    ttt++;
    OLED_cursor(0, 0);
    OLED_printP(Message1);
    OLED_cursor(0, 2);
    OLED_num(ttt/100000);OLED_num(ttt/10000%10);OLED_num(ttt/1000%10);OLED_num(ttt/100%10);OLED_num(ttt/10%10);OLED_num(ttt%10);
    OLED_cursor(0, 4);
    OLED_printP(Message2);
    OLED_cursor(0, 7);
    _delay_ms(1000);
 //   OLED_clear();
///// I2C ///////////////////////////////////////////////////////
void I2C_init(void) {DDRB  &= ~((1<<I2C_SDA)|(1<<I2C_SCL)); PORTB &= ~((1<<I2C_SDA)|(1<<I2C_SCL));}
void I2C_write(uint8_t data) {
  for(uint8_t i = 8; i; i--) {I2C_SDA_LOW();
    if (data & 0x80) I2C_SDA_HIGH();I2C_SCL_HIGH();data<<=1;I2C_SCL_LOW();}
  I2C_SDA_HIGH();I2C_SCL_HIGH();asm("nop");I2C_SCL_LOW();
void I2C_start(uint8_t addr) {I2C_SDA_LOW();I2C_SCL_LOW();I2C_write(addr);}
void I2C_stop(void) {I2C_SDA_LOW();I2C_SCL_HIGH();I2C_SDA_HIGH();}
///// OLED ///////////////////////////////////
#define OLED_ADDR       0x78
#define OLED_CMD_MODE   0x00
#define OLED_DAT_MODE   0x40
#define OLED_INIT_LEN   13
// OLED init settings
const uint8_t OLED_INIT_CMD[] PROGMEM = {0xA8,0x3F,0x81,0xff,0xA1,0xC0,0xC8,0xDA,0x12,0xD3,0x00,0x40,0xAF};
// Standard ASCII 5x8 font (adapted from Neven Boyanov and Stephen Denne)
const uint8_t OLED_FONT[] PROGMEM = {
  0x00, 0x00, 0x00, 0x00, 0x00, //   0
  0x00, 0x1c, 0x22, 0x41, 0x00, // ( 8
  0x00, 0x41, 0x22, 0x1c, 0x00, // ) 9
  0x14, 0x08, 0x3E, 0x08, 0x14, // * 10
  0x08, 0x08, 0x3E, 0x08, 0x08, // + 11
  0x00, 0x00, 0xA0, 0x60, 0x00, // , 12
  0x08, 0x08, 0x08, 0x08, 0x08, // - 13
  0x00, 0x60, 0x60, 0x00, 0x00, // . 14
  0x20, 0x10, 0x08, 0x04, 0x02, // / 15
  0x3E, 0x51, 0x49, 0x45, 0x3E, // 0 16
  0x00, 0x42, 0x7F, 0x40, 0x00, // 1 17
  0x42, 0x61, 0x51, 0x49, 0x46, // 2 18
  0x21, 0x41, 0x45, 0x4B, 0x31, // 3 19
  0x18, 0x14, 0x12, 0x7F, 0x10, // 4 20
  0x27, 0x45, 0x45, 0x45, 0x39, // 5 21
  0x3C, 0x4A, 0x49, 0x49, 0x30, // 6 22
  0x01, 0x71, 0x09, 0x05, 0x03, // 7 23
  0x36, 0x49, 0x49, 0x49, 0x36, // 8 24
  0x06, 0x49, 0x49, 0x29, 0x1E, // 9 25
  0x00, 0x36, 0x36, 0x00, 0x00, // : 26
  0x00, 0x56, 0x36, 0x00, 0x00, // ; 27
  0x08, 0x14, 0x22, 0x41, 0x00, // < 28
  0x14, 0x14, 0x14, 0x14, 0x14, // = 29
  0x00, 0x41, 0x22, 0x14, 0x08, // > 30
  0x02, 0x01, 0x51, 0x09, 0x06, // ? 31
  0x32, 0x49, 0x59, 0x51, 0x3E, // @ 32
  0x7C, 0x12, 0x11, 0x12, 0x7C, // A 33
  0x7F, 0x49, 0x49, 0x49, 0x36, // B 34
  0x3E, 0x41, 0x41, 0x41, 0x22, // C 35
  0x7F, 0x41, 0x41, 0x22, 0x1C, // D 36
  0x7F, 0x49, 0x49, 0x49, 0x41, // E 37
  0x7F, 0x09, 0x09, 0x09, 0x01, // F 38
  0x3E, 0x41, 0x49, 0x49, 0x7A, // G 39
  0x7F, 0x08, 0x08, 0x08, 0x7F, // H 40
  0x00, 0x41, 0x7F, 0x41, 0x00, // I 41
  0x20, 0x40, 0x41, 0x3F, 0x01, // J 42
  0x7F, 0x08, 0x14, 0x22, 0x41, // K 43
  0x7F, 0x40, 0x40, 0x40, 0x40, // L 44
  0x7F, 0x02, 0x0C, 0x02, 0x7F, // M 45
  0x7F, 0x04, 0x08, 0x10, 0x7F, // N 46
  0x3E, 0x41, 0x41, 0x41, 0x3E, // O 47
  0x7F, 0x09, 0x09, 0x09, 0x06, // P 48
  0x3E, 0x41, 0x51, 0x21, 0x5E, // Q 49
  0x7F, 0x09, 0x19, 0x29, 0x46, // R 50
  0x46, 0x49, 0x49, 0x49, 0x31, // S 51
  0x01, 0x01, 0x7F, 0x01, 0x01, // T 52
  0x3F, 0x40, 0x40, 0x40, 0x3F, // U 53
  0x1F, 0x20, 0x40, 0x20, 0x1F, // V 54
  0x3F, 0x40, 0x38, 0x40, 0x3F, // W 55
  0x63, 0x14, 0x08, 0x14, 0x63, // X 56
  0x07, 0x08, 0x70, 0x08, 0x07, // Y 57
  0x61, 0x51, 0x49, 0x45, 0x43, // Z 58
void OLED_init(void) {
  I2C_init();
  I2C_start(OLED_ADDR);
  I2C_write(OLED_CMD_MODE);
  for (uint8_t i = 0; i < OLED_INIT_LEN; i++) I2C_write(pgm_read_byte(&OLED_INIT_CMD[i]));
  I2C_stop();
void OLED_printC(char ch) {
  uint16_t offset = ch - 32 -7;
  offset += offset << 2;
  I2C_write(0x00);
  for(uint8_t i=5; i; i--) I2C_write(pgm_read_byte(&OLED_FONT[offset++]));
void OLED_printP(const char* p) {
  I2C_write(OLED_DAT_MODE);
  char ch = pgm_read_byte(p);
  while (ch != 0){OLED_printC(ch);ch = pgm_read_byte(++p);}
  I2C_stop();
void OLED_cursor(uint8_t xpos, uint8_t ypos) {
  I2C_write(xpos+1 & 0x0F);
  I2C_write(0x10 | (xpos >> 4));
  I2C_write(0xB0 | (ypos & 0x07));
  I2C_stop();
void OLED_clear(void) {
  for(uint16_t b=0;b<8;b++){
  OLED_cursor(0, b);
  for(uint16_t i=129; i; i--) I2C_write(0x00);
  I2C_stop();
void OLED_num(byte num){
  OLED_printC(num+48);
  I2C_stop();
2 (2024-12-02 14:00:30 отредактировано gabiivg)
Re: oled 1.3 sh1106 + Attiny
3 (2025-01-13 10:56:35 отредактировано klause)
Для  OLED I2C 128 x 32.
#include <avr/io.h>
#define I2C_SDA         PB4
#define I2C_SCL         PB3
int main(void) {
  OLED_init();
  OLED_clear();
  while(1) {
    OLED_printC(0,0,0);
    OLED_printC(11,0,1);
    OLED_printC(22,0,2);
    OLED_printC(33,0,3);
    OLED_printC(44,0,4);
    OLED_printC(55,0,5);
    OLED_printC(66,0,6);
    OLED_printC(77,0,7);
    OLED_printC(88,0,8);
    OLED_printC(99,0,9);
    OLED_printC(110,0,10);
    OLED_printC(121,0,11);
#define OLED_INIT_LEN   12
  0xA8, 0x1F,       //  0x1F for 128x32, 0x3F for 128x64
  0x22, 0x00, 0x03,
  0x20, 0x00,
  0xDA, 0x02,
  0x8D, 0x14,
  0xAF,
  0xA1, 0xC8
  0x00,0xF0,0xFC,0xFE,0x06,0x02,0x06,0xFE,0xFC,0xF0,0x00, // 0
   0x00,0x07,0x1F,0x3F,0x30,0x20,0x30,0x3F,0x1F,0x07,0x00,
   0x00,0x00,0x08,0x0C,0xFC,0xFE,0xFE,0x00,0x00,0x00,0x00, // 1
   0x00,0x20,0x20,0x20,0x3F,0x3F,0x3F,0x20,0x20,0x20,0x00,
   0x00,0x0C,0x0E,0x06,0x02,0x02,0x86,0xFE,0x7C,0x38,0x00, // 2
   0x00,0x30,0x38,0x3C,0x36,0x33,0x31,0x30,0x30,0x38,0x00,
   0x00,0x0C,0x0E,0x86,0x82,0x82,0xC6,0xFE,0x7C,0x38,0x00, // 3
   0x00,0x18,0x38,0x30,0x20,0x20,0x31,0x3F,0x1F,0x0E,0x00,
   0x00,0x00,0xC0,0x20,0x18,0x04,0xFE,0xFE,0xFE,0x00,0x00, // 4
   0x00,0x03,0x02,0x02,0x02,0x22,0x3F,0x3F,0x3F,0x22,0x02,
   0x00,0x00,0x7E,0x7E,0x46,0x46,0xC6,0xC6,0x86,0x00,0x00, // 5
   0x00,0x18,0x38,0x30,0x20,0x20,0x30,0x3F,0x1F,0x0F,0x00,
   0x00,0xC0,0xF0,0xF8,0xFC,0x4C,0xC6,0xC2,0x82,0x00,0x00, // 6
   0x00,0x0F,0x1F,0x3F,0x30,0x20,0x30,0x3F,0x1F,0x0F,0x00,
   0x00,0x06,0x06,0x06,0x06,0x06,0xC6,0xF6,0x3E,0x0E,0x00, // 7
   0x00,0x00,0x00,0x30,0x3C,0x0F,0x03,0x00,0x00,0x00,0x00,
   0x00,0x38,0x7C,0xFE,0xC6,0x82,0xC6,0xFE,0x7C,0x38,0x00, // 8
   0x00,0x0E,0x1F,0x3F,0x31,0x20,0x31,0x3F,0x1F,0x0E,0x00,
   0x00,0x78,0xFC,0xFE,0x86,0x02,0x86,0xFE,0xFC,0xF8,0x00, // 9
   0x00,0x00,0x00,0x21,0x21,0x31,0x1D,0x1F,0x0F,0x03,0x00,
   0xF0,0xF8,0x0C,0x06,0x02,0x02,0x02,0x02,0x0E,0x0C,0x00, // C //10
   0x03,0x07,0x0C,0x18,0x10,0x10,0x10,0x10,0x1C,0x0C,0x00,
   0x00,0x1C,0x22,0x22,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,// degrees // 11
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  I2C_init();
  I2C_stop();
void OLED_printC(uint8_t x, uint8_t y,char ch) {
  OLED_cursor(x,y);
  for(uint8_t i=0; i<11; i++){
  I2C_write(pgm_read_byte(&OLED_FONT[(ch*22+i)])); }
  I2C_stop();
  OLED_cursor(x,y+1);
  for(uint8_t i=11; i<22; i++){
  I2C_stop();
  I2C_write(xpos & 0x0F);
  I2C_stop();
  OLED_cursor(0, 0);
  for(uint16_t i=512; i; i--) I2C_write(0x00);
  I2C_stop();
http://forum.rcl-radio.ru/uploads/images/2025/01/d50fffcd26be8d89671f3b1174cbb91b.jpg
Attiny85 + OLED I2C 128 x 32 Плавный шрифт.
   David Johnson-Davies - www.technoblogy.com - 21st October 2020
   ATtiny85 @ 1 MHz (internal oscillator; BOD disabled)
//SCL - PB2 -7
//SDA - PB0 - 5
// OLED I2C 128 x 32 monochrome display **********************************************
const int OLEDAddress = 0x3C;
// Initialisation sequence for OLED module
int const InitLen = 15;
const unsigned char Init[InitLen] PROGMEM = {
  0xA8, // Set multiplex
  0x1F, // for 32 rows
  0x8D, // Charge pump
  0x14,
  0x20, // Memory mode
  0x01, // Vertical addressing
  0xA1, // 0xA0/0xA1 flip horizontally
  0xC8, // 0xC0/0xC8 flip vertically
  0xDA, // Set comp ins
  0x02,
  0xD9, // Set pre charge
  0xF1,
  0xDB, // Set vcom deselect
  0x40,
  0xAF  // Display on
const int data = 0x40;
const int single = 0x80;
const int command = 0x00;
void InitDisplay () {
  Wire.beginTransmission(OLEDAddress);
  Wire.write(command);
  for (uint8_t c=0; c<InitLen; c++) Wire.write(pgm_read_byte(&Init[c]));
  Wire.endTransmission();
void DisplayOnOff (int On) {
  Wire.write(0xAE + On);
// Graphics **********************************************
int Scale = 1;
boolean Smooth = false;
// Character set for text - stored in program memory
const uint8_t CharMap[96][6] PROGMEM = {
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },//(space)
{ 0x00, 0x00, 0x5F, 0x00, 0x00, 0x00 },
{ 0x00, 0x07, 0x00, 0x07, 0x00, 0x00 },
{ 0x14, 0x7F, 0x14, 0x7F, 0x14, 0x00 },
{ 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x00 },
{ 0x23, 0x13, 0x08, 0x64, 0x62, 0x00 },
{ 0x36, 0x49, 0x56, 0x20, 0x50, 0x00 },
{ 0x00, 0x08, 0x07, 0x03, 0x00, 0x00 },
{ 0x00, 0x1C, 0x22, 0x41, 0x00, 0x00 },
{ 0x00, 0x41, 0x22, 0x1C, 0x00, 0x00 },
{ 0x2A, 0x1C, 0x7F, 0x1C, 0x2A, 0x00 },
{ 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00 },
{ 0x00, 0x80, 0x70, 0x30, 0x00, 0x00 },
{ 0x08, 0x08, 0x08, 0x08, 0x08, 0x00 },
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 },
{ 0x20, 0x10, 0x08, 0x04, 0x02, 0x00 },
{ 0x3E, 0x41, 0x41, 0x41, 0x3E, 0x00 }, //0 48
{ 0x00, 0x42, 0x7F, 0x40, 0x00, 0x00 },
{ 0x72, 0x49, 0x49, 0x49, 0x46, 0x00 },
{ 0x21, 0x41, 0x49, 0x4D, 0x33, 0x00 },
{ 0x18, 0x14, 0x12, 0x7F, 0x10, 0x00 },
{ 0x27, 0x45, 0x45, 0x45, 0x39, 0x00 },
{ 0x3C, 0x4A, 0x49, 0x49, 0x31, 0x00 },
{ 0x41, 0x21, 0x11, 0x09, 0x07, 0x00 },
{ 0x36, 0x49, 0x49, 0x49, 0x36, 0x00 },
{ 0x46, 0x49, 0x49, 0x29, 0x1E, 0x00 }, //9
{ 0x00, 0x00, 0x14, 0x00, 0x00, 0x00 },
{ 0x00, 0x40, 0x34, 0x00, 0x00, 0x00 },
{ 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 },
{ 0x14, 0x14, 0x14, 0x14, 0x14, 0x00 },
{ 0x00, 0x41, 0x22, 0x14, 0x08, 0x00 },
{ 0x02, 0x01, 0x59, 0x09, 0x06, 0x00 },
{ 0x3E, 0x41, 0x5D, 0x59, 0x4E, 0x00 },
{ 0x7C, 0x12, 0x11, 0x12, 0x7C, 0x00 },
{ 0x7F, 0x49, 0x49, 0x49, 0x36, 0x00 },
{ 0x3E, 0x41, 0x41, 0x41, 0x22, 0x00 },
{ 0x7F, 0x41, 0x41, 0x41, 0x3E, 0x00 },
{ 0x7F, 0x49, 0x49, 0x49, 0x41, 0x00 },
{ 0x7F, 0x09, 0x09, 0x09, 0x01, 0x00 },
{ 0x3E, 0x41, 0x41, 0x51, 0x73, 0x00 },
{ 0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00 },
{ 0x00, 0x41, 0x7F, 0x41, 0x00, 0x00 },
{ 0x20, 0x40, 0x41, 0x3F, 0x01, 0x00 },
{ 0x7F, 0x08, 0x14, 0x22, 0x41, 0x00 },
{ 0x7F, 0x40, 0x40, 0x40, 0x40, 0x00 },
{ 0x7F, 0x02, 0x1C, 0x02, 0x7F, 0x00 },
{ 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x00 },
{ 0x7F, 0x09, 0x09, 0x09, 0x06, 0x00 },
{ 0x3E, 0x41, 0x51, 0x21, 0x5E, 0x00 },
{ 0x7F, 0x09, 0x19, 0x29, 0x46, 0x00 },
{ 0x26, 0x49, 0x49, 0x49, 0x32, 0x00 },
{ 0x03, 0x01, 0x7F, 0x01, 0x03, 0x00 },
{ 0x3F, 0x40, 0x40, 0x40, 0x3F, 0x00 },
{ 0x1F, 0x20, 0x40, 0x20, 0x1F, 0x00 },
{ 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x00 },
{ 0x63, 0x14, 0x08, 0x14, 0x63, 0x00 },
{ 0x03, 0x04, 0x78, 0x04, 0x03, 0x00 },
{ 0x61, 0x59, 0x49, 0x4D, 0x43, 0x00 },
{ 0x00, 0x7F, 0x41, 0x41, 0x41, 0x00 },
{ 0x02, 0x04, 0x08, 0x10, 0x20, 0x00 },
{ 0x00, 0x41, 0x41, 0x41, 0x7F, 0x00 },
{ 0x04, 0x02, 0x01, 0x02, 0x04, 0x00 },
{ 0x40, 0x40, 0x40, 0x40, 0x40, 0x00 },
{ 0x00, 0x03, 0x07, 0x08, 0x00, 0x00 },
{ 0x20, 0x54, 0x54, 0x78, 0x40, 0x00 },
{ 0x7F, 0x28, 0x44, 0x44, 0x38, 0x00 },
{ 0x38, 0x44, 0x44, 0x44, 0x28, 0x00 },
{ 0x38, 0x44, 0x44, 0x28, 0x7F, 0x00 },
{ 0x38, 0x54, 0x54, 0x54, 0x18, 0x00 },
{ 0x00, 0x08, 0x7E, 0x09, 0x02, 0x00 },
{ 0x18, 0xA4, 0xA4, 0x9C, 0x78, 0x00 },
{ 0x7F, 0x08, 0x04, 0x04, 0x78, 0x00 },
{ 0x00, 0x44, 0x7D, 0x40, 0x00, 0x00 },
{ 0x20, 0x40, 0x40, 0x3D, 0x00, 0x00 },
{ 0x7F, 0x10, 0x28, 0x44, 0x00, 0x00 },
{ 0x00, 0x41, 0x7F, 0x40, 0x00, 0x00 },
{ 0x7C, 0x04, 0x78, 0x04, 0x78, 0x00 },
{ 0x7C, 0x08, 0x04, 0x04, 0x78, 0x00 },
{ 0x38, 0x44, 0x44, 0x44, 0x38, 0x00 },
{ 0xFC, 0x18, 0x24, 0x24, 0x18, 0x00 },
{ 0x18, 0x24, 0x24, 0x18, 0xFC, 0x00 },
{ 0x7C, 0x08, 0x04, 0x04, 0x08, 0x00 },
{ 0x48, 0x54, 0x54, 0x54, 0x24, 0x00 },
{ 0x04, 0x04, 0x3F, 0x44, 0x24, 0x00 },
{ 0x3C, 0x40, 0x40, 0x20, 0x7C, 0x00 },
{ 0x1C, 0x20, 0x40, 0x20, 0x1C, 0x00 },
{ 0x3C, 0x40, 0x30, 0x40, 0x3C, 0x00 },
{ 0x44, 0x28, 0x10, 0x28, 0x44, 0x00 },
{ 0x4C, 0x90, 0x90, 0x90, 0x7C, 0x00 },
{ 0x44, 0x64, 0x54, 0x4C, 0x44, 0x00 },
{ 0x00, 0x08, 0x36, 0x41, 0x00, 0x00 },
{ 0x00, 0x00, 0x77, 0x00, 0x00, 0x00 },
{ 0x00, 0x41, 0x36, 0x08, 0x00, 0x00 },
{ 0x02, 0x01, 0x02, 0x04, 0x02, 0x00 },//~ 78
{ 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF }
void ClearDisplay () {
  // Set column address range
  Wire.write(0x21); Wire.write(0); Wire.write(127);
  // Set page address range
  Wire.write(0x22); Wire.write(0); Wire.write(3);
  // Write the data in 26 20-byte transmissions
  for (int i = 0 ; i < 26; i++) {
    Wire.write(data);
    for (int i = 0 ; i < 20; i++) Wire.write(0);
// Converts bit pattern abcdefgh into aabbccddeeffgghh
int Stretch (int x) {
  x = (x & 0xF0)<<4 | (x & 0x0F);
  x = (x<<2 | x) & 0x3333;
  x = (x<<1 | x) & 0x5555;
  return x | x<<1;
// Plots a character; line = 0 to 3; column = 0 to 131
void PlotChar(int c, int line, int column) {
  Wire.write(0x21); Wire.write(column); Wire.write(column + Scale*6 - 1);
  Wire.write(0x22); Wire.write(line); Wire.write(line + Scale - 1);
  Wire.write(data);
  uint8_t col0 = pgm_read_byte(&CharMap[c-32][0]);
  int col0L, col0R, col1L, col1R;
  col0L = Stretch(col0);
  col0R = col0L;
  for (uint8_t col = 1 ; col < 5; col++) {
    uint8_t col1 = pgm_read_byte(&CharMap[c-32][col]);
    col1L = Stretch(col1);
    col1R = col1L;
    if (Scale == 1) Wire.write(col0);
    // Smoothing
    else {
      if (Smooth) {
        for (int i=6; i>=0; i--) {
          for (int j=1; j<3; j++) {
            if (((col0>>i & 0b11) == (3-j)) && ((col1>>i & 0b11) == j)) {
              col0R = col0R | 1<<((i*2)+j);
              col1L = col1L | 1<<((i*2)+3-j);
      Wire.write(col0L); Wire.write(col0L>>8);
      Wire.write(col0R); Wire.write(col0R>>8);
      col0L = col1L; col0R = col1R;
    col0 = col1;
  else {
// Plot text starting at the current plot position
void PlotText(PGM_P s, int line, int column) {
  int p = (int)s;
  while (1) {
    char c = pgm_read_byte(p++);
    if (c == 0) return;
    PlotChar(c, line, column);
    column = column + Scale*6;
  InitDisplay();
  ClearDisplay();
  Scale = 2;
  byte t=0;
  Smooth = true;// Smooth = false;
  PlotChar(t+48,0,0);
  PlotText(PSTR("RCL-RADIO"), 2, 0);
  delay(1000);
